PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Flexplate Question-LS1-LS2
  2. Yank 3600ss efficency
  3. trans cooler install
  4. guys with stalls... whats ur 60ft
  5. 4l60e shift kit
  6. Can i bypass removing the valve body to get to my clutches
  7. 6l80 awd
  8. m6 to a4 wiring questions
  9. 4L80E PLS. Help
  10. okay guys help. i need the pin out and wiring schematics for 4l80 and 4l60
  11. glossy black billet converter????
  12. 93 z28
  13. 700R4 rebuild question
  14. Cooler Lines...
  15. Do I have the correct converter
  16. Anyone with regrets...4L80E into a 98-02 F-Body
  17. how harsh is the transgo HD 2 shift kit for DD?
  18. 4l80e seals ?
  19. RPM Transmission Break In Period
  20. 4L80e conversion problems .
  21. Tranny fluid over flow
  22. Who is running a ss3600 yank options wanted
  23. shudder at 1500 rpm
  24. Put the car in park a little too quick?
  25. How much drive train loss?
  26. any specific 4L60E
  27. Curiosity question about downshifting
  28. Q about PI vigilante 2600 stall
  29. 1999 vette auto trans question
  30. 700r4 vs. 4l60e
  31. 4L65E fluid type and drain and refill quantity
  32. 1993 z28 stall converter
  33. New Circle D tq installed
  34. trans fluid
  35. So What is the Bottom Line on GMT900 Trans Cooling?
  36. anybody use the aeroquip socketless hose for cooler lines
  37. going from m6 to a4?
  38. 4L60E help
  39. 4L60E weird problem
  40. Anyone using a CSR 200 AL-LS flexplate?
  41. If I have a 9.5" 2800 stall and a 12" 2800 stall, which is better and why?
  42. 4L60E will not shift at WOT
  43. Performabuilt 9.5" billet converters- any good?
  44. 4l80e w/ 5.3 Help!
  45. Turbo LT1 Stall. need help
  46. Trans am w stall
  47. 4l60e help
  48. Reading trans temp from PCM vs Sender in pan
  49. stall for the street
  50. noob question?
  51. Not technical but for anyone interested we are on facebook now.
  52. Help me pick a stall, 93 z28 - 383 stroker, 700R4
  53. I have Manually shift into 3rd and 4th HELP !!!
  54. trans shops in nky?
  55. 6L80E in a 4th gen?
  56. Auto tranny swap from 02 V6 Firebird to 98 V6 Camaro?
  57. what needs done to the 4l60e to hold 600 wheel??
  58. 4l60e getting stuck, not shifting propertely
  59. flexplate differences
  60. 700r4 lost 3rd and 4th
  61. Stall locking up at wot at 100mph? Feels like a shift?
  62. lock up and gas mileage
  63. 4l60E- No 4th or 1st gear or dash gauges *HELP*
  64. How much hp do I lose through a stall and gears?
  65. 4l60e dipstick options
  66. 6.0 and 4l60e?
  67. PT4000 for my first stall?
  68. Transmission trouble please help
  69. 4L65E loosing 4th when converter locked
  70. Transmission Fill Plug C5 vette??
  71. lt1 4l60e and the LS1 swap
  72. safe to lock up on pull?
  73. anyone ever heard of a Transmision Specialities converter (TSI)?
  74. Need help stay 4l60e or PG ???
  75. 700 horsepower tranny's
  76. throw your stock flexplate in the fucking trash!!!!!
  77. 4L80e standalone help
  78. Thread Revival! A4 shift issues
  79. Stall & specing a new converter question
  80. 4l80e cable driven speedo ?
  81. rebuilding 4l60e in 99 trans am
  82. 4l60e no shift after 2nd
  83. 99TA - Blown Transmission?
  84. What is the track to getting this damn top bolt out for our transmisson
  85. Help me determine my gears (they're not stock)
  86. Transmission had no braking-need help
  87. 4L60e 2nd gear issues
  88. where to purchase 4L80e overhaul parts
  89. fitting question
  90. Torque converter cover bolt size?
  91. transbrake
  92. flexplate question
  93. Pros and cons of running stock and aftermarket cooler?
  94. 7/16" or 1/2" on converter shims?
  95. wrong shifting points ? PCM ??
  96. About to order a Yankss 4000, dr's,ect..
  97. Vigilante Converter
  98. 97 z28 4l60e in a 2004 sierra
  99. 4l60e interchangeable?
  100. 4L60E swap...need suggestions
  101. What converter for N/A Car
  102. deleting torque management?
  103. Trans fluid in C5 Vette
  104. Trans pan bolt broke off in trans
  105. New tranny
  106. Convertor swap..how hard?
  107. 3:73's or 3000 stall first?
  108. Need help!!!
  109. blowing thru converter question
  110. TCI six speed auto
  111. stock 6.0 flexplate
  112. question about overheating transmission
  113. 4l60E parts list needed
  114. Stall without tune?
  115. 4l80e 2wd vs 4wd
  116. transmission neck broken on c5
  117. Before and after acceleration showing difference with stall
  118. new stall with dr's but car feels slower.whats up?
  119. a4's with 4.10's come on in
  120. LS1 swap into 95 Z28 tranny question
  121. torque converter efficiency?
  122. 4L60e Doesn't Want to shift into 4th at WOT
  123. what gears and converter for my combo?
  124. Transmission for a 01Z
  125. How to install a torque converter
  126. does any of tbe sponsors or you part whorders have this 4l60e part laying around
  127. CPT transmissions
  128. which flexplate for an up to 2000hp application ?
  129. 6 Speed AUTO guys come in please
  130. 700r4 reverse valve body shifter gate??
  131. Converter lock up?
  132. TH350 manual valve body options
  133. Tranny swap from manual to automatic
  134. vibration only in 4th
  135. 4l60e from hell!
  136. tci 6xsixspeed
  137. 5 pinions in a 4l60e
  138. 700r4 lock up.
  139. can someone explain this to me!
  140. Circle D single disk goes 1.61 60ft on stock suspension full weight 06 GTO
  141. Turbo TA TH400 w/PTC - possible cause of stutter?
  142. 4L60E bell housing broke, inspection plate missing
  143. Looking for a shop to do Tor. convertor around Chicago and how much?
  144. LT-1 4L60E behind an LSX
  145. 4l60e slipping in 3rd and 4th
  146. Look what I found in my tranny pan...what now?
  147. Dilemma...gear selection for ss3600 stall
  148. US stall converters
  149. does anyone have any pics of a cheetah shifter install or a writeup
  150. Trap Speed after torque converter change?
  151. Valve body and such
  152. Powerglide shifter in 6-speed console
  153. Average increase in trans temp after ss3600 stall?
  154. 6L90E Compatability with 6L80E harness ????
  155. Which flexplate? Vig LS1 converter to LQ4
  156. Recommend me a flexplate
  157. 4l60e swap, Whats it worth??
  158. Just Ordered..
  159. Stock Stall?
  160. Rebuilding my trans
  161. Just installed my first stall....
  162. best 4l60e rebiuld kit
  163. Transmission shifts to a higher gear when going half throttle between 35-50mph
  164. no reverse.. ??
  165. TCI paddle shifters
  166. shift kit and line pressure
  167. 2006 tbss with a 6l90e and awd transfercase
  168. So the stall is in.
  169. TH350 to a ls motor.
  170. 700r4 shift problems?
  171. th400 Rear servo spring and manual valve body ?
  172. what usually causes dtc 81 selonoid B code?94 z
  173. 700R4 Pan Bolts Stripped?
  174. just rebuilt it and no 1st gear in 3 or 4
  175. where to buy a yank online
  176. Converter locked for dyno pull?
  177. 4L65E behind a diesel
  178. Help needed TH400 4wd output shaft
  179. Any full weight 9 sec 4l60s??
  180. Stall in now no reverse
  181. Slipping sensation in OD??
  182. 4l80e no speedo no help on truck site :(
  183. 4l60e--no 4 or 3 after rebuild
  184. Exploding 4l60
  185. powerglide speedo?
  186. What size stall?
  187. no overdrive???
  188. Only Rev, 1st & 2nd gear in 4l60E
  189. Th400 whining when cold????
  190. DEX III or DEX VI for Yank Converters, opinions?
  191. good transmission shops in houston...rebuild/build
  192. Jakes performance Converters anyone running one?
  193. 4L80 swap into a 68 camaro
  194. Pulling tranny tommarow for converter install
  195. 4L65E computer ?'s
  196. Converter Choice
  197. Monster Transmissions ??
  198. What's needed to make this work?
  199. Anyone have any experience with TCS Convertors??
  200. Anyone know what torque converter this is?
  201. 4L60E transmission removal help
  202. Shift Kit That Gives Manual Valve Body?
  203. Recent Trans Problem
  204. T/A 4l60e Slipping under WOT
  205. Transmission problem with my '98 Grand Prix GT
  206. TH400 to 4L60 (shifter ?)
  207. m6 to a4, cooler line question
  208. 4L65E Bellhousing ?
  209. TH400 or 4L60e suggestions...
  210. 4l80e swap questions
  211. "early" 4l80e's vs "later" models for fbody swap - differences?
  212. 4L80E line question
  213. 95 4l60e into 96 f-body
  214. FLT Lvl 5, no gears, good pressure
  215. 4l60e pump vs 4l65e pump
  216. Will 160 degree thermo help tranny run cooler?
  217. Good find?
  218. Question for 4l80e builder regarding max rpm
  219. 4L60E from 3.4L v6 to 5.3 v8?
  220. couple questions..
  221. Yank SS Versus Circle D Pro Stage III
  222. 6spd auto
  223. Installing a new shift cable.. any how to's?
  224. Anyone using the Superior/Fairbanks Servo for 2nd???
  225. Anyone Ever had this prob?
  226. Transmission HELP
  227. Tranny will not shift out of park, no tension when moving selector
  228. Best Stall to match up with TSP 228R cam?
  229. Cal Speed 4L60E
  230. Help ID'ing this 4L80e?
  231. transmission recomendations?
  232. Red Torque converter???
  233. What year 4l80e should I get
  234. Is it worth it to fix it?
  235. Need help 98 z28
  236. 4l60e
  237. A4 removal question
  238. Auto Trans Radiator Fitting
  239. 4L60E will not shift out of park, but gear selector moves freely
  240. torque convertors
  241. Know these parts on a 4L80E?
  242. LS1 flexplate on LQ4 6.0?
  243. Tailshaft play/noise
  244. Where to buy a "cheap" 4L80E converter?
  245. Who has a Revmaxx Converter please post your experience
  246. What trans.cooler?
  247. Stock 4l60E pan bolts?
  248. 4L60E is leaking again
  249. Please help. Have read for days and still cant find anyone with this problem or fix
  250. Cut away pan ID!?!?!?
