View Full Version : Automatic Transmission
- Fan for my tranny cooler
- tranny cooler leaking....WTF
- Beter Set up
- What et can i expect?
- tranny questions
- 4l60e?
- th400 dipstick tube
- Trans VIN # or letter, 2001 Camaro 5.7
- LS7 4L60E durability?
- in the 5's with Fuddle!
- TCI 3000 review
- shift kit improvement?
- Converter installed!
- ANOTHER fuddle 3400 2.1 str review
- Removing the Shifter knob???
- 350 turbo kickdown cable, does it need to be hooked up?
- Which torque arm
- 4l65e?
- help trans
- what could it be?
- Just got a TCI 3500 stall...
- Achieving best gas milage with a stall...
- Lock-up Issue???
- Is 4400 streetable?
- trans cooler
- How do I know what gears I have now?
- Transmission Cooler for M6 to 700R4 swap
- 98 v6 tranny?
- HELP on stall speed. have a PT4400 but....
- 4L65E tranny converter questions...
- Boycott Monster Transmissions
- write up for auto trans removal?!?
- need help car got slower
- Should I change the tranny fluid?
- TC install, what am I in for?
- Want to buy converter... some ?'s
- Going from SS4000 to PT4400
- Flexplates and converters... please help
- Who sells TH400 driveshafts!!!
- Converter on an 84k mile tranny . . . .
- what converter to go with??
- Reusing Converter after Trans Failure?
- 4l80 trans
- can i run a Stock convertor with a Cam
- fluid in stall
- Shift kit?
- Got the newly built 4L In!!
- what shifter
- Stock Gear Size?
- Blown converter?
- Went for a test drive in my Level 3 FLT transmission and new Vigilante 3200 stall.
- what causes driving through converter
- I wanna get high...
- Hitting the rev limiter???
- Should I install the Yank?.....
- tci th400
- Can I us a Stall from a 99 f-body in a LS2 GTO
- Stock stall...
- What are my options for a 4l60e?
- Yank SS4000
- Flexplate Bolts
- 4L60E people w/ Lokar dipstick
- transmission problems where to buy
- cost for a new tanny/ rearend
- probs with fuddle 3600 2.2 converter
- what is the strongest tranny for ls1
- flexplate for 4L60e
- tranny logging
- Ideal converter?
- New Converter! A Few Other Questions...
- the best cam for 3400 stall?
- Got my best 1/4 mile time so far
- Launching a TCI 3000
- noise problem
- Converter: good and bad news
- Th400/gv ???
- 4000 stall and 3.73s enough for TREX
- good tranny builder for th400
- TH400 problems
- converter question
- will a th350 that was on an lt1 fit an ls1?
- The converter is in.
- Aftermarket Servos
- Daily Driver Stall Size?
- Stall Install
- Pan with drain plug
- Is my vig 3600 F**king up my tranny.
- wats the stock line pressure?
- Will it fit..
- what size stall
- shift kit
- advice on stall size
- 700r4 problems in tow vehicle
- 4l60 filter
- TH400 problems
- megamaxxtrannys on ebay
- 4L60E no go
- Converter Tuning Question???
- Bad times from early shifts
- How long to rear ends usually last for you guys?
- Help me choose my TH400 options
- New stall Do I need to Retune??
- Shifting Very Hard.. opinions needed.
- how hard is it
- putting stall in ..anything else???
- Car feels sluggish on launch
- 4l60e Question?
- question about stalls
- Shift Kit / Stall
- Do I need different bolts when having my Vigilante 3200 installed my tranny?
- 4L60e Died.....Again?
- Why are most of you scared......
- viglante stall
- tranny cooler?
- I Got Yanked!!!1.520 60ft 11.50@117.09 N.A.
- Max RPM on 4L60E? 300RPM Change on shift point = hit limiter?
- ATF change question
- 4L60E Shift Kits
- question on the 4l60e important
- Tranny cooler and deeper pan...
- ENERGY SUSPENSION tranny mount
- Converter lockup mind of its own
- New 4L80E Conversions Now Available!!!
- 3800+ Convertors Tranny temps?
- Dyno sheet question torque spike
- 4L60E & Transfer Case
- Is it out there?
- anyone regret adding a converter to their car?
- skip shift
- Props to Doug Rippie Motorsports (DRM)!
- Squeel during shifts
- 4200+ guys
- Cheetah Shifter Owners need your help
- Shift Kit VS Computer Tune
- New guy with tranny question.
- yank and PI
- ATTN: Pro Built Transmissions
- Turbo 350 wont go in gear
- 4l80-E in C-5 /C-6
- looking for a good rebuild kits
- another TC question
- rebuild stock or buy aftermarket?
- TC install PITA?
- Torqe Converter Question
- shifters with th400
- Who in here is good at polishing??
- shift kit issues on 4L60E
- which one th-350 or th-400?
- getting a fuddle, what stall? str?
- Royal Purple/Amount of Fluid?? A4 Goat
- Another Fuddle 3400 2.1 review
- converter question/problem
- Where to mount bung for trans temp gauge?
- B&M hammer shifter for 4l60E? HELP
- 700r4 vs. 200r4
- Fuddle 3000 Q's
- 4L60E line clips
- Transmission Mount Height
- What should my 60' be?
- th400 on freeway?!!
- Th400 Won't Go Into Reverse
- Not sure how much longer trans is going to hold up!
- 4l60e to a 700r in a 94 4x4 ?
- need help
- What to replace?
- What is the best Trans Oil to get for a 4L60e Trans?
- No first gear
- rebuilding difficulty 4l60e
- 460le rebuild question
- Str?
- shift problems with fast 78 tb?
- fuddle 3600 stall
- rossler trans problem?
- Picking my FLT transmission will a Vigilante 3200 stall Fit a TCI Flexplate?
- converter and gear ratio
- trans for an '87 trans am GTA
- New FLT tranny installed!
- TCC lock-up issues
- th400 short shifting problem
- Tranny cooler question
- How much dur. on stock convertor
- ? about tras swap
- Converter ordered!
- 4L80E First gear question
- How hard is it to replace the universal joint? (rear)
- tranny is dead....
- Tranny Pros Come on in....
- ANOTHER 3600 FUddle vertor track results
- What could it be
- code po757 need help
- B&M Shift Improver or Transpak?
- will 60e converter work for 80e?
- 2 quick Trans cooler question
- question on lentgh of sender in port
- Cost of tranny swap?
- Installed a MS3 cam and now tranny problems
- Firmer shifts
- 4L80E Questions, please inform/help!!
- what shifter will work with no cuting
- rubber hoses and trans cooler 4l60e
- Transmission temps
- 4L60E to TH350 Swap??
- tune?
- 98 c5 help
- BURNOUT question
- One shot deal.
- What is the best trans mod auto
- stall question
- How much play in the tailshaft?
- 373 gearing on auto
- Link or instruction to install Super Servo
- BIG Converter Problems HELP PLEASE
- 4L70E experience
- What is your experience with Finish Line Transmissions??
- T-56 to TH400 VSS reluctor ring?
- Anyone running stock tranny tune with high HP and shift kit?
- 4L80E Trans and MS3 cam
- Shift kit installed = Crappy shifts....
- Has anyone changed their clutch inside of their Converter??
- Has any one heard of this?
- best place for tranny cooler
- Help:TH400 LS1 Starter Problems
- 6l80 in a fbody?
- should i stay a m6 or go to a th 350
- Where to get built th350 and other questions?
- I did it this time…
- 3400 TC installed,
- Does anyone lock their converter at the track?
- LT-1 to th-350 or th-400.
- Tranny rebuild/TC nightmare!! HELP!!
- Trans Temp
- convertor advice
- "D" or "OD"?
- how do i launch a 3600 stall from a roll.
- converter: how big?
- 106K Too High For High Stall Converter?...
- Codes,Codes, and more codes
- Stall Size, STR and MPG???
- Cleaning the tranny cooler lines
- torque convert lock up
- Transmission removal, NEED HELP!
- 4L65E comes in what vehicles?
- Weird Tranny Problem
- B&M deep pan on a TH350?
- shifting seems different?
- need some help
- 4L60E Rebuild??
- Need help. No shift from 2-3
- PY 3400 trouble here...
- what else to do while in the a4???
