PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 [128] 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Overfilled trans! Easy way to drain some off?
  2. Somebody help....
  3. how much did u guys drop after tc
  4. HELP! how could I fry another??
  5. I Need Overdrive
  6. Trans broke. Does this sound about right?
  7. Is a B&M 24k GVW cooler enough for a 5000 stall converter?
  8. Anyone done a 4L80E in a turbo F-body?
  9. help!!!
  10. help please!
  11. str
  12. what parts do I need for a 4L80E rebuild to handle 600ft/lb of torque??
  13. dirty work...any tips
  14. torque converter
  15. Torque Converter
  16. Good idea or waste of $$
  17. Trans not downshifting
  18. Drivetrain warranty
  19. Life expectancy of stock trans...
  20. Best choice torque converter for this?
  21. Stall / How to launch
  22. HELP: What am I doing wrong (stall/gear swap related)???
  23. What Tranny to hold 600-1350 RWHP??
  24. Dyno Graph
  25. Rebuild/New Tranny?
  26. major trans issues
  27. Th 350, B&M rebuild tolerance problem
  28. 4L60E Transmission Wont Go Into Gear
  29. What to tune on an automatic car
  30. P1870 DTC Sanity Check
  31. P0748 Code/Sanity Check
  32. serious th2004r inquiry
  33. i want a tranny that can hold 600hp and 650+TQ
  34. How will I know if I lost 2nd gear?
  35. Ordered new Fuddle Racing Converter...
  36. Th400 : short tailshaft...swap it?
  37. New Transmission Mount Can't be Found
  38. what do u think of the flaxplate for 4l60e
  39. 2, d, od to 1, 2, d, od...HELP!!!!!
  40. Stock trans and transgo shift kit, need opinions on performance
  41. 4L60E transmission filter oring seal on my 98 Z28
  42. TH350 Info Needed All Help Appreciated!
  43. TH350 parts
  44. Launching An Auto
  45. Tranny cooler 'kits' with cooler, fan, thermostat....
  46. PATC Need Feedback!
  47. Non-LS1 Transmission Problem... Need suggestions
  48. 4L60E Trannies...How Much Horsepower Do They Use?
  49. Stupid tranny cooler lines are leaking
  50. What rear end gear do I have?
  51. ok think I F'ed up, tranny/verter install question
  52. aftermarket shifters
  53. People with Modulated 4l60e's does your car throw a code for the e/modulator?
  54. what tc to get?
  55. Problems after Prostars installed, (trans)
  56. NEED Auto tranny swap this week, HELP
  57. testing waters: paddle shift kit for 4th gen camaros
  58. Shift problem
  59. Major shifting issues after cam and tune. Please Advise.
  60. Big nitrous users and 3speed guys in here
  61. Yank SS4000 is in!!
  62. Converter Selection help!
  63. How much converter run out is acceptable?
  64. How much does a 4L60E weigh?
  65. Question about driveablity and gas mileage
  66. Evil Transmissions???
  67. slapshifter/shift kit for 2002 auto z28
  68. 700 plus HP and I want a 4 speed auto - what tranny to get?
  69. Auto Tranny
  70. a4 + tc + gears
  71. Question on slipping TCI
  72. Quick ??, should it feel this way
  73. V6 & V8 Tranny are 4L60E's?
  74. What tranny comes in a lt1 trans am
  75. Would this be an interesting product?
  76. Fuddle Convertor questions and my broken TCI convertor
  77. What trans fluid for A4?
  78. Is This Normal
  79. tranny slipping into neutral, comp. problem?
  80. I think my Transmission is slippin?
  81. check out my upgraded fuddle
  82. how much can my auto take
  83. Tranny rebuild help
  84. What color wires for the 2 shift solenoids
  85. TH400? how to hook up speedometer?
  86. trans cooler question
  87. Is my car a dog, or do I have sticky tires?
  88. No 3-4 Accumulator Spring in 2000 T/A
  89. Quick Question Help
  90. Th 350/400 ?
  91. partial tranny failure...possibly stall converter related
  92. H.P. Street Fuddle 3600stall / 2.2str
  93. how much hp can a a4 hold
  94. Th400 slipping at the track (question)
  95. 4l60e
  96. hard shifting ws6 -00
  97. Yank Torque Converters
  98. Is it better to lock up the converter in 3rd or 4th gear?
  99. TH350 vs 4L60E
  100. A3 in!!! one question
  101. Higher Stall add Stress?
  102. 3rd??
  103. Good 4L60E
  104. trans doesn't not shift into 4th at WOT
  105. trans info requested...
  106. Will higher line pressure wear out clutches faster?
  107. Please help! Speedo way too fast!
  108. Transgo shift kits
  109. What is this thing?
  110. Running a NON-lockup transmission on a 700R4?
  111. I hope we can make this fit!
  112. Inconsistent 1-2 shift ('00 w/2.73's)
  113. The Fuddle is in
  114. Gear Vendors
  115. Tranny noise.
  116. torque converter
  117. locking TCC in 3rd for racing???
  118. Transgo Shift Kit Instruction help.
  119. M6 to th350 swap in S10, need info
  120. car wont start!
  121. Energy Suspension Tranny Mount
  122. tranny won't turn
  123. built trans w/ 4K stall shifts soft??
  124. I'm retarded! trashed my th350
  125. Vacuum Port
  126. Need a Built Th350
  127. What STR do you have Poll
  128. Fuddle Converter & TCI Flexplate
  129. Tq converter install
  130. 4th gear shudder/slip.
  131. sad experience...
  132. TC and stalls
  133. Tranny is acting weird...
  134. Crack in the extension housing
  135. who builds the best 4l60e
  136. ls1 and lt1 auto swap parts interchangeable?
  137. Parts list/ write up on a th 400 swap
  138. neutral safety switch
  139. How long will the A4 last?
  140. Tranny Fluid???
  141. buying a z28 with a4
  142. ARP Flywheel Bolts
  143. tranny swap...what do i need
  144. I need tranny help Bad
  145. What can I get for my 4L60E?
  146. What tranny cooler and shifter to use?
  147. Converter help please
  148. somebody near their car please respond
  149. 6l80e
  150. Trans help and advice please...
  151. th-400
  152. My luck is getting worse somehow
  153. Help to separate Trans from Engine
  154. program my stall
  155. 4L60E Build Up
  156. Will it hut my transmission to down shift form OD to 3rd manually?
  157. midwest converter question
  158. 4L65e /3600 stall tearing up TC Clutches
  159. not shifting at WOT
  160. Crunch/Creak during moderate/heavy acceleration??
  161. which converter good for ls6 hot cam
  162. which converter good for ls6 hot cam
  163. Stall Converter?
  164. '00 C5 flexplate work for 99 z?
  165. Yank convertor installers got a question
  166. TH 400 Length ??
  167. new to the tranny world a little help please.
  168. vacuum loss after stall install
  169. 2.73s + stock stall.
  170. Guess the problem...
  171. car shifts twice in OD...
  172. anyone know................
  173. How long does it take...
  174. Torque converter for V6
  175. auto tranny to withstand 750+ HP
  176. Vss
  177. Need Help - Rebuild Kit and Tranny Slipping (Opinions Wanted)
  178. Fuddle at the track? What do you recommend?
  179. wont shift till 3grand
  180. 80E Swappers Need Help
  181. How to replace rear tranny seal?
  182. problem with tranny?
  183. th400 pickup mod?
  184. Trans coolers
  185. How Much Power Do You Loose Going To Th-350 From 4l60e
  186. 1000+rwhp 4l80e shifhting late
  187. Take my poll! Final TC decision!!
  188. 200-4r Swap
  189. 24K Cooler not enough for 4K stall?
  190. Torque Converter Won't Lock Up
  191. ATF in a c5?
  192. Aluminum flexplate?
  193. No 3rd or 4th gear!!!!
  194. Got Fuddle?
  195. Is there a better stall/TC than the stock one??
  196. R.M.V.B. th-400 question!
  197. 3.73's vs RPM's
  198. Need help!!!
  199. th350 or th400
  200. M6 vs A4
  201. How can I tell???
  202. Tranny problems! HELP!
  203. Steel Braid Lines
  204. tranny life
  205. opinions?
  206. Pressure with vacuum modulator???
  207. transgo?
  208. Anybody heard of Raptor Transmissions?
  209. Stock 02 Ls1 4l60e Tranny Stall Rate
  210. Going from t56 to A4
  211. No OD, D, or 2. Only Reverse. !!!???
  212. Higher stall or no?
  213. 2001 C5 - car wont shift to 4th *quickly*. Whats wrong?
  214. Fuddle
  215. New to auto tranny--need help adjusting the TV (kickdown) cable.
  216. what to expect with a tci sf3000
  217. 4l80e build questions
  218. Tranny ideas?
  219. help i dont knwo what im doing rong
  220. What MPH to lock up 4L80E?
  221. will it work?
  222. Silverado drain plug part #
  223. Help - where to buy a beefed up 4L60E?
  224. Will a tranny cooler make my stock tranny last longer?
  225. Help!
  226. Stock A4 Ls1 Z28 times?
  227. Converter Lockup Problems
  228. just wondering??
  229. How much RWHP can a stock tranny hold?
  230. Fuddle 3600 Install Today??
  231. N20 and Stock tranny?
  232. 4l60E Transgo
  233. Turbo 400 or Other Trans
  234. how many of u run the magic stick or the mini stick?
  235. Cracked flywheel. Can I weld it?
  236. 4200 or 4400 with stock internals??
  237. Need help with th400
  238. art carr???
  239. How much can the stock 4L60 take
  240. Just finished stock rebuild!!!!!!!!!
  241. shift kit ??'s
  242. 4l60e problems
  243. 4l60e not downshifting properly?
  244. How to tell if a tranny has a shift kit?
  245. 1-2 shift knocking help
  246. Stall without Subframe connectors?
  247. ordered my fuddle 4K, times????????
  248. gas mileage?
  249. Mount problem
  250. WOT in D or 3 in a trans am
