PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 [144] 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. yank ss4000
  2. fluid change
  3. Driving impressions: SY3500/Y3000vs SSF3500(long)
  4. wont go past 2500rpm
  5. Can I install a Transbrake?
  6. I need a scattershield for a TH400
  7. TH-400 xmember lt1/ls1??
  8. TT2800 3.0str 60ft?
  9. 4l65e race or not
  10. Quick torque converter bolt question
  11. Swapping from an suto to a 6speed? anyone intrested?
  12. Car keeps getting the Solenoid B Code
  13. Your opinions for a "boost" converter
  14. Tranny cooler
  15. 98 trans into 01
  16. Trans line question...
  17. 4th to 2nd downshifts slipping??
  18. Just installed converter.... need advise
  19. I need a new tranny, where?
  20. locking vs non-locking?
  21. th350 torque convertor
  22. Speedo conversion for your TH350?
  23. Converter question regarding efficency?
  24. 4l60e Help!!
  25. Converter unlocking under VERY light acceleration
  26. choices for autos w/ OD
  27. Wanted: stock ls1 auto flywheel
  28. my car is shaking badly
  29. will a yank ss 3800e be good for n/a?
  30. DIY 4L60E rebuild possible??
  31. Yank SS3800E and 200 shot.
  32. tc for 3.07:1 gears??
  33. thinking about doing a tc
  34. Which TC to use with cam?
  35. I need opinions on what this could be??
  36. tranny guage in air vent??
  37. top speed
  38. Tranny cooler in front of A/C, engine temp??
  39. Fluid Level after Cooler install
  40. Trans Temp gauge install
  41. TC and flywheel
  42. auto shifter cable hook up problem plz help
  43. urgent: tc over 3400 is bad!! PCM??
  44. TCS t/c
  45. Bigger TC bad for tranny?
  46. Vibs felt in drive only
  47. Can someone give me an opinion on this
  48. Vigilante 3200
  49. ???????????????
  50. Best prices on extremeduty 4L65E parts?
  51. SS4000 or PT 4000?
  52. Not shifting to OD
  53. what the hell is rattling
  54. Can you spray with a YPT4400?
  55. Going from a Vig 2800 to a Yank SS 3600 help?
  56. Speed Inc. Pure Evil Tranny feedback wanted.
  57. Transbrake on a 200-4R
  58. question from a manual guy
  59. Traction Control vs Torque Management
  60. 4L80E problems
  61. Need Help! Won't Idle...Transmission Related???
  62. Tranny Cooler Size
  63. 02 owners, TCI 3500?
  64. Changing from Vig 2800 to TCI 4400
  65. 4L60E Checkballs
  66. tci converters what you guys think?
  67. torque "dip" and optimum shift points
  68. any tc out there that wont destroy mpg?
  69. Fluid change
  70. tool for pump?
  71. TCi 3500 to Yank 4000 gains??
  72. Anybody put a non lock up converter in a 4L60E?
  73. does locking a TC based on MPH hurt performance?
  74. What size converter? Supercharged
  75. BMR now offers Trans K-member for 4L80E conversion!!
  76. What trans temp are u getting with Yank SS400?
  77. what do codes mean?
  78. And why is my tranny fluid turning purple?
  79. Trans temp gauge help.
  80. drivetrain clunk is it normal?
  81. trans slipping?
  82. new torque converter
  83. Is 3000 stall too low?
  84. Wait!! I use less throttle after SSF3500 stall?? HUH
  85. 4L60E TC's Diffrent???
  86. Turbo 400
  87. SES P1870 and my converter doesn't seem to lock?
  88. Convertor choice for H/C and 150 Shot.
  89. SSF 3500 guys inside.Got Q Im going to the track soon.
  90. installing my ssf3500 tomorrow
  91. Paging Kevin Winstead @ Tci
  92. why wont it shift right away WOT??
  93. Finally I Feel At Home Here...blown Tranny
  94. stupid question
  95. Need suggestion with 4L60E from my LT1 into my 00' LS1.
  96. temp gauge installed....question?
  97. 4l60e/Powerglide swap crossmember
  98. Transmission slips only when TC locked... tranny or TC problem?
  99. What size converter for a daily driven camaro.
  100. Yank email address not working
  101. How big of a stall?
  102. vig 3200 guys with tuning...come on in
  103. Driveing in 2 past 55mph Im I in trouble?
  104. tcs converter..six mounting lugs??
  105. Yank's ultimate drag converter?
  106. Where to get Transgo, Vette servo, accumulator, etc.
  107. Hard/quick shifts. WTF?
  108. Why is 3rd gear so long?
  109. shift kit, yea or na?
  110. TH350-What converter for LS1 with LS6 cam
  111. TCC lock during shift question?
  112. question about flashing a stall..?
  113. trans after cam install
  114. Anybody buy a PTC converter?
  115. SES codes and idle surge after PT4400 install..
  116. installing ssf3500. keep 4.10 or drop to 3.23
  117. 4L80E? Or anything strong
  118. weak tq numbers, 3500 stall/bolt on guys, what did you dyno?
  119. SSF 3500 went in yesterday......LOTS of info inside
  120. Stall question?
  121. What's the best value in converter right now?
  122. Yank SS4000 vs SS4000E what's the diff?
  123. help w/4l80 yank converter/flywheel issue
  124. 2 Torque Converter bolts sripped????? I need help asap PLEASE
  125. Shift knob for stock 4l60e shifter?
  126. Look Ma - no dipstick tube from factory?
  127. everyone who knos about converters please help
  128. What makes an 8 inch converter unstreetable?
  129. "Catch Can" to solve venting problem? Anyone done this?
  130. Jiffy Boob - cooked slush box?
  131. New C7 vette - sealed slush box
  132. Misfire/knock from a 3600 stall???
  133. Filling a sealed auto tranny??
  134. Converter choice. HELP!!
  135. ss3600 vs viper in video section
  136. Best Way To Raise Line Pressure
  137. What fluid to use and where to get a cooler at
  138. Changing a converter on a Vette...
  139. Problems ? within
  140. PG w/ LS1??
  141. loud "clunk" sound from under car
  142. Ordering TC soon: Vig or Yank
  143. From:Vig3200 to Midwest4000 to Yank PT4400 impressions
  144. 4L60E Converters
  145. 200-4R Converters the same as 4L60E?
  146. trans is starting to run hot.....
  147. connect t-cooler to radiator??
  148. Found Problem with 4L60
  149. Tci4400 Vs Pt4000
  150. dowel pins came off with tranny
  151. Tranmission problems
  152. How much RWHP before the stock 4l60e goes boom?
  153. 1-2 Late Shift
  154. When to switch to OD
  155. 4L60E rebuild.
  156. Should output shaft have play?
  157. TCI SSF 3500 40 meg video "City driving" as promised.
  158. tranny overheat please help !!!
  159. Is this common with 3.73's and a 3600+ stall?
  160. Question on backing a converter off the motor?
  161. Not sure about this.
  162. Need help: braided line, AN fitting parts list
  163. locking crankshaft for converter
  164. vig3200 guys come on in!
  165. Troublesome Trickshift?
  166. Can a tranny cooler get hot?
  167. TransGo Shift Kit
  168. Need Help with trans problem!!!!
  169. a4 tranny having problems with stall
  170. stall w/o shift kit?
  171. NFG to the whoel conveter thing
  172. TCI 3500 problems help!
  173. Tc and 60's..
  174. VIG guys inside plz
  175. B@M Tranny cooler w/fan @ thermostat, need wiring instructions.
  176. Rattle/Ting From Under The Car, Any Ideas?
  177. Torque Coverter-new cam?
  178. POS tranny stuck, can't break loose
  179. tranny rebuild
  180. Alternative Tranny Cooler
  181. Torque management deleted...?
  182. Convertor Adapter.
  183. Just finished swap VIG3800 to YTP4200.
  184. help ASAP: Tranny lines; reverse thread or not?
  185. TH350 Torque converters: LT1 != LS1
  186. Permacool Install What A Pain!
  187. TT3000 is locking and locking on 1 to 2 and 3 to 4 upshift...
  188. Converter locking, unlocking, locking, unlocking
  189. 2-3 shift problem
  190. TruCool or B&M Transmission coolers?
  191. TH400 Swap -Fact page??
  192. Rear end, gear questions
  193. Counting the cost:
  194. Converter Lock-Up?
  195. Converter came loose?
  196. Transbrake
  197. why not the 200-4R instead of the pop TH400?
  198. Shift extension of the Yank TP series....
  199. A4 c5 will not WOT shift after 3.15 gear and P1870 code
  200. Altering Shift Points for 4L60E
  201. 4L60E wont shift into 2nd
  202. TCI tranny (Street Fighter 4L60E)
  203. Desired shift time...
  204. Converter Choice Help!!!!!
  205. What size transcooler and where to mount it
  206. Who has decent prices on 4000 up converters??
  207. can i fit another cooler?
  208. No shift on WOT
  209. Hesitation in 1st gear start?
  210. Should I swap from T-56 to 4L60E
  211. well crap my flywheel is cracked
  212. TC for daily driving, hot weather & heavy caprice
  213. Coverters??
  214. who makes a driveshaft for an m6 to th400 conversion?
  215. precision Industries
  216. Tranny help
  217. Trans temp sender
  218. converter with t-rex cam?
  219. which converter
  220. ST3500 vs. PT4200
  221. how to m ake an A4 shift quicker and crisper
  222. SS3800 Doubters, come on in
  223. am i forgetting anything
  224. fast question
  225. Any Good Allison trans Tips!!!
  226. Just installed a TCI 3500 need some help
  227. TC: how much power??
  228. A couple of ? for those switched from low stall to a higher stall
  229. Help with M6 to TH400 Swap
  230. Speedo hookup from manual to 200r4??
  231. Paint cure smell ?
  232. help with verter choise
  233. Powerglide dipstick
  234. Driving a higher STALL converter description
  235. M6 guy asking an A4 question... long
  236. Tranny Flushing??
  237. Locking up PT4400 in 3rd gear
  238. output shaft play
  239. checking tq converter
  240. Who has a TCI Comp 4000?
  241. SSF3500 good for nitrous?
  242. what is the stall on a stock converter
  243. TransGo Problem
  244. Anyone heard of or use this transmission?
  245. FLP = Serious Customer Service
  246. 4l60e
  247. F/S Built 4L60E
  248. Quick question on convertors....
  249. tranny clinking
  250. which converter / anyone with a converter
