View Full Version : Automatic Transmission
- tci 3200 2.6
- Tranny should be ok right?
- Shift Firmness
- Parts List Please
- M6 to 700R4
- Built my tranny and converter
- Does a lighter weight torque converter free up horsepower?
- 4l60e pistons
- Lockout Q
- Anyone have pics of a modified M6 crossmember for a TH400
- Do i need a PCM to run a 4l60e..
- Transmission Problems...HELP!!!
- Manumatic conversion on 4L60E?
- Tune with Converter
- Proper transmission lockup behavior question
- Transmission condensation?
- Yank Stealth 3100 Installed and Running
- Broken Tranny Mount...
- 96 Grand Am V4
- How much will my mpg go down after stall
- my tranny's acting up!
- Percentage difference in rwhp and torque between locked and unlocked converter?
- M6 to TH400 speedometer conversion
- Guys with TCI flexplate and ARP bolts.
- Stock Flexplate
- which linkage for th400? 4l60 bracket wont work on pan
- TH350 problem
- Will my trans be fine??
- Vigilante and Nitrious Question?
- high stall and dyno
- Tranny Cooler
- B&M cooler question.
- TH400 Converter Cover
- Custom Torque Converter???
- TC coming apart?
- Anyone here sell....
- billet servos
- Dropped the Trans Pan....
- anyone ever had a problem with a yank?
- High stall TC guys, turn off your lockup TC!!!!
- B & M tranny pan woes
- Stupid question regarding Yank converters
- incorrect flywheel installation?
- lightweight flywheel in autmoatic??
- 4l80 to 4l60 wiring help
- Where do I get a Flexplate spacer
- Hughs converters?
- tranny acting up
- Gears & Stall
- Help Me
- th400 help
- TH350/LS1 & 3rd Gen
- Yank PT 4400 finally installed
- Aprox price of Having a shop change out a transmission
- Has anyone used a Yank PYE converter?
- Torque Converter dead.. time for aftermarket..
- tailhousing keeps breaking
- TH400 Vacume line
- 4l80 not dyno proof!! a little help please
- TransGo SK: HD2 vs. the one w/Video ?
- **maybe you guys can help me out?**
- My Turbo Action Cheetah Shifter! *Pics*
- will a stall kill my tranny?
- B&M
- Rossler 4l60E
- a4 to m6 converstion
- 4l60e problem?
- 4l60e from LT1 to LS1...
- TH400 conversion problem
- Speedo part #s in sticky wrong???? WTF?
- yank converter
- Paging Kevin @ Tci
- Bad shifts at high rpm
- Converters bad for stock 4L60E's?
- "Grinding" after TCI SF at 55-60mph (under lite load) ?
- Looking for Stall Converter Insight
- stupid fuddle racing converters...stay away from them
- Shift Kit
- t400 shifter options??
- straight cut planet gears vs helical
- power limit of a stock 4L80E??
- 3/4 clutch pack clearance specs?
- Fluid Temp & Converter
- A.N-6 fittings for a 4l60e?
- Transking th400
- 4l60e question
- Billet servos
- Stalled/built 4l60 guys,what temp are you running?
- Unique 4l60e slip problem
- fuddle or tci conv?
- Whats a good rpm stall for a daily driver?
- Its that time again
- Who has dropped their own a4 Tranny?! help me out here...
- Vig 3600 is in....
- how many guys have a TCI
- How did this converter carnage happen? $PICS$
- will it hold?
- Problem at the track with 3rd in the 4L60
- 4l80 torque coverter fit ls1 w/ 4l80?
- Help.. want to convert from m6 to auto
- 4L80E plug and wiring harness
- Yank SS3200 vs SS3400 vs SS3600
- New tranny issue....
- Quick Question about New Converter..
- If you are trying to contact Fuddle...
- Fuddle.....Hit or Miss??
- Trans/Converter issue....verter locked in 1st gear?
- New B&M Shifter?
- New High-Efficiency TCI Converters!
- Mike/Yank
- How about Rock-On?
- [Vendors] What Torque Converter can u offer?
- Tranny cooler lines popping off
- Relocate the trans cooler
- My th350 doesn't have a 2nd gear
- how hard is it to convert an m6 to a th400?
- Front Pump Seal Install
- Shifter position off after kit install
- high stall converter grinding on lockup? Transgo has your fix..
- th400 guys, have some questions......
- Best Converter for F13 Cam
- 4l80e swap, shift linkeage for stock shifter...
- Stock stall loosened up to 2500 ???? question need help ASAP!!!
- Stall noise?
- felixable dipstick
- YANK, custom stall questions..
- stall converter not locking
- finally drove my FLT built trans w/ converter
- Who's got 600+ hp? What is your set up
- TCI Converter Stall Problems
- any shops in vegas?
- th400 and gearing
- How does the Yank PT 4000 Compare to a Yank SS4000?
- Please Help Me select a New Converter
- Question about the A4
- Yank Pt4000,pt4400, Ss4000
- A 3400 stall on a 355 will stall at _____ RPM on a 396
- strange noise?
- what should i do???
- th400 fluid......
- For those of you that want a Fuddle verter please read!
- Any sponsers sell A3 Conversion Kits
- Oil Leak
- what stall size for nitrous?
- trans deminsions??
- M6 to A3 th350 flywheel
- Driviability Difference between 4k and 3200 stall
- 4l60e linkage
- help y would this happen
- Th400
- I am Sick of A4 and Converter Troubles
- B&M Cooler Installation
- Transbrake for 4L80?
- built transmission....=boom
- What dipstick 4l80 in a f body
- TCC settings
- electrical problem with trans.
- need help with ma automatic transmission
- Welding on a TH400?
- 350 Turbo
- Tranny mount which one
- tranny problems i think help!
- shift kit VS adjusting the shift points with a computer
- 700r4 shift kit
- Weird.....problem....help?
- Tranny cooler and Cold Air kit problems?
- No Shift Kit???
- 4L60E overheating again!!
- 4l60e question.mine broke
- 1, 3 and 5 disc converters???
- What kind of tranny?
- Stall question
- help with converter choice...
- looking for a 4l60e
- Mad Dog Transmissions
- DIpstick.
- Downshifting the TH400
- The "Ultimate" Transmission.
- Tranny doesn't shift!!!
- Gear Vendor
- Thoughts on this Trans kit
- thinking of N20.Will I need anti-ballooning plates
- th 350 in car,,dipstick???
- what would be the benefits...?
- transmission whining???
- Quick question about shift kit and shift firmness...
- Need Some Advice...........
- can 4l60e holds more than 400 hp????
- Rossler customers come inside
- need help with tranny
- TH350 Electronic Speedo Troubles
- Dacco Converters?
- Will my stall kill my transmission?
- Car jerks when started?
- Transmission coolant line question.
- DD on a th350 or th 400??
- 2nd accum
- 411 gears with a4??
- Fuddle Racing out of business?
- has anyone used this transbrake on a 4l60e
- Lockup or not?
- short shifting commanded RPM, after cam
- 1-2 shifts
- Help
- Just got my TH400 in, got a few driving questions.
- 4400 stall installed
- Midwest 3600 finally in. Daaaaamn!
- 2003 silverado to 2000 Camaro
- Tranny maintnance Question.
- After takung the car to 2 differant shops they have come to
- what kind of tranny do i have
- TH400 overdirve?
- can you use a th400 with 9" tail?
- heads and cam on auto?
- Paging Fuddle
- After adding NOS Rev limiter keeps getting hit
- Left over parts
- who makes aftermarket flexplates?
- line pressure band-aid
- Yank messing up Idle
- tranny costing hp
- track results after VIG 3200
- A4 at the Track Question
- What is a trans brake?
- Need help decide which tranny
- Torque specs for B&M tranny pan
- swapping a 4L60E for a TH400?
- TC lockup issue
- Thinking of doing the T56 to TH400 swap; got a few ???'s
- lock up issues...
- 1-2 delayed shift and no shift at WOT
- 4L65 in a 01 camaro?
- not happy with Fuddle, now what
- how much can th350 handle?
- Proper 4L60E Trans Fill Procedure?
- th350 pan torque specs.???
- P0751 1-2 Shift Performance or Stuck Off
- torque converter install question
- What Do I Do????
- 1-2 shift problem 4l60e need help asap
- 4L60 pump problems
- Vigilante Sloppy?
- Big Difference going from 3800 stall to 4000?
- Which one would you do? Rebuild your own or buy a used built one?
- need help asap
- 4L60E & 4L80E Shifting
- What does a dry th400 actually weigh?
- what shifter to get
- 383 lt1, th400 w/ transbrake?
- what is an alternative converter to tci 242933 4400-4500 stall
