PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 [133] 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. trans mods???
  2. Need a OEM Transmission Mount
  3. Heeelllllppp Transgo install problem?
  4. Want to trade
  5. wanting a stall....
  6. need advice on trans problen
  7. whats going on??
  8. vacuum modulator vs no vacuum modulator
  9. trans fluid question
  10. Th200r4
  11. Soft 1-2 need advice
  12. different transgo shift kits?
  13. FS: Ac Delco 3-4 shift selenoid for 4l60e
  14. Tci 3600
  15. can i rebuild?
  16. 2002 Z28, bouncing off rev limiter.
  17. Is this a sign of time for a rebuild?
  18. TH400 as adaily driver, advise?
  19. Schaffer shift control for a-4
  20. Trans tuner
  21. Trans go shift kit
  22. Bolts for TCI SSF3500
  23. 4l60e housing
  24. Banging noise
  25. most desirable 4L60e
  26. 4L60E Foward clutch pack
  27. Was a TCI ssf 3500 a good choice?
  28. 1-2 shift problems
  29. Paging Dave@Rock-On......
  30. 80e strength
  31. Tranny cooler question
  32. Help w/ md 3600
  33. Midwest Stall and spray
  34. HELP!!!Tranny dipstick...
  35. Need help picking a trans
  36. Transgo Install Question
  37. Everyone with the TCI SSF3500, question?
  38. HELP(asap), Fuddle TC installed = problems
  39. Finally got the 80e in my formula
  40. A4 shift problem, please help.
  41. crashed 94 tranny
  42. Is a Predator programer enough to tune a Converter?
  43. NEW Dexron - VI
  44. help.....how many quarts does a 4l80e hold?
  45. Help Me Pic An Str Ratio.
  46. throttle sensor
  47. Bigger stall in a stock 4L60E?
  48. what stall converter to go with MTI G1 ?which stall is the righ 1 ?
  49. RPM Questions from a newbie
  50. changing converter
  51. YANK'S crossmember with t/a mount 350/PG
  52. Installed Vig 2800 and "check engine oil level" light came on.
  53. vig3200 or vig3600 for TNT150 shot?
  54. Changing Shifter Handle
  55. 700r4 in my '98 Z28
  56. Is this normal?
  57. torque converter question?
  58. Low/Reverse clutch stack 700R4
  59. Problem launching after TC install.
  60. more HP to turn a 4l65e than a 4l60e ??
  61. tranny woes
  62. midwest converter
  63. Just got a built tranny now ????
  64. Plastic Accumulator
  65. Automatic Transmission Lost First Gear - Help!!!
  66. Trans Temp Discrepencies
  67. 4l60e question:
  68. deep pan? or not to deep pan?
  69. O Ring MAdness
  70. Stall - Torque Ratio
  71. Trans Oil Cooling Line Connections
  72. TCI SSF 3500 question
  73. T350 tailshaft/driveshaft questions
  74. who makes powerglides for a ls1
  75. I think my "bullit proof" 4L80e is hurt
  76. vigilante bolt length PLEASE
  77. Tranny Cooler
  78. Locking Up The Converter?
  79. Help finding a shifter for 1998 TA
  80. Stage 3 4L60E
  81. Rattling Noise Coming From Converter
  82. Need help w/ selecting a stall and brand
  83. TCI Converter Issues
  84. I Need A True No Nonsense Answer!!!!
  85. converter accessories 5 basic questions!!!
  86. Anyone drop in a Fuddle Racing TC yet?
  87. Future Looks
  88. 2800 B&M Stall
  89. Stock Flexplate
  90. Wiring for a TH400/TH350 swap...
  91. Str vs stall please explain.
  92. Need TH350 Help!
  93. Where can I find a th400
  94. Any LUCK with HUGHES 60E
  95. Pro Stick VS. Pro Ratchet shifters?
  96. Converters
  97. What exactly does a stall do?
  98. 4L80E Questions...
  99. My M6 to TH350 swap with pics
  100. Stall Rating?
  101. 4L60E 3-4 clutch pack
  102. LS1/Powerglide. What must I do????
  103. th350 swap problems
  104. PY4000E for f14 cam and nitrous? or smaller
  105. One last question before I buy the TC
  106. TCI new 4l60e
  107. Will a 2000 LS1 4l60E go in a 98 v6 camaro?
  108. When Removing Center Console?
  109. TransGO shift kit install.. Initial impressions.
  110. B&M MEGASHIFTER WITH TUBRO400
  111. Transmission Cooler decision
  112. tranny ?'s
  113. Shift Kit in a 700-R4
  114. Is 3000 the right stall?
  115. Best TC to buy.
  116. vigilante tc ??
  117. Recommended mods for a 4L60E?
  118. stall quote
  119. flywheel/flexplate bolts. torque specs, help!
  120. servos only instead of shift kit???
  121. lost 2nd gear for 2nd time
  122. Help!!! My tranny (A4) rolls off when in Park! Drives in Neutral!
  123. Where should I look on the tranny for the "Pump Stator"?
  124. Is this EXACTLY what will prolong tranny life?
  125. I have no 1st or 2nd gear!!!!
  126. Gear recommendations
  127. pics of 6L80E
  128. Anyone tried Red Line ATF
  129. wiring diagram for a 4L60E
  130. Think I solved the misterious TC unlock problem(long)
  131. stall \ str suggestions
  132. converter lockup
  133. Do i need a tranny?
  134. 2nd to 3rd RPM flare
  135. 4L60E question
  136. TH 350 Guys look here
  137. SS3800 or SS3600 for a f14 cam
  138. fluid flush and change.
  139. Vig 4400 stall
  140. Best launch technique for YPT4400 and 4.10's
  141. What times for a full bolt on car minus TC
  142. quarter stick for a 4l60e
  143. Plug in Trans shift improver
  144. what about the ValveBody !!
  145. They said it couldnt be done Megashifter
  146. 3-4 shift hits the rev limiter unless I let up a bit, prob with tune or shift kit??
  147. Tubro 400 dipstick
  148. Where to get 4L80
  149. CRAZY CRAZY 4L60E question for you..........
  150. do not use this trans shop
  151. Can the shaking of the motor cause problems with the tranny?
  152. Help changed tranny and getting alot of trouble codes
  153. Torque Converter?
  154. 1-2 shift gets worse after tune
  155. TRADE my A4 for your T56, i need T56
  156. Another shift slipping question - no search answers:(
  157. Synthetic ATF?
  158. Questions about Yank ST3500
  159. 3-4 clutch pack
  160. I need help
  161. Anyone have a cheap source for the transgo 4L60E vacuum modulator??
  162. No lockup, what does this hurt?
  163. unsure of stall size.
  164. yank TT3000 3.0str..thoughts? pls...
  165. Slipping during shift...
  166. Seating the torque converter?
  167. a4 newbie questions
  168. WTF is going on
  169. Ultrabell.... tranny bolts?
  170. doing a th400 conversion, what should I expect
  171. pics/instructions for sonnax valve conversion
  172. Need Help Asap !!
  173. Transmission Fluid ?
  174. Strongest 4L60E
  175. Where to get billet servos
  176. Transmission Problem
  177. help me find the leak in my tranny
  178. Transgo shift kit instructional video question
  179. Fuddle.. Whats The Verdict????
  180. How good are Tci converters?
  181. How much abuse can a stock A4 take?
  182. Two questions...
  183. how much $ to transfer to th400
  184. How long of plate needed?
  185. I searched lots, but still have several TH400 questions (auto valve body?)
  186. stall question
  187. Fuddle Racing TC
  188. 3.42 shift points HPPIII, what are your settings?
  189. Trans / ABS problem
  190. is this a decent setup?
  191. Is a 4400 stall to big
  192. Shift solenoid questions?
  193. Need input on 4l60e that can handle 650 rwhp
  194. Fuel economy with a stall
  195. newbie question on stalls
  196. 4L60E Question
  197. Tranny Cooler Install Help
  198. dealerships, bullshit, etc
  199. Is a 3500+stall and 373s a good combo?
  200. 3400 Yank and stock flexplate
  201. Midwest Racing Converters...
  202. ive got a problem
  203. 700R4 Planetaries?
  204. 1-2 shift problem???
  205. Looking for TH-400 advice from builders
  206. Stall or gears?
  207. V8 torque converter on V6?
  208. has anyone had any track time with a fuddle converter?
  209. 3rd gear or Drive?
  210. Is D more powerul than OD?
  211. 1st to 4th?
  212. shifting from 2nd to 3rd while racing IS SLOW
  213. Jasper Transmissions
  214. 4L60E vs 4L80E
  215. TH400 drive shaft length?
  216. Who here runs a PTC converter
  217. shift points
  218. Trans SLip.. or electrical?
  219. i need help!!! converter problems
  220. 4l60e doesnt shift right need help wtf?
  221. LT1 4L60E in 98 Trans Am?
  222. Tci Ssf 3000
  223. Converter tuning-yes or no?
  224. Shift kit(s) questions
  225. 1st or not
  226. How long untill my tranny goes BOOM?
  227. Yes! It's here!!
  228. TH400 vs. TH350 converters.....
  229. Flexplate differences?
  230. Tci Software ..some One Please!
  231. Tranny making funny noises.... please help!
  232. What 4L60e Convertor for 9sec Turbo Setup?
  233. WOT Shift Issue
  234. cheap 4l60e????
  235. Which rear end gears for TH400
  236. what is m6 and a4
  237. could this be my converter ???
  238. tci 3500 or 3000 (repost)
  239. Yank SS4000
  240. New Converter or tranny went broken?
  241. ET/MPH Gain going from Vig 2800 to Yank SS4000
  242. Converter or transmission problem?
  243. how to make 4l60e full manual shifted
  244. Anyone Experience this with their 4l60e?
  245. 400 turbo in f body???
  246. started as flare 2-3 WOT, now won't go at all
  247. ? on my Fluid
  248. opinions on yank tt300 and pi2800
  249. TCI stalled guys please enter
  250. fuddle converters.. whats the word?
