PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. 4L60E Recommended Rebuild Kit (2nd Time Around)
  2. 4L60E EXPLOSION! What Happened?
  3. Where to buy a 4l60e rebuild kit?
  4. Re-use converter or buy new
  5. Bmr TH400 crossmember help
  6. 4l60e limp mode
  7. Built transmission/ TC issues
  8. TCI Outlaw Gate options
  9. 4l60e experts needed
  10. Noise coming from Flexplate
  11. 40k tru-cool
  12. What does it mean when a torque converter "flashes" or "flashes high"?
  13. Quarter Stick or TCI Outlaw?
  14. 4l60e
  15. Slipping 2nd gear 4l60e?
  16. Circle D , Fti , or Yank?
  17. 4l80e to 4l60e
  18. 200-4r or 4l80e
  19. 4l60e help!
  20. 4l80e help - hardware questions
  21. Help !!! 6l90e won't shift out of 1st
  22. Why does my trans sound like a fuel pump?
  23. 4l80e 4x4 to 2wd lube hole?
  24. Which converter?
  25. Jakes Performance 4L80E Recalibration Kit - QUESTION
  26. TH400 w/ UltraBell - Texas Speed headers - Clearance issues?
  27. 4L60E Torque Converter Problem
  28. Turbo 350 won't maintain 3rd when up to temp
  29. 3500 stall as DD?
  30. LM7 TH400 Flex Wheel & Torque Converter Options?
  31. Shift linkage bushing for '96 4l60e?
  32. In the market for a built 4L80e, suggestions?
  33. bucking/surging when cruising on highway, slips into neutral at WOT
  34. Hay's torque converter good?
  35. How many springs in 1-2 shift valve lineup ?
  36. 4l60e shifter mounted switch pin-out
  37. Another 4l60e bites the dust? No 3rd or 4th gears only 1st and 2nd
  38. Help with converter choice
  39. 1-2 shift accumulator
  40. 400 swap in progress. Quick question.
  41. Will a 4160E bolt up to a small block 400?
  42. 5.3 flexplate on lq4 to Mate 4L60E
  43. 4L80E over run clutch kit
  44. What variation of the 4L60E will fit my car?
  45. Funky 1st and 2nd gear
  46. Reverse input drum hits the input drum
  47. 4L85E swap in place of a 4L65E
  48. 4l80e in Limp mode?
  49. Rebuild 4l60e mild performance
  50. 1998 f-body speedometer calibration
  51. 4l80e shifter adjustment
  52. TH700 R4 for Dummies
  53. 4l60e transmisson shifting to early
  54. 4L80 Swap-need opinions
  55. So you can't change the stator support
  56. Swapped and won’t shift
  57. Rebuilding a 4L80 tips? tricks?
  58. 4l80e
  59. Has anyone actually used GM 4l75E?
  60. Limp mode?
  61. Anyone reuse molded pump to case seal? + gasket question
  62. Adapter Housing Types
  63. Vibration after Trans Rebuilt.
  64. FTI Triple Clutch Converter Give-Away!!!!!!
  65. VSS question
  66. Shifter plastic disintegrating... crumbling to dust...
  67. Tranny options- TT lsx
  68. Priming the pump ?
  69. TH400 overflow catch tank/venting
  70. 6speed T/A going to a 4L60e Or 4L80e Pros and cons
  71. 2003 4L60E slow to shift when hot, Solved 12/18/17
  72. 4L60E 1-2 shift and OD slip
  73. 08 Burb won’t move
  74. Weird acceleration prob 4l60e
  75. 4L60E Range Selector Switch Wiring
  76. Auto trans no 2nd gear any more
  77. Shifts D to R
  78. converter recommendation / thoughts / experiences
  79. Th400 let go yesterday (surprised at what failed)
  80. 4L80E Guru's got a question 1992 454 SS
  81. 4L60E Build Info
  82. What is it like driving a stalled auto?
  83. FTI's Stage 4 Tranny? Who Runs One?
  84. stock 4l60e hold
  85. Jakes trans brake wont bump in
  86. Swapping out T56 for a 4L80E what needs to be done?
  87. C5 98 vette auto trans problems
  88. 4l65e issues in a 5.3 Swapped Tahoe
  89. 6.0/4L80E swapped Trans Am shifts immediately into 2nd gear from a dead stop
  90. source for 4l80e input shaft & 34 element sprag
  91. Happy Thanksgiving all you gear heads
  92. Which torque converter for 5.3 mild cam?
  93. Advice on 6l80 Rebuild
  94. Possible to run 11x11 trans cooler with SSRA?
  95. bad vibration in my 700r4
  96. Opinion on torque converter for standing mile race car
  97. Best year 4l80
  98. 4L60E Interchangeability
  99. Hi mileage pan and filter change
  100. 1-2 shifts very delayed
  101. Transmission Dimensions
  102. 4l80e using 5 bolts?
  103. Removing washers from flexplate
  104. TCI flexplate and 4l80e ?
  105. 4l60e soft 1-2 WOT
  106. FTI'S LOCK-UP The Savings Thanksgiving Sale!
  107. TH400 2002 f-body swap questions
  108. 4L60E no overdrive
  109. Could my cooler banjo fittings be causing this?
  110. 2002 A4 1-2 shift point suddenly way too high.
  111. Torque Converter for my Ls1 398 stroker
  112. Which 4L80E?
  113. 4l60e compatible years and versions
  114. 4L60E Parts list for my build, Calling out all the guru's!
  115. 1997 gmc 4l60e
  116. 4l60 plow truck, not happy. Codes inside
  117. 4l80E swap P0742
  118. Normal stuff on pan magnet?
  119. 2012 4l60e with 2006 L33 Compatible?
  120. 4l80E, HD-2, dual feed question
  121. Mid engine mounting
  122. How to make a stock 4L60E survive high hp/track
  123. Shift kit actually worth it?
  124. 2002 Chevy S10 ZR2 transmission problem
  125. TH400 rebuild kit decisions
  126. 4L60E - think I sabotaged my pump, now what??
  127. LT1 4L60e to 4.8 engine
  128. Th475 behind a turbo 4.8 help
  129. I have no 3rd gear
  130. Factory vs built trans tune differences
  131. Can anyone help with this 4l60e problem?
  132. sonnax custom roller clutch race
  133. Th400 soft when cold
  134. FTI 9.5" BILLET 8L90E Converters now available!
  135. 4l60e rebuild now no 4th gear
  136. TH400 swap speedo mod with ABS?
  137. 2002 LQ4 6.0 with a 1997 4l80e torque converter questions
  138. 4l60e swap wiring
  139. 77898e-k
  140. 6l80 stuck in limp mode
  141. 4L80E wont shift into gear with transgo HD2
  142. 4L60E Shift Points... Best RPM for Drag Racing?
  143. Pardon my ignorance
  144. Th400 reverse manual hughes. Come in
  145. Transmission Slips In Every Gear
  146. 4l60e 550 hp
  147. 5.3 W/4l80e swap....higher cruise TPS%
  148. 1200hp Transmission for an LS3 Swap?
  149. 4l80e pcm 12200411
  150. B&m 70274
  151. 4L80e Recommendations for a LS3 57 Swap
  152. 4l80 overdrive problem, 4th gear kicks in, then drops out
  153. 4L60e 1-2 Accumulator Spring(s) & Sonnax 1-2 Pinless Piston
  154. LS swap transmission wont shift
  155. PerformaBuilt Holiday Giveaway is back see inside
  156. Help confirming cracked flywheel noise?
  157. 4l80e fitment for which 4.8/5.3 years?
  158. 4th Gen 4L80E Shift Lever & Bracket Mods
  159. 4l60e won't shift out of 2nd gear and rapid rpm drops
  160. Tranny issues 99 WS6 turbo
  161. Launching question
  162. tci outlaw shifter noob
  163. 4l60e slips but is fine after I restart
  164. What stall speed on turbo engine
  165. 98' gmc 2500 van 4l60e question
  166. Converter stall issues
  167. 6L80 tap shift from 2 sources ?/help
  168. High Trans pressure = Thrust Failure?
  169. What torque converter with my transmission?
  170. Trans brake
  171. 4L60 Rebuild Cost
  172. No 2nd gear after rebuild, 4l60e
  173. New 4L80
  174. 4l60e transmission identification
  175. Help me do some failure analysis on this 65e before i repair it again
  176. People with F1 procharger an 4l80e over 800hp
  177. Shift problems
  178. pls confirm identity of TCC lockup solenoid picture
  179. 4l80e swap vibration fixed!
  180. 4l80E hard shift question
  181. 4L70E Build for TBSS
  182. Ls1 to th400 converter problem
  183. New to this site, need help with 4L60E
  184. 80E pressures road test
  185. 4l60E 3rd Gear Vibration
  186. what transmission cooler with 3k
  187. Going 400 with a brake. Question..
  188. Performabuilt 4l60e trans stage 1 or 2
  189. 4l60e servo valve delete
  190. Need help with stalling engine in drive or reverse
  191. Help! Smoked 4L70E Post-mortem Analysis (W/pics)
  192. Recommend a site sponsor for stall purchase
  193. Th400 swap issues
  194. 4l80e swap, won't crank
  195. Possible Damage from Converter Pilot (too short)
  196. 4l80 swap, getting a p1810
  197. 2002 TA auto trans
  198. Cant find truck 4l60e into fbody threads
  199. 4l80 swap vibrations
  200. Shift kits and tuning question long post
  201. Trans brake install ?s
  202. So I'm here at whatever it takes transmissions....
  203. 4l60e rebuild driveline vibration at hi rpm in each gear
  204. Vibration coming from tranny ?
  205. Factory transmission angle
  206. Best all-around transmission option?
  207. 4l60e rebuild part list
  208. Do I put the shifter in d3...d2...or d1 drag racing
  209. Choice of trans mount
  210. Lq4
  211. 4l80e swap dipstick?
  212. 4L80E converter not locking
  213. Probably a stupid question forgive me
  214. 6l80
  215. Failing Transmission??
  216. 4l60e D3 vs 700r4 D3
  217. Th400 data point/tear down
  218. 4l60e with YANk power adder series 3400?
  219. 6L80E + PCS GSM-5000 Shifter + Paddles
  220. WTB 4l60E rebuild kit
  221. Part #: 10405604 (Bracket, Trans Fluid CLR PIPE)
  222. 4L60E low line pressure?
  223. 4l60e won’t shift 2-3 WOT
  224. Th400 RMVB transbrake not shifting into 3rd wot
  225. TH400 Modulated Kickdown
  226. Junkyard Automatic Electric Trans Cooling Fan
  227. Th400 auto vs manual valvebody
  228. torque tube bearings
  229. 4L60E shift solenoid replacement as regular maintenance?
  230. Th400 crossmember
  231. 1000rwhp turbo street car new to fbody ?
  232. TH400 rebuild kit?
  233. Another automatic transmission problem
  234. 4l60e separator plate mod mistake help
  235. 4L60E question
  236. 68 Camaro With ls6/t56 swapping a 6l80e
  237. LS 4l60e connector voltages
  238. 2002 5.3 swap with TH350 and NP205 transfer case VSS question
  239. Just Bought A Yank PT4000
  240. Budget build 4l80 must haves?
  241. Mods for a Rubber-Band Powered 4L60E?
  242. Scored TQ Rear Hub
  243. E40/T42 Experts - please help
  244. Avg temp gear
  245. 4l60e stall upgrade on stock trans
  246. 94 corvette-slow to engage drive
  247. Is this the transmission vent hose?
  248. Should I replace this on 4l80e?
  249. 4L80E clunk
  250. 4L60E Cable Drive Speedometer Conversions
