View Full Version : Automatic Transmission
- 4l65 in 2004 Corvette
- transmission linkage for 4L80e swap?
- stall converter identity
- 4L60E 04 gto
- starter and flywheel don't fit together.
- 4L60E transmission problem
- 2002 Tahoe 5.3 Won't Start After 4l60e Swap
- 4l60 Wont Hold 1st Gear
- I need help
- 4l80 temps
- 200-300rpm flare before converter locks (80e)?
- Possible Converter issue? 4l80e
- 4L60E firm&crisp part throttle, WOT shift points high
- 4l80e Bell housing cover
- 4l80e staying locked in 3rd and 4th gear after passes
- th400 Converter bolting to ls 5.3
- HELP:No drive or overdrive(4l60e)
- 4l60e Trans go hd2 clutch spring kit necessary?
- 4l60e With FTi 4000 Not Locking up!!
- electronic shift kit yay or nay
- V12 and 4L80E
- Electrical issues, where to start?
- 4l60e/65e need help!
- LT1 feels slow AF after rebuild
- Stall for my 6.0 gt45 chevelle
- 4L60E Has been sitting for 2 years
- Super Servos
- Need Shifter Help
- torque control
- Bad wire on shift solenoid
- 97 T56 to 4L60e Question
- 2wd truck 4l60e to ls1 camaro?
- P0757 after new trans and 3200 stall
- 2002 silverado 4.8 wont move. Clicking noise
- 4L60e lost all gears during a pull
- How many of you auto guys with street/strip cars removed E brakes?
- Converter is staying locked?
- Performabuilt Level 3 - **Update**
- No second gear, but has first, third, and forth!
- Th400 and quarter stick shifter issue
- Turbo 350 to lq4.
- p1860 code - HELP
- powerglige vs turbo 400
- 4L80 questions
- Converter size question
- 8L90 going to be available?
- having trans issues
- th400 transbrake boost building
- FTI street brawler 3200 with 350whp?
- 4l80e extension housing bushing
- Did I mess something up?
- Performance 4L60E build thread
- Old pre-97 4L80e cooling fittings
- Craigslist 80e w/ Transo shift kit clunks into reverse, normal?
- 4l60e storage question
- 4L60e no 3rd or 4th, shifting 1-2-1??
- .490 boost valve
- TH400 not staying in gear
- How to remove stator shaft from pump half?
- th400 shifting problems
- Rebuild 4L60 beginner question
- 4l80e TCC not locking
- USShift (Optishift) w/1991 4L80e
- New stall upgrade need a tune?
- 4L80e wiring. Pink wires?
- When are 300m shafts necessary
- Need help wiring 2step and trans break
- 4l80 brass in pan
- FLT 4l65 with a transbrake
- Choosing a torque converter
- Finishline Transmissions FLT
- 4L80E Filter options?
- TH400 question(s) and help
- TSP Converter by Yank
- Where to get 4L80e input shaft o ring
- 4L80 shift kit install
- 4L60 wont unlock or down shift at high speed
- 4l60e vent tube leaking
- TCI 399753 4l60e yank ss4000 bolts
- 80e manual up/down shift
- Transgo 4L80e-3 Data
- electric solenoid shifter
- Fluid flow to and from transmission and cooler
- tci converters
- 4l60e problem
- 4l80e soft 2-3 shift slips in 3rd
- ls 4l60e questions
- 4L60e dropping out of gear...
- 4L60e 1-2 shift shudder
- I'm about to be on my 9th 4l60e rebuild
- TH400 direct drum piston help.
- Tci flex plate 399754
- Please help!!! I just wanna go fast sometime b4 I die
- 4L80 guys, which pan are you using?
- 4L60e all of a sudden wont shift into OD. 1,2,3,are good
- 4l60e help please
- 4l60 third gear problems
- 7500 RPM with a Built 4L60E?
- 4L80E cooling lines installation
- Question on tuning shift point for track only use
- 4L60/Vigilante 4000 price check?
- What kind of shifters do you guys use on a 4L60E?
- 6L80E with upshift noise and gear slippage. Please help!
- 400 Turbo vs. 4L60E transmission improvement in ET times?
- How to hook up the speedometer on a 400 turbo on 99 Camaro?
- Pull the tranny to finish Transgo Hd2 4l60e?
- Transmission build Q
- LS3/4l70E Trans heat issues Jeep TJ
- VSS for th400
- Tranny Guru's step on in!
- Which 4L60E rebuild kit ?
- Superior shift kit w/sonnax pinless accumulator
- B&M pro stick shifter woes
- Shifting problems
- P1870 code
- 3/4 accumulator spring
- Advise on Re-Stall for Stroker
- WOT shift hesitation after stall installation
- performabuilt 460le 4000 yank stall
- (4L60E) Violent noise from trans going into Drive
- 4l60 or 4l80
- Ballooned converter?
- 4l60E Transgo HD2 Questions?
- 4L70E with a bad, sometimes, 1-2 shift
- Rossler or fti th400
- Built 4L60E shift pressure inconsistent
- 94 Formula - 3rd gear, just rebuilt.
- 4L80e swap into older car. Range switches?
- How much difference would a fan make
- 4L60 HP/Torque Limitations
- 4L60e 3-4 Shift Time Any Help?
- 4l60E No 3rd gear. Rossler Trans, 9k miles
- what would cause this? TH400 rear bushing destroyed.
- Anyone running Rollerized reverse input drum from PATC?
- How to disable lockup converter??
- what part's from a built 700r4 are worth using in a 4l60e
- Broken torque converter
- car reverse but won't drive when in drive gear? help!!
- 4l80e torque converter nightmare!! please help....
- Hitting rev limiter?
- 4l60e converter question
- 99 Pontiac trans am - blown trans
- 2003 4L60E Rebuilt 1st-3rd Shift Fine, No 4th (OverDrive)
- Best Trans Fluid ??
- 4L60 1st Gear Shifting Issues
- 4l60e tear down
- Another t56 to 4l60 or 4l80e auto swap question
- Need help identifying this trans
- 4l60e slipping on freeways
- 4l80 temp reading location
- help with powerglide setup
- Blew my transmission. Suggestions?
- FTI vs Circle D budget converter
- HINSON Motorsports GTO Transmission Mount Update
- 4L80E D1 brake doesn't seem to release??
- Need to get 4L60E temp down below 200 degrees *Help*
- Help diagnose transmission whine
- 2002 z28 4l60e removal
- 4L60e make it stay in first
- Help 4l60e problems after couple of track passes
- 4l60e no first gear
- need help
- 2002 4l60e with 99 Tahoe PCM
- 1993 LT1 gear selector switch circuit Code 72 cause surging?
- Is it broken again? (4L60E)
- 04 GTO Weird behavior
- Converter input wanted, dyno sheets included
- 4l60e metal in valve body bore?
- Yank PAS 3800 anyone?
- Next step?
- 94 Chevy 1500 no reverse
- Dacco Stall
- Recommend me a converter - 4L80
- Precison Industries 4l80e Triple disk grinding issues low load?
- 4l80 shifting issues
- Can 8 speed auto be done on a ls1 f-body
- 95 4l60e
- LS to TH350 Converter vs flex plate transistion
- 4l60e longevity
- Jakes d3 trans brake wiring
- Steel braided lines...tranny cooler lines.....Easiest way...?
- 4L60E output shaft swap questions
- Anyone put a 4L80 into an 04 GTO?
- Need help locating trans parts
- 4L60E shift problems
- 98 Suburban 4L60e vs f body 4l60e
- 4L80e stall converter recommendation
- I Need Opinions On a Converter for Turbo Car
- vss senser for 200r4
- 4L60 driving characteristics
- 4l80E reverse hesitation
- 98 0411 pcm repin running 4l80. Get in here
- should the new converter spin both ways?
- Loud noise after 4l60 swap?
- 4L60E 1st gear issues
- Tuning a 4L80E with Holley Dominator?
- 4L80e downshifting?
- 87 Monte Carlo LS swap.
- 1-2 will not engage manually.
- 4l80e tq convertor help
- T56- Powerglide swap, tips, 1/4mile times, useful info
- 4l60e EX Raptor level 5
- TH350 shifts hard in reverse
- 4l60e las
- 4l80e hangs right before WOT shift point, No shift at WOT
- fti converter help/questions!
- FTI LS brawler converters
- What 4L60E Rebuild Kit is Best for my 1995 S10?
- Trans Brake Button Mounting Location
- 4l80e hd 2 transgo ?'s
- New EPCS (force motor) solenoid. Shift points different, bounces off rev limiter WOT
- Trans problem on 2008 Impala SS
- flexplate quickie
- Must have upgrades for street/strip 4l80e
- Planetary Question
- help diagnose my 4L80e issue please. Videos of pressure gauge
- 99 K1500 5.7 with 01 5.3 4L60E?
- change trans pan question
- Clips upside down in Valve Body (1998 4L60E)
- 4L60e won't shift into 3rd or 4th
- Weird issues with '99 4l60E
- Converter suggestions for powerglide
- 4l80 gurus
- What fluid to use in ATI Th350?
- Video - The Circle D Billet
- 4l80e wont shift in to 4th and feels like I am hitting the brakes
- 4l60 Whines in park, neutral, reverse
- 4l80e pump
- Any way to identify an ls torque converter?
- 3600-4k stall on stock 4l60e?
- Y pipe hanger for automatic?
- 4l80e converter choices.. Yank SS vs Edge Street Series
- Think I damaged my 4L80E again...
- TH350 dipstick
- Broken th400 bellhousing, is my converter okay?
- what are the best gears for a 4l60 and a 26" tire
- Red or Blue Locktite For Coverter Bolts
- Shift Kit and Performance mode line pressure question
- Tranny help!!
- trans question
- 4L60E Issue
- Help with 6 speed to 4L60e conversion
- looking to trade my built T56 for built 4l80e
- B&M Prostick cable adjustment
- Dipstick Hitting Hood
- optishift 4l80e tune
- Torque converter bolt installation - nothing is threaded
- Error 4L70E Supermatic GEN2 please help
- 4l60 leaking from harness plug...
