View Full Version : Automatic Transmission
- Th350 Failure (video inside). Any guesses?
- PRW Industries SFI flexplate any good?
- Yank Shift Extension Question
- shifting problems
- cant trans to an fitting
- I need some help, im having major 4l80 problems
- Stall...
- FLT Sale
- 4l60 grinds in park and when stoped... Help
- Why does my Fugging TH400 xmsn run so hot???
- Need opinions on TC re-stall
- '96 Corvette 4L60E in a '96 Firebird?
- i think my tranny shifts weak!!!
- M6 -> 4L80E wiring info
- 95 T/A trans cooler lines leaking
- Need recomendation/opinion for a converter
- stock 4l60e
- having my 4l60e built hows this look?
- Trans wont shift helpp
- lq9 .. need cam advice
- Get a trans (4l60e) from Who?
- TH350 Torque Arm Relocation kits and Torque Arms?
- Leaking transmission fluid from electrical plug?
- Truck transmission in F-Body?
- TH400 builders/experts, ever seen this kind of issue?
- To reflash or not to reflash after a stall upgrade?
- 4l60e no 3rd and 4th
- Need Help and Advice to Upgrade My Torque Converter.
- Transmission cooler ?'s - where to mount with A/C + intercooler + pusher fans
- LS1 Stock Torque Converter
- Trans Fluid Change: Drop the pan or complete flush?
- 4l80e info needed
- TH400 Automatic Shift Transbrake
- Transmission pump
- drive shaft?
- I am buying a 2002 camaro z28 with a bad TRANNY?
- The right trans cooler
- Ok to drive w/ tune for yank, but still have stock stall in the trans?
- did i just kill my trans?
- 2000 4L60e in '92 firebird. WILL IT WORK!?!?!??!?!
- Need a 2000hp powerglide
- ss3600 to ypt 4400 tune change?
- Champion A6 vette and Circle D 1.48 60ft
- 4L80E 3-4 Shift Problems
- 4l60E rebuild kit.. ebay?
- Stall Question...Is this how it works...
- v6 trans in v8?
- Do I have a Shift Kit?
- 4x4 4l60e - LS1 Fbody
- 6L80e adapter harness for a 98-02 Camaro
- 4l80e
- Anybody have video of yank 3600 stall acceleration vid?
- Trans doesn't seem to wanna downshift
- anyone else SS3600 under stalling? *nevermind!*
- lockup on dyno
- SS3600 and FLT Level 5
- SS4000 Getting it done.
- Challenge: LS1Tech GM vs. Ford Jake's Performance Customers
- trans swap speedometer ?
- is my stall to small for this cam?
- LS3 flex plate fit an LS1
- transmission cooler in c5 corvette A4
- Trans won't tilt back
- Tailshaft/VSS sensors
- Problems with 2-3 shift in 4l60E
- trans temp?
- Hunting this converter:
- 2001 camaro z28 som 4l60e question, newbie
- 4L60e no second gear
- Question about Jakes valve body kit
- need input
- Compushift TPS calibration problem
- Need help deciding! 4l60e vs 4l80e
- forward sprague the problem with my built 4l60e
- 4l60e 3/4 problem
- which gives you a better top end and automatic or a 6M
- my 4l60 rear tail housing is leaking?need advice.
- the infamous 3&4 4l60e...w a twist
- 6L90e in TBSS Truckin' project!
- 4L60E Slips in 3rd gear
- 4l80e cooler line fitting question
- Tranny Questions / Problems 4L60E
- The "Beast" sunshell question
- Buzzing sound coming from my 4l60e
- Bell housing trouble (need help)
- Is my TH400 torque converter bad? (Video)
- tci ez tcu
- 4l60e performance rebuild kit
- Thinking about getting a performabuilt transmission
- Automatic Shifter for FLT Level 7
- Torque Converter Problems
- Pretend a guy has no clue how an AT works...
- Tranny advice for an 02 B4C with mods.
- Shift solenoid suppose to be loose?
- Custom made tcs vs off shelf?!
- 4L60E Identification
- 4l60e questions
- TH400 burnt 2nd gear band?
- How long did it take your your Yank Converter? to ge
- 4l80e bolt yoke removal
- 01 ss with glide...any tips
- Stock 4L60E Rebuild advice
- 4l80e rebuild kit
- How To: 4L60/65E trans tuning. Shifting/TCC/TM (w/ Pics)
- guys with neal chance coverters come in
- Inspection cover?
- 700r4 transmission swap
- Broken Converter Bolt...Frick me
- T56 to 4L60E swap
- Tuning for new stall suggestions????
- 4l80e help please!
- Need advice on 4l60e rebuild
- Transmission Grounds?????
- rear transmission housing cracking
- Help with Th400. No Third
- 4L60e issues
- Wiring 4l80e to LS1 w/T56
- Just finished 3400 Stall, install.
- Trans no worky after shift kit install! Help
- No 4th gear and lock up problem. tune?? or internal problem?
- what rpm should i launch at?
- My 4L80E swap problems.
- Correcting The VSS with a Th400
- Anyone know how to best measure the clearence in a 4L60e low reverse clutch pack ??
- 4l80e yoke
- how much can the A6 from the C6 handle
- SRTA identifications?
- HD2 servo mod question.
- 4l60 tailshaft?
- Like to swap tranny.
- Plan on doing a cam in my A4
- what stall?
- 4l60e help
- First day at the track...need your expert ears!
- how to identify Precision Industries Vigilante converter stall?!??!?!??!??
- glide in an 01 camaro...tips please
- TCI 6x anyone use one?
- blown tranny?
- obd1, lt1, a4->th400 swap - PCM questions
- TCI trans
- Need help fast
- 4L60E & torque converter from my 94z28 into my ls1 z28 possible ?
- How long did your rebuilt 4l60e last???
- 4000ss Problem
- Need help from you guys badly
- Need help!!!!!!!!!!!!!!!
- iron headed 6.0 to th400
- Want to build 4l60e, boosted line press. killing trans
- tbss stall better than f-bod stall??
- B&M SuperCooler Mounting
- you poly mount guys..
- installing new 4L60E dipstick tube 98-02 fbody
- sealant/loctite on flexplate to crank bolts?
- What needs to be done here?
- DIY 4L60E Rebuild
- 6l80e anyone interested?
- 4l80e What T-Brake are you running and how do you like it?
- No engine braking in 4th??Fresh rebuild
- Dumb convertor question but here goes
- th350 break in period?
- Fluid for TC
- help me decide th400 or 80e
- 4L80E shifter question
- Good Trans Rebuild Kit?
- speedometer and th400 ???
- Need help diagnosing a 4l65e
- Need help with 4L80 swap - shifters from what cars/vans will fit? No F-bodies here
- 4L80E Questions
- Car is stuck in park.
- Perma Cool 20-22000 GVW Transmission Cooler ???
- cooler mounting
- What size of stall should I get for this cam?
- Jerking from Park to Drive
- need some info, trans not shifting into 2nd
- what controls 93 4l60 shift solenoids
- welding torque arm bracket to truck tranny?
- 93 z28 auto shift problems
- Did I screw the pooch?????
- Quick answer for JW ultra-bell fitment?
- Stock flex plate
- Tci 4l60e
- BMR relocation crossmemeber bushing?
- trans wont shift into 3rd on its own
- confused on stalls
- Trans issue at drag strip.
- OD and drive doesnt pull
- Auto windows switch kit
- 4L60E swap question- '05 interchange
- 4l80e bolt sizes
- Extra WIDE 29 element sprag
- not shifting at WOT
- LS1 to Powerglide Quick Q
- what wire in 99-02 pcm tell it P/N or in gear
- Will a 4l60e and converter from LS1 bolt up to LT1?
- Extreme Transmissions 4L60E Reprogram
- What mail order tune for Yank stall?
- Art Carr Torque Converters- Feedback Wanted
- Get a bigger transcooler?
- th400 rebuilds?
- Standing mile 200mph - for autos too?
- Rebuild Books on 4l60e ?
- Anyone know where to get separator plate gaskets?
- Best bang for the buck 4L60E for 500rwhp?
- confused please help
- 4L60E puked after stall
- Clutch Pack?
- 4L60E slow after 60 MPH in H/C car
- 4l60e to 700r4 swap??
- having an issue with the 2-3 shift @ WOT
- recommend me a converter for a street build
- modified stock crossmember TQ arm
- Finally did it!
- Xtreme Transmissions Spring Sale. Converters and Transmissions on sale
- sharing pics of convertor swap
- 4L60E Problems - Need some input
- manual valve body in 4l80e
- 4L60E doesnt kick down sometimes
- What shifter to use doing M6 to 4L80E swap?
- 11's on a budget, how to make my stock trans last?
- 4L60 Convertors
- TH400 VSS Plug
- 93 tv cable adjustment????
- CDS - SFI Flexplates
- Tranny Went Again
- V6 vs v8 4l60
- Installed my edge racing converter today
- after 80e swap second slips
- p1860 p0740 help!!!!!!
- Need help with 4L80E connectors (pics inside)
- 4l60E replacement LS1 fbody
- HELP!!!! 700r4 has me puzzled.
- bushing driver kit for 4L80E
- just another curious newbie
- how about these stalls
- 93 4l60 Transmission Fluid.
- a4 to th400 driveshaft length
- New Guy... Dumb Question
- use Stock flex plate with new powerglide ??
- Transmission rattles??
- 4l60e holding capacity
- WOT lockup
- Ticking / Vibration noise (WTF)
- Stupid question?? Transmission Dipstick ??
- Newbie ??
- upgrading vig3600 to ????
- need some help please...
- 6 speed to auto sheetmetal question
- Speed Inc SFI Flexplate
- 4l60E Help
- need some help with 4l60e won't shift to third
