PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 [123] 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. What is the lowest 60ft you cut with any size converter???
  2. Manual Valve Body for 4l60-e
  3. Last Day For 15% Off All FLT Transmissions
  4. Can I put the temp sender in the pressure port?
  5. M6 to A4 how much??
  6. Need Help
  7. What Size Temp Gauge???
  8. after dumb ass dropped DS, BAD vibration
  9. Huh? Help
  10. I don't know shit about auto's, but have one question
  11. Fuddle Convertor Selection
  12. Fuddle Convertor Selection
  13. TC stall question?
  14. TH400 lock up or non-lock up
  15. What does it take to...
  16. le1 package stall 2400,2800,3000,3200+?
  17. no 2nd and 4th gear
  18. 4l80e question
  19. 98'Z28 LS1, hypertech -Shift points??
  20. converters?
  21. temp. gauge in camaro
  22. Tranny hiccups at the track, 1st to 3rd?? WTF?
  23. what th-350 dipstick
  24. New servo on the market
  25. What should i run w/ this set-up?
  26. t56 to auto
  27. "Thud" coming from underneath the car.
  28. those with YANK SS3600...
  29. Effects on reliability..
  30. th350 swap from t56
  31. I keep Frying 3-4 clutch pack!
  32. Is drivetrain loss a percentage of total power & torque or a fixed amount?
  33. Converter clutch?
  34. Fuddle Review #11088910981098
  35. Tranny line C-clips Question?
  36. Need Help!
  37. Transmission shot?
  38. A4 Guys with 3.73's - Come in
  39. Possible Lockup problem???
  40. Flexplate replacement?
  41. big stall and limiter problems
  42. tranny linkage problems
  43. need a trans
  44. M6 DS in an A4
  45. T/C clearance issues?
  46. Dowel pin help!
  47. Replaced shift solenoids still having problems
  48. anyone know of decent tranny place in Palm Beach?
  49. How often??
  50. Metal Chunk found in pan!!!!! *PICS*
  51. What exactly is a helicoil?
  52. Manually Downshifting an A4
  53. TCI,BBK vs. YANK, VIGILANTE Torque Converters
  54. *HELP* shift solenoid locations
  55. tranny not downshifting from a roll????
  56. What are the symptoms of a broken torque arm bushing?
  57. 4l80E help with converter bolts
  58. Horsepower lost in A4?
  59. tranny life with stall
  60. CAN I gain RWHP and MPH with a very efficient TC?
  61. need 4l60e parts!!!
  62. Getting the speedo to work in a M6 to TH350
  63. How long will 4L60E hold up??
  64. Stock TC bolts
  65. M6 to A4
  66. Hurst shifter on 4L60E?
  67. Stall Converter question
  68. 2.73 to 3.73 question...
  69. trans go shift kit
  70. stock aluminum d/s question
  71. drawbacks of using a TC
  72. Yank Torque Thruster 3300 for D/D ?
  73. quick question about vacuum shifting??
  74. Downshifting from 4rth(OD) to 3rd in A4 (4L60E) at high speeds
  75. downshifting from 4rth(OD) to 3rd in A4 at speeds
  76. B&M ratchet shifter, unratchetable?
  77. whats the STR on the HP fuddles?
  78. Questions: New to Automatics
  79. ES poly mount questions
  80. quick converter question
  81. which converter for Street tires
  82. anyone ever heard of a tranny/converter destroying thrust on crank?
  83. Transmission safety sheild?
  84. best place to get a TH400 from?
  85. 4l60 vs 4l60e?
  86. which stall for 3.73
  87. Fuddle TH400 Stall ordered, few questions.
  88. Is this safe for my transmission?
  89. what part# for trans temp gauge are you using
  90. Yank transmission crossmembers
  91. need service manual th700r4 4l60 1990
  92. Which Transmission??
  93. completely confused
  94. Which Convertor To Buy?
  95. guys w/ prothane tras. mount...
  96. Has any one gained MPH with fuddle?
  97. Cooler line removal
  98. What is this Part on a 700R4? See Pics
  99. Good old vig
  100. Newest info on 6l80E?
  101. 1-2 shift banging limiter... help diagnosing?
  102. Verter swap issue!
  103. Critique my new setup
  104. converter problem
  105. New Tranny Help
  106. T-Handle gone bad...
  107. tranny cooler question
  108. Converter Question?
  109. TC installation instructions
  110. how can i tell if it the transmission???
  111. Which stall for G5X3 and 3.73?
  112. Tranny Cooler line question...
  113. How many years on stall?
  114. trans temp gauge
  115. Can A 4l80e Be Sprayed In All Gears???
  116. Want a new shifter handle
  117. Tci Rocks!!! 1.563 60ft
  118. Fuddle TC guys inside please
  119. should I be able move th400 tailshaft?
  120. Valve Body question?
  121. bolt-on cars w/ stall
  122. what trans cooler for th400 with ssf converter???
  123. TH400 Valve Bodies (RMVB)
  124. What TC to get????
  125. I have credit card in hand and gonna do it
  126. Flexplate
  127. How big should i go?
  128. Vacuum Modulation
  129. Shift kit
  130. 4L60E Replacement
  131. shift kit question
  132. Need a Lesson...
  133. TC $ fuel economy
  134. LS1 to TH700R4 (flexplate and spacer question)
  135. Th350
  136. LS1 to 350 torque convertor hub/spacer
  137. Who Here Daily Drives a 4000 stall?
  138. Hitting rev limiter with nitrous only?WTF
  139. Thinkind of stalling my 98 Z.
  140. Gear Vendors ???
  141. help Trans problem
  142. what the best way to race an auto
  143. Cooler Fittings on Transmission
  144. How Do I Street Race with a A4
  145. need ls1 edit trans file
  146. is this bad?
  147. fuddle review
  148. 4L60E gear ratios
  149. Tci Sf3000 ????
  150. tail housing help????
  151. 4l60e, slipping in overdrive?
  152. Tranny shop (what would you do?)
  153. LS1 4L60E into LT1 car
  154. Need Help Now!!!!
  155. Trans temp sender placement
  156. shift extension?
  157. Paging John@fuddle
  158. Should I replace the shift solenoid???????
  159. Optimal Trans Temps?
  160. Advise - what STALL for converter ?
  161. Reposting my newbie questions in the right forum...
  162. m6 to th350!
  163. Trans problem i think.. any suggestions
  164. 1 2 3 Drive or just keep in drive
  165. A3 Gear sets
  166. "That car's hot, man... oh wait, too bad it's an Auto..."
  167. Dtc P0751
  168. Converter for H/C non-daily driver??
  169. poper selection
  170. 4L60E Strength
  171. Times with yank pe 4200
  172. Building a Beast
  173. Drivetrain BANG
  174. BIG problems after TC install
  175. Trans problem?
  176. What stall / str for 400 turbo?
  177. Tranny question
  178. 2-3 shift problem
  179. Rebuilding My 4L60E
  180. Guys w/ tranny coolers please chime in.
  181. th350 behind lsx
  182. Shift solenoids ?
  183. Hey A4 guys
  184. getting a "T" brake in MY 4l60e
  185. car feels slower?
  186. Need HELP before 11am 1/14/06
  187. Need Flywheel bolt Answer!!!! QUICK!!
  188. Please HELP with a Yank converter.
  189. tranny doing something weird
  190. signs of a broken trans mount..
  191. What effect will a Torque Converter have on normal driving?
  192. Car wont line lock
  193. 480LE Questions
  194. FLP vs FLT - And Level 4 vs Level 5
  195. Hypertech
  196. Transmission Expert please come in
  197. What does a stalled A4 dyno sheet look like?
  198. What does a stalled A$ dyno sheet look like?
  199. B&M shift plus shift improver??
  200. New 2nd Gear Super Hold Servo (4L60 & E)
  201. how do u rebuild a 4l60e
  202. high milage n shift kit
  203. Good converter for 383 engine
  204. have to get tranny rebuilt have yall had this problem?
  205. Custom 3200 to Fuddle 3400/3600
  206. Shift Kit Install Help in 4L60
  207. th350 and th 400 questions and comparrions
  208. T/C in LT1 VS LS1
  209. Highest Daily Driven Stall?
  210. Bolting up an th350 to LS1
  211. stall (locked,unlocked)
  212. 4L60E top speed question
  213. 4L60E - Two gears at once
  214. stall mph?
  215. TC bolts with shorter heads?
  216. Question's for 4L60E owners...
  217. Do i need a TC
  218. How much HP do you lose when you add a stall?
  219. 4L60E HOW fast can go 1/4 mile
  220. so what is the estimated difference ?
  221. Anyone have a B&M Shifter???
  222. biggest converter
  223. how many of you are running tci rebuild kit?
  224. Help me choose a converter
  225. yank guys get in here
  226. "New 6 speed auto....."
  227. Tranny Options
  228. Converter and tuning?
  229. 4l80e-full manual?
  230. Trans pan
  231. Lock up Switch question, 1st gear?
  232. TC Install Questions
  233. I think my trans is gone...Please help.
  234. Couple dumb Qs that I cant find answers for.
  235. Paging John @ Fuddle!!
  236. Help, M6 to what auto? on 408ci + 350 shot!
  237. So my luck continues
  238. How will the 4L60E endure?
  239. 60E 2/4 servo rod length
  240. Brake fluid to stop trans leak?
  241. problems with breaks and vac modulated
  242. 4l60e
  243. tranny swap flexplate questions
  244. help tranny rebuilt and 3-4 lost
  245. Stock Converter stall?
  246. Best Auto tranny Fluid
  247. How much for TC install
  248. Fuddle 3000 stall, not very good!!
  249. Another TH400 question
  250. TH400 in to C4 Corvette'91 - 700 to 400 swap - possible???
