PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 [137] 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. trans go shift kit andtci ssf 3500 what fluid and how much?
  2. I wonder who is really responding to post here?
  3. 700r4 swap, electrical connections???
  4. Torque Converter Won't Lock Completely
  5. HELP 2000 silverado with 4l80e
  6. 93 vette engine, no forward
  7. TRANS WONT BOLT/MATE BACK UP.. wtf???? 98 4l60e
  8. A quick question on trans install, first timer here!
  9. Where can I find a used 4L80e Yank PY converter?
  10. Which would be better with my future combo?
  11. First Time installing a trans, yes it happened to be 4x4 lol!
  12. What would it cost to ship a Trans.
  13. 700R4's???
  14. need a parts list for TH400 swap.
  15. 4l60E + heads and cam....
  16. shift kit
  17. TCI Flexplate Bolts
  18. Powerglide gear selection
  19. what is the cheapest i can do?
  20. Lokar shifter on 4L60E???
  21. is there anything special to putting in a trans go shift kit??
  22. Torque converter problem
  23. Mos complete rebuild kit for 4L60E (Impalla SS)?
  24. looking for tq converter?
  25. Installing a shift kit in a 4l80e
  26. does midwest torque converter have website
  27. after a rebuild, should u change fluid out after a few break in miles?
  28. time to get a real trans. suggestions?
  29. Weak points in 350 turbo
  30. 4L60E, no 3 or od
  31. need advice on what to buy
  32. How to Connect 24 pin connector?!?
  33. Superior shift kit?
  34. TH400 question, need help picking tranny
  35. shift problems please help me!!!
  36. F/S 383 H/C w/black zr1s
  37. Flushing a tranny cooler?
  38. TH350 endplay problems
  39. what converter to get ???
  40. tranny problems
  41. YANK'S NEW 350/400 converters (look)
  42. th400 w/high stall?
  43. I have a A4 Harness for a conversion
  44. dumb question
  45. TH350 swap
  46. car makes tickin sound when goes in gear
  47. Anyone running a Yank SS3800??
  48. th-400 adapter spacer question
  49. A4 Help
  50. Automatic Trans Slipping.....Help!
  51. Not a LS1...but I've got a 4l60e problem
  52. diff between nonlock up and lockup
  53. 4L60 ? Hollander interchange
  54. Vig 3200 or TCI SSF 3500?
  55. Advise: Does a stall converter make a differance in mid and top end or just at a stop
  56. Talked with Precision Industries about changing Torque convertor..
  57. Hard Shift
  58. [b]shift kit or programmer[/b]
  59. Anyone know anything???!!!???
  60. TH400 Vs. TH350 tranny crossmember?
  61. th400-forward vs reverse valve body
  62. Trans Acting Up
  63. Trans Temp question
  64. How difficult is it to put a 4l80e in a 4th gen f-body?
  65. 4L60E Swap - What years will fit
  66. tranny cooler install
  67. Dipstick tube
  68. pics of progress
  69. what are the best upgrades to do to my A4 while i have it out
  70. What will a TCI 3500 stall do?
  71. ? about a stall
  72. TH400 converters... What's good? Who's got what?
  73. A4 Tranny Help Please... Quick
  74. Installing new 3500 verter. What trany fluid sould I use
  75. What to upgrade in a 360rwhp 4l60
  76. Looking to buy a new converter
  77. hesitation during 2-3 shift
  78. transgo?
  79. TH 350 Swap
  80. Manual shift body for 4l60e ?
  81. Horribile Downshift during a WOT pass
  82. Are 5 pinion planetaries necessary?
  83. GTO 4L60E Difference?
  84. shifter questions
  85. I know this is vague, but fluid everywhere
  86. locking converter on the dyno....
  87. HPP3 Question
  88. Transmission Question
  89. Attention anyone from YANK!!!!
  90. Lookin for help on removal and Installing trans. (first timer)
  91. Shift Extensions: TCI 4000 vs 4400
  92. Anyone know 700r4 tranny well help!?
  93. keep the auto, or switch to m6
  94. Coverter Bolts?
  95. Trans Problem
  96. 2001 ss-----1996 camaro
  97. Any difference in the truck and f-body 4l60s
  98. used converter question
  99. Turbo 350.. will it last?
  100. NEED HELP TC randomly unlocks after rebuild
  101. Hey jxaxsxoxn, now quick question on droppin trans and install new???
  102. anyone else have this problem.
  103. Does my 200-4R Converter fit in a normal GN
  104. 4l60 to 4l80
  105. Parts list For a TH400 Rebuild
  106. Attention A4 4L60E guys FYI
  107. help shift kit and servo?
  108. Need to buy a 3500 or 3600 converter help.
  109. M6 to A3!!Need list of parts and prices
  110. 4l60e trans ?'s
  111. 2-3 shift hits rev limiter
  112. TC stall speed?
  113. TH400 Adapted to DANA 300 Transfer Case
  114. 4L60E sqauk noise or clunk....Any Ideas
  115. trans ?
  116. 4l60 shift problems (at track)
  117. Car likes to die in reverse after converter
  118. To all tranny swappers.. What shifter do you use>
  119. 1999+ 4L80E Truck Transmission
  120. torque converter question
  121. EL60E troubles, anyone can tell me what to look for when troubleshooting?
  122. Differences between Truck 4l60e and Fbody?
  123. For a TC, who has the best priced tires?
  124. M6 To Vacuum Mod 4l60e Pcm Help
  125. Anyone know of a drop in crossmember for a 4l80 in z28?
  126. What gear placement?
  127. **!!700r4 Tranny Problems HELP!!**
  128. Transmission Shudder
  129. 6L80E, some early info......enjoy
  130. Is the 4L60e really that bad?
  131. Vacuum modulator for my 4L60 or not.
  132. HCI Torque converter
  133. 4L60E took a dump, what now?
  134. New trans installed, now have a ?
  135. Need some help
  136. 4L60E compatibility
  137. more problems
  138. question about shifter pattern
  139. What did I break?
  140. SSF finally installed
  141. Yank pulled through!
  142. 40 rwhp gain after locking 3200 stall. This can't be good.
  143. Changing tranny's A4 to 350 turbo>> Torque convertor ??
  144. Line lock in an Auto??
  145. Help...I was told this is a PCM/Tuning problem.
  146. whats the best converter for roll races?
  147. 4l60 slipping?
  148. who has th400 LS1 ready converters???
  149. Transmission cooler question/recommendation
  150. can a man get some help????? Please
  151. A4 rebuild! what upgrades are good?
  152. Converter Problems (Vigi)
  153. best way to ship a tranny
  154. Vig 3600 won't lock up on Dyno!
  155. Talk about bad luck
  156. what is the best sprag to use. blew mine today
  157. Trans Temp Gauge?
  158. trany cooler
  159. TC delima
  160. not going into park or neutral
  161. Torque converter/ Error code
  162. Th350 conversion, was told to get a 4l60e crossmember?
  163. TC delima
  164. Somebody tell me what the deal is with Vigilante converters.
  165. Torque Arm
  166. How many of yall run a vig or yank 2800?
  167. a3 shifter pics what do u thinK?
  168. What am I in for?
  169. Will a 2000 V6 4l60E trans fit behind a ls1?
  170. Best place to mount tranny cooler
  171. 10 ttranny gone. need help!!!!!!!!!
  172. Help TH-400 Speedo problem
  173. 4L60E to TH400 swap
  174. Tranny just up and quit working. What gives?
  175. Transmission Fluid
  176. restall
  177. Slipping
  178. 1-2 shift bangin HARD REV lim
  179. 2nd gear upgrade
  180. tranny went out
  181. 4L60E: 98 vs. 02 programs
  182. Transmission locks up hard
  183. 34 element sprag
  184. no speedo, abs light on, and tranny codes
  185. 4l80e
  186. Yank SS3800
  187. 4l80e?????
  188. Auto tranny probs on 99 Yukon
  189. 4L60E Now!! Overdrive
  190. trans electrical question
  191. With my converter, etc... what 0-60 should i see?
  192. TCI 3600 won't lock up???? Help!!!!
  193. question
  194. shift kit problem
  195. Blown Tranny
  196. m6 to 4l60e conversion please help
  197. max hp on a 4l60e
  198. Where to Buy Torque Arm Adapter for th350
  199. Info on how the 4L60E operates
  200. Tranny slipping?
  201. Yank ST3800 and 2.73
  202. upgrading my stall
  203. TH400 pan gasket
  204. LS6 and 4L65E
  205. Transmission jack question
  206. Bent TA mount need help...
  207. flexplate for t-400, and shifter Q.
  208. Transbrake in 4L60E?????
  209. TC unlocks when moderate throttle applied while cruising on the highway?
  210. Delete/reduce torque managment or a shift kit?
  211. Looking for opinions on Art Carr Trannys
  212. A Little Off Topic
  213. Question about the"pulse width modulater"for 4L60e?
  214. ?? for anyone with a 3500 stall or higher
  215. TCI or B&M deep pan on lowered car
  216. 4L60E experts, need help. Lost reverse.
  217. Different shift kits for 93-98 & 99-02 camaro?
  218. Trans Go 4L60E Shift Kit
  219. looking for information on CIRCLE D converters
  220. Help on stall convereter
  221. TH350 install
  222. anyone had any exp. with precision?
  223. Best 4l60e
  224. Desperately Need Tranny Advice!
  225. Best servo, tune, washer, hole combo?
  226. Strange 1-2 Shift
  227. what all do you have to do to install a trans go shift kit?
  228. opinions on setup
  229. Car won't downshift out of overdrive
  230. Super Street Fighter Tranny on Fbody
  231. cam duration
  232. Tool for A4 guys
  233. Question on Transgo install
  234. rebuild 4l60e or different tranny all together
  235. views on 4l60e?
  236. what do you think about this
  237. Question about torque converter lockup
  238. trans ?'s
  239. Rapid deceleration with the A4
  240. Transmission dimensions for 200-4r vs glide vs T56
  241. Is anyone running this tranny???
  242. When do you shift tour A4 into OD?
  243. Converter question?
  244. 4l60e and B&M
  245. what comes stock??????
  246. need diagram of th350, line hook up q's
  247. people w/ 3 speed shifters, custom leather boot?
  248. what is a reverse manual valve body?
  249. Differeces between truck and fbody 4L60E?
  250. certified mechs
