PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 [106] 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. YANK th400 crossmember help
  2. flow diection
  3. DTC P0758 2-3 Shift Solenoid Circuit Electrical
  4. 4L60E leak
  5. LS1 style engines to old style trans(th350, 400, 2004r, 700r4, 4l60e)
  6. question about converter install
  7. turbo 350 pilot spacer
  8. 4l80e and TCI controller box
  9. tranny cooler qustion
  10. Can C6 paddle shifters be adapted to F-Bod??
  11. bolts for pilot spacer
  12. 4l65e
  13. Firm 2-3 shift?
  14. trans brake?
  15. tranny help
  16. TCI converter issue
  17. what flexplate for a ls1/turbo350?
  18. st3500 vs ss3200
  19. Crossmember bolt hole locations
  20. difficulty level remove/re-install 4l60e?
  21. Tranny Problem Help!!!
  22. Yank SS4000 installed!!
  23. Torque convertor help.
  24. How many stalled A4's have upgraded rears?
  25. 1.38 60' on a fuddle/howard converter
  26. Looking for a built trans...need opinions
  27. converting from A4 to M6
  28. Taking off in 2nd gear
  29. Trans cooler spews ATF
  30. What happened? 4l60e Ka-Boom!
  31. 4L60E tranny mount for 61 Impala
  32. 4L80E wiring diagram (Is this correct)
  33. need help asap
  34. How R FLT Level 4 transmissions?
  35. Would a Yank PT4000 converter be wrong for me???
  36. Grinding Noise from TCI Converter
  37. feed/return
  38. Tranny takes to long to shift!!
  39. b&m shift delay
  40. 4l80e electric to manual valve body...
  41. My 3600 Fuddle Review/Story
  42. 4L60E application
  43. how to test for bad components on 4L60E
  44. TCI flexplate strikes again...
  45. ??Transgo band adjust shims with Sonnax 2nd & 4th Servos??
  46. WTB:converter
  47. 4l60e or Th400 any recommendations
  48. will this converter fit an ls1?
  49. differences between a 97' 4l60e and 98+
  50. shifter cables
  51. no 1st?
  52. T56 to Th400 what wiring do you hookup / keep
  53. Best trans for mods
  54. powerglide - pros & cons
  55. recommended stall for 3.23s
  56. knocking noise-tranny mount?
  57. ove rstalling/undercamming?
  58. 3800 to big?
  59. trans or rev limiter?
  60. do it yourself 4L60E woes
  61. Tranny exchange
  62. 4l60 broke yesterday
  63. fluid spray
  64. What Did You Gain With A Converter
  65. Transmission wiring help
  66. please help!!
  67. Stahl??
  68. no hypertech with shift kit??????
  69. Difference between BTU and GVM in Trans coolers
  70. 9C1 tranny in f-body
  71. Problem with trans shifter cable, anyone else?
  72. Trying to track down a Vibration in the tranny/converter/flywheel....help
  73. Converter shopping...
  74. Quik Converter Question!
  75. th350 lockup
  76. onemore 4l60e ?
  77. th400 kickdown question
  78. too many fans to pick from jegs, which do i use?
  79. How fast can the 4L60E shift?
  80. help me please
  81. loose throttle
  82. Tranny cooler question
  83. Trans guys step inside
  84. New tranny = messed up shift points...
  85. removing torque managment?
  86. I helped rebuild my 4L60E yesterday!
  87. it goes in in february
  88. shift point solenoid malfunction please help!!!!
  89. built 4l60e?
  90. I present to you............
  91. trans cooler mounted, *pics*
  92. tranny?
  93. These are some capacity specifications for the stock 4l60e I thought of interest
  94. 4l60 shifters?
  95. Exactly what is wrong with the 4L60E transmissions?
  96. converters
  97. How to tell what kind of Automatic
  98. th400 with 3.73 gears
  99. 4l80 swap
  100. tranny leak..
  101. Full manual for road race......help
  102. built tranny and 2500 stall
  103. TH400 guys what did you do for Y pipe hanger
  104. Has anyone ever used a...
  105. Torque Converter
  106. Autozone master cylnder
  107. need help with a converter change
  108. dumb question
  109. Stall Converters explained
  110. tranny?
  111. what fits
  112. TCI 3000 stall or Yank
  113. Install my tranny w/edge converter today.
  114. Help me with a convertor.
  115. TCI Converter Fails after a 2 Months
  116. Please help with 4L60E!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  117. weighed my TH350
  118. need help
  119. Tranny decesion
  120. Any one auto-cross with a stalled a4?
  121. 4l60e starting to slip....what next?!?!
  122. Idle problems after 4l80e install
  123. What Tranny ?????
  124. 4l60e 5500 rpm slip
  125. which 4l80 flexplate?
  126. performabuilt transmissions
  127. what stall for 342's on th400? tci or yank?
  128. Good Deal or Not?
  129. temp gauge and dipstick
  130. moving to th400 WSS/VSS PCM sampling question
  131. guys with performabuilt level 2
  132. Need a little help with tranny removal (yea i searched)
  133. 4L60E is taking a dump
  134. how to tell which trans i have?
  135. ok to run a 24,000 cooler without the stock cooler?
  136. swapped from m6 --> a4, got a question
  137. looking for an Auto..
  138. Happy New Year From PerformaBuilt
  139. is 4l60e going bad
  140. My point of view.
  141. Shifter Question
  142. 4l60e vs. 4l80e
  143. trans cooler
  144. SS4000 install?
  145. ls2 flexplate?
  146. Yank SS3400 - Will it stall higher with more cubes?
  147. 4l60e Problem?!??
  148. 4L60E transmission filter oring seal on my 98 TA
  149. converter intsall..what to expect?
  150. time for a fluid change...
  151. Yank stall, TCI flexplate
  152. A6 in an F-body?
  153. ss3600 vs py3600e
  154. Repalce front seal during converter swap?
  155. tranny pump??
  156. GM part numbers - deep pan
  157. SY3500 and 3.42 gears
  158. Trans cooler location
  159. Shifters- please explain some simple stuff to me
  160. P0101 and TCC issue
  161. th350/400 guys
  162. stall and the freeway?
  163. TH350 bell housing
  164. stock converter gone bad?
  165. 4l60e shifting problem
  166. More carnage
  167. Racing with an auto! Questions inside..
  168. 4l60e 1-2 2-3 sliding in
  169. basement 4l60e buildup (photos)
  170. Wierd tranny issue
  171. FLP vacuum modulation question..........
  172. How many miles on your converter
  173. anyone have a good write up?
  174. Is it normal to feel drivetrain slop while shifting gears?
  175. 4l60e problems...
  176. 4l30e to 4l60e conversion?
  177. tuning help needed. no manual shift at wot
  178. Converter questions??
  179. trans is jerking
  180. car dosent idel right with out tranny
  181. At WOT tranny sticks in 1st and shifts to 3rd when you let off
  182. 'Dope Style' Cooler Mounting.
  183. big stall or n20 converter
  184. From LT1 a4(built) to LS1 -T56(swapped)
  185. cheap but effective convertor...
  186. rock on
  187. A4 Problem..please Help?!?
  188. how to do a 4oo swap
  189. Chewing up the drivetrain
  190. Any opinions on EDGE converters?
  191. those in the 10's (and high 9's) on a 4L60E, come in please
  192. Do our cars come with....
  193. What cause this?? PICS inside
  194. Cars been done now, but
  195. Yank converter question
  196. th350 good replacement?
  197. 94 Z28 Transmission compatibility need help
  198. New TCI StreetFighter for th400
  199. tranny instal problems
  200. Stuck in 2nd
  201. Trans Problem
  202. TCI part #
  203. TH350 overflow?
  204. What converter for torquer v.2
  205. Where to get trailblazer stall?
  206. B&m Shift Kit
  207. Want New Converter: Your advise please!
  208. Very Important FLT Info Please Read
  209. 700R4 in a 2002 camaro??
  210. TH350 swap into LT1,4L60 question
  211. turbo 350 flexplate
  212. TC recommendations
  213. Paging YANK and YANK users :)
  214. what is wrong with my A4?
  215. Built 4L60E problems Opinions wanted.
  216. Installed 2800 Yank Yesterday
  217. flexplate problems
  218. Help understand....
  219. tranny cooler/radiator question
  220. powerglide stall question
  221. tranny problems
  222. Swaping Trannies
  223. Trans Cooler Install (Pics Inside)
  224. Assistance please....
  225. how to tell if 2nd is slipping?
  226. PerformaBuilt will be open all week
  227. th350 convertor to flexplate question
  228. Performabuilt's 4l60e
  229. Converter?
  230. th400
  231. Ls1 Th400
  232. last two thin bolts for ls1
  233. 4l60e
  234. how torque converters work?
  235. manually shifted 4l80e?
  236. look at this converter
  237. Car wont go into 1st once warmed up??
  238. What my driving experience going to be like?
  239. Yanks production plant will be closed for the Holidays
  240. ARP converter bolts??
  241. Converted FWD Converters
  242. Urgent What Size Are The A4 Tranny Bolts
  243. I need the truth
  244. Update on tranny issue
  245. Where Can I Buy A 4l60e Tranny Ready Togo.
  246. Tranny Vibration while in D at a stop
  247. Who sells the??????
  248. what do you think of this shift kit?
  249. M6 to Auto guys in here please
  250. Engine revs much higher before moving after stall installed
