PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 [154] 155 156 157 158 159 160 161 162 163
  1. T56 swap or converter
  2. wrong stall?
  3. Has anyone bought a tranny from
  4. E.T. differences between the 4L60E and the TH400
  5. where can i get a transgo and supercooler for cheap?
  6. 4l60 shift points
  7. trans shifting problems
  8. How to determine what the best shift extensions are for you?
  9. Turbo 400 w/ Stock 10-bolt w/ 3.42's?
  10. having a converter buit. how does this sound? **update**
  11. Refreshing a converter
  12. B&M Deep Pans
  13. Torque Management Issue
  14. cam and stall speed
  15. I need information on a shifter for my 2002 A4 Camaro
  16. Installing a TC and trans cooler this weekend... tips?
  17. Where can you get a lockup TH350 converter? anyone used?
  18. Can my 4000 stall cost me 30 rwhp over a good stall?
  19. Best place to get a 4L60-E?
  20. How long has your stock 4L60E held out?
  21. need help REALLY bad!!!!
  22. Predator & Vig 3200--'02 F-body
  23. TH400 Reverse Pattern Valve Body Question
  24. TCS 3500 or TCI 3500
  25. Safety Question
  26. fittings on B&M BIG trans cooler...
  27. SY 4000 or TCS 4400
  28. Does anyone have a Pace 4L60E w/ 2300 stall?
  29. PT4400 = Installed...
  30. Just broke my IV tranny!
  31. transgo reprogramming kit----full manual control????
  32. Leaky transmission, let's play where's the LEAK!
  33. What's the most miles a 4L60E has went without failing?
  34. Can you calculate converter slippage from dyno??
  35. TCI Deep pan for 4L60E
  36. RWHP between 6-spd vs Th350 4000 converter??
  37. Questions about stall speeds and STR?
  38. 4L60E 3-4 Clutch SetUp
  39. Those with Transgo Shift Kit
  40. I installed a 3000 tci in my 2001 SS
  41. Lost drive and overdrive on my new 4L60! Anyone?
  42. any trans brake for a 4l80e
  43. New problem with converter?
  44. Trans brakes for 4L60E's
  45. What stall for me?? H/C/Boltons
  46. Did messing with my MAF screw up my tranny?
  47. Anyone have the scoop on the beefed up 4L65E the GTO get?
  48. Anybody here heard about doing a 4L65E swap?
  49. TCI users in here
  50. TCS Converter Users Come Inside
  51. Please define "loading the converter"
  52. SY3500 install
  53. Lets talk about the Vig 3600 #7 pump converter
  54. If money wasnt an issue, would you buy...
  55. Feels like tranny is "slipping", HELP!!!
  56. Having tranny installed tom (A4) any tidbits?
  57. Remove TM?
  58. question about manuel vs auto
  59. Going from a 4L60E to a Turbo 400, tuning?
  60. Dynoing w/ Converter: Locked vs Unlocked
  61. Spraying with a stock 57k mile 4L60E?
  62. fluid?
  63. converter 2800 or 3000 on stock cam
  64. shift firmness poll and suggestions
  65. Ordering B&M shift improver
  66. TH400 BEHIND A 6.0
  67. Big problems
  68. Lost 70rwhp after swapping converters?
  69. 4L80E question.
  70. Dropped Trans Pan = Trans feels weak
  71. M6 to A4 swap question.
  72. Installing a tranny pump.......how hard and
  73. Manually shifted A4 at the track with odd results..
  74. a4 tranny (4l60e) stock shift points in RPM (i found em)
  75. Tranny free spun today while driving...
  76. which transcooler to get?
  77. question for the a4 gods (very basic but hard to find)
  78. A4 experts
  79. Best 60 ft's pulled N/A /w TCI SuperStreetfighter converter?
  80. B&M Trick Shift Users?
  81. Got the TransGo installed, and I like it
  82. Trans cooler w/FTRA
  83. 1-2 Accumulator spring ???
  84. How do you determine when a built in fan is needed?
  85. What makes Yank the best over other competitors?
  86. Looking for some strong 4L60E parts.
  87. ....Daily Driven TH400 users withing.......
  88. missing 2nd gear
  89. Little problem with th400
  90. vacumn hose on 4L60E
  91. what converter and gears do i need?
  92. lost my tranny dipstick plug...part number???
  93. Transmission Fluid for a 4l60e
  94. need trans cooler?
  95. Clearance Question
  96. Building a Better 4L60E
  97. Tranny cooler ?s Non LS1 related
  98. what year of truck pan will work on my 98 Z A4
  99. Which tranny?
  100. what size is the line on a 1998 Z28 A4 3/8s or 5/16s
  101. Where can I find 4l60e installation instructions?
  102. yank converter in 02 car
  103. Did I over stall my motor?
  104. 1-2 gears feel like your standing on the brake?????
  105. Tranny Cooler
  106. Tranny problem?, 'scratching' between 1-2 on hard accelerati
  107. huge convertor slip with new engine/fresh tranny and no L/U
  108. Broke the trans pump??? Here is how to fix it..
  109. break in for new converter?
  110. How cool is too cool for transmission?
  111. Is a shift kit a good idea?
  112. my 4l60e is down for the count
  113. Best rebuild/new options?
  114. 3qt. Pan Does anyone besides B&M make one?
  115. Deep pan or a tranny cooler
  116. built tranny now having problems on start up... Please help
  117. Disable the converter lock-up
  118. Is this cooler enough?
  119. TH400/TH350 users
  120. Precision converter pumps
  121. Installed new cooler today!
  122. Torque converter hard to turn on input shaft when fully on..
  123. Got my transgo today
  124. Question on my FLP LEVEL IV trans.....
  125. PTC,LS1,2800 STALL
  126. Best Tranny fluid /// synthetic or not?
  127. Question about STR and converter efficiency
  128. 1-2 and 2-3 lag between shifts, what's wrong
  129. What size tranny cooler?
  130. Trans lock up probs
  131. Stock Trans Cooler Flow ?
  132. Transmission settings?????
  133. Pic of B&M shifter
  134. Trick to removing the stock converter?
  135. 4L HP CAPACITY
  136. Trans Went South on the Z-71
  137. Shifting problem from 2-3
  138. Tranny Coolers Help
  139. Built tranny and higher line pressure?
  140. Tranny Swaped. No reverse lights?
  141. T-56 ---> "Built" 4L60E conversion?
  142. name this part
  143. Those with a 400T, did you have to shim it up?
  144. Planning to install a TC, what stall best for my application
  145. what gears with Vig 3800? 3.42's or 3.73's?
  146. does my converter "lock up" by itself or is their a button??
  147. help me pick better stal for my th350!!
  148. 2 questions (tranny issues help)
  149. racing transmissions sponsor?
  150. For those that are running between 3200 and 3800 stall speed
  151. Most bang for the buck converter?
  152. Opinions wanted - Yank 2800TT 3.0str on a stock Z28?
  153. Your opinions on the TCI 3200
  154. buying a t.c from t.c.i #242932
  155. Manual lockup wiring diagram
  156. What th350/400 n20 converter are getting 1.4 60 ft's with??
  157. about to buy new tranny, PLEASE READ and reply
  158. TH400 Trans Brake
  159. Tranny cooler...
  160. Should I stay an A4 or go M6
  161. NEED HELP!
  162. Harlan's 2-step Doesn't Exist!
  163. Extreme 4L60E stage 3 hits going into D or OD!!!
  164. Where to buy TCI converters?
  165. str?
  166. Yank vs TCS
  167. will vig restall a 3200 to a 3600?
  168. Vig Stall Upgrade
  169. Help me pick a converter please
  170. Anyone ever heard of, or used a COAN converter
  171. Need help! truck wont move with 3200 stall!
  172. How to get speedo to work w/ TH-400 tranny?
  173. Hope the breakup of A4 and M6 is useful
  174. switched from ST3500 to Vig3800...et difference?
  175. Cammed cars with stock converter
  176. Locking and Unlocking????
  177. what year 200 r do you want to use for swap
  178. Does SLP's gear/speedo recalibrator also change A4 shift pt?
  179. Did I do the right thing,kinda long???
  180. What TQ Converter?
  181. TCI OR MIDWEST?
  182. Question on installing a 3500 Stall Torque Converter on a A4
  183. Help!!!
  184. turbo 350 or 400?
  185. Tranny Question
  186. Need New solenoid
  187. VIG 3600 & 4.10s
  188. Anyone with a 4L80E?
  189. Will TH400 bolt right in?
  190. Installing A4 dipstick
  191. How hot is too hot for auto tranny?
  192. Is this too much stall?
  193. Who all makes shift kits for a 200R-4?
  194. St3500 vs ST4000 vs SY4000 vs Vig4000
  195. Going back to stock gears and verter. 373 to 273.
  196. most stall and STR on street w/ 315 DRs
  197. problem getting lokar dipstick to seal
  198. Any harm in driving with the torque converter always locked?
  199. trans go = best shift kit or no?
  200. A4's durability with stalls and headers?
  201. Vig 3600 installed!
  202. To big of a stall
  203. Track times with Vig3600...hoped for better
  204. Do ALL 4L60E's bolt up to an LS1 motor
  205. Yank 2800 any good?
  206. PYE3600 users inside?
  207. trnsmission shops frown at T.C and shift kit install
  208. Took my car to get converter in (Need feedback)
  209. T56 shifting less smoothly since 9" install. *DELETED*
  210. wow...1 bolt killed my tranny....pissed!
  211. Best tranny cooler for a 200R-4?
  212. Just out of curiousity...do performance flexplates exist?
  213. suggestions for A4 tranny problem??
  214. who builds the best a4 tranny's? opinions please
  215. toasted trans need advice!!!
  216. PT owners...I need help with my PT4200
  217. Paging: All non-stock A4 guys
  218. Buying a BUilt 4L60E worth it?
  219. Where can I get a 200R4 for a core exchange?
  220. Size, type, brand, etc. converter for street/strip 200R4?
  221. What type of pressure plate bolts for Fidanza?
  222. Life With a Converter, What Do I Need To Know? (Maintenance)
  223. Install writeup on Moser 12 bolt??
  224. My Vig3600 isnt what i though it would be.....
  225. Converter shift extension
  226. How many bellhousing bolts for the 4L60E
  227. Transmission Flush: How good is the all purpose ATF ?
  228. Converter Switch: Vig to TCS
  229. 12 bolt 3 channel abs installing in a 4 channel car?
  230. 2-3 shift problem, please help...
  231. Best auto for the street but will hold up to the track?
  232. Ram 6130 Installed..I
  233. Silly question about tranny cooler
  234. How do you pick a converter's stall speed?
  235. TCI Converter Failure, questions
  236. Where to get an aftermarket shifter/knob for an auto.?
  237. Do they make high performance flexplates and...
  238. Where can I get a custom built converter?
  239. Anyone running a 200R4?
  240. installing mcleod master cylinder question..?????
  241. Any place to put tranny temp besides drilling pan??
  242. Vig. 3200
  243. Yank SS3600 track results...
  244. anyone have the converter lockup switch diagram
  245. Just installed Vig3600....Trans temp really high any ideas??
  246. stock stall speed
  247. WHICH CONVERTER TO GET?
  248. A4/3.42 gears need help
  249. Could my converter be slipping like mad?????????
  250. PRO 5.0 INSTALLED!
