- 4L60E oil pump
- TH400 guys chime in PLEASE!
- th350 convertor ?
- firebird tranny bolt up to an ls1?
- Is my trans going out?
- Po757 after a stall converter and how to remove it in hp tuners
- help identifying converter
- 4l60e broke?
- Does anyone have a pic of a 4l80e shifter cable?
- No second gear
- TH400 tranny shield
- Lock-up converter question
- 4l60 rebuild kit advice
- Built 4l60e's
- Broken Case on TH400
- what tranny do i have
- th 400 VSS- what vehicles?
- have a question about a transbrake???
- Complications with my 4L60E.Pushed it too hard???
- Who is using tractor fluid in there trans?
- Torque Converter Going?
- programming question
- Stock 4l60- Corvette servo already in it ?
- 5 Bellhousing Bolts used for TH 400? (SEE PIC)
- Vibration in Drive and OD in higher rpm range.
- m6 to th350 swap. SEARCH SUCKS!!!
- How long can you idle a 4L80E that has pumped itself dry through the cooler?
- Help my ID Transbrake manufacturer
- TC Installed
- Are pump bolts a one time use?
- GTO (AKA LUMINA) tranny swap
- Still have problem and need some help
- bucking issue
- Circle-D 4C goes 1.59 60'
- stock tranny slips going uphill
- rossler 4l60e???
- Anyone have exp. with zpak clutch kit?
- how can you tell the difference in the 4L80's?
- 4L80 low profile pan???
- 4l60e question
- did 4l80e swap and vibration diagnosis help
- tci flex yank tc install help
- C5 Converter Installation
- Question for guys with stall and cam
- 4L60E problem
- Stall for street car LT1
- temp gauge wiring
- crazy flexplate question
- Trans cooler line "E" clips
- Trans cooler....
- Just bought a Yank SS 3600....
- what are the 4L80 ears?
- th400 with converter whine?
- 4L80 how much rwhp stock?
- Verification Request, just to make sure
- Newbie question rebuild or buy new?
- FTI Converter Beat the Heat Sale!!!!
- TCI 6 sp auto
- hey quick question
- Pro Form transmissions?
- Tci superstreet fighter
- 700r4
- driveshaft length
- 6.0-turbo 4oo with mid engine plate
- Pontiac TH350 or Th400
- Clunky torque converter? Help!
- 4L80 RMVB w/ transbrake build questions
- 10 second capable - highway friendly, not M6...
- th350/th400 dipstick able to be modified for 200-4r?
- 94 z28/4l60e soft 2-3 shifts
- best th400
- Car won't go into gear and strange noise
- quick flexplate question
- Speedo Question
- Is my trans shot AGAIN???
- 4l60 problem
- TH400 Hurst Shifter w/ Auto Console *Pics*
- extra p in PPRND21??
- What transmission comes in the V6 cars?
- pro form trans?
- Another 4l80e swap question...
- Anyone interested in a TH350/TH400 vs 4L80e test?
- 4l60e rebuild kits
- 4L80e - Trans cooler fittings...seals?
- FLT level 5 4l65e or Performabuilt's level 3 4l65e????????????
- Yank SS4000 vs PT4000
- Tranny brake???
- Art Carr 4l60 problems
- Wierd Transmission problem
- th400 vacuum source on LQ4??? Help!!
- Trans builders inside please
- What would be a good rebuild kit for 4l60e
- Yank3200 and Stage 2 tranny installed
- Who runs a TCI TCU?
- 4l60E Tranny tugs while going uphill
- cracked 4l60 tailshaft while installing poly mount
- TH400 help. TBRMVB blows up case. On #4
- TH 400 power tuning books?
- stupid ? and i searched .. how to remove stock torque converter ??
- Hot specials at Yank
- Warranty question
- TH400 swap ?
- help
- Installed the level 2 performabuilt today
- Convertor Lock up on the dyno..
- th350 driveshaft length?
- help transgo hd-2 question
- how do you determine optimal shift points
- Front pump question!?!
- DO I need a flexplate??
- lt1 trans into 99 ls1 trans am
- tranny quik question
- problem from 2nd to 3rd at wot
- TH400 deep oil pan
- changing 4wd to 2 wd 4l80e
- Performabuilt LVL 3 Good For Daily Driving mostly street car????
- Diablo tune
- Rebuilding my A4 myself...Hints?Tips?
- th400 crossmember(BMR) WTF
- Tranny Problem???
- does any one make a barbed trans line fitting 4l60e
- delayed shifting?
- tune after stall
- anyone ever use a B&M racing overhaul kit?
- Where to buy TCC solenoid??
- Stall decisions
- Need help 4l60e
- How Do I Use the Ratchet Shifter in our '73?
- 4L60E wont pull!?!
- Cradle Drop, Trans Swap?
- stall now or wait on tranny and stall
- Please Help!!
- My experience with TH350 swap into 98 Z28
- Cost $$ Converter Balance
- TH350 vs TH400 / speedo
- Th400 trans lines
- Tranny or Tune? Lame 4L60E inside!
- Need help repairing new trans
- Overdrive Tranny Slippage. Is this Normal?
- Need help with th350 coverter to 98 flexplate
- 97 LT1 T/A Auto tranny help?
- Convertor interchange - need fast answer
- Broke Transmission Converter still good?
- 4l80e Question
- Bang bang 4l60e
- Anyone running a pt4000 w/spray?
- help?? will a truck Tranny work
- Win a LT1 or C5 converter 4l60-e converter
- lookin for a thread on swap
- Vendor for TH400?
- Question about Shift Kits
- C5 Vette 4l60e Torque Converter work in a 4l60e F-body?
- Converter Question
- 91 4l80e
- Probelms with shifting automatic tranny
- People with Powerglide, Get In Here.....
- How About PTC Converters???
- stall question
- strange tranny noise
- Floor shifter questions (Automatic)
- th400 question
- Recommended ATF for Braked 350
- Any Ideas?
- Tranny ?
- 4L60E to th400 computer changes?
- Right shift kit?
- 4l60e help
- Strange tranny problem
- Th350 Trans lines legnth
- whos the best
- Downshift to 1st taking too long 4L60E
- 6L80 problem
- Trans help for l92
- Changing ATF
- More Transmission Problems HELP!
- torque convertor problem
- Well i thought i had this figured out.
- Built 4L60E Transmission Issues at the track :(
- Need oppinions on building my Transmission!!!
- Could this be a broken flexplate?
- Problems w/ tranny(4l60E)
- Transmission cooler Question.
- 4l60e
- Name of the seal?
- Tci 3800 sc
- Performabuilt Trans is finally in....
- Noob question, how to check atf level
- second cable coming off shifter?
- L460E leak
- Installing RMVB in th400..
- Do you need a LSx 4L60e?
- trans busted
- 2-3 shift problem. not engaging smoothly
- what tranny is in a '94 v6 camaro
- Performance tuning settings for 4l60E
- Perplexing Problem After TC Install
- converting from auto to manual transmission
- Best converter for me? size?
- 04 Suburban 1500?
- What would you do?
- Would you keep the level 4 or...
- Still wondering why I hear about manual shifting of 4l60e?
- Transmission slipping, now engine wont run
- High flow tcc?
- M6 to A4 swap
- 4l80 pressure problem/soft shift problem
- Best place to mount ATF temp sensor
- B&M Electronic shift kit
- "The Beast" died.
- Vibration in 3rd only
- what type of ATF
- THE Good,bad and the ugly on FUDDLES???
- how much power???
- NEW Stage 2 Tranny & stall!
- NOT down shifting at WOT
- Need help bad... before something breaks!!
- Vig 3600 owners-60' time check
- Checking the Tranny Fluid
- Yank PT4400 whining after install. Is it OK?
- Help!!!
- 4l80e troubleshooting
- P1870 code
- Help! TH400 Tranny & Flexplate Shield in 02 Trans Am
- str3600 LS1408
- Billet SFI approved flexplates from FTI
- auto to manual valvebody
- B&M tranny cooler install
- stall+long drive
- hitting the rev limiter question
- input shaft seal?
- What Shifter Do You Have?
- Leaking trans fluid out of output shaft
- LS1 and LT1 4L60E differences
- bad pump?
- Bellhousing bolt size?
- Which shift kit for my 93 z28??? Need help
- Launching issues
- tranny problems
- Derale pan on 4L80e
- M6 to 4l80 speedometer ?????
- LS1/TH400 neutral safety switch
- Help Setting Up SGI-5 C Speedo Cal. Box
- best th350 rebuild kit???
- Converter Queston
- perm. trans pressure gauge
- Trannsmission won't take fluid.
- 4l80e and th400 questions
- Which 4L60E am I looking for?
- 68000 mile tranny-4000 stall and cam ok?
- Just had tranny job car still lunging.
