PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 [157] 158 159 160 161 162 163
  1. A4 guys...do you race in D or OD?
  2. which converter
  3. How Difficult is a Converter Install
  4. I need HELP on a B&M hammer shifter install ASAP
  5. Midwest 3000 stall 2.5str now I hit the rev limter sometimes
  6. possible m6 to a4 swap. Any advice?
  7. Art Carr Trans.& Converters in So. Cal.
  8. How to drain torque converter
  9. TECH ARTICLE ON INSTALLING 12-BOLT?
  10. M6 to A4 tranny swap is done...
  11. Variable Pitch Converters
  12. Location of trans temp sensor
  13. Can someone explain unlocked and locked to me?
  14. MAX street performance converters
  15. stall converter
  16. Speed Sensor for TH400???
  17. Problems with VIG 3200..
  18. converter / tranny / dif issues . need input for the night.
  19. 12bolt installed now a slight tranny whine M6 under accel
  20. Convertor Locup trouble again,please help!!!
  21. vig 3600 kicks butt
  22. whats the best torque converter
  23. 3800 to much stall???
  24. Cam related shudder??? A4 with 3600 stall
  25. stage 3 4l60e and Vig 3800 F/S
  26. ?s for those who have yank th400 with transbrake
  27. SY3500+3.15 to SS3800+3.73?
  28. Need Help With Shift Points
  29. TCS Converters Available to Ship within One Week
  30. 3600 stall: Too much for daily driver?
  31. Can your stock A4 car break the tires loose from a 30 mph roll??
  32. converter /whats the best for nos and motor
  33. Yank SS-3800 ?
  34. Vig 3600 with #7 pump
  35. LS1 to 700R4??? my new project -- Please help
  36. LS1 Edit, 3.73's, transgo on a A4????
  37. Phoenix Converter Questions
  38. A4's: Do you use
  39. Shoot. I thought Yank was sooo good?
  40. What tranny cooler?B&M or Permacool
  41. Converter Problems
  42. TQ Converter question
  43. well,m6 to th400 swap is done,rwhp#s inside.
  44. Guys in the know......SLP 3300 converter?
  45. My converter is here! Have a ?
  46. please help, what rpm at 70 w/ 3.73s w/ A4
  47. Just installed RAM 402/910, Fidanza, Adj master, few ?
  48. TH350 N2O converter?
  49. Yank's infamous "shudder" problem, how bad is it to run car with it?
  50. Would a Converter Increase my Highway?
  51. PLEASE($3000 budget)need help on choosing parts(header, converter, intake)
  52. Help, 2-3 shift slipping?
  53. How much of a difference between these two gear/converter combos in a race?
  54. th400/350 guys using yank plate?
  55. If you're using a turbo 350/400 please post your 60 and stall.
  56. restalling a VIG3200
  57. At what MPH can you recover first gear with your A4?
  58. Bypass radiator for trans cooler?
  59. Ok to buy used converter?
  60. Transgo shift kit the way to go?
  61. I just ordered my first Yank! And it's a biggie
  62. What Trans. Mount for TH350
  63. What size T400 stall for turbo setup shifted at 6800?
  64. trans cooler lines
  65. 4L60e-after market shifter?
  66. Converter help
  67. 200R4 on a LS1 or 6.0?
  68. Any opinions about the Yank turbo 350 or 400...any users?
  69. help me choose a converter
  70. 4L60E little help please!
  71. I want a fairly stock stall, 2600, 3000 or 3300?
  72. Trouble downshifting into 2nd since Pro 50 install...
  73. Where to get 4400 TCI Converter
  74. 4L60E Fluid Leak, Torque Arm Bushing, and Fluid Level Questions
  75. is my trans going to be ok?
  76. 422 th400 9"rear what gears??? help!
  77. 4l60-E Rebuild Kits
  78. Tranny temp gauge
  79. Flexplate covers?
  80. FLP Level 4 Tranny
  81. 91 700R4 tailshaft on a 4l60E
  82. Help me with my converter choice.
  83. Billet 6 Pinion planets for 4L60
  84. Vig. 2800 w/boost....
  85. Question about 4L60E
  86. Aftermarker stall converter
  87. good converter
  88. Vigilante's with multi-disk internals
  89. Daily driving a Turbo 400? How streetable is it?
  90. 4L60E, its dead need help diag'n the problem
  91. Gains with 3.73 and TP4400 over 3.23 and ST3500??
  92. What size tranny cooler??
  93. should i fix the 10 bolt or upgrade to 12 bolt? (a4)
  94. C.A.G.S. Skip Shift Elim install question?
  95. A good converter...
  96. Alright guys, need help...Whining Noise after Moser 12 Bolt Install
  97. What do I need for a Rear Install
  98. PRO 5.0's installed!.UPDATE!! use loc tight!
  99. th350/400 cars,what tranny MOUNT are you useing?
  100. FLP Stage4 for everyday driver?
  101. TH 350 vs 4L60E.
  102. Track results for the SS line from Yank, anyone?
  103. 4L60E leaking need help to stop it
  104. I'm having a problem removing my 4L60E from the engine...
  105. Anyone have info on COAN Tq converters???
  106. What??? Colonel runs a TCI converter?!?
  107. Will shift kit work w/ Yank converter?
  108. 8.8 install
  109. converter upgrade
  110. Paging Midwest TC owners
  111. anyone have pics of slp linelock install
  112. rear gear/converter
  113. FS: Vigilante 3200 - $500
  114. What results with the TCI converter for LS1
  115. trying to build up a 4l60e, please step in
  116. Trans Swap A4 to M6 what is needed
  117. A4 1st to 2nd shift problem
  118. Converter Break in?
  119. Who has installed a converter and still had the dreaded....
  120. Best converter for MAX ET on DR's???/
  121. M6 to A4 swap
  122. Help, installing Eaton posi
  123. TransGo: Stage 2 or Stage 3?
  124. Tranny Argument
  125. Bell housing bolt question (4L60E)?
  126. 4L60E question
  127. What causes the 4L60E to fail
  128. converter
  129. Hose from Trans to Torque Arm on 4L60E?
  130. How does a trans brake effect converter selection?
  131. SLP linelock install...dont work....
  132. Paging all TH400 guys.....got a vibration question......
  133. LT1....Manual transmissions vs 4L60E transmissions ???
  134. Which stall to get ?
  135. Scattershield for a TH400
  136. convertor question
  137. Trap speeds w/ converter?
  138. 4L60E tailshaft on a TH350?!
  139. Midwest 3000 track results!
  140. yank convertor probs please read
  141. Yank's 21 blade stator
  142. slipping 4L60E
  143. I pulled out my Yank converter and found...
  144. Edge Racing Converters
  145. hmm, problem with FLP tranny
  146. SUPERIOR A4
  147. Whats a M6 and A4?
  148. Midwest 3500 2.5STR & shift points
  149. ALL with 9in please Post Pics of it installed!
  150. Anyone run a T.C.S phoenix converter
  151. How would I go about "flushing" my converter?
  152. What brakes first with A4
  153. vig3200 vs ss3600.
  154. th350-th400 builders,please help!!
  155. A4 Trans
  156. What will A4 hold
  157. anyone here run a Reverse Manual Valvebodied 4L60?
  158. 422+th350/400 guys which converter?
  159. verter question
  160. Converter unlocks randomly on the highway
  161. Whats the average install price for a 12 bolt?
  162. to drive or overdrive in bigger stall convertors
  163. How many have used shims w/ SPEC Gen2 Luk Pressure Plate?
  164. problems?
  165. Best converter for these applications.
  166. TH350 to TH400
  167. Flywheel with TH-350
  168. TH400 and Gear Vendors overdrive kit..... reliability?
  169. Whats a Vigi with a #7 pump?
  170. Rebuild or converter issues
  171. new converter quiz
  172. Help...installed Adj. Mcleod MC
  173. guys with TH350/TH 400
  174. How do i make A4 mofo to downshift?
  175. 4L60E Choices - who would YOU pick?
  176. 4L60E or converter issues?
  177. those of you with th400 and useing speed sensor HELP!!
  178. A4 lost 3rd and 4th Gears
  179. yank SS3600 converter with 273 gears?
  180. Help with surging and shifting after converter install
  181. TH350. To 2.75 or not to 2.75?
  182. Trans problems (A4)
  183. Vig 3800 for a bolt on & cam car?
  184. what type of support should be used with a 2800 stall
  185. Coan stall converter
  186. How many RWHP will a stock 4L60E take?
  187. st3500 and 315 nittos = smoke
  188. best converter for nitrous
  189. Stall size with 422/TH400.....4400??
  190. Might have found a sfi approved flexplate
  191. Yank SS converter
  192. Anybody see any et gains running the Vig. 3 plate converter?
  193. SY3500
  194. using stock shifter on th350,400 trans
  195. TH400 vs. 4L80E
  196. Need help choosing a converter
  197. flp tranny is sweet
  198. Who makes a 4L80E conversion kit?
  199. What’s the average install price for a race prepped 4l60e?
  200. Yank SS3800 Converter - Driving Impressions
  201. TH350 need reprograming?
  202. SFI appoved flexplate needed
  203. Yank 36-3800 SS converter times??
  204. Removing 4L60e With Solid Motor Mounts
  205. Shift points & rev limiter question?
  206. Differental Temp.????
  207. TOTAL cost of gear install with everything included???
  208. installed 3.73's have ?'s
  209. just got my flp tranny going, got a couple of questions
  210. Speed Inc 4L60E or FLP ?
  211. M6 to TH400 conversion---->question?
  212. FLP Level IV good for monster H/C?
  213. Art Carr Converters?
  214. best gearing and converter
  215. Would 3.73s benefit me any with a 4400 stall?
  216. Where to get TCI Converters??
  217. should I change my converter myself or have a pro do it?
  218. ST3500 and 100 wet shot
  219. Opinions on convertors wanted
  220. Pressure Bleeding
  221. converter w/ nx
  222. How do you route tranny cooler lines on TH350
  223. everybody with th400 enter
  224. Do I need special torque arm for moser 12bolt and th400
  225. Convertor Locup trouble, please help!!!
  226. Vig 3200 to PT4400, what did you gain?
  227. A4 ?, HELP PLEASE, Mine slips in 1 and 2, but not 3 and 4
  228. 4L60E shifter question
  229. What the best trans I can put in for a daily driver (no 4l60e)
  230. 3.73 installation Problems
  231. Converter for TH350
  232. Anyone have a Th400 and a Moser 12 Bolt, Please stand up...
  233. Why can't I rebuild a 4L60E tranny?
  234. What stall with 3.73 gears???
  235. Converter question
  236. Need a Quick anwser from you A4 tranny guru's
  237. M6 to 700 R4 what is needed
  238. stalls, can you explain to me how one would effect...
  239. SY3500 question
  240. Master cyl, slave cly, or pressure plate.
  241. Any help for A4 to M6 swap???
  242. Art Carr Converters?
  243. What type of fluid for TH350
  244. Gear noise in A4 after dealer visits
  245. Has anyone here reprogrammed there stock stall converter to a higher idle?
  246. Who has a 3.73 and a STALL
  247. Converter Locked-Unlocked Question?
  248. TH350 Yank Converters?
  249. Converter acting wierd
  250. Need A4 parts removal list for A4 to M6 conversion. That is all :)
