View Full Version : Automatic Transmission
- TH400 speedo question
- is 4200 to high for a 150 shot?
- 4L60E or 700R4 in 1995 Camaro Z28
- For Those With Tci Flexplate Please Help
- 4L60E vs 700R-4....
- what is the trick to get converter to seat
- Which Shifter for a TH400?
- Tranny HELP!?
- When does fluid starvation occur?
- TH-400 Sludge
- 4L60e-> Not shift past 2nd
- need transmission
- Very strange.. Would like input on this..
- Trans mount
- problems with T/C
- Is a 700-r4 the same as a 4l60e???
- polythane tranny mount
- 1800 to 2000rpm stall is stock?
- tranny shifting at 6300 rpm!!!
- Hard Shift from 1st to 2nd on auto tranny
- which transmission?
- The Best Trans. Overhaul kits for 4L60-E?
- Is This A Shift Cable Problem?
- Shift Cable Trouble Please Help
- 01 Suburban - Neutral Switch Location
- factory trans cooler?
- After market shifter?
- Th350 T/c
- Pwm Solenoid
- t-handle shift knob
- trannys gone
- 4L60e no lockup
- TH350 Trouble
- 4l60 or th400?
- Stripped bolt hole
- Major 4l60E Problem
- is my trany gone?
- Tranny Temps Climbing
- If you have been wanting a YANK converter see this
- 700R/4l60 shifter
- Tranny Swap ... but what to?
- More 4l60e ?'s
- th350 in got a question
- 4l60e tranny problems
- What did I break, Converter or Transmission?
- I need a cheap 4l60e core for a rebuild in South Florida
- No O.D.
- wont shift WOT a4
- Swapping Silverado trans to z28?
- Tranny rebuilt, intsall question
- problems with torque converter going in
- 4l60e 2-3 shift problem!!!
- why aint my tranny comming off ?
- need tranny/tqc help
- anyone running this converter?????
- 4l60e Woes please help!!
- Stall Help ...
- where to buy tci controller for 4l80e into 98ls1
- You think you know the 4l60e cont.....
- Doing the coverter. need some opinions
- 4L60-E any solutions?
- Where to buy a 4l80e? Vendors?
- vig 3600!!
- auto tranny help
- indentify the trans in my car - help!
- No Power to Soilnoids 2 and D ( Drive )
- What parts for a blow proof 4L60E for 800+ hp
- Driving RMVB on the street?
- Please help me get this straight....
- transmission cooler
- Tranny won't go in gear, ideas?
- Question about Th400 mount
- need help to find a 2 step
- Help!!!!!!
- Vacuum modulation
- Torque specs for trans mount please
- TCI Flexplate, do I need to sand off the paint...
- Circle D - New Converter Line
- kaboom 4l60E
- Should you hear anything if you shake a converter??
- A4 Won't Upshift at WOT/ Backfiring
- Routing trans pressure gauge line
- Who has dropped the engine/tranny together in from the top?...
- Clunk Noise On Down Shift
- 03 truck 4L60E and a 2000 WS6 ?
- VIG converter compatibility
- Is it my 4L60E or my Fuddle converter that gave out?
- Yet another 4L60E potential problem
- stock 4l60e power
- Low Gear Set for Street Driven 4L60E
- jw bellhousing for th400 to chevy
- Think you know the 4l60? Then I need help.
- NEED HELP ASAP lt1 trans same as ls1
- bellhousing
- trans cooler help
- 4l80 TC lockup with Transgo full manual kit
- Another 4L60E Problem
- Trans or converter problem!!..help!!!
- 4L60E problems
- tci flexplate came with unknown piece?? help
- torque specs for flexplate?
- Help with stall speed and STR
- Will a LS1/4L60E vertor fit a LS2/4L65E?
- What happened to the poly tranny mounts
- transgo shift kit HD2
- Trans temp difference??
- 6.0 to tranny??
- wich torque converter for my setup???
- wierd trans problem?
- whats all need for repair? codes thrown!
- M6 to 4l80 (pics)
- Is there anyway to tighten up my YANK 3200?
- Tranny rebuild ?
- 4l80e 00 vs 04 and what to keep from 4l60e
- It just wont make the 2-3
- any ideas?
- Question about Vigilante and nos!
- write up on installing a tranny cooler?
- Need some advice on a stall....
- WOT 1-2 shift
- whats wrong with my trans pic inside(4l80e)
- B & M T-Handle
- MS4 + 3800 STALL = What shift RPM
- What cooler and how many?
- Trany Fluid
- 4l60e trans lines
- Yank SS3800 won't lock up
- Whos gone from a 3200 Vig to a 3600 Vig or vice versa? Why? Results? N2O users?
- Guy's with FLT or built 4L60-E, Thoughts?
- Converter flashes too low
- Anybody make a postive lock shifter for 4th gens?
- 4L60E shift problem
- troubleshoot this problem for me please!
- show me pics of your 4l80e installed
- Need some help... converter won't lock
- tranny cooler?
- m6-4l80e swap (shifter problems)
- A4 C6 Not shifting to third
- 24 bm transcooler
- Adding stall to stock 4l60-e reduce its life?
- what converter with my cam?
- chevy 6-speed automatic?
- ls2 to 4l80e
- TH400 install in progress...Few ?'s
- Full Built 4l60E
- 4L60e to Th 400 Swap? (i already read sticky)
- Opinions on BW waffle plate clutches in a th400
- Performabuilt lvl2 4l60e ?
- c5 transmission solution
- broken tailshaft housing question
- Symptoms of a dying stall?
- Tight 3K Converter?
- newbe on stock transmission
- 3600 stall, how streetable?
- 700r4 question
- Best Glide builder for a 2900lb car with 1300FWHP and stock PG case?
- th350 free speedo fix problem: who wants to do some math for me?
- Hydra-matic ???? what are they
- Is my tranny going bad
- LTI 4l60E swap to LS1
- 4L80 f-body guys PLEASE COME IN
- 4l60E Wont Move!
- need 2002 f-fody 4L80 bin. file
- Stalled Guys: Do you stall or flash?
- B&M Universal Pro Ratchet shifter
- Good placement for tranny cooler(s)?
- Used Vig with brown brick like chips inside the packaging? Help!!!
- Terrible vibration after rebuild & stall
- Looking for an EXPERT on 4L65E ... vs 4L80E
- V-6 460le to V-8
- TCC Slipping with Royal Purple Max ATF
- Stall ??? cooler???
- For anyone wondering about if they should use the Meziere flexplate
- 98 flexplate question...
- 4L60E wont go into park =(
- Talked to Energy about their trans mounts
- Vacuum modulated tuning
- Transmission problem 3/2 shift
- 4l60e Shift Pattern Help....
- new torque converter and when put in reverse sounds like its bout to die
- What shops can check out a converter?
- Best prices for PI Vigilante converters on here?
- Bigger Gears
- Tranny cooler mounting solutions?
- I can't stand lockup in overdrive!
- 4l60(non electric) slipping bottom of second??
- Transmission cooler question
- 4l80e question....opinions needed
- Why do 4l60e's lose 3-4
- can someone thoroughly explain the stall converter
- LS1/4L60E TCI 3200 Super StreetFighter NEW TC For Sale!
- Aftermarket torque converters available for the 6L80E?
- 4L60E power rating
- Anyone want to trade converters? Vig 2800
- turbo 350 help plz!!!
- Fix it!
- not downshifting
- How do I contact Transgo? Missing pulse valve in HD-2 kit
- got my speedo to work, now what
- 1-2 shifts when hot
- broken trans dipstick
- what would the vehicle do if the tcc isnt getting power
- stock 4l60e is stronger than I thought
- Anyone heard of these transmissions?
- hurst quarter shifter???
- 4L60E Problems
- HELP Tranny cooler lines leaking-cause transmission to slip?
- ABS INOP comes on when Tranny slips
- Transgo Kit part #
- Need help choosing stall-dyno graph included
- Stall on 3.23s?
- Can the ABS Affect Tranny?
- Converter unlocking, locking, unlocking
- th350 stall converter
- EndPlay and Band selection
- trans cooler... search isnt working
- would a shift kit
- what tranny cooler
- HELP! Torque arm Clamshell bushing unremovable? Picture
- 3000 stall??
- 3.42s to 4.11s
- need help with flywheel
- Z-pack????
- M6 to TH400 Swap - Codes Thrown?
- 4l60e build ?
- How much should I expect to pay for stall?
- Stall size need help?
- I'm F'ed!
- turbo 350 ???
- Nitrous shiftpoints
- Built 4L60E Transmiission PROBLEMS
- How much for a Rebuild??
- TH400 Reverse Problems
- Who's runnin Performabuilt?
- new stuff added to faq page and cust service sales and tech open all day the 4th
- Powerglide or TH400
- Yank converter bolts
- Driving in 3rd???
- Dumb Newbie question...
- difference between 4l60e and 4l65e?
- Guys with cammed 4L60E, HELP!
- C5 4L80E Yank Conversion..where is Mke??
- where to measure tempeature
- Neil and Chance converter ????
- Synthetic ATF is a No with Yank stall?
- C5 can use a LT1 Torque Convertor?
- Yellow torque convertor?
- 4l60e drum lugs sheared off
- Best 4l60e turbo stall ideas?
