PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 [158] 159 160 161 162 163
  1. Is there an A4 LS1 tranny that will hold the repetitive abuse of 480rwhp and 500rwtq?
  2. Thanx FLP
  3. weight of a stock 4L60E Converter???
  4. weight of a stock 4L60E Converter???
  5. A4 guys in here
  6. Driveshaft installation.. problems?
  7. M6 to TH400 Difficulty Rating (Do it yourself ?)
  8. Stall talk YANK vs. Viglante
  9. Come see the new Yank Super Stock converters!
  10. Is this possible with a converter
  11. converter question???
  12. Hitting Rev Limiter on A4
  13. weight of stock A4 tranny please
  14. M6 to A4 conversion?????
  15. VIG 3600 WITH #7 PUMP
  16. Torque Convertor...Should I?
  17. 4L60E Upgrade questions.
  18. 4L60 tranny line question
  19. WTB: Vig3200 or Vig3600.....
  20. How neccesary is a TA cover with installing 4.10s???
  21. Any H/C A4 guys still running 3.23's?
  22. Vigilante and Corvette
  23. flexplate/tranny shield?
  24. Installing adj master cylinder...
  25. trans temp
  26. CONVERTER QUESTION
  27. 4L60E rebuild complete!
  28. Installing Deep tranny pan, NEED HELP
  29. A4 kickdown points on the highway
  30. Installed TT3000 and now I have no 1st, 4th, or lockup...
  31. Torque Converter and Dyno Numbers?
  32. Had Trouble With the 2-3 shift at the Track. Will Drill Out Mod Help?
  33. How much did YOUR TH400/TH350 swap cost...
  34. Stupid trans cooler!!
  35. stall converter
  36. th350 or 400 conversion
  37. Where can a find more info on the new Yank SS converters?
  38. who sells midwest converters
  39. Shifter: 2002 F-Body A4 4L60E
  40. no 3rd gear, is converter ok?
  41. TORQUE CONVERTERS ?
  42. Which converter
  43. Who sells Cyberdyne tranny temp gauges?
  44. yank tp4400 install help
  45. SY3500 Unlocking and Hard Shifts
  46. I have a strange torque converter question
  47. Insertion of Dipstick Tube into 4l60e
  48. Whats the difference between 200-R4 and 700-R4?
  49. 4L60E Internals question
  50. Getting ahold of mike at Yank
  51. Vigilnte3200 to 3600? Changes in Performance
  52. 4L60E Rebuild kit...?
  53. what causes a converter to "balloon"?
  54. Yank A4 tranny x-member
  55. How to build a A4 to take manual shifts....
  56. TH350?????????
  57. Manual shift for A4
  58. WHAT CONVERTER
  59. New converter from Yank
  60. Help, Vig 3200 and 2.73
  61. Best 4L60E rebuild kit available?
  62. Please recommend me a new converter for my combo...
  63. Any ideas on a mod to keep A4 from downshifting?
  64. Level 10 PTS solenoid
  65. Pressure Control Solonied Electrical Code in PCM
  66. converter lock up
  67. car shudders when converter locks
  68. will a good 4l60E shave any ET?
  69. Can I mount a temp sensor
  70. 4L80E transbrake question
  71. Install Yank and Lose 3rd & 4th gear??
  72. 4.10 gears installed in my '01 C5
  73. adj master cylinder install
  74. cracked tailshaft housing TH350...weld it?
  75. People who have done the A4 to M6 swap, inside please...
  76. How much to expect to pay for 4L60E rebuild & upgrade??
  77. A4,2.73s,Buy gears or converter???????
  78. A4 gurus,inside please.....
  79. YANK or FLP 4L60E?
  80. Replacing M6 with A4... which tranny to go with?
  81. Possible 4.10 install problem ......
  82. did a4 to m6 and have questions....
  83. stock A4 going out?
  84. will the vigilante 2400 work for me
  85. What stall converter would you run?
  86. Stock tranny and Stall question
  87. trans pump install???
  88. CONVERTER LOCKED OR NOT???
  89. converter questions
  90. trans problems after cam install
  91. anyone with th350or th400 conversions 1/4 mile times!!
  92. Converter for Nitrous
  93. 3.73s in A4 daily driver questions
  94. converter ?
  95. Wight of a converter....
  96. TCI Converter more efficent than a Yank???
  97. Gear install in North Alabama
  98. Best place to get quality TH400
  99. 8.8 Ford Rear installed PICS
  100. I don't want to get bored with a new verter.
  101. converter lock up questions.....
  102. Install of 4.10 gears
  103. Yank TH350 versus Standard TH350...what's the difference?
  104. HELP!!! A4 TRANS FAILURE
  105. how to test converter and trans pump
  106. auto tranny temp
  107. What Size converter for my setup? YANK
  108. TCI converters exposed, Part II
  109. FLP or Yank 4L60E? Opinions wanted please?
  110. Trany Temperature Monitoring
  111. Speed Inc race 4L60E tranny owners step inside
  112. SHIFT POINT PROBLEM
  113. CONVERTER HELP ASAP
  114. Technical converter Question
  115. Vig3600 for my '01, work in a '97 f-body???
  116. '02 Z28, A4, 2.73's, all bolt-on's, converter or bottle?
  117. 3.73s and affect on converter
  118. shift points going from 2.73-3.73's
  119. Has anyone ever used an Art Carr converter???
  120. Converter Experts >>> Question about stall
  121. Help guys.. My driveshaft vibrates hard @100+ mph after new 12 bolt & DS install.
  122. How much Horsepower can the 4L60
  123. Why does it seem that everyone I know w/a stall blows there tranny?
  124. How many quarts to add on fluid change on A4 ?
  125. ST3500 Questions within
  126. M6 or A4??
  127. What is the most efficient auto tranny out there.
  128. Flexplate differences
  129. What type of switch for manual converter lockup?
  130. New mods installed (Pro 5.9 and TQ arm).. Pictures!
  131. Mcleod Master Cylinder and drill mod install??
  132. torque converter...????
  133. WHEN DO I NEED A TORQUE CONVERTER??
  134. vig3200 problems
  135. Hookers and TP4500 installed!!!!
  136. any thoughts about th350 behind stock internal ls1?
  137. when you installed your ripper did you use set it to "rear" or "forward" spacing
  138. Best MPH converter
  139. converter vs. tranny life?
  140. anyone running a vig 3600
  141. Transmission flush worth it??
  142. how do you flush out a converter?
  143. I just installed a New 9inch Moser Rear end but do I need a new drive shaft because
  144. Anyone have a list of torque specs for 12-bolt install?
  145. Keep the Vig3200 or go put in the PYE 3800
  146. stages of a bad A4 tranny?
  147. Tranny Going Bad? Maybe Converter? ST3500
  148. What Converter??
  149. T-56 conversion kit + installation = $2100
  150. tranny / converter problem
  151. what is the transgo pt# for their shift kit?
  152. Gears or Converter?
  153. Converter question, technical....
  154. need site or posts on M6->A4 conversions
  155. PY3600E Flash Stall?
  156. How many passes on your Yank ST 3500
  157. Bad Vibration Under Converter Lock Up
  158. doing 700r4 swap soon, anybody tried this yet?
  159. Converter install
  160. Vig3600 that inefficient?
  161. which converter should i get......
  162. Flywheel Install/balance issue PLEASE HELP
  163. motor and trans going back in today, need answer for trans flluid
  164. how to install tranny cooler
  165. How easy is it to install a TransGo shift kit?
  166. Just installed Mcleod Twin Disc, opinion.
  167. If I change from a 2.73 to a 3.42 rear, do I need to adjust shift points?
  168. anyone use the slp 3300 torque converter
  169. What is the fastest anyone has run with the FLP tranny?
  170. Gear install
  171. A4 guys with Ported MAFs - Read This
  172. too much converter?
  173. just ordered extreme 4l60e from speed inc.
  174. 18 MPG with 4400 stall
  175. TBYRNE'S Super Yank 3400 Extreme......
  176. TH400 guys, I need your help!!!
  177. how many 4l60e guys and have broken the tail shaft?
  178. Which Converter and Street ET's ??????
  179. going to drop 2k on a tranny, speed inc or FLP, help me decide
  180. Hit the limiter on 2-3 shift (A4)
  181. Bearing Heater for 12-bolt install rather than press
  182. Maanual Valve Body for 4l60E!
  183. which is the better convertor?
  184. MW converters,alot of good talk....
  185. Anyone intrested in swaping an A4 for my M6?
  186. converter and gearing choice
  187. Converter question....
  188. question about convertor efficiency
  189. Jegs has TH400
  190. help me choose a new converter
  191. Problems after Vig 3200 and SLP LT's...HELP!
  192. Crossmember bolt size(A4)...anybody know?
  193. Yank SY3500
  194. A4 trans oil circulates through the cooler.....
  195. 6-bolt A4 Flywheel for use with PY3600E
  196. best converter for motor and nitrous?
  197. Should there be a HOLE on the bottom of my auto tranny?
  198. Ordered a VIG3200 last week...
  199. Is it possible to adjust the firmness of shifts with the FLP IV trans?
  200. What converter should I get?
  201. 2002 with vig 2800
  202. SLP "3300 YANK MADE" Verter
  203. ST3500 vs. PT4000 on heads/cam car??
  204. How many have ~400RWHP and still have the stock 4L60E?
  205. Torque Converter Rebuilder?
  206. Vig High Stall converters
  207. FLP IV transmission is in along with VIG3600
  208. swap diff unit or just gears? A4
  209. 4L60E Bellhousing:
  210. 4000 Stall: put Slicks on, dropped .35
  211. Midwest 3200 installed
  212. A4 Guys with Hypertechs .. ??? Help ??
  213. What race preped 4l60e is everyone running?
  214. Converter Suggetions???
  215. A4 to M6 swap conversion kit! Where to buy?
  216. Thoughts on 200R4?
  217. What Stall to use With this?
  218. Hughes torque converter
  219. 200R4, who us using it in the 4th gen?
  220. ABS INOP lights after 12 bolt install:
  221. Adjusting line pressure via LS1Edit with aTrans Go Shift kit
  222. TCI LS1 Torque Converter
  223. installing shifter
  224. 4.10 gear install cost???
  225. Owners: Vig3200 and Vig3600 (questions)
  226. People who have an FLP IV trans, come inside
  227. TCI converters exposed!
  228. Converter swap number 12
  229. th400 guys what converter you using? yank plate?
  230. TCI LS1 CONVERTER = TOTAL JUNK !!
  231. Torque Convertors???
  232. what tranny for 700+ ft-lbs
  233. Paging ALL TH400 Users!!!!
  234. Is it possible to customize the gears in an auto tranny
  235. gears for A4 Supercharged C5
  236. Weight difference: TH350 vs. TH400 vs. 4L60E
  237. 2-3 SHIFT SOLENOID FAILURE SYMPTOMS
  238. Whats wrong with my Pro5.0- Spring pressure??
  239. Trans cooler Question
  240. anyone have any before/after dynos when installing a 9" ford?
  241. Tranny temp guage install Qs.
  242. Considering another converter swap. ST3500 - Vig3600
  243. 2000 TA with TH400 in place of 4L60E with problems
  244. th400/ get trans brake?
  245. th400 please explain why to get 275 1st gear??
  246. Just bought 99T/A A4, What gear do I have?
  247. WHICH TORQUE CONVERTER??
  248. Transmission mounts, A4/M6 same?
  249. Recieved my VIG3600 today, HELP!!!
  250. I want an A4 for the track!!!!
