View Full Version : Automatic Transmission
- shift knob?
- Flexplate
- Who can do a torque converter cut and clean - how much???
- Reuse or send off?
- Lots of gray sludge - are my converter and tranny junk??? PLEASE HELP!!!
- clunk when shifting
- 4L80E in a Street Rod project...
- Swapping gears
- Second Thoughts On Buyin a Built 4L60E
- How Many Quarts?
- Data logged my N20 pass... Question about converter and Trans.
- traction?
- Thinking about going manual valve body
- Swapping gears
- Flex plate with TH400
- Stall/TC selction ?'s
- Lokar Dipstick
- new tranny break in period
- Circle D - New Street Series Billet Converters!!
- M6>>A4 Shifter cable hole?
- My own fan?
- 4WD 4l80E??? sorry im new to this
- anyone to determine slipping?
- I just got Yanked....
- Limp Mode Under 70degrees Outside???
- adjust kickdown
- 6l80 questions... i searched
- 4l60e dipstick hole
- Rebuilding Trans
- Code p0753 but it runs great ????
- Driving in "3".
- So what did I break in my 4L60E?
- i need help...
- only 1st gear
- Beefing up the 4l60e
- Tranny Removal
- Shift kit
- -8 tranny cooler lines too large????
- finally!!!!!!!
- Keep getting P0757
- Third and forth went out, what now?
- V6 Firebird 4L60E bolt pattern
- Hesitating and/or slipping when downshifting to second
- Which one should I chose? (oil cooler)
- Best bang for the buck converter for a 400 rwhp ls1 fbody street car
- Does cold tranny temp affect shifting?
- Is my converter cooked?
- It'll buff right out.....Right?!
- Royal Purple MaxATF on the cheap
- Fuddle Racing
- How much stall.....and what cam...
- How long will a tranny swap take in my garage???
- Slow Auto
- 4L80e slipping on Dyno....
- A4
- Tranny not engaging in OD, D, 2, 1 or R - please help!!!
- Tranny cooler??
- 4L60E question
- David Childress wins LSX shootout with YANK
- Happy Birthday Frank at Performabuilt!
- 4L80 where,what,year....?
- No 2-3 shift at WOT?!?!?!
- Auto WS6
- AN fittings for transmissions
- 4l60e tranny build....
- 4L60E out of a 90's model truck???=car?
- vibration
- 700R4 stall in a 4L60E?
- Any shops building STRONG A6`s????
- Need help! Anyone in b.c. have a auto tranny for a 94 trans-am, lt1
- 4l80e slip yoke length?
- Anyone regret your 4L80E swap
- Transmission Coolers with Fans
- torque converter?? i have no clue
- 2002 camaro trany tunes with new converter....?
- Paging Performabuilt
- Transgo dh2
- what the hell why is this trans mount on back order?
- tranny problems
- Transmission acting strange
- Frank at Performabuilt!!
- Oil cooler? is it good, this one exactly....
- installing line pressure and temp guage
- 2002 camaro converter question
- 05 GTO stall converter Help
- best of the best
- 4l80e manuel shift/auto conversion
- Torque Converter Lockup Problem..
- 700r4 - 4l60e converter difference??
- fittings from hardline to braided hose? help?
- a4 shifter
- Procharger & Fuddle Hp/street 3600
- school me on TCs
- Is my trans shot?
- help
- 200r4?HELP!!!!!
- v6 cts tranny question/problem
- 700R4 Speedo Question
- 4L60E Hard Line Question
- More trans problems - advice please - 418ci motor
- whats the difference?
- FLT modulator>>?
- More 4L60E Problems
- transmission selection
- Performabuilt lvl 2 trans. and vig 3600!
- Vehicle stability...
- 4l80e w/lock up converter & boost
- I need 4L60E to 95 LT1 bellhousing to engine bolts
- 6-speed to an 4L60 swap
- Whats the best transmission oil to use?
- what stall
- who makes the strongest th350
- th350 and th400 stall converters
- tranny swap
- will it make it?
- FLT60E Goes 9.88@140.86 in a Truck - With Video and Dyno Results
- Tranny Problems??
- 4l65e
- PLease help....Stupid newbie...
- do i need a MVB?
- stall converter brand?
- Problem manually shifting a 4L60E
- Performabuilts New T400w/brake Just Got It
- Converting M6 to A4.... Need help!!!
- I'm confused about 4L80-e's
- Break in period for built tranny
- 4L80E 4WD in a 2WD car?
- TCC slip/duty
- converter suggestions?
- No overdrive after rebuild
- 700r4
- TH400....short or long tail and why?
- lock-up ?
- tranny shipping questions
- no 2nd
- v-6 tranny swap
- TH350 2nd Gear launch - Pros Comment
- 700R4 Help!!
- New Transmission section
- LT1 T400 in LS1
- 06 GTO 4 speed auto ratios
- T.Converter bad I assume?
- 4L60E Swap
- 2-3 shift problem
- Damaged TCC solenoid/need harness?
- YANKs New converter line is here!! Check it out
- 4 rebuild will a vacuum modulator help me?
- You aint gonna believe this trans mount was less then.......
- Update on Race Operations at ACE Racing Transmissions
- Ordered: FTi Converter
- 10% Off any ACE Racing Transmissions Transmission
- flexplate flywheel recomendations
- Torque Converter Bolts are STUCK
- Will this fitting on my cooler hurt the tranny
- Transmission Trouble...Need a little help
- Need some help / advice from the pros
- Identifying a 4l80?
- Transmission handling after rebuild?
- What shifter for TH400 on M6 console?!?!
- th 400 to power glide weight difference
- 4l80e manuel v/b
- strange shift extension
- Car Work and Now Some Funny Noises
- tranny problems
- would a bad rear u joint cause premature trans mount failure
- keep losing 3/4 gear 4l60e
- Cracked flexplate, need advice/ recommendations
- used powerglide... need some help, please.
- How to contact Speartech?
- No forward what gives???
- Look at this 4l60e
- trans help
- Installed Transgo HD-2C not working...
- Circle D - Pics!
- th400?
- Performabuilt or FLT which one would you choose?
- Do you think it's better for me to run out 2nd instead of shifting into 3rd?
- Vigilante converters: Who has the best price?
- 4l80e differnces?
- LT1 4L60E Problem
- So.....
- Converter for 6L90E?
- A4 SWAP TO A T400 shifter car will not start unless I have it wired to the old shifte
- What are the differences between an LS1 and LT1 converter?
- TQ converter in light weight car?
- 4L60E Stall help.
- trans cooler
- 4L60E Fluid Levels
- Did a t400 swap and motor now the car will not start.
- How does a stall work?
- Level 5 4L80 power levels...
- [B]98 TA Auto[/B]
- need to know what this goes too??
- will a 98 c5 trans bolt up to a 98 trans am
- Help with stock 4l60e mods
- Where can I get a 3.43 or 3.73
- No reverse and very little drive - 1993 LT1
- 4l60e/p0785
- Another 4L60E Question.
- how to build a bulletproof 4l80e
- 4l60E problems
- 4l80e
- What would you think the problem is (4L60E)
- Converter Question...Please help
- Torque converter and shift kit
- T400 shifter linkage. How did you run yours any pics
- 4L60E servo size vs. sep plate hole size
- 4L80E Shift kit & manual valve body ?
- Peak torque vs. stall speed
- LT1 4L80 cross memeber w/ t/a mount?
- Ordered my Vig 3200 for my TH350 swap today!
- Just replaced my trans mount man world of difference.
- YANK Converter October specials
- what is the role of TCC
- Hows the trans?
- Yank PT4000 installed
- Replacing Metal cooler line with transmission hose?
- need 4l80e suggestions
- question on 4l60e
- 95 Z28 aL60e
- Fuddle
- TCC lockup at the dragstrip
- transmission swap
- Average Cost for a restall
- T-400 Converter question
- 4l60e from caprice or roadmaster
- cant 60 with my vig 3600
- Need a little help with a TH350 Transmission
- in my Lumina (Like GTO and Commodore) th350 or th400 ??
- .490 boost valve
- What Stall To Go With???
- yank convertor problems 4l80e
- Stock 4L60e questions
- tranny wont hit going to 3rd (a4) after cam install
- Help me decide on a 350
- Help Me decde whether im best with Auto or manual
- Sponsors Need A New Trans Th400 Or Maybe A 4l60e If It Will Take Serious Abuse .....
- 6-speed to th400-dipstick and tube
- More converter and gear?
- PICS of T400 tranny lines. Or what did you do with yours
- STS transmission
- quick ? on my 4l60e
- M6 Pilot Bearing Still in There
- gearing problem
- Launching with a stall
- TH350 shifting problems
- Rossler TH400 installed
- Circle D getting the job done...
- LS1speed Flexplate?
- how fast on a 60-e
