- tranny weights
- Hurst QuarterStick install
- Is anyone running a PTC converter? Is it any good?
- fuddle 3600 stall, please commet
- PTC Converter any good?
- Is $250 a good price for a converter install?
- Will a 4l60e cooler fit on my 4r70w?
- Please help!!! Is my transmission going out?? Slipping in 4th
- Need Help With Drive Shaft Length
- fuddle 3400 or 3600
- Where can I get a th350 rebuild kit
- Whine from tailshaft
- Pro Yank 3400 Extreme
- what tranny mount?
- kinda of a newb question.
- TH400 Bellhousing Question
- torque management delete???
- Vig or Yank?
- Help!! P1870
- Going rate on used 4l60e
- What can I do with Mercon V?
- Stock Auto Shifter Button Won't Depress
- Finishline 4L60E Burnout ?
- Who did their own stall installation?
- YANK'S Big October Fest Sale is here!
- A4 Tranny Problems!!!
- hot to use stock shifter with th400
- Factory filled units
- What stall for a turbo?
- Yank SS3600
- Help.....Tranny shifts hard from 2-3 ?
- th400 with 4500 stall
- 4l60 question
- M6 to TH-400 flexplate question...
- ATI/402 Stall Recomendations
- My Ta Shuts Off At 4500 Rpms After New 4l60e???????????????
- ses: P0757
- STR??? what does it mean???
- which stall please help
- Basic tranny upgrades?
- TCI converter/ls1 pilot
- Problem with my 4l60E
- How high does your 2nd gear go?
- ls1/lt1 tranny but other way around
- Who has the STRONGEST BUILT 4L60E??
- Stall Converter Qs
- '02 4L60e won't shift out of 2nd
- C5 corvette output shaft measurement needed..please help
- 2nd Accumulator Piston
- Stall size?
- 4l80e in gm hightech shootout
- tranny fluid?
- ATF and converter question.
- Is it possible to fill the tranny this way?
- Urgent LS1 AND 4l80E problem
- was there a th375 produced after 1976?
- 4L80E post-install followup...
- pros/cons th350
- tranny whines in reverse
- 4L60E, MAF and LS6
- 4L60E Shifts hard from N to Drive
- need new transmission-DFW area
- best place to put
- 4l80e difference
- need asap help th400 or 4l80
- 350 turbo
- Can anyone help explain the TH375
- Tranny noise
- What would you upgrade?
- torque specs
- what will cause tranny to bounce of rev limiter at WOT??
- 4L60E to TH-350
- Q's about input shaft 4l60e
- yank ss3600 is in an runin!
- Pt4400 Users Only-inside Please
- Anyone use aftermarket radiator w/trans cooler?
- What Stall?
- setting shift points
- Neutral safety on A4 to A3 conversion with an aftermarket shifter?
- what size stall should i go with
- 4l80e -> 4L60e wiring
- rmvb best place to get one
- Need opinions!!!
- Help!!!! lock up and speedo issues...
- Bolts - Flexplate to crank
- Trans shifting question
- Need some Help
- Got my 4l80e swap done, one question...
- Need some help! Car won't go doesn't go forward anymore
- Trans slipping in overdrive . . . . .
- t-lock questions???
- th-350 guys
- stall acting weird
- 4L60E techs
- largest cam on stock converter
- Many 4l60e problems
- life of trans after converter
- th400 in 2000 Trans Am
- decoding the th 400
- Transmission is going out...What should I do??
- 1st gear gone?
- 4l80 Output Shaft Pic... which yolk do i need
- Wiring nightmare
- trans cooler
- Case differences
- Automatic Get me more MPH????
- Dropping a 4L60E...
- PG Driveshaft
- anyone ever run an in-line tranny filter?
- Final word on transmission mounts
- Want to manually shift my 4l60e
- TransGo 4L60E HD-2 ?
- Which Stall Should I Go With????
- converter help
- clips for hard lines
- help 4L65E
- stock pan burning up 2-3 clutches??
- a4 tranny
- HELP TCI 4l80 Converter, TCI Flexplate, ARP bolts hit
- Where To Build 4L60E In South Tx. Area
- stall is in..
- fuddle is awesome
- any sponsers have built th350s
- Highway RPM with new convertor kinda high?
- Having Yank SS3600 installed Tuesday...couple questions??
- idle problem
- Need Help! Tranny problem between 65-80mph
- 3.73s are in my A4....
- tranny cooler before or after the stock cooler?
- TH400 leaking from filler tube & shift shaft
- Need Better 60 fts with 2.73's
- How do you install the dipstick tube w engine in the car???
- Shift Kit
- Any advice?
- Best Converter for Future Mods??
- pro ratchet installed pics
- Stall from a 40+ roll?
- th400 shifter mounting question.
- shifter question
- 2nd Slipping, do i need a rebuild?????
- Aftermarket shifter for 4L80E.
- TransGo 4L60E-S and HD-3 MVB ?'s
- will this work?????
- Trans going out?
- Fuddle 3600 is in!
- YANK Converter from 01 work on 99?
- which bellhousing do i have?
- torque converter gap to flywheel
- Do I need a shift kit with a RMVB?
- best cooling transmission oil pan
- torque management?
- Best price for Vigilante converter???
- Help me install my tranny cooler
- transgo kits 7002+3 and SK 700 jr A kit?
- how does this plan sound?
- heat off trans
- Looking for a local transmission shop
- re-stalling a TCI
- what do u guys think
- need help deciding what to do...second gear slipping bad
- Anyone Use The J.w. Ultra Bell?
- Why is AT fluid circulated through 2 coolers?
- TCI stand alone for 4L80E ??????
- Help with th400 install (converter clearance issue)
- 98pcm temporarily controlling 4L80e questions
- Stall kills the Speedo
- Is it really possible to "Overcool" tranny fluid??
- Am I in trouble? Mods + 2800 verter
- how to put a trany temp gauge
- Trouble code P0758
- Short shifting at 3000-3500 rpms at wot!
- vendors that will buy 4L80E core
- Which flexplate bolts?
- My TH400 running hotter than before with higher stall and rebuild
- taking off the transmission..
- ACE Racing Transmissions.. Guys are A+++
- whats the lsx bellhousing threads
- Th350
- Cold shifts vs hot shifts?
- Anyone know the part number for bellhousing to block bolts?
- HELP!!! I Think My 4l60e Just Took a Dump!
- TH 400 flex plate??? Please Help.
- terrible smell..tranny fluid
- Difference in 4L60e's?
- 700r4 in a 94 camaro?
- Need Help Bad
- wth is goin on?
- any write ups on how to convert from 4l60e to th350?
- 4L60e slips in OD and Drive?
- HELP, i NEED a 4l80 tailshaft housing!
- Quick ?, 4L80E bellhousing shield bolt pattern
- 4l80e in a 05 GTO?
- Who knows the weight difference from a 4L60E to a 4L80E?
- Tci Converter??
- thm475 / 3l80HD
- Does A Th400 Eat More Power Than A 4l60
- No 2nd Gear
- th400 spacer question? Help Installing Now!
- |Need help with a disassembly question
- Trans Brake
- Shifting issue's
- where to get new bolts for bell housing?
- Need Help with Torque Converter
- Park?
- manual to auto swap
- Anyone through bolts for the converter/flexplate?
- Rock On Level 4 4L60e ??? thoughts???
- New 4L60E..Sound good?
- size of cooler fittings on 4l60e and th400
- shift kit
- No Upshift?!?!?!
- Help with stutter with 4L60E @ 75MPH
- Trouble w/ new tranny not shifting
- 4L60E question???
- Shaking after Stall Install around 45-60 mph
- Tranny/Convertor revisited.. More info
- Average 60fts with Yank SS3600?
- Need a complete schooling on 400trans
- need a better converter!!!!!!!!
- 20mph roll downshift
- 4l60e shifter query
- Transmission Problem
- please help
- will stall do??
- 4l80e with classic gauges (flexible shaft driven)
- Shifter Q's
- Hayden tranny coolers?
- possible new t/a owner
- Bolts for tranny crossmember
- Shift Kit/Stall question
- th-400 to moser 12 bolt help.....
- Torque converter question.
- Z-PAK Concerns
- What is wrong with my transmission ?
- When bolting the 4l60e up....
- SS4000vsYANK PRO ELIMINATORvsPT4000
- M6 to TH350 (speedo question)
- Manual valvebody?
- LT1 auto transmission combinations
- TH400 Fluid from Vent Tube
- Will i be satisfied with a 2800 stall?
- Sticks in 2nd Gear!
- 700R4 and 4L60e - do they interchange?
- For all the people that talk sh#t about Fuddle converters
- SS4000 is in!!!!
- broke my second coverter...
- Flexplate Opinions
- Ss Tb 3600 Yank!
- RPM or Performabuilt ?
- Does i need an oil flush?
