View Full Version : Automatic Transmission
- Please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!! doing engine swap!!!!!!!!!!!!
- 4L60E issue.
- 3500 stall?? tuning??
- Is this ok??
- Wtf Could It Be! Help!
- need help with trans guys
- Will I like a th400?
- Take me to school, PWM
- 4L60E troubleshooting...(v6 version)
- I need some help on an engine swap
- what cooler is everyone using on 4l60e
- TC to flexplate bolts size?
- m6 to a4 swap help
- V6 4L60E vs LS1 4L60E
- Bolt sizes...
- What shifters are most of you th400/th350 guys using?
- Yank SS3800 videos
- Rev Limiter!!!
- Stainless steel braided hoses for tranny hose?
- shift extensions
- How much is it worth? 4l60e
- Who makes a "Reliable" TH400 4000Stall Converter that can handle a 300 shot?
- Want To Hop Up My A4 4l60e Trany, But ? What
- Converter junked? (to cut and clean or not??)
- What the hell does this mean??
- Can I get some tips on an transgo install?
- what stall
- The best tranny cooler line...
- How did you tap your tranny temp sender into either the feed or return cooler line?
- 4L60E does not engage
- 3600 Vig going in and taking it to the tuner what do I ask him to change?
- 3-4 shift
- Write up on installing a turbo 400 tranny...?
- TCI 4L60E Problem?
- Manual lockup switch
- Rev Xtreme Extreme Torque Convertors!
- bad vibration...built A4
- 1998 Firebird transmission Mission submission!
- Clutch flakes in my filter 4L80E
- avg trans temp for 4l60e
- Yank Shift Extension and Gear Size
- TH400 and converter questions
- Attention FLT
- Rebuild Transmission?????
- th350 to ls engine
- question with my shifter 4L60E
- Transmission problem
- Pressure issue???
- 4L60E Yoke
- Upgrading the servos necessary??
- flexplate??????
- M6-a4 Reverse Lights ?
- Got some money need some help
- Is my stall blown?
- My tranny
- people who race with 4l60e
- nitrous on 460le
- Vette Trans???
- was taking the bellhousing off and stripped a bolt
- 3-4 clutch pack
- Happy Holiday's
- Swapping a 98 4l60e into a 94
- corvette c6 auto gear box 6 speed suk
- one piece tranny is now a two peice...
- TH400 kickdown with DBW
- over spinning torque converter? (rpm limit)
- Cant get my bell housing seperated from my block
- At what point do you need an aftermarket ratchet shifter and what are real benefits?
- electronic controller for transmission?
- 97 4L60e to a 94 4L60e
- Fuddle wont lock up
- Transmission slippage
- Screw you, Precision Industries!
- hooking up spedo for th400
- goodbye t56 hello 200r4
- 700r4 missing plug
- Need help on stall speed.
- Borg Warner HD clutches
- Fast Toys Now Selling Pro Torque Converters!
- advantages of going with a turbo 350 over...
- Manual Valve Body in 4L60E
- Mechanical or Eletrical Tranny Gauge
- Ideal driveshaft yoke engagement
- Converter recommendation...
- transgo shiftkit
- what can i do 2 beef up my stock 4l60e????
- Power glide on the street?
- Transmission Perform Button
- Transmission Issues
- Clunk sound
- what trans does this have
- Manual Valve Body
- Vigilante Stall Converter
- ss4000 not locking up
- PT4400 question?
- Removing 4l60-e.....
- how dangerous?
- What can a stock 480le trans hold for power/torque? What stall can handle up to 1000
- TCI 3500 Street Fighter Question
- Rollling In Park
- 4L80E temp drops 40* in 45 seconds at TCC apply-Why?
- Opinions on what shifter to with my TH-350
- is my pt4400 going bad?
- flex plate problem!
- Question for a 4L60E
- Just blew up, a new tranny
- 4L60E Vent Tube
- 1993 trans am trans mission problems
- converter question
- 4L60E from an S10?
- ls1 to a 700r4
- stock shifter with th350
- 4L60E pump bolt part number?
- If stock G.M. trannys are...
- Last chance on YANK converter Sale
- Lock-Up Switch...
- anyone have a diagram for routing through the radiator and cooler
- Fuddle ??
- whining acceleration
- Mid sized cam....MPH better, Vig 2800, 3200, or 3600??
- after rebuild car moves at 5mph at really high rpm, like something not grabbing
- Parts to handle more power?
- Tranny issues?
- Pulling Trans With Longtubes..
- need c5 auto transmission measurment see inside
- where can i get a rubber tranny mount??
- how a 2 step work in a auto?
- converter choise guys
- DANG!!! 4L60E Codes
- Vigilante Triple disk vs Single disk....difference??
- 4L60E fluid leaking
- Converter Guru's plz
- Vigilante 4L60E Triple Disc 3600 rpm - In Stock
- Ok Its Not A Electrical Problem!!!
- Need Help Quick!!!
- Quick question
- Manual shifting/d-shifting
- good speed to start at in a roll race? Downshifting manually?
- How many of you guys running stock 4l60 with heads and cam?
- my 4l60e parts list any suggestions?
- REVIEW: ACE stage-2 4l60e / 9.5" converter package
- Crank Bolt With Auto?
- pics of neal chance!! anyone have any?
- No trans temp gauge.. Safe??
- Converter causing the HP to take a dump on the dyno?
- Clunk & Vibration Trans problem?
- Bolton LT1 with a almost stock TH350? or 4l60E
- Question for performabuilt
- Trans removal
- having problem with install on 4l60
- What happiened!!!!!!!!!!!(4L60E)
- 700r4 broke today...
- Th350 Questions
- Th350 Vs Th450
- TCI or Vigilante
- Th350 Vs Th450
- Recommend me a transmission cooler
- trans issues after tune
- What side of the pan did you locate your trans temp sender??
- Torque Converter Bolt, HELP!!!!!
- Manual Valvebody...
- 4L60E Question
- installing TB in a th350
- B&M LS1 Converter Efficiency dyno results
- where to mount cooler if i have the slp cold air package?
- Trans Cooler w/Fan Questions
- Bypass the rad. or not?
- Cadillac 6-speed
- Yank 4000SS w/ 18" BFG Drag Radials....streetability & performance??
- 4l60-e
- trans brake 4l60e???????
- how to spray 4l60e
- Who sells rebuild kits for TH-400
- yank or vigilante stall ?
- no o/d, 1-2 solenoid?
- Bad Vibration......need help please
- TCI 3000 Lockup Problem
- Higher Stall TC???
- Ever Wonder What Goes Into An ACE 4L60E?
- brand new tci th350 no 3rd gear
- what stall should I go with?
- Which Converter?
- Vig-Yank reliable?
- I know this has been asked before but....
- 4l80E Torque Converter Advice..4l80E guys come in!
- Will a Turbo 350 Trans hook to a 2000 LS1 motor?
- Transmission Temperature Help
- Seperator Plate 4l60e
- Tranny issue or what?
- 4l6E / Stall problem!!
- Uhh, my 3rd gear ran away
- Hypertech PP Question??/shift points??
- Road Racing Transmission
- 4L60e/80e Solinoid questions...
- Yank SS4000 and MS4, good match?
- Powerbraking from a Roll
- Overheated computer trans not shifting????
- Hitting the rev
- foot brake!!!!!!!!
- 4L60 trans rolling forward at start
- Transmission Problem
- Hey guys... converter Q
- 02 silverado trans 4l60e
- Props to FLT!!!
- flywheel the same on LT1 and LS1s? HELP
- Installed th400 I have a ?
- fluid change
- what flexplate with 408 and built 4l60e? (street car)
- 4l60e???
- transmission cooler hose
- O.K. searchy no worky......
- 4l60e want shift after tune
- Ultrabell installation (aka JW ultra bell)
- TH350 trans brake
- D or OD with a stall?? at the strip
- question
- 4L60e tranny cooler lines for 04-06 GTO
- Adding vacuum line and still don't shift
- cousin's 01 ss
- Sonnax Servos
- TH350 or 4L80E?
- transmission slipping
- Weird third and fourth problem
- Hot shift?
- My car seems slow from a roll?
- Basic/Somewhat strong rebuild kits...
- flexplate bolts?
- The 99999999th P1870 thread
- need tranny info
- No Lights on Gear selector? Any ideas?
- performabuilt lvl 1....
- Th400 or 4l60E for my 68 Firebird LS1 swap
- whats converter is better Yank or Vigilante?
- transgo shift kit?
- vig converters
- Still no shift!!!
- rpm drop after shift into third
- What in the removal of my 4l60e could have messed up my TCS
- transgo 4l60e-hd2
- Perfrombuilt Lvl 2 tranny
- can i make it shift smoother?
- Not Shifting into 3rd @ WOT...
- Dyno Testing From Flt Video
- Stall
- stall and 4.10s
- 700R4 speedometer in a 4L60E
- SS4000 in an LT1
- Midwest Opnions
- How much quicker and faster did you go when you removed your torque management?
- Vacc Modulation Explained
