PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 [140] 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Shift solenoid?
  2. Looking to buy a converter for my A4. Help me!
  3. Difference between converter for LT1 and LS1?
  4. How long will it hold?
  5. M6 to A4 swap
  6. 4l60e 93 truck tranny
  7. results from tci 4000
  8. Who is/has used nitrous on a Vig multidisc 4000 stall???
  9. Upshifting/Downshifting
  10. Shift Kit
  11. 4l60e: "Corvette servo"?
  12. Need advice on stall rpm
  13. Vig. 3600 or Similar Yank?
  14. Help.. I need a quick question answered :)
  15. B&M LS1 Converter (results)
  16. 4L60E: please help me to get the big picture
  17. Help! I think I killed my trans or verter
  18. How trans brake works
  19. p1870 code
  20. p1870 code
  21. Rubber or Metal Line to Tranny Cooler
  22. 98 flexplate
  23. manual lockup switch???
  24. 4l80e flex shield and tranny shield
  25. how
  26. Can you spray on a Yank PT4400? Has anyone done this?
  27. a4-400 swap, what all needed??
  28. Installed converter now the car wont move
  29. Aftermarket A4 Shifters...
  30. 4L60E Auto
  31. Team trip Question
  32. Metal tube on the top of a 4L60E
  33. Glide or T400
  34. short shifting
  35. 4l60e servo
  36. Shift extension on PT4200 question.
  37. Whos Yanks new owner?
  38. Tranny/Converter Issues After New Cam Install
  39. 4l60e probrems help
  40. WOT at 5600RPM car shuts off/backfire HELP!!
  41. tranny temp gauge install
  42. New PT4200 is in!
  43. 4l60e
  44. Yank SS 3600: to do or not to do?
  45. MAF ends or In need of shift kit?
  46. Nice 700R4 Find...
  47. Trans fluid change to come soon!
  48. converter question
  49. A4 install with PT4000, problems...
  50. yank re-stall quesiton
  51. the yank is in
  52. t-56>A4 swap, now code p1860...
  53. Down shifting harder after TC install.
  54. Transgo Shift Kit. Anything I need to think about before installing?
  55. Newbie ?: What gear do u race in?
  56. TH-350 help, Shift kit Help, and stall converter help
  57. Wanna guess !?
  58. TCI Converters?
  59. tranny cooler
  60. tranny type and torqe conv???
  61. What gear in 1\4
  62. B&M LS1 Converter
  63. Who uses a 4l80 with BIG horsepower???? T-brake?
  64. Midwest vs TCI vs Vig
  65. Please Help Me, Noises From Tranny?
  66. auto/man
  67. tranny or converter?
  68. what rear gear are you th400 (semi street) guys using?
  69. fewST3500 questions
  70. 4l80e stock converter in Z28?
  71. Problems installing transmission cooler
  72. Shudder at deceleration
  73. Lockin the Torque Converter....
  74. Rattling Shifter
  75. A4 snapping like twigs!!!
  76. Stall Converter Help!
  77. Which tci converter for me????
  78. Need Immediate Speed Inc. Tranny help!
  79. LT4 Hot Cam Timing
  80. Which T/C for Boosted car??
  81. Shift Kit Question
  82. Which ART CARR, SO-CAL or TEXAS?
  83. 4l60e woes :(
  84. Cheetah SCS part numbers 70073B and 70002B, do I need both?
  85. vig 3200 problem
  86. quick vaccum line question
  87. replaced 2-3 solenoid but still having problems??????
  88. tci 3000 track results
  89. WTF is wrong with this damn tranny
  90. Tranny wont shift out of first gear! Help!
  91. WHO here on this forum, REALLY knows transmissions, converters & dyno's?
  92. What would be the gains from a ST3500 to a SS4000
  93. stall converter bolt lenght
  94. tailshaft ext. housing
  95. can I use an LT1 trans mount on a LS1
  96. A4 from LT1 go into an LS1
  97. How much is too much?
  98. Car dies in reverse. After stall.
  99. Shift Extension
  100. 4l80e install in a 67chevy ll
  101. best convertor combo for pure street driving
  102. Problems blocking off trans cooler lines???
  103. T-56 vs TH400
  104. Shift point adjustment...going from 26's to 28's need help...
  105. 00 z28 converter
  106. parts for a a4 to a3
  107. I want to upgrade my Yank ST3500. Please help.
  108. TCI Flexplate trouble
  109. LS1 Bellhousing
  110. 2nd gear gone!
  111. Shift light installe question
  112. love my rock-on!
  113. which tranny/stall for ATI D-1SC Procharger?
  114. Wiring on a 96' 4l60e Fbod the same...
  115. Recall???
  116. Turbo-400, people who has done this help me out.
  117. 1st gear only, whats up????
  118. Im f***ing pissed
  119. Tailshaft length for a 400
  120. What Vehicles Come With 4L80e?
  121. looking for LS1 to 200r4 or 700r4 adaptor
  122. New converter, slippin trans.
  123. P0757 2-3 solenoid stuck on ..
  124. LS1 guys with 373 gears, at 45 mph at WOT you still get that screaming performace?
  125. need info
  126. 4L65, sliding 1-2 shift.
  127. converter quest
  128. Torque Converter Bolts???
  129. "plastic bushings" in 4L60E ?
  130. is it possible that my tps voltage is low, causing my trans not to downshift at WOT?
  131. New TCI 4000 stall SSF converter
  132. Restalling a converter, who's good & fair priced????
  133. 4L80E questions
  134. how to replace my 2-3 shift solenoid
  135. TCI SSF 3500 slipping bad & chattering
  136. TC Questions...
  137. Need help bad, Tranny not working.
  138. do you have to upgrade the trans filter when using the deep trans pan for the LS1's?
  139. Tranny Help!
  140. Th 350?
  141. restall or sell Y3000 ?
  142. Anyone in Phila or S. Jersey have the FLP Level IV tranny?
  143. FLP Level IV users..........
  144. 4l80e Problems
  145. Just took my friend for a ride in my "slow auto"
  146. question on stock convertor
  147. Trans Temp Gauge Install
  148. Looking for converter recommendations!
  149. 1350 yoke for 4L60E?
  150. Trans. went out today.
  151. what stall ??????
  152. Flywheel/flexplate bolt size, thread, etc...
  153. Damn 4L60E
  154. Need help with potential converter problem/drivability issue
  155. B&M deep tranny pan installed...
  156. First Experience With ST3500 Stall Converter
  157. trans go
  158. Transmission lines on stock cooler
  159. shifting problems. help
  160. corvette servo
  161. Tranny Swap Question
  162. tranny has started slipping... rebuild time...
  163. Daily Driver Mod Recommendations Please
  164. Where to get my Turbo 400 rebuilt in CA
  165. anyone uses the deep trans pan for their Ls1's, if so how many total quarts to use?
  166. converter hub too freaking short????
  167. $300 to convert my SS4000 to a PT4400, what do you think about that?
  168. ultimate street converter for a stroker/superstroker?
  169. new car, new problem
  170. th-350 inspection cover..
  171. want to buy tci ssf 3500 but read some horror story's
  172. How much is this gonna suck?
  173. Stall RPM question with STS turbo....
  174. Tranny problem
  175. Here's a website for all your trans needs...
  176. ?questions?
  177. Neutral safety switch
  178. help!! trans mount problem
  179. Need some opinions on SY3500 & Y3200
  180. TC and tuning transmission
  181. Screaching sound
  182. self 4L60E attempt.
  183. Good Transmission Shop in Denver
  184. No Downshift to lowest gear at WOT
  185. T-56 to Th400 swap PLEASE HELP. Or 4l80
  186. 4L80E Vs. Built4l60e Vs. TH400 ??
  187. Good verter for an FM11 cam?
  188. 2-3 shift clunk with transgo
  189. 4000 Stall Question
  190. My tranny feels like its slipping when I stall it up?
  191. Anyone know how the Trailblazer I6 TC would do in a Whippled 5.3?
  192. Heres one for the experts....
  193. Fourth Yank Converter in 4 Years!
  194. 4l80 How strong?????????
  195. TH350 using clutch take off?
  196. Need some advice on a converter
  197. Help me find the right shifter!
  198. How much do you think..
  199. can it be done??
  200. 350 vs 400 turbo
  201. Oversize 3-4 clutch pack/input drum anyone tried it??
  202. Broken Tail shaft on the dyno today.
  203. torque converter?
  204. Anyone familiar with 6 pinion planetaries for a 4L60E?
  205. What parts do i need to make my A4 stronger?
  206. will my stock 10 bolt hold up to this?
  207. are these 2 tci ssf converters the same? please help
  208. s-10 4.3 radiator trans coolant lines witch in and out???
  209. Does this sound like a Vig 3200
  210. Converter Lockup = KR
  211. Tranny Help!
  212. How much am I leaving on the table? SS4000 vs PT4200
  213. tc from a roll
  214. info for A4 to 6 speed swap
  215. Trans is acting up
  216. LT1 vs. LS1 4L60E ?
  217. Shift point question
  218. changed stall on my verter, now i have a small problem
  219. just ordered my vig 3600 & trans go
  220. HELP!! SY3500 troubles.
  221. Lt1 Transgo Shiftkit in LS1
  222. Trouble with B&M Shift improver kit
  223. how much difference in a TCI 3000 vs. 3500 please help
  224. 4L60E Question HELP!
  225. Cant find "fbodytrans.com"
  226. Overkill?
  227. other add ons i will need with a stall and gear??
  228. 2005 1500 truck transmissions
  229. Max hp and torque a stock 4L60e can hold
  230. suggestions about a stall
  231. Did I screw myself with a TCS verter???
  232. Performance Tranny Parts
  233. just had converter installed i have a question
  234. where to find cheetah shifter, and how much?
  235. 4l60e's interchangeable from 1997-2000
  236. trany ? help please
  237. TH400 guys, do you regret NOT getting the Gear Vendors OD unit?
  238. 4l60e And Cryo Smart Techs Please Read
  239. 2-3 servo issues???
  240. Procharger + Converter:
  241. How much RWHP will 4l60E handle Rebuilt!
  242. what holds the output shaft steady in a 4l60e?
  243. need professional help on converter selection
  244. th350-400 conversion kit?
  245. converter change?
  246. stall converter buying question
  247. Launching with TCI 3800
  248. New B&M 3000 stall for sell.
  249. Muti-disc question?
  250. Anyone with 3200VIG come in! Pease!
