PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Any drag trans experts in Tampa?
  2. Got my Circle D today!
  3. Which ATF for Yank
  4. Is a 4k stall worth the money for a bolt on car?
  5. POWER-GLIDE om a 4400lb 1000hp truck???
  6. Converter Choices
  7. Cleaning a stall
  8. did i f**k up my trans??
  9. Need help stuck on radiator removal
  10. Circle D 278mm whose got one
  11. 4l60E questions, Can I make this work?
  12. Converter to handle 1000+RWHP and WOT lockup for a 4L65?
  13. stickies don't spell out - LT-1 = WHAT CONVERTOR W/TH400 WILL FIT?
  14. 4L85E with supermatic controller
  15. tc bolts
  16. The ULTIMATE 4l80 builder & MY experience !!!!
  17. Installed my tranny cooler tonight-Pics
  18. 4l60e with 4.10
  19. Yank, PI vigilante and now Circle D
  20. Park acting like Neutral!... WTF?!
  21. Tc?
  22. manual valvebody 4l80e
  23. m6 to a4 back up light wiring.
  24. fresh 4l60e wont shift
  25. converter question.
  26. M6 to Auto Conversion wiring questions
  27. Fuddle Stalls
  28. Converter bolts stuck?
  29. pulling 4l60e
  30. i got a shake
  31. REAL USERS: 4L80E behind 95 LT-1 OBD1
  32. jake 4l80e 6spd conversion
  33. 700r4 Torque Converter Won't Come Off
  34. TQ Converter ?
  35. short Tail TH350 on camaro got questions
  36. stall
  37. Wrong transmission?? wtf...
  38. Buying a Yank Converter: SS3600 or SS4000 in a light car
  39. Trans not shifting right after cam
  40. swapping to a 4l80e
  41. Turbo 350 or 4l60e??? Street Car
  42. 4l60e-Bang while on the highway!!!
  43. Transmission taps when in gear?
  44. 4L80E rear shaft into TH400 carrier
  45. How much power can the best built 4l60 hold
  46. Jake's Performance Holiday Sale, Two weeks left
  47. shift kit
  48. Any interest in TH400 automatic transbrake valve body?
  49. Xtreme Transmissions New Year Sale + New 6L80E Converter
  50. what a good torque converter to buy
  51. Anybody have a circle d 1c 245mm? Trying to make decision
  52. 6L80E / 6L90E tow haul mode?
  53. TV cable plug?
  54. 4l65e conversion
  55. Circle D converters
  56. Dipstick ? for th350
  57. 6L80 w/cruise for those who said it couldn't be done!
  58. Power Glide Question???
  59. Need to drain trans fluid from torque converter to ship it
  60. 4L80E Stall On 6L80E?
  61. tranny is being weird
  62. Anyone using this transmission mount?
  63. jake brake install questions
  64. 4l60e ?
  65. 4l60e no top gear
  66. Truck trans/housing will it fit in an fbody?
  67. 4l80E Full manual VB Q
  68. WTF no 3rd gear?
  69. adjustable shift settings on the fly via Jet power shift for 4L60e auto tranny
  70. Need some converter help, SPONSORS
  71. Yank SS3600 or Yank SS4000 with set up?
  72. th400 questions...
  73. 4l60 crap!!!
  74. 4L80e ?'s
  75. th400 install help!
  76. 4l60e/4l80e what is the difference?
  77. 4L60E Shift Kit or NO?
  78. 4l60e valve body?
  79. 4l80e HELP!!!
  80. 4L60E Problem
  81. performa built converter ?
  82. Different year 4l60e swap
  83. 4l60E tail housing question
  84. 04 GTO trans i put in 99 TA broke last night...
  85. Downshift MPH Settings
  86. 4L80e vs TH400 - Which one is faster?
  87. Convertor question
  88. New Year Stall Specials?
  89. Transmission troubles
  90. GTO trans cooler input needed..
  91. Circle D A+++++
  92. 4l80 Trans brakes/mvb ??
  93. Trans Cooler Questions
  94. D and OD feel like Neutral in my 98 A4, help...
  95. '95 Caddy Fltwd Brghm(RWD)
  96. New built transmission w/new converter question
  97. FTI Trans rebuild? or are they just converters?
  98. Convertor for my setup
  99. 3400 stall
  100. 4L65E Problems :*TCC Solenoid refuses to disengage*
  101. 4L60e Trans Rebuild
  102. TCC not locking, 95 rebuilt trans
  103. Tranny issues
  104. th400 dipstick?
  105. FLT level 4 or performabuilt level 2 ?????
  106. 4L60E problums
  107. 4L80e---race in Drive or OD
  108. Torque converter bolts
  109. 4l60e trouble
  110. Putting a used 4l60e in
  111. Any of you guys running a Yank PY3600 Converter? Just loking for opinions
  112. Looking for shifter linkage solution: C5 shifter to auto trans
  113. Th400
  114. Decisions, desisions...
  115. 4L65 w/trany cooler only
  116. Any Head and Cam cars running a SS3200
  117. is anyone using this shifter with their 4l80e swap
  118. 6 cyclinder convertor
  119. 4L65E with no provision for 3-2 solenoid
  120. M6 to A4 conversion backup light/pn switch question
  121. 700r4 into 2000 formula A4
  122. how much quicker are you on a trans brake then foot brake?
  123. Torque Converter With Stock Transmission
  124. Stupid question - LY6 to 4L60e
  125. Switching from 4l60e to 400 turbo. need ideas!!!!!!!!!!!!!!!!!!!!!!!!!!
  126. Help...4l60e not engaging!
  127. What kit to rebuild a 4L80E trans?
  128. Best 4L60E REBUILD KIT???
  129. 99ss lq4 m6 to th350 ?????'s
  130. ???'s about auto shifter in stock m6 console
  131. 3200 stall what cooler?
  132. 4l60e ls1 tail shaft
  133. Tranny swap cause high idle
  134. No start after new tranny install
  135. TCI RMVB for 4L80
  136. Tailshaft bushing
  137. 4l60e interchange
  138. Finish Line Transmission Holiday Special!
  139. Help me fix my 4L60E!
  140. 4l80 questions
  141. Which stall is tighter?
  142. Pulled my tranny!!
  143. turbo 400 in a 95camaro ls1 car?
  144. Automatic safety switch?
  145. 4l60e interchangeability question
  146. 4L80 out of a 93 suburban
  147. Glide or Th350
  148. Help with mystery meat stall
  149. TH400 Swap Overwhelming
  150. Introduction! Jake's Performance
  151. Anyone using an optishift?
  152. Shifts into overdrive too soon, bogs, won't downshift
  153. light-weight th400?
  154. Now offering Automatic trans Rebuilds on ANYTHING GM (General Motors)
  155. I need a reaction carrier assy. for a TH400
  156. tci th 350 and percision stall for ls engines
  157. P0741 code on 07 silverado NNBS with perforabuilt converter
  158. 4l60E Tranny For Sale
  159. Dangers of a trans that has sat???
  160. Converter unlocking/locking as I crusie down the highway
  161. building a 4l80e parts questions????
  162. Driving with a 5600 stall... vid inside
  163. Does GM make a version of their 6L80E/6L90E for European OEMs?
  164. converter clutch acts normal at sealevel and shitty at high alt.
  165. Bulletproof rear trans seal 4l60e
  166. driving in thrid
  167. 4l60e shopping for prices
  168. Cold shift bogging
  169. anybody heard anything good about these guys?
  170. Weird 4L60E 1-2 shift issue when footbraking off the line...
  171. Table for MPH Shifting
  172. keithz28 2001 camaroz28
  173. Stall and 2.73's
  174. debating on stall company...
  175. RPM Transmissions - Cyber Monday Sale!
  176. Circle D - Black Friday Sale
  177. 1994 4l60e with 1996 LT1
  178. 4L60E Issue - 1-2 Shift @ WOT
  179. will this 4l80e work?
  180. Anyone with circle d hp 278mm?
  181. Anybody with a 2800-3400 stall post up some vids plz!
  182. B&M Pro Stick Shifter
  183. th350+700rwhp+semi budget=what can i do?
  184. Starts in 3rd or 4th, No 1st at all
  185. 4l60e tps problem
  186. pickup converter
  187. 4L60e Parts
  188. For you TH350 guys, what brand TransBrake did you go with and why?
  189. YANK SS4000 new best 60ft 1.291 h/c/i na 346
  190. think my torque converter is goin.... help please
  191. 4l60e tailshaft housing?
  192. 2800/3200 Stall and Gear Vendors Overdrive
  193. what route to go? Damn transmissions
  194. th400 random slip in second
  195. Anybody go under 1.50 60ft with 4l60e?
  196. 4L80E conversion
  197. Built 4l60e not shifting 3rd at WOT
  198. what torque converter should i get
  199. How much did you pay...
  200. transmission cooler beneficial...?
  201. Need Help, TBSS won't shift automatically, shifts manually
  202. torque converter failure
  203. New Yank SS4000 Installed :)
  204. Need help with a "must have" parts list!
  205. Highway RPM
  206. tranny parts
  207. car goes retarded in reverse
  208. 6Spd T56 to Automatic
  209. corvette to f-body
  210. 2001 4l60e IS THIS POSSIBLE
  211. Shortening drive shaft to install TH400?
  212. SS3600 & 3.42's
  213. Early 4L60-E and carbed LS1 question
  214. Question about park/neutral switch on a 4l60e
  215. 4l80e red eagle and shift kit??...help
  216. No threads about Stall=drivetrain damage
  217. 4l60e - feed/return line
  218. th400 speedometer help
  219. how much for a ss3600 stall run me?
  220. no park reverse or neutral
  221. do i need the dust cover on the 4l80e
  222. Paddle shifter HELP
  223. Manual Valve Body Driveability
  224. Vig3600 vs SS3600
  225. quick question about a4 to m6 swap
  226. 700r4 into 1993 camaro
  227. Cracked Flexplate?
  228. Stall Problem?
  229. neutral safefty and gear selector switch
  230. Where are you guys buying TH400's and conversion parts?
  231. 700r4 shifting problems
  232. edge stall driveability?
  233. Anyone shorten the camaro auto shift knob?
  234. converting stock converter into stall?
  235. Help me ID this converter
  236. Thank you FTI
  237. TH400 problem need pros help.
  238. Yank SS line and Pro Yank Extreme
  239. silverado 4L60e different from regular cab to ext cab
  240. stall choice questions
  241. built 4l60e problem
  242. 97 4L60E bolt directly into a 95 car?
  243. 80 z28 4l80e??
  244. Tranny slips and then it doesn't??
  245. 4L60E 3rd gear problems
  246. TH400 going forward in all gears
  247. ANYONE really using a 4L60E with 600rwhp?
  248. Transmission guys inside. Is my tranny failing
  249. 6A or 6m trans. in a 4th gen?
  250. torque converter bolts?
