View Full Version : Automatic Transmission
- Looking for Reverse manual Th400 shifter - what is a "neutral safety switch"
- Pink converter?
- Extreme issues! What is it?
- 4l80 guys whos converter are you running??
- tranny short shifting problem
- About to put my converter in
- Car vibrates with shifter in " 3 " ??
- Did I Go Overboard On The Coverter?
- 2.73 car, stall, cam.. good combo?
- 94 z28 Automatic
- Yank Stealth 3000
- 4L60E swap
- Transgo
- 4L60E No overdrive
- shift kit or....?
- tranny question
- Stall converter help?
- yea i did something stupid...
- Help!
- TCI 3800...and some questions..
- What tranny will interchange in my 96 Jimmy
- ? About Setup & 3600-4400 Stall
- Rattling noise > New Yank SS3600 installed
- what stall for my cam/bolt on
- 4l60.
- tranny problems! MAJOR. NEED HELP
- have a question about 4l80e
- th400 and torque arm
- Will a th400 or 4l80e fit in a C5?
- What rear end gears for a TH400?
- Trans pan question
- whats the point of having the tb convert over the stock convert in 2002 chevy 1500???
- Torque Converter problems
- Tranny cooler lines removal in TC install
- I have 273 gears thinking about changing them. Need some input
- M6 to A4 questions
- Tramission Maintence
- 4L60E No Overdrive
- Flex plate balancing?
- Transmission Conversion Crossmember for Glide?
- 4L80E vs. TH400 with GV OD
- Converter?
- anyone from ls1tech help me out?
- 1994 4L80E electrical
- Trans Problem
- Where to find a good 4l60e??
- Conversion kits?
- drivability question
- th400 kickdown
- B+M hammer shifter
- Transgo + EC³ = damage?
- How hard is it to install a shift kit???
- convertor/flywheel?
- Serpentine Belt Slipped off, now 4L60E shifting hard HELP
- 4L60e acting up, only in certain conditions...strange
- transgo shift kit help
- Whats the best converter for me?
- Converter isn't locking up sometimes????
- May sound like a dumb ?, but can you spray the transbrake?
- Auto Trans problem any ideas
- 02 Trans Am TC install, torx or alan?
- Shifter for race?
- tranny fluid?
- tranny cooler install
- How much is your FLP or Rossler holding up to?
- 4L60E transmission problem
- Another question: On a freeway does a stall help or hurt the top end?
- Lid and exhaust guys + converter, what 60 ft?
- which hypertech shift points?? 2.73 with auto
- need help i broke my pump
- soon for tranny rebuild
- Loss of MPH IN 1/4 mile
- Transmission line leaking, any ideas??
- Speed Inc. Evil Transmissions?
- lockout stall for t400??
- Transmission Question?
- Stall and Tuning
- Strange "clunk" from a4 tranny?
- On more less a stock LS1 motor will a stall help much?
- 1,2,3 then...
- Merry Christmas all!!!
- Any benefit to using trans cooler on totally stock 04 GTO with 100-150 shot?
- got wrong TC, but should i keep it???
- Anybody dyno after a t400 install?
- when i get hp tuners what should i delete or remove with my biult 4l60e
- Stall converter questions. Please come in and give me some good input everyone please
- Need help fast!
- Tranny cooler .. really necessary ???
- car hiccup? What could this be?
- Anyone Tried This shifter?
- 96 auto
- 700R4 Conversion
- OFFICIAL "I want a B&M or Hurst RATCHET SHIFTER for my '98 and above F-Body" Thread
- B&M Trick Shift Fluid, good? bad?
- Installed Yank SS3600.
- Do any sponsors sell a th400 package?
- Did you know that a C5 can't have a.....
- Help me to rebuid my TH400 ?
- If anyone is interested...
- what is free-wheeling a TH400?
- What is it like driving a TH400 trans
- Change from M6 to Th400 ??
- do you need a tune for a 23-2500 stall?
- Tranny emergency
- Not sure where to post this, but is this a problem or normal?
- Which stall for my daily driver?
- tranny wont downshift and soft shifts now
- Rebuilding my tranny. Need an honest opinion and some advice
- Will this hurt my tranny?
- What causes this??
- th350 guys please come in
- What do you guys think about this honestly!
- Transmission holds gears too long when coming to a stop
- Yank SS3600 vs Vig 3400 vs TCI SSF3500 vs Yank TT II 3300
- Converter won't lock when really cold?
- TCI 3500 and n20!
- How soft are shifts with Vig 2800.
- Tranny Cooler Line Popped Off!!!!!!!!!!
- Is it true Hurst has a ratchet shifter for A4?
- Some questions others might have.
- Is Vig 2800 Right For Me
- Tranny issues?
- Transmission Leak
- 4L60/E crossmember
- 3-4 clutch pack: Borg Warner high energy or Raybestos
- HELP! Installing torque arm mount on tranny
- old th-400 to LS1 adapter?
- weried nosie
- 3-4 drum assembly with hardened shaft
- TransGo in Longwood, Florida
- To change or not to change....
- What do you guys think???
- Anybody think a TCI SSF3500 converter too much.
- servo help
- broke a hose please help
- what setps to take when installing a converter???
- whats wrong with my transmission
- 4L60E Help PLEASE!!!
- Automatic Car Starter
- how long is the shifter cable
- th400 not fitting with 4l80e spacer
- 80e trans brake??
- Deep pan, filter upgrade?
- th400 rebuild kit
- Can a rearend have slippage
- 3.23's to 3.73's Who made this swap? How do you like the results?
- What stall for a stock new GTO???
- making LT1 verter fit LS1?
- Shift Kit
- what's it like with a th400 and no overdrive
- how do you shift a reverse manual th400
- tranny probs please help
- torque converter question
- No 3rd or 4th gear in my A4
- tc not unlocking
- A4 to M6 or not
- Vig3200 re-stall question
- Anyone with 3-4 lockup issues please come in
- tranny shifting hard after short drive
- who can I get to put in a transgo kit around hickory NC?
- TH400 tranny crossmember
- TH400 output shaft
- Tci Ssf 3500
- Any aftermarket trans?
- Will my tc fit a suburban?
- Stock Converter NOT locking
- 4l60e problems
- TH350 Nitrous Converter
- VIG3200 Rocks
- a dime got into my gears?
- Corvette Servo, worth it?
- transmission life with a big cam
- ??????Is it right that auto trans have problems more than manual? ??????
- Car shaking after vertor install?
- lock-up converter?
- Had new trans installed recently, when to change fluid?
- A Transmission and Transfer Case Question
- Help picking a stall
- TH400 shift kit
- TH-400 or 4L60E
- TH400 guys....
- Grinding Noise when rolling?
- am i driving through the converter?
- Transmission temperature
- 4L60E build up.. whats needed?
- Screw 4L60E
- rear transmission seal
- 4l60e wake up kit?
- Installed new Yank Pro Thruster 4000, pleased!
- Thinking of getting a TCI 3500
- TC Selection.. help me decide!!
- Time to change the fluid???
- Has anyone tried a Lenco?
- Trans Go Shift Kit
- how much does a 4L60E in a crate weigh
- th400 shifter?
- Code P0757 - solenoid stuck open...HELP!
- How much time did you pick up with a 3500 stall?
- 4L60E TC Question
- Priming the TC?
- So is my transmission gone?
- TH-400 Blow-By Catch Can
- Transgo? Fluid?
- racing clutches in rebuilt 4l60e.. drive or overdrive around town?
- Trans OR Converter problem
- TC install writeups/info?
- removing a 4l60e tranny
- Trany question?
- Misfire and lock up
- converter bolt pattern
- Who built your 4L60E???
- transgo shift kit
- 96 LT1 4L60E in 2000 Camaro LS1?
- car stall to high in a WOT run?
- What trans. is in the V6 cars? 4L60E same as V8 cars?
- tranny cooler line length ?
- Best tranny fluid for TH400?
- shift kit
- Quick Th400 swapp question..
- Banging Rev Limiter between gears
- Stall Speed
- What kind of converter behind a 6.0?
- What trans?
- Anybody here used B&M shift kits?
- Help me identify my stall speed (in-car video)
- will 19000 gvw be big enough?
- Strange noise form gears
- worst speed for ls1 A4 roll race?
- 4l60e question
- 408ci with 4L60E
- quick question on a part name..
- Th350 vs TH400?
- All Midwest torque converter owners step inside...
- TCI e-mail address
- Help with converter choice.
- Help choosing converter
- Reverse manual shifter inlay for stock shifter
- Your Opinion
- 4L60E cooler line fittings
- how do you disconect the engine from trans
- stalled a4 vs. M6 who would win?
- size stall converter?
- Need HELP, Don't know if tranny is screwed.
- Aftermarket Transmission Crossmember
- need Help ASAP
- pump rotor ?
- A4 Question?
- tranny question...?
- shop refuses to install tci
- Car Surges when comming to a stop
