View Full Version : Automatic Transmission
- 1993 4L60 5 Pin TCC connector converted to 92 and older?
- Need a new transmission.
- Automatic stock shifter handle swap to pistol grip
- how much should a trans pump install cost
- 98 blazer tranny same as vortec v8?
- Where to get bolts?
- Tune required after stall?
- Love my new transmission and stall!
- Automatic/Manual valve bodies for TH400 and other transbrake questions
- how do I connect the two hardlines back to the trans?
- How do you get the shift linkage rod out of the case?
- 93 z 700r4 help
- installing trans dipstick tube ?
- what size conv to run with a carb 6.0 239/244 duration @50
- 94 z28 auto soft shift question
- Looking to Swap A4-M6
- ok what did i mess up
- Did I break my converter?
- Circle D - Check out our new Website
- Decisions, decisions, decisions, another broken 4L60
- What caused my transmission pump to blow up
- 4l60e dead?
- Hey guys got a quick ? about swapping in a truck 4l60e
- Best place to buy: transgo hd3 kit
- 4x4 4l60e in 2nd gen
- shifting problems
- Another will it work question
- ACC Performance Boss Hog Torque Converter...
- Need help w/ 4L60 build...
- 4l80e controller wiring question
- 4l80 or th400.?
- "You have TOOOO much converter"
- Help me decide stall speed for my car!
- gm performance
- help!!!transmission won't go into any gear
- 4L65e What tail for stock position mount?
- What can cause my pumps to keep exploding?
- new here need some 4l60 advice
- MYC Trans
- 1994 z28 a4 burning clutches help????
- Corvette 2nd servo and the billet 4th servo how does this hold up without breaking th
- A4 transmission noise
- What trans came in a 93 lt1
- B&M Pro-Stick or Hurst Quarter-stick?
- need help m6 to a4 and wont shift
- performabuilt last?
- 4l60e fluid pressure question?
- Trans. lines for a th350
- Need help finding a 4L60E wireharness
- Yank SS series converter GROUP PURCHASE
- TH400 Driveshaft
- 4l60 manual valve swap, anything I need to know
- which stall
- Converter disengage question after m6 to A4 conversion
- m6 to a4 conv.. wiring help please!
- V6 4L60e work on V8
- Bolt size: transmission to block?
- shifting into 4th early!!
- 6l90e Manual shift
- 80E/Converter/flexplate ?
- automatic conversion question
- T400 in now no speedo?
- 700r4 Shifting / Leaking Issue - Pro Help
- transmission trouble
- Is this the correct a4 4l60E harness
- looking for a great cooler line kit
- Will a 97' F body trans fit in a 97' GMC 2wd 1/2 ton?
- anyone ever used or heard of this converter
- Tranny shifting pre-maturely
- TC install question?
- converter help???
- Going th400 want you thoughts on cam?
- lock up stall
- HELP Trans R&R
- What STR for my converter
- PerformaBuilt Holiday GIVEAWAY special SEE INSIDE
- Soft shifts after pt 4000
- 4L80e Vacuum Line
- new exhaust
- Paddle Shifters
- Hurst Pro Stick
- this is crazy
- 4l80 question
- Trans rebuild kit good idea for stall install? Which stall
- what does everyone think of 4.10 gears and stall converter
- ARP flywheel bolts- pos
- th400 yoke help
- Transmission Help 4L60e
- tci flexplate bolts hitting
- Expert 4L80 Question
- Car Feels Slow Unless I Really Get On It
- Stall & Shift Kit
- Transmission Noise - Please Help
- Finish Line Transmissions
- th400 no 2nd or 3rd
- factory green paint markings
- 4l60e servo question
- Th400 or powerglide
- Line Flush & Leak Question
- 98 Pontiac Trans Am Finish Line 4L60E Tranny issue
- Autos at the track?
- Th350 swap. Tci flywheel Hughes adapter?
- B&m TRICK SHIFT
- part number for shifter cable grommet in tunnel?
- how to replace broken shifter cable?
- What is a fair price for a 4l60e?
- TCC Lock Up Issue
- 4l60e Fluid leak - Out of Elec. Connection Port
- Add performance shift option to 98 4L60E trans
- Calling all AUTOS! *LS1 A4 Newbie insite*
- which flexplate to buy
- Cant shift out of 1st after tune ?
- th400 guys
- Electrical Question
- man look
- Trans Pan
- 4l60e soo many problems with local builder...now this
- Any way to make this happen...?
- 4th gear only vibration
- which 4l60e?
- place to buy transmission parts?
- Does a 2008 Silverado 1500 trans have an ISS?
- trans shifting problems
- my head hurts help!
- Side by side TH350 - TH400
- Quick question about A4's and lockup at w.o.t..
- Motor Dies When Put In Drive
- I downshifted and nothing...
- 800 rpm slippage thru convertor at redline
- gap between torque converter pad and flexplate is .317 help
- Stall Converters
- TH-400 Question
- has anyone seen this output shaft (4L80 conversion)
- 4L60E Converter advice please + adding ISS
- Lock up problem
- How much coaxing to I need to get the trans off of the engine?
- How Much Love 4L80E
- 4L80 problems help please!
- th400 to LS motor flexplate ?
- 4l65 parts to use in 4l60
- Converter freespin after engine stop?
- 4l80 4wd to 2wd wiring...
- Yank PY3400 Extreme 4L80E LS1 Converter on its way
- Monster 700R4
- th400 f-body cruise control ?
- Tell me what i need to fix/replace
- FTI Black Friday Converter SALE
- 4L60E rebuild parts
- th350 swap questions
- converter advice please
- How much stall for my new setup?
- possible causes for rev. input drum failure?
- 4:60E Reccommendations - 550-600 RWHP
- Pro ratchet shifter
- fuel line hoses, enough strong to run as coolant lines?
- What others will work?????????
- A stupid Th400 question
- clips to hold coolant lines in tranny?
- t56 to 4l80 swap ,shiftlock question.wiring experts please come in..
- question on putting a 10 vane rotor in a 13 vane pump
- 4L60E Stator support torque spec?
- th400 swap completed, now I've got some questions
- Cant pull the Dipstick
- Are the electrical plugs on a 4L80e the same as a 4L60e?
- What 60's have you got out of your circle D converter?
- keep getting a leak around trans cooler
- 1 LE trans mount
- Installed a new 4L60E tranny from RPM Transmissions, now my Z is slower???
- grade 8.8 bolts good enough for flexplate bolts??
- derale 4l80 trans pan with cooling tubes or tci pan..
- anyone replace there bellhousing on there th350/400's?
- Which tranny do I have?
- th400 pressure regulator valve...?
- 2 step with transbrake wiring
- Shifting? Does someone have the knowledge
- Close up pics of lokar 36 inch 4l80 dipstick in car
- Is my trans slipping?
- bought used trans with vig conv need help i.d.
- t-56 to auto conversion where to find reuired parts and would my cam work
- No shift at WOT in all gears!
- what causes a flywheel to make noise?
- Would I like a 3200 stall or higher on a stock motor?
- servo return spring missing
- Front Mounting a C6 6L80E transmission
- What parts to buy for a 4L60e w/200 shot?
- 4l60e wont shift past 2nd on startup
- 1995 4L60e VS 93 and 94 ?
- Tranny mount or motor mount broken?
- Ideas for quieter crossmember mounted torque arms..
- Two step for transbrake
- Vigilante 3600 vs YANK SS3600
- 4l60e limp mode fix??
- Install Tips on my 4x4 Trans Converter install?
- Can I get away with JUST putting in new clutches and shift kit? Please help guys
- FLT 4l60e and pt4000 combo
- th400 vs. 4L60E
- LS3 4L60E without ISS
- Converter Break-in Time?
- Close to stock 4L60E
- Help, 2-3 shift at WOT is sluggish, hit rev limiter once
- 3rd&4th th700r
- extended crank and what trans
- t 56 to 4l80 guys trans cooler questions..
- Questions regarding removing the bellhousing bolts
- Frozen trans to block dowels...what worked for you?
- Texas Performance Transmissions shop in humble
- th400 swap now it won't start
- Tranny mount and pinion angle
- Gear stuck after WOT
- Longer 4L60E Shifter cable???
- What does your car stall foot braking it?
- 700r4 wont shift out of first
- 4L60E question
- 4l80e tranny speedo
- do flexplates lose there balance when you drill them for a differnt verter?
- Tranny Cooler
- A4 w/solenoide problem..
- 3.8 bellhousing mated to a 5.3?
- what tci flexplate to crank bolts to use. ASAP plzzzz
- cooler fan question, and arp flexplate bolt question.
- Broken trans? lost all gears on dyno
- stock vs th350
- 3 pumps blown, converter hub bad? HELP!
- Torque converter bolt size
- Help with lock up issue
- 6sp to a4 conversion price??
- 4l60e vss part#?
- WHAT TO STALL A SS4000 stall
- Won't engage 1st from neutral or park without a bit of revving?
- Odd TH400 issue...sometimes no reverse/drive gears
- transmission making sqeaking noise...????
- A few question about torque management
- Guys with TH400 RMVB w/Transbrake... What shifter and TQ arm is best???
- Having a Problem
- transmission questions
- What size cooler for a Th400?
- Th400 built to hold 800hp
- 4L60-E VSS issues
- turbo 350 i need help
- 4L60E - lost all gears - trans gurus please enter
- 4l60e ?
- flutter sound??
- Just drove my SS after swapping my M6 to 4L80E.. have Qs...
- RPM 4l60e stage 5 *** In here***
- 6l80 clarification
- TH400 rmvb w/compression braking in all gears
- will not go into reverse 4l60e
- Circle d +4c or PT4000 in Z06
- th400 users, what trans mount are you using?
- P0757???
