PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 [131] 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Removing Trans
  2. when to lock and unlock tc?
  3. tH400 GUYS IN HERE!!
  4. Va/Md Tranny shops?
  5. how important is the converter in TH400's/4L80E's
  6. How many washers to put in the TransGo setup?
  7. WOW I like it "Yank 3600 stall"
  8. car bucking!
  9. B&M Shift Improver Kit???
  10. Custom Converter
  11. Tranny or converter?
  12. Stock tranny gone :(
  13. CK Transmissions?
  14. Transgo users, do I have everything?
  15. Which cam for a 3000 stall?
  16. Do I Have A Tranny Cooler From The Factory???
  17. help changing tranny fluid??
  18. Auto tranny cooler AND SLP cold air induction?
  19. Which Stall for me???
  20. intersting ?
  21. manumatic paddle shifting????
  22. Mk... 4l80E Q's... search couldn provide info
  23. John @ Fuddle...
  24. should i upgrade to vig4000-4400stall?
  25. how does this look for tranny cooler mounting location??
  26. shifter pics anyone.........
  27. Transbrake wiring
  28. Any tricks to getting a stubborn servo out??
  29. DR EVIL 4l60e's
  30. What stall converter is right for my car?
  31. 4L65e tranny mated to a ODB1 LT1 PCM
  32. Tranny temp gauge hookup?
  33. Those savvy with Trans/TC tuning please help
  34. something doesnt seem right
  35. Where can I get FLT?
  36. What shifter for a reverse manual valvebody TH350?
  37. BMR or Yank TH350 crossmember?
  38. Pilot Spacer for TH400 swap???
  39. My A4 97 Formula has a really strong 1-2 shift?
  40. torque ?
  41. Cooler Trans Temps!!
  42. Fustration....!! Trans won't shift from 3-4 and it Neutrals out at 120 in 4 once I
  43. Lt1 convertor tune question
  44. Won't shift out of 2nd no matter what HELP PLEASE!
  45. 4L60E Questions- Please help!!
  46. What do you do when you need a serious speed fix, and....
  47. Fuddle converters
  48. ViG3800 Y does it feel SLOW!!!
  49. Help me go TH400
  50. $300 Paper Weight
  51. Wot
  52. Torque Converter Clutch won't engage, even overriding with HP Tuners?
  53. shifting problem please help
  54. stall converters from a roll
  55. Anybody have experience with trans king?
  56. what tranny for 94 z28?
  57. Will a 4L60E computer control a 4L80E?
  58. Lifetime trans fluid
  59. 4l60E dipstick
  60. TC Lockup Question?
  61. Any previous or current Protorque converter users out there?
  62. Yank or Vig???Owners respond please...
  63. Converter gone
  64. Would mixing up the trans cooler lines cause it not to cool properly?
  65. Tci SF 3000 Bolts
  66. How much tranny fluid for TH400 please!!!
  67. will it hold up(4L60E)
  68. What Gears For use with TH400??
  69. Tranny problems PLEASE HELP!!
  70. Good gear/converter combo?
  71. Poly mount to stock mount.
  72. Tranny tuning?
  73. Have a 1997 Vette stock converter, will it fit in 04 GTO?
  74. BOOST and 4l60e
  75. how do u lock up a stock converter?
  76. 4L80E guys - what size gears & tires are you running?
  77. Just switched from M6 to A4
  78. changing fluid
  79. Now I need a 6 speed swap!!!
  80. tranny question
  81. Will some One Help Me Please.........
  82. Converter Install: Issues
  83. Any interest in my 3500 converter??
  84. parts Q. for TH350 pros
  85. vibration problem!
  86. Will ford AOD tranny fit in our cars?
  87. Vaccum Modulation on a 4L60.....
  88. 4l80e question
  89. 4L80E parasitic loss over 4L60E, high RPM issues??
  90. 3500 Stall For Th400, What Will It Stall At For A Th350 Trans???
  91. 4L60E to a th400 worth it?
  92. dipstick tube broke
  93. 3.5k stall enough for g5x2 on 112?
  94. 4l65e
  95. Vette Servo Install?
  96. spray into 4th gear? load high or low on the tranny?
  97. Potential problem with the tranny in my Z?
  98. transmission perform
  99. identification help
  100. ? for all you big stalled guys
  101. stall?????
  102. Anyone wanna take a guess at whats wrong with my tranny?
  103. TCI ssf 3500
  104. Here's one for ya
  105. 4th to 2nd downshifting...
  106. TCI Super Soft Lockup, Random Unlock?
  107. Th350 Help!
  108. 2nd Question
  109. 4L80E conversion help
  110. Installing converter real quick question
  111. Converter efficiency from in-vehicle logging?
  112. At what mileage does the 4L60E fail?
  113. My car sucks.
  114. Problem WIth 1-2 shift in my A4.....HELP!
  115. Transmission Cooler
  116. SS or PT4000 stall conveter question...
  117. TH400 torque converter slippage?
  118. restalling for n2o?
  119. stall converter
  120. Beware of reaction shell
  121. 4l60e
  122. M6-->A4 wiring
  123. Is this really worth it?
  124. making the speedo work on a th350 swap
  125. mounting points for 4l60E and th350 same?
  126. SSF3500 No Lockup
  127. rEMOVING DIPSTICK
  128. Neutral for long idle periods?
  129. b&m trickshfit or regular atf?
  130. what a good cam for the street
  131. Dr. Evil 2 SS3600
  132. what trans for my bracket car?
  133. Swapped on truck pan
  134. TH400 guys inside
  135. Need torque specs for drive plate!
  136. Help with shifting problems
  137. 400 vss parts?
  138. What does a 3800 stall feel like?
  139. guys with cam and stall?
  140. Converter on NOS
  141. Will it ever be right again????
  142. houston we have a problem
  143. Clunking when put into gear..???
  144. Part # and install help for Trainy temp sender on TH400
  145. transgo shiftkit install...need help
  146. Truck 4L60E onto '98 LS1 interchangeability?
  147. Possible problem with th400 swap in LT1
  148. 1 st gear boggs when you power brake ?
  149. m6 to a4 conversion
  150. Tranny Problems with New motor
  151. weight of 4l60e?
  152. What do i need for TH350 swap?
  153. Cracked Tailshaft??
  154. Another 2-3 shift problem
  155. quick question about draining?
  156. A4 Shifter Button
  157. need help
  158. Tranny recommendations
  159. SSF 3500 trouble
  160. shift solenoid a malfunction?
  161. limits of a 3500 stall
  162. a5 or a6?
  163. how many qts does a bone dry trans and new converter hold?
  164. new dexron 6...
  165. Ordering Converter Single or Triple plate?
  166. Highspeed tranny accident. Info please.
  167. Won't shift 1-st - 2nd at WOT
  168. What brand dexronIII ?
  169. 4l60e 3-2 downshift problem
  170. Damn rock-on transmission ;)
  171. Car acting funny?
  172. Guys who Drag Race, Come On In...
  173. Tranny getting stuck in 2nd
  174. [B]Diagnostic code 1870... 99 v6 firebird[/B]
  175. Raybestos Z Pak (3-4 clutches)-opinions-
  176. First Time at track with Vig 3600
  177. 4l60-e ... in "1", but it shifts into 2 ...wtf
  178. Converting to TH350 from 200-R4, have some questions.
  179. Price for a rebuild.
  180. Tranny problem all of a sudden?
  181. Tailshaft Bushing
  182. bigg problem helpp!!!!!!!
  183. Question about Overdrive and Drive???
  184. Trans Failure
  185. what the hell could be wrong?
  186. Does anyone Have a part number
  187. About all This Converter stuff
  188. 700r4 transmission fit in our cars?
  189. converter not locking when warm
  190. An honest discussion about high stall converters
  191. my tc has a long and sloppy lockup all of a sudden
  192. Simple TCI Converter Question
  193. Torque Converter Vibration?
  194. can my transmission survive 150 shot on a 400 hp car?
  195. TH400, how easy would it be to convert?
  196. Torque converter tuning
  197. how much to fix a Solenoid?
  198. Transmission problems 50k
  199. Falls flat on it's *** in first!
  200. Best Daily Driver 4speed 10sec transmission
  201. Anyone Run 4.10's With Th400??
  202. p1870 transmission component slipping" code
  203. Does it hurt to shift
  204. Do I need a custom tune going 3.23 to 3.73
  205. Stall for F12 Cam?
  206. Which tranny?
  207. Which Shift Kit?
  208. Any recommendations on trans fluid?
  209. Will 3500 TC get me an 11?
  210. 4L65 questions
  211. What part # or where to get Scattershield??(TH400)
  212. Is this worth buying?
  213. Th400
  214. Best way to keep your tranny in good shape!?
  215. TH400 and 402 swap, now car won't turnover
  216. Anyone tried the ART CARR Th350 for $899?
  217. n00b A4 shifting q's
  218. How much did you 4L80E swap cost and where did you get it from
  219. time for new trans
  220. Dyno Testing an A4 trans...
  221. gear vendors
  222. Converter Slippage by gear?
  223. Is this a good Stall Convertor
  224. Restall the VIG
  225. Problem with 2-3 shift. Please Help!
  226. opinions on drivetrain trans/gear setup
  227. Tranny or stall?
  228. TH400 vs Built 4L60E (price)
  229. gears or stall
  230. Help with Stall convert Choice
  231. anyone put a lenko in an F-body yet?
  232. SY3500 Questions
  233. quick question
  234. build my tubo 400
  235. restalling a stock converter
  236. mods for LOng lasting transmission
  237. quick ? 2000 silverado 4x4 transmission
  238. Shifting into overdrive
  239. Bad news on my TCI converter
  240. Help: B&M Electronic Shift Improver for 4L60E
  241. trans problem or diff.
  242. 4l60e upgrade
  243. stock a4 w/410s - what speed @ 6,500 in 3rd gear?
  244. A4 issues @ WOT during track runs
  245. 4l60e to 700r4
  246. installed a 3500 TCI and WOW!!!
  247. Th 350 gear ratios?
  248. Throwing a P0751 for the trans...why?
  249. Engine knocking after converter install & oil pressure problem
  250. Do you need a vacuum mod to increase line pressure?
