View Full Version : Automatic Transmission
- Car dies when put into D and R.
- in a dellema
- TH350. How much weight do I need to drop?
- ok so i have a problem....transmission i think
- Bellhousing bolts question.
- Anybody have a Yank SS4000?
- how long will it last
- 4L80E compatability
- stall size
- Want to give thanks to Greg@FTI
- PWM mod?
- Identify this converter...
- tranny trouble
- got th350 to ls1 questions
- 4L60E compatibily question?
- 4L60E dipstick length
- Installing converter
- Question about Midwest converters
- where to buy 4l80E 4th gear seal install tools
- redneck racing?
- Hughes tranny equal junk
- lets talk "blow thru"
- 4L60E Firm 1-2 shift, lazy 2-3 HELP!
- Personal pref
- T-56 to 4L80e
- Tranny HELP, video inside.
- 4l60e Shift Problem
- which 4L80e shift kit for engine braking
- Flexplate help
- When did it blow.
- Cooler Hook-up
- TCC slip while driving?
- 6l80vs4l65
- flexplate Replacement
- Lockar dipsticks
- Need help identifying a PTC converter - 36508
- transmission swap question
- Auto reasoning
- 6l80e swap questions into fourth gen f body
- T56 to TH400
- Are the gear ratios in the 4l80e and th400 the same?
- will i be ok
- Horrible squealing sound coming from tranny
- Will thIs Work with 04 lq4
- LT1 and LS1 4l60E Wire harness question
- Driveshaft out of a t56
- PerfomaBuilt 3800 question
- 4l60e rebuild
- Converter Choice!
- Just bought my first converter! Just a few questions.
- Tranny issue
- 4L80e trans question
- 4l80e controller question
- 4l80 derale pan f body guys.
- Looking for stall recommendation please
- Trans Fluid ?
- Whats the best MPH to roll race with an A4
- Aftermarket VSS for TH350
- Is my transmission saying bye-bye?
- Lt1 4l60e will fit ls1 just changing the bell housing?
- 4L60E Trans Swap
- need help diagnosing problem plz
- 4l60e question
- how do you check the oil level in a 6L8E
- ms4=? stall
- trani cooler line size?
- Anyone DD a 400 trans?
- Tranny and torque converter questions
- 4L80e shifters
- 4t60e
- Transbrake People
- need help with trans fluid,A4?
- Stall
- Need help so i can order the right parts.
- Yank stealth thruster 3000 4l60e/
- i need your opinions
- Performabuilt? FLT?
- Whats the current 4L60e record?
- i had to ask...
- boost valve bushing feed holes
- ok to go from regular ATF to Dexron VI?
- Need help bolt ons stall guys come on in...
- PCM TCM 4l80e idiot question
- Shift Solenoid LED Light Mod
- What gears do you TH350/TH400 guys run?
- all th400 turbo 400 pressure ports same size?
- manual valve body for 700r4
- Stock 4L60E and cam guys
- Will B&M cooler w/fan (70297) fit under pass. side fog light, dope style?
- Not going into 1st or 4th... Please help!!
- Was my A4 in limp mode?
- tranny slipping..
- Tci Valve body?
- Price/source??
- 4L60 to TH400 Question
- Shift Extention Question
- Billet forward piston
- Does anyone have a LT1 with a TH350
- is a stock converter worth anything?
- lokar stick correct?
- Help me id this converter
- replacing grey connector to pcm. its leaking
- which stall? would it be worth it??
- TH400 build question
- Cold Weather?
- late and real lazy shift into 2nd gear
- Converter and Autox
- TH350 cooler lines, dipstick, oil, questions.
- Poll: What rear end do you have - stock - 9" - 12 bolt
- Got me a 4L80e Questions...
- Good troubleshooting chart I found.
- A/C condenser as tranny cooler?? any thoughts?
- 350 turbo
- Can a 4l60e handle high speed turns?
- trans wont shift to 2nd
- 6L80E to F Body
- 3400 Stall with 3.73s; Gas mileage?
- dexron VI
- Stock stall in a 02 ss camaro
- 1st Hard shift, only 1st?
- Questions before cooler and stall install...
- will not shift into overdrive
- another powerglide can I use it question
- should there be....
- Th400 and new rear end
- A4 shifter console light
- 1,000 RWHP...converter...which kind
- can you identify this flexplate?
- OEM flexplate bolts suck? What to use?
- converter shudder?
- 4L70E Leak if Overfilled?
- Vigilante Stall Converter to Flywheel bolt size?
- Converter Differences?
- Stall convertor flush?
- A4 not shifting out of 2nd.
- Back home from RPM Transmissions!!!
- Need a New Transmission?
- LSX swap, but which trans?
- 4L60E Question..is it slipping?
- 4l60e Manual Valve body
- Stall install questions.
- transmission won't go into first
- stall
- What trans to use in my 1969 LS1 Nova
- Speed Sensor affection!
- 700r4 Transmission has me puzzled
- calling all rebuilders, what is the diffrents between 4l60E and 4l80E
- 99 Trans Am WS6 4speed auto to TCI 6speed auto
- question
- trans temp gauge sending unit
- 4L80 Swap Vibration
- I think I am in need of a new separator plate.
- 4l80 wiring harness/plugs
- transbrake and line lock
- ripped out speedo plug help
- 4l80e tail housing
- Pics of B&M ProStick mounted in LS1 console
- Too much stall???
- differences in years?
- Good TH350 Rebuild info?
- 4l80e trans brake ??
- which one is better?
- How many mounting bolts 4L80??
- Overdrive for th350?
- Merry Christmas from Circle D
- in and out of lockup
- Converter Help
- transgo shift kit instructions
- 3200 Stall and Now a Tranny Leak
- Yank SS4000 converter question
- 1st gear bind up?
- Driveshaft
- What size stalls are u guys running with you decent and big size cams?
- Circle D 245mm Sweet!!!
- tranny cooler install w/ fast toys ram air
- TH400 in a camaro question
- Yet another TH400 yoke question
- problem at wot
- Request from the Auto Mod
- Recieved my Circle D TC
- Could this be a tcc solenoid or converter problem?
- 4l80 build what internals for 1000 rwhp
- C6 6L80 trans with SS3600 converter runs 9.90s
- I think this could be the beginning of a transmission problem.
- th400 question
- transbrake clutch question
- Stall Question
- 4l60e suddenly started slipping in 3rd and 4th whats wrong
- Who makes a TH400 Crossmember w T/A mount
- please help im lost
- what does a 4l60 weigh?
- 4000 stall? come on in!!!
- Converter Lockup
- SS3200 commentator lol
- Performabuilt Level 2 tranny holds 678hp/763lbs
- swapping to 350 turbo
- 4l80e info
- What goes first in the 4L80e?
- need 4l60 built in dallas tx
- Will a GTO A4 transmission work in 98 F body?
- stock 80e how much power
- lock up converter with manual valve body.
- Still Looking for That Perfect Gift???
- Stall's w/ stock cover/lock-up disc?
- how to figure out that year my 4l80e is?
- YANK will be closed Dec.23 and reopen Jan. 4th
- 4l60E wont shift at WOT!!
- flt stage 7
- How do you know if your blowing thru the convertor?
- Performabuilt
- Limp mode, ugh...
- Flex plate
- AWD question
- 3rd acculmator
- stock trans and spray
- What's this little part in the pan
- Performabuilt lvl 2 limits?
- t56 to 4l80e
- Everyone must read
- This a good 4l80e to use
- Circle D & GMHTP
- Tranny cooler question
- Shipping a Transmission, how did you do it?
- Removing tail housing on 4L60E
- '98 LS1 transmission rebuild kit
- 700r4 question...
- Check out our new Website now finished
- Th400 LS1- what shifter ? cable length ? DS length ?
- No first gear, electronics?
- '03 4.8l, 4l60 in a 99 T/A
- Help Identify Trans
- TH350 help!!
- Shifts getting less firm after long drives
- which shift kit?
- Borg warner Hi energy VS Alto red eagle Clutches
- 4L65E Weight
- Help decide were to get my new 4L80E converter.
- TCI new Line Lock for 4th gen f bodys
- Fresh Rebuild 60e slips in reverse only
- Truck 4l60e in a fbody?
- TCI Max Shift Opinions
- 6L80e output
- ? Anyway to get some money out of this $7000 paper weight sitting in my garage?
- How often change fuild on stalled 4L60E?
- Trans not going into 3rd gear. Trans shop in Tulsa area to take it to?
- V6 vs V8 tranny
- How to tell what tranny?
- Vigilante converters, low mph, low effeciency?
- Just got Home from PRI
- Trick Flow Deep Pan
