PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. What transmission will work with my 06 lq4
  2. LS3 swap into 01 Z28. Best flex plate?
  3. 4L80 swap guys
  4. 4l80e teardown, inspection and rebuild
  5. 4l60e install
  6. reluctor ring added to 4L80E?
  7. What else is necessary with a stall?
  8. 4l60e rebuilt but just lost reverse
  9. 4l60e skipping second gear
  10. th400 converter question
  11. 4l60e behind a lq4?
  12. 4L60E not going into 2nd under wot
  13. Problem shifting out of 1st
  14. 5.3L / 4165e Shifting issues 2nd to 3rd
  15. Who wants to sell me a transmission?
  16. QUICK!! Tech - Help me pick a converter
  17. Am I seeing trans slippage? Pics inside...
  18. Trans compatability
  19. Trans cooler between radiator and condenser
  20. 4L80E experts: overheated forward drum
  21. 4L80E weird shifting
  22. 4l60 with lt1?
  23. Please tell me if this setup will work :pics:
  24. 2005 envoy 4l60 into 2003 Silverado
  25. 4L80e wiring and differances
  26. Needing a 6L80 Rebuild
  27. 4l80e Rebuilt w/ Jakes D1 Brake, No reverse, No 3-4 Question
  28. Torque for Banjo bolts
  29. th400 help
  30. 4L80E rebuild tools: Rent? Make your own?
  31. transmission
  32. 4l80e Accumulator Delete
  33. 1971 TH350 Leak
  34. My new converter has arrived!
  35. Fluid level cold?
  36. TCC slip after rebuild and new TC
  37. Attaching Fan to Stacked Plate Cooler
  38. Hurst Quarter Stick in OEM Console
  39. 4l60e 2wd output shaft w/ or w/o sleeve
  40. 4L80e swap Questions
  41. Best price on yank 3600ss?
  42. 4wd boost launch with 4l80e?
  43. where do i get stock trans mount?
  44. 4L60e not shifting right
  45. 4L80E Running Hot
  46. Need Help on Speartech Harness, connecters not labeled.
  47. 4L80E Rebuild kits: Jakes vs Probuilt vs ???
  48. 4l60e Problems
  49. Stall in a 200k miles 4l60e
  50. 98 4l60E behind Ls1
  51. 4l60e swap help (bolts)
  52. Stall converter question from a newbie
  53. 4L60e Help
  54. Shifter help.... (ppp shifter)
  55. transmission help
  56. Reinstalling trans
  57. C6 Vette 6l80e Paddle Responsiveness Tune?
  58. 2600 stall torque covertor any good
  59. Mystery converter, need it checked
  60. Rebuilding 4L60e, part recommendations
  61. Lots of useful info complete codes troubleshooting and more.
  62. Choosing 4spd for LQ9
  63. Holley Dominator 4L65E Shift Parameters
  64. 2002 SS CamaroLS1 SLP L460 trans
  65. Removing 6L80E from L76 engine. How do I get all the TQ converter bolts removed?
  66. what is needed for a LS1 torque convertor upgrade
  67. Overdrive problems
  68. Problems with 1-2 and 2-1 shifts (4L60E)
  69. New to Autos: Choosing a converter
  70. 700r4 corvette servo
  71. 98trans
  72. 4L80E slip yoke....fully splined rear output shaft....which one?
  73. 4L80E transmission mount.....which is best...?
  74. Converter recommendations for Titan 3 ls3 cam
  75. Converter recommendation for my truck.
  76. Choosing a Converter for my Silverado
  77. 4l60e 3/4 question
  78. I want a transmission termperature gauge set up.
  79. TH400 help!
  80. Converter recommendations please
  81. 2-3 shift again
  82. Bad converter?
  83. A4 top speed run
  84. 4L80E converter locked in Over Drive
  85. Flush or rebuild
  86. Rossler 4l60e trans brake will not engage.
  87. Question regarding internal trans temp sensor on 80e swap.
  88. Seems that my 4l60 may be dying..
  89. Torque converter question.
  90. Slip yoke strength
  91. Car is eating 4L80's within miles. Please Help!!
  92. TCC / Brake switch ?
  93. Corvette lost 4th gear (4l60e)
  94. carbon wideband
  95. 4L60E w/20.10 volts @ pin E
  96. t-56 to A4 swap 98z ?
  97. Sold a bad Trans
  98. Trans/Motor Drop and TC Install
  99. 2000 Camaro SS, just installed poly trans mount
  100. 2000 Z28 throwing code P1860
  101. 4th gen a4 newbie. Code p1870 help!
  102. TH400 Noise Under Full Load From a Stop (Video Inside)
  103. Reputable Trans. shop in Las Vegas ?
  104. 4L60E 1-2 accumulator spring
  105. Help chose converter for cam
  106. 4l80e swap OD neutrals out
  107. 2nd gear feels like its in neutral at low rpm
  108. Gearstar Transmissions. Worth the Price?
  109. 4l80e trans tuning?
  110. 99 4l60E in a 95?
  111. 4l80e separator plate question
  112. Need help with 1981 Corvette with LS3, what trans?
  113. Trans won't shift after pre warm, limp mode? Need help
  114. 4l80e swap complete speedo doesn't work....won't shift out of first gear
  115. Highend Turbo + HIgh Stalled Converter = Fun Street Car?
  116. any street/strip guys regret making the m6 to a4 switch?
  117. improperly seated converter or pump failure
  118. Transmission control solenoids
  119. 4.10 gears and a4 shift points.
  120. Is this a flywheel sound
  121. 4l80e segment swap
  122. Trans comparability
  123. Please let me know if this is normal? Performa stage 1 / yank3600ss
  124. Hard Neutral to Drive, now every gear is drive? 4L80e
  125. No TCC lockup or 4th gear 4l80e
  126. My Conversion T56 to 4l80 and LS1 to LQ4
  127. Having problems with my tranny (4l60e)
  128. 4L80e no 1st, 2nd or 3rd gear- fresh rebuild
  129. Where to get stock trans lines?
  130. Who's conveter to use
  131. help gap between flexplate and torque converter
  132. 4L80E: Can I rebuild one?
  133. Car Shudders/shakes when the T/C is locked.
  134. 4L80e dip stick Mad Man?
  135. Bout To Start 4L80 Swap, Questions?
  136. 4L80E Line pressure rise rate
  137. 4l80e Yoke options
  138. Pan bung location?
  139. ISS speed sensor on 4l80e
  140. 3-4 shift problem
  141. Strange 2-3 shift problem
  142. 4l80e guru's
  143. th 400 swap, m6 program, how to eliminate skip shift code
  144. Flex-plate to Converter bolts bottom out ?
  145. Which servo?
  146. TH400 Leaking from plug
  147. Circle D or Pro torque?
  148. M6 to 4l80
  149. Trans Cooler BTU
  150. Stage 2 transmission
  151. ss3600 to ss4000 worth it? new rearend comimg soon
  152. 4l60E Shift Help!!?
  153. which lokar dipstick for 4l80e?
  154. Lokar dip stick not staying in th400
  155. Tail Shaft Bushing Bad?
  156. Freshly built 4L60E noise
  157. T56 to Th400 swap Speedo working woo hoo!!!!
  158. 4L60E Issues
  159. What converter for 4.8/th400/76mm?
  160. 4L60E 2-3 shift flare solved!
  161. Yank re stall
  162. Transmission cooler
  163. limp mode and converter
  164. 4L80E high line pressures - now stalling in gear again
  165. Rebuilt 4l60e
  166. What yoke do I need 4l80e swap
  167. 4L60E Internal Modifications for 660rwhp build
  168. ES poly trans mount ???
  169. GM Re-manufactured Transmissions
  170. Edge racing converters any good?
  171. 4l60e
  172. 4l60e Sunnax pinless 1-2 and transgo sk4l60e
  173. 4l60e dipstick
  174. No possible way to fit a 6l80e or 6l90e (GM A6) into an f-body huh?
  175. th350 has reverse no forward gear
  176. TH400 no gear engagement
  177. Converter to flexplate space
  178. Did I damage the pump? Trans has no gears what's so ever..
  179. 4L80E Engine Braking Question
  180. Pwerglide to LQ4
  181. No TCC lockup after 4L80E rebuild due to failed alternator
  182. 4l80e without a computer
  183. 4L80E core value?
  184. 4L80E second gear starts except when lever is in 1
  185. 4l80E swap 5.3 questions.
  186. 4L60E high pitched noise w/ video
  187. Problems after rebuild.
  188. Broken Bolt on Pressure Manifold 4l60e
  189. 4l60e hitting rev-limiter
  190. 4L80E TCC stuck locked
  191. Yank vs. Circle D Billet Converters
  192. TH400 for my Honda S2000
  193. Diff in Yank Stealth & SS Series
  194. please help identify transmission
  195. B&M transmission cooler install. Direction of flow matter?
  196. New Converter and Something Loose Inside
  197. WTB- powerglide setup
  198. Best TH-400 Builder/Driving issue.
  199. 4l80e Crossmember
  200. RPM Transmission Upgraded Level VI Installed
  201. 4L60E from 4wd for 2wd corvette
  202. 4l80e transmission builder/options
  203. Bad 2-3 shifts 4l60
  204. 4l60E to TH400 - Help
  205. LY6 Motor, bought used TH400 but found metal inside TC, rebuild or...??
  206. Stall question for setup
  207. about to order an RPM transmission. additional parts?
  208. Question on gearing/converter trapping low MPH
  209. Madman dipstick..were can i get one?
  210. Best 4L80e solenoids?
  211. 4l70 problems
  212. 1000hp 4L80E rebuild kits?
  213. 4L60E feels like going to Neutral
  214. best bang for buck converter
  215. Th400 speed sensor
  216. 4l80e no first/second gear
  217. hydraulic fluid 4l60e
  218. Way to Tell if a Transbrake is Installed?
  219. Trans cooler, looking at derale but still not sure
  220. 4l80e rachet shifter
  221. Recommended shops in denver
  222. 3800 stall good for nitrous?
  223. Tci flex plate for 408 to th400 question
  224. Fresh 2003 4l60e rebuild - skipping 2nd gear and part throttle 3rd gear starts -
  225. Flexplate for 4L80E....what are you guys using...?
  226. TCI converter fail? Help please. Thanks
  227. Rebuilt 4L60E and having issues
  228. 4l80e WOT line pressure high
  229. Installing stall what seals and gaskets should I replace
  230. Converter recommendation.......1,000 RWHP....Stage 4 4L80E...?
  231. th400 yoke question
  232. 4L60E down shift surge?
  233. 4l80e output carrier chipped
  234. Magnets for aluminum pan
  235. 4l60E TCC wont lock up
  236. Th400 question about speedo
  237. 04 2500 Silverado 2WD Shifting and Speedo problem after new trans
  238. Th400 pro brake questions
  239. 4L80E Shifter - 2nd gen Camaro
  240. Normal A4 operating temperatures?
  241. 4L80E How much resistance turning drive shaft? (dynamic racing)
  242. exploded pump
  243. 4L80E leaking from tail shaft seal/bushing
  244. 4L60E to 4L80E Conversion
  245. Quick question(s) about replacing transmission lines (4L60E)
  246. 6.0L/4l80e feels super weak after swap.
  247. 4l60e crapping out after dyno
  248. Yank SS 3600
  249. Stock Camaro Driveshaft to 4L80e HELP!!
  250. 4l60e problems solved.. I feel obligated to share.
