- Urgent!!!
- What fits a 99 z28
- 4l65e in a 2000 z28???
- Trans won't shift normally
- 4l60e reaction carrier shaft and 5 pinion planets
- Urgent help needed... Servo Removal
- Huge thanks to chris @ circle d
- Hitting revlimiter and not shifting
- MBA shift adapter?
- Is my 4l60e blown
- T-56 to th350 swap
- Swap tranny 6speed to Auto
- buying a new transmission which one?
- top end speed compared 4l80e to 4l60e
- 4L80 or 6L90??
- New Powerglide- wont move.... Nothing happens, ideas?
- 700r4 tranny install issue.
- A4 1-2 Shift problem
- 1999 t/a lsx 454 tangelo hok 4l80 what gear to run
- Jakes transbrake users, got vids?
- A4 700r4(4l60) questions
- A4 swap power lost
- 98 z28 ls1 skiping 2nd gear
- Fresh rebuilt 4l60e question
- ATTENTION DFW Area Racers!
- Trans tune issues, experts needed
- Check out Yanks holiday converter sale
- Chasing down the nasty p0748
- Which stall for a supercharged C5?
- Auto meter cobalt gauge not working properly
- 4l60e pump swap old vs new??
- 4L60E Removing Tailshaft
- Shift knob removal
- 4l80e borg warner high erengy rebuild kit....where???????
- Question on 4L80e tailshaft + slip yoke
- Jake's Performance Memorial Day Sale
- 4l60E troubleshooting
- 4l60E on long crank 6.0 (99-00)
- Converters
- Th350 converter choice for turbo motor
- TH350 with VSS
- 4L80e HD2 Shift kit: How much power?
- Rebuilt 4l60e in limp mode!
- 4L60E Questions
- converter to flexplate problem
- built 4l60e issues
- Need help deciding
- 4l60e rebuild, what should it cost?
- 91' 700r4 reverse drum probelm, help!
- 1996 4L60E swap LS6
- How can you tell a 4l60 from a 700r
- What size bolts hold PNP switch on?
- remove check ball with non lock up converter?
- Possible rebuild issues.
- Older TC in 2000 z28
- t56 to th400
- Need Help! Swap car needing TQ Converter
- Looking for new 4l60e
- 4L80E limp mode or something else?
- 700r Schematic or Wiring Diagram
- Trans line fitting size ??
- No over drive?
- 4L80E swap stuck in limp mode
- Non-lockup converter in stock 700r4
- Performance Torque converters of Texas
- Yank or Circle-D?
- starting my 4l80 swap this weekend..just have some final questions
- car not shifting right after gear install
- Tuners: Can you notice a 4k stall?
- 4l60 tuning question
- th350 stall options ?
- 4l60e shifting problem
- th400 tc bolts
- Just smoked a newly rebuilt 4L60e
- Best tranny for a heavy nitrous car?
- 4l60e no end play after pump installed
- Replacing a 4l60e with a 4l80e random questions
- converter lock up while racing question
- TMAX Converter Stall
- C5 4L60E Pan. Yay or Nay?
- 4L80e LM4 5.3L 67 Camaro install ?'s
- Shifting Problems
- 4l80e swap codes
- 4l60e trans
- Speed Sensor Air Gap
- What Flexplate for Long Crank 6.0 and 4l80e?
- pin travel
- Jake's Performance Contact
- Am I asking for trouble?
- 2001 M6 roller getting my engine and 4l60e. Manual to Auto SWAP QUESTIONS
- Shifting a auto?????
- Here is some vids with PerformaBuilt T400
- please help trans does nothing after motor swap
- Trans problems
- Anyone ever skip the top bellhousing bolts because of solid motor mounts?
- PRNDL Pigtail
- 4L60!Transmission rebuilders
- 4l60e trans problems
- Caprice 4L60E behind Gen III LS1 OK?
- 2 1/16 transmission pressure gauge
- Lt1 4l60e hybrid??
- 700r4 to 4l60e speed sensor options
- trans fluid??
- transmission fluiid flush?
- Th350 and VSS
- 4160e shifting problems
- 4l60e valvebody
- flexplate issues
- B&M ShiftPlus?
- el60e no drive or overdrive
- chatter or shaking? th400 rmvb
- new transmission suggestions pleas give your input!
- what to look for in a used stall?
- buying tranny need options
- Flush New Converter?
- powerglide
- Help, 4L60E input shaft end play question
- Auto Trans Problem
- 4l60e MVB Conversion
- putting 4l60e together help
- converter ?
- Please help me choose size and brand stall converter
- Torque converter or just the TCC solenoid?
- Stall benefit to bigger cam
- ADVICE NEEDED! 4L60E w Circle D 3600 stall not shifting correctly at all
- curious A4 swap question
- Anybody deal with True Tech Performance Transmissions?
- Trans cooler question
- Vent tube leak?
- Difference Between 4L60E From LT1 & LS1 F-Body??
- How does the PCM respond when in Park vs. Drive vs. Neutral?
- Converter problems
- Special Sale for LS1tech members!
- 4l60e stuck in low gear after rebuild..
- Tranny
- rossler transbrake programming
- Where to buy tailshaft housing extension?
- 4k stall in turbo car with th350 to high?
- Check out Mad Dog's Level 4 TH400!
- MUST READ!!! Mad Dog Transmissions
- 4l80e swap in Silverado
- LS1/4L60E swap in limp mode (p0758)
- 4L60E to T56 Wiring
- 700r4 problem?
- inputshaft 3-4 feed hole enlargement
- Rmvb th400
- TH350 stall size?
- HELP: 4L60E Not Shifting Under WOT
- Th350 late 3rd shift
- 4L60E removable bell housing question
- 700r4 issues...
- Shipping a Transmission..
- 2nd accumulator piston help!
- Where to buy forward clutches for 4l60e
- pulling the 4l60-e need rebuild kit ADVISE
- rebuild 3-4 clutch packs clearance prob
- LS1 4L60E (new 98-up style) to LT1 engine?
- 4l60e problems no reverse
- 4l60e problems
- 4L80E swap - Codes P0740 and P2761
- 4L80E Cooler Line Ports
- Slipping 4l60e
- Late 1-2 shift part throttle
- Have a used 4l60e just sitting their, HELP TO REBUILD
- Sonnax Smart Shell used in 1000 HP 4L60E
- 4l60 cold hardshift
- need stock converter flushed near chicago
- 4l80e chevelle help..
- Revmax converter Track results!
- th350 trans
- 6180 Converter ??? I think
- Drive shaft won't spin
- Shift kit help
- Cutting the bottom of the bellhousing? Can I? Should I?
- Th400 question?
- New transmission
- what needs to be done to a 80e to stand up to 700rwhp
- New Transbrakes Available Now!
- Stage III trans + stock 10 bolt. Asking for trouble?
- 4l60e TC Stall Opinions
- 4l80e question, late/no shift until throttle lift
- transmission "clunks" into drive
- how long
- 4T65E Whining noise after freeway drive
- Flt for 4l80??
- Car won't accelerate in 4th gear
- Thank You
- thanks yank!!!!!
- HELP! 4L65e 4x4 to 4x2 Converstion. How do I tell if done right?!
- Dust shield?
- th400 help
- Trans Brake Switch Location
- 6L80E Yoke Question
- bolt size?
- Ratchet shifter or anything like that?
- 4L80E in '88 K5 Blazer Questions
- m6 to a4 ?
- Car goes in gear but wont move.
- 4l60e bellhousing bolt question
- TH350 on an LS1
- 4l80e converteer and flex plate differences by year???
- No drive or 3rd but 1st and 2nd gear work
- Familiar problems
- G8 6l80 swap to 4l80 or options HELP!!
- need advice on a stall.
- TH400 intermittently will not 1-2 shift
- 700R4 TV cable Adjustment!
- TH350 Conversion to a 700R4!
- 700R4 Conversion!
- 10% off sale ends soon and other news.
- 08 LY6 to 02 4l60E wiring questions?
- weird vibration jerk feeling accelerating??
- 700R/4l60 parts swap ..question not asked here before? Help
- Mad Dog Transmissions!
- Considering the M6-A4 swap
- 4L60E Rebuild
- Installing converter tomorrow and tune changes
- 4L60E swap...weird WOT issues...
- Probably my optispark?
- Need help starter is hitting flexplate th400
- 4L80E segment swap problems?
- 4l60e CONVERTER SWAP?????
- 4l60e vibrations ?????
- 4000 stall to much?
- Speed sensor, auto vs manual
- 97 RS Shifter
- 4l60e problems and question
- trans question?
- HD2 kit or not?
- 4l60e 2-3 flaring
- 700r4 speedo
- 2002 lq9 with 4l60e
- Th400 to 2003 LQ4
- 4L60E Riding Gears Too Long
- 2nd place finish at king of the street thanks PerfomaBuilt a cpl vids
- Dyno graph from one of our customers
- Will TH400 still shift smoothly with T-ReX v.2 cam?
- 3200 vs 3600 vs 4000 stall converters
- Need help with 4-point (!!) Torx on Bellhousing
- 4L60E converter lockup
- Performabuilt Warranty?
- 4L60e P0757 not shifting into third Help!!
- 4L60E shift kit
- TH400 conversion kit for sale!!
- Will a 4L60E work without the gear selector plugged in?
- OptiShift help
- 4l80e optishift issue?
- power glide
- 4L80e PWM
- 80e swap help
