View Full Version : Automatic Transmission
- Patrick G?Best Gear for bolt on A4 with TP4400?
- Who here has driven both a ST3500 and a SY3500 ?
- a4 seems to be shifting prematurely with the Yank.
- TAGirdle Install - Tips or Tricks??
- 4L80E experience and/or comments, I'm planning on getting it.
- Which gear ratio for SY-3500??
- FLP level 3 Trans. what is it rated too?
- Anyone in the SouthEast wanna trade their M6 tranny for my A4?
- Yank Stall Speed Change
- Flexplate recommendations
- 4L60E Vacuum Shift Modulator ...benefits ?
- ST-3500 rocks!!!!!!
- Good place in Houston to install TransGo shift kit?
- TH350/400
- Have any of you A4 guys heard this noise on your 1-2 shift?
- Best Shift Points???
- ST-3500 users having any trouble codes, limp-home mode issues?
- can someone explain a manual valve body?
- Ratech Complete Install Kit - is this what I need?
- Those with TH350/400 are you sorry you got rid of your OD?
- Transgo shift kit question
- Finishing up 12bolt install, question..
- 4l80E?
- Fully automatic TH350?
- 2.73 to 3.42 swap on daily driver A4 good idea or bad?
- 1LE tranny mount A4 and M6 use same mount?
- Misfires causing lock-up problems?
- Install page for a TH350 swap....
- Trans Brake for 4L60
- I'm about to install BMR torque arm.Help!
- Need pics of B&M Megashifter install...
- Besides the price, will a 4L80E fit?
- Question about 3.73's paired with a SY3500
- Anybody want to swap my A4 for their M6?
- torque conv. install info
- Tranny Fluid: Hot/Cold, Low/High
- Tranny cooler sizes?
- Pics Of Completed B&M Hammer Install
- Those with heads/cam/A4 and 4.10s
- 2000 MY LS1s with Transgo or aftermarket A4 trannies, come in here...
- Converter lock up switch
- Stroker and 2600 Vig converter....
- What Drive shaft saftey loop will fit FLP's??
- TH350 / TH400 swap info........
- switch pitch converter?
- stage IV 4L60E tranny from FLP
- ST-3500 keep hitting the limiter!!!!!!
- TH350 vs TH400...... Whats the difference?
- Big Converter's & Shiftpoints...
- A4 / TP4400 problems....
- TransGo shift kit for 2002?
- TH400 Cheetah Shifter pic you guys have been wanting!
- Need help installing Ripper Shifter....
- How long did it take your YANK converter to come in?
- 3.73's and a PI 4500 or 4.10's and a PI #7?
- TH350 Torque Converter Question?
- Any 12 bolt install docs out there?
- Pyle Bros. (Houston) gear install
- torque convertor question...
- A4 w/higher stall, shift point theory ?
- Anyone have install pics of a PRO 5.0 Shifter????
- ?4.10 or 3.73? in an a4
- Does Vig. have anything to compete against this?
- Help me understand gear ratio's and Torque Convertors
- will my flp level 4 tranny from my ta work on a auto c5?
- Flashing SES light,converter not locking up!
- 2.73 with ST3500 vs. 3.73's with SY3500
- What convertor should I get?
- 1st impressions: Ed Wright tuning w/ "line pressure/TPS mod, 3.73's
- A4 bogs after 1-2 and 2-3 shift after vig2800 and TransGo shift kit installation.
- Finally, ST3500 in
- Do you think its worth it to swap m6 to a4??
- CONVERTER install on a 00 Z
- 4L60E Rebuild, what to upgrade?
- What size stall convertor does your A4 have
- My thoughts on switching converters
- TH400
