View Full Version : Automatic Transmission
- Anybody have a rebuild "guide" like the M6 guys have?
- Tranny slipping through 3-4, can I firm it up?
- Transmission Temp Help Please!
- cam and converter question
- tranny mount vibrating
- Who is running a 3000 stall 2.5 str and 3:73?
- What tranny to use?
- Modified Transgo ??
- Best place to buy 4.10s
- hurst promatic shifter and neutral saftey switch on 3rd gen camaro
- Trans leak ????
- selonoids
- sonnax "super hold servo" piston
- my transmission or torque converter broken?
- th350
- oh crap, is this my problem????????????
- Too many problems to summarize, plz read (long)
- 4L60E trans brake
- Stalls
- Thanks Fuddle!
- Need new shift knob: Which one?
- No downshift - 4L60E
- Poppin noise on launch
- Stall Converter Help Please
- 02 SS - stall converter???
- car shifts at 6500 rpm
- C6 Automatic 6 speed
- Does anyone know what the TCI clutch is made of.
- Stall Speed vs. 60 ft.
- what converter to get!
- Need some input...
- New B&M Trans Temp Gauge
- Blew my stall?????
- A4 shifters
- TC difference
- Starter and Flexplate
- converter lock up
- Will not go into gear after Shift Kit and Converter?
- what stall with hot cam
- adding a shift kit, worth it???
- Buying a conveter do I need a shift kit?
- Tranny noises?
- Will a Vig 3200 stall fit with a TCI flexplate??
- Tranny cooler
- trans temp\fuild level?
- what is STR? (converter wise)
- need help
- Any idea?! Need help...
- 4:10s and what stall???
- tranny problem?
- What tuning with a Stall on 2001?
- 2002 Z28 shift kit?
- Advise: Is it time to step up to a better stall then my TCI
- Shipping a 4l60e
- Low tranny fluid make it seem broke
- 4l60 gurus in here please!!!!!!
- Energy Suspension Trans Mount
- 5.3/th400 Parts help
- Whats wrong with my tranny?
- rattling noise coming from converter
- A4 4.10 gear ratio guys help!
- Another Big thumbs up for Fuddle
- Trans cooler and dope style
- 224 224 cam = manditory stall?
- fineline or rock on
- Aftermarket converter guys ->
- brand of tranny fluid?
- 4L60E coolant lines
- Fuddle Converter?
- sbc/Turbo 400 n a 97 ta
- M6 to 4L60E swap
- How many quarts in a TH400
- converter
- where to buy a shift kit for my 98ls1?
- how to remove reluctor in the trans
- rock-on and fuddle in
- what trans is in my 98 c5 a4?
- Worst day ends with P0751 code
- stall issues, please help!
- tune with stall
- tranny problem!
- bought new tranny
- B&M COOLER IS THERE A HOW TO GUIDE
- Where does the converter located precisely in the car?
- Post your t/c times before and after
- line lock
- stahl help
- Need some help or advice......
- th350 guys in here...
- Tranny cooler+ ssra
- who makes a good shifter for an A4?
- OK... i think ill buy a torque converter
- Royal Purple trans fluid
- TCI 378000 Deep Pan Install
- what 60ft time
- Fuddle Ultimate/Street Series
- transmission temp guage
- When your tranny goes, does it take anything with it?
- Where to find a 4LE80?
- No first or fourth, somtimes.
- Transgo HD2
- the same tranny problem,only worse
- DO any ls1's come with factory tranny coolers?
- TCI vs PI Vigilante vs Yank
- Tranny options need help
- stall size... again
- Post your track times Fuddle users
- Hurst Shifter Cable Mount
- Who's got the best stall prices?
- HELP!!!Trans hits revlimiter and wont shift(long post)
- Lowest stall w/trex??
- vibration problems
- done a lot of research...fuddle 3500 w/ 2.0 str for dd?
- New Converter Bad
- Whats STR???
- Trans bit the dust
- Fuddle with stock transmission?
- drive shaft? 4l60e- th350
- Car Sputtering while at a stop
- street only
- flywheel question
- Yank SS3200 vs. Yank SS3600?
- Hit revlimiter??
- How to launch with a 4000 stall?
- Transmission Woes
- Planning for new trans.... Which one?
- converter help
- 4L60E to 4L80E conversion
- Precision of New Hampton 3500 Stall?
- tranny cooler ?
- difference between 700r4 and 4l60
- Shift Boot for A4?
- what is a v6 trans worth??
- Clunking when shifting at WOT
- Stall help
- A4lowstall vs A4highstall
- Looking for some good companies to rebuild a TH400
- Retune with new stall?
- 4l65e?
- curious on the stalls, which one to get???
- Shifting in an auto
- no 3rd or 4th
- Tranny Smart Guys, POWERGLIDE ?
- how to change valve body?4L60E
- rebuild time ?'s 4l60e
- How good is a stock A4?
- Backup lights TH400!!!!!!!!!!!!
- Worst time to go WOT
- Could I use TH350 for daily driver?
- energy suspension tranny mount
- Vacuum Line Connection?
- Need some advice......
- 700R4 on trans am
- Anyone Familiar with Mad Dog Transmissions?
- predator question
- What stall to get with these mods?
- converter
- Trans stuck in 3rd????
- th-350 help
- HELP! Slipping in 3rd.
- 4L60E Speed Sensor O-Ring Size
- Output carrier assembly stuck please help
- Cracked Flexplate????
- wanted more opinions on problem
- Choice of cooler
- built 4l60e
- Need help th400 parts!!!
- Transmission Aux Cooler
- M6 to TH400...have a couple of questions?
- Low mile new trans, min mods to help it hold up
- question about converter and stall....somewhat technical
- Does High Stall Torque Converter lock?
- Yank is just amazing SS3600 2.2str SI 1.57 60ft
- no 2-3 shift at WOT
- Is this Yank Converter good?
- So what fluid does everyone use?
- How much can a stock A4 handle?
- which shift kit?
- Ordering Stall Reliability ?
- Trashed new built A4 in 21 miles
- t-350 w/aftermarket shifter come inside!!!
- Shifter in stock t56 console...
- Converter acting strange, please help!
- 3800 Stall daily driver
- Vehicle Speed Sensor
- Weird lock up experience.
- just got my converter in!!
- Fluid mixing
- Converter and Cam In!
- Im going for the swap, couple of ????'s
- Tranny just went
- How to tell what stall you have
- Th400 install almost done, quick question
- Just put B&M supercooler on dope style
- 4l60e to a LT1??
- Writeup for changing tranny fluid and filter?
- 4L60E Rebuild?
- shutter when driving around
- Almost finished A4 to th400, what to do with this stuff...?
- Yank SS 3600
- Full weight car with a th350?
- need stall converter (TCI)
- 700r4...
- tq conv ?
- Help To Make Up My Mind
- torque convertor/tranny vibration?
- TH 400 Guys Come Up
- Trans won't shift under wot.
- tranny cooler. Yes or No?
- What needs to be done t56 to th400?
- Converter selection.. interesting results
- 6.0L swap 87 El Camino
- Paddle Shifter?
- manual to a th400
- 2004r vs. 4l60E
- Do I really need a transbrake
- trans not wanting to shift before engine rev's out
- Jet Perf. Billet intermediate and overdrive servos?
- Converter Install....?
- T56 or 4L80e
- Flexplates 168 tooth or 153?
- Delayed Shifting into 3rd
- code p0757 info
- Will my stock TC fit a 97 LT1?
- tranny ???
- wtf is going on?
- 4L60E linkage adjustments
- size tranny cooler
- converter survey
- which tailshaft for th350?
- 4l80e cooling line?
- whats it my vig worth?
- 4l80e cooling line fitting???
- Mod Marker
- Dumb Question
- emptying stall
- Does anyone know what this could be I think its something with tuning
- Need Opinoins please!!
- Torque Converter Help
- Electrical differences between 4L60E's?
- THANKS - Fuddle 3400/2.1 plus mail order tune = new car
- T56 to Th400 short tail. Lengthen Drive Shaft?
- Flexplate question need help asap
- how bad did i mess up my tranny?
- New T/C 2000 miles later need new trans
- 4L60E Rebuild Help
- Anyone Make A Full Lock Torque Converter?
- Behavior of my th350 problems (should I rebuild?)
- Lower first gear for 700-R4?
- Wanting to upgrade Tranny.
