PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Rmvb 4l80e issue
  2. 4l60e reverse problem
  3. 4LE85 no OD
  4. 4l80e problems again and again
  5. Stock 4L80E lockup issue
  6. LS1 automatic fluid test sample
  7. 4l60e vibration from cold start? any ideas
  8. 4l60e v6 trans to fit v8
  9. 4L65E Forward Sprag Questions
  10. TCi x6
  11. 4l60e ODD 1-2 shift behaviour?
  12. th400 instal question
  13. new 4l60 won't shift past second
  14. Only 12 quarts after rebuild 4l80.. stalling
  15. Lil Help on identifying 4L80E Yoke
  16. Transmission problems, need advice.
  17. TH400 WOT will not leave 2nd or go above 4500rpms
  18. 4L60E No Reverse after Rebuild
  19. 4L60e in 1st gear manually shifts 2
  20. 4l60e shift issues after idling truck
  21. looking for a little help with the interchange on my 4l60e
  22. 4L60E Input Shaft Question
  23. 4l60e servo what if (possibly posted in the wrong spot)
  24. Unknown plumbing fitting
  25. HOLLEY DOMINATOR and Jakes 4L80e D1 transbrake
  26. couple of 4l80e racing questions
  27. What do I need to do to use 4l80??
  28. Transmission question
  29. Th400 billet shaft/drum...sub 1krwhp?
  30. 4l60e temp sensor accuracy
  31. 4l60e - need a good separator plate diagram
  32. 2014 camaro ss transmission problem
  33. Trans fluid leak at rear of case
  34. Bad 60 foot and poor ET with a 80 compared to Th400
  35. 4l80e Valve Body qeustions after rebuild
  36. LPE Rpm-003 help on how to wire for air shifter
  37. 2002 Sonoma 4X4 4L60e
  38. 4l60E shift cable bracket
  39. L99 with 6L80
  40. gear ratio
  41. 1 Year Tear down and inspect live of Performabuilt Black Edition 4L60E
  42. 4l60/65e to ls3
  43. 4L60E high pitched noise, almost police siren-like
  44. Front Exit or Rear Exit cable
  45. 4l80e Torque converter lock up not working
  46. What needs to be done to a 4l60e that will hold 800hp?
  47. Build a 4l60E or get a new 6l80E
  48. transmission
  49. Wiring in a manual switch for TCC on a 4l80e
  50. Converter acting tighter?
  51. 4L60E transmission works in reverse and manual gears only
  52. Trust Bearing failure in a BBC street car
  53. Trans problems!
  54. 4L80e makes car die in Drive only!
  55. 4l60e
  56. Goose honk on 1-2 shift
  57. 4l60e check ball question
  58. 4L80E Yoke Engagement
  59. cleaning the planets
  60. 4l80 no 4th for about 10 minutes
  61. Wont shift into 2nd
  62. 4l80e issues
  63. Help with Transmission Selection for LS6 in Rolls Royce
  64. 6l80 Won't Start after Valve Body Upgrade
  65. 4L60E VSS erratic reading
  66. Trans temp sender location
  67. Question:Will my 4l60 work with my ls3 motor??
  68. 2nd accumulator bushing
  69. 4L65 Valve Body in 4L70
  70. Is a stalled converter supposed to unlock right before you come to a stop?
  71. Vacuum port SBC
  72. 4l60E temp question
  73. ATF leaking from yoke?
  74. Turbo 350 over torqued pan
  75. Google has failed me ! Any exploded views of a 4l60 E with GM P/Ns ?
  76. Converter?
  77. 4l60e/nitrous/window switch tuning....
  78. 4l80e slamming into 2nd
  79. th400 converter pressure questions
  80. 4l60e looses gear HELPPPPPPP
  81. Recommended Transmission Rebuild Kits & Suppliers
  82. Anybody have a 6l80 for sale??
  83. 4l80 mods?
  84. 4l60E oil pan isn't sitting all the way down after rebuild!
  85. Circle D Turbo Converter
  86. 350 to ls
  87. Strange 1-2 Shift on 4L60E at low TPS value
  88. Scan tool
  89. 4l80e cooler lines
  90. Ls swap stall help
  91. Issues after rebuild 04 4l60e
  92. Best 4L80e Race shifter??
  93. P0751 code, 1-2 shift solenoid, hitting rev limitter
  94. 4L60E from 94 F body to 97 WS6
  95. A little help with 4l60e please
  96. 4l80 questions
  97. 1995 4l60e HD Questions
  98. 4l60E kickdown problems
  99. 4L80 Swap problems
  100. 4l85 question
  101. 4L60e problems after rebuild
  102. 6l80 slip yoke conversion
  103. Geared up Transmissions?
  104. 4L60e Intermittent second gear
  105. 3600 stall slow 2-3 shift
  106. Best Flexplate for Long Crank Lq4 w/ 4l60e converter
  107. 98-02 f-body
  108. TH400 only reverse...
  109. Late Model 4L60e Valve Body Hardware guide
  110. Ground clearance on UMI Tq Arm kit
  111. What transmission is a straight,no mod swap to a 93 LT1 F-Body?
  112. 2002 5.3 Transmission Compatibility
  113. 4L80e No OD, oddly low trans temps? Any help!?!
  114. Th400 locking up wheels in drive, need help.
  115. 60 issue or converter
  116. No 3-4, bad valve body gasket?
  117. 4L60e Converter Problems
  118. 4l80e B&M Pro Ratchet issues
  119. Wiring a transcooler fan??
  120. Need some trans cooler help
  121. 4L60E Rebuild Checklist
  122. GTO limp mode
  123. Need a TH 400 to 1310 yoke - anyone have one lying around?
  124. Trans brake solenoid question.
  125. 4l80 OD sprag
  126. Help please. Brake light on after m6 to t400 swap
  127. 2500 stall unlocking/locking
  128. almost 5 vs 8?
  129. 4L60E do you think this build will last?
  130. TH350 swap
  131. 4l60e Rebuild or Change pump?
  132. putting 4l80 in chevelle
  133. some assistance please..
  134. Cannot locate a leak
  135. Driveshaft?
  136. Trans fault code help
  137. 4l80 converter
  138. TH400 acts like it hits Neutral during 1-2 Shift at WOT.. Any suggestions??
  139. 4l60E lockup randomly disengaging
  140. tranny
  141. Help identify '60E valves/Stuck reverse bore plug
  142. Transmission cooler
  143. The &^%*(#@ allen head converter bolts !
  144. 4L80E electronically or manually ?
  145. D to R bang 4L60E
  146. Everyone with 4k stall come in
  147. LS2 w/TH350 Flexplate to Case Interference
  148. 4l60e Dropping out of OD when Warm and Light Throttle
  149. Adjustable transmission mounts
  150. 4L60E shifter upgrade
  151. 4l60e Problem Help!!!
  152. 4L60E done blowed up - questions
  153. transmission
  154. transgo kit install: should i replace solenoids while im in there?
  155. 4L90E Transmission module.
  156. 1998 T56 to 4L80E swap. Whats the cheapest way to do it ?
  157. Torque converter / stall?
  158. Separator plate 4l80 transgo hd2
  159. 4L60E at high rpm?
  160. 4l80 or 6l80
  161. 4l60e shifting issues
  162. Trans Controller
  163. Had transfer built an I still hit Rev limit 2-3 shift
  164. 1993 Trans Am Speedo off. Have correct gears.
  165. decision time: ss3200, ss3600, or pt4000
  166. 700R Transmission on a LS Swap
  167. 4l60e swap stuck in 2nd gear
  168. inconsistent stall convertor
  169. Another TCC issue
  170. 4l60e no forward gears unless pull fuse then has 3rd?
  171. 4L80e rebuild and dramas
  172. Is ss3600 too much for a DD ?
  173. 3600 stall wth wider tire/wheel = traction.
  174. 2000 Silverado 4x4 tranny problem
  175. 2004 Chevy Colorado tranny dipstick leak
  176. Which way for the 4l60e the force motor connector
  177. To go bigger converter or keep ss4000
  178. LS3/4L80 into a Ford
  179. 4L60E WOT 2-3 Shift
  180. Converter I'd help!
  181. Routing trans cooler lines
  182. 4L60E Transmission temperature sensor
  183. Rebuilt 4L60e fluid level mystery
  184. TCI Turbo 400 Car rolls backwards when in PARK?
  185. 4l60e 4th gen TA cooler- air conditioning?
  186. Did anybody get an 1/4 mile improvement on built tranny
  187. 2000 Silverado 4x4 tranny problem
  188. 2005 escalade transmission
  189. M6 T56 to TH400 F-body swap ???
  190. rpm level 5 4l80e launching issue
  191. transmission swap info.
  192. trans recipe: for disaster or one fine running 4l60e
  193. Converter Loose or Tight
  194. Yank Truck Thruster 2600 or Circle-D 300mm 2600 for towing
  195. LSA and 4L80E flexplate
  196. Weird 4l80e 2-3 shifting problem
  197. mild rebuild - which 4l60e spacer
  198. 4l80e Overheating Issue
  199. 4l60e problems
  200. Convertor Dealers
  201. 4L60E Extreme Slipping
  202. Swap Harness Modification
  203. Need help on determining what transmission will best suit my daily
  204. 4L70E Banging when TCC is locked
  205. 60E No 1st 4th w/o Manually grounding pin, also no auto downshift in D
  206. 4l60e reverse puzzle
  207. Transmission mount question
  208. Picking a stall
  209. Transmission problem? (loud screaming noise)
  210. TH400 mount issue
  211. transmission or rear end?
  212. 4l60E 3-4 clutch pack
  213. Car jolting in lockup
  214. Help with stuck band anchor!
  215. 4l60E Sun Gear Questions.
  216. 4l60e 2nd Accumulator springs
  217. 200r4 1 to 2 upshift RPM Flash
  218. 4L80E conversion help
  219. Can V6/V8 4L60E's be interchanged?
  220. Need 4l80e dipstick measurement....
  221. 4L60E Transmission Rear Seal
  222. Help: LSA 8 bolt crank to 4l80e
  223. 4l80e will not engage any gears
  224. Part number for 4l60e filter?
  225. 2002 Silverado won't start or shift out of 1st
  226. Rubber plug in transmission pan
  227. 4l60e limp mode but no SES light
  228. 4l80 flexplate with 4.8
  229. New GM 4L60e separator plate, any good ?
  230. Engine transmission compatibility
  231. How to fix no forward clutch clearance in a 4l60e ??
  232. 4L80e rebuild. Weakest links?
  233. Any gurus on a 4l60e 2002
  234. TCC Constantly Locking and Unlocking
  235. Odd 4l80e issues.
  236. Grinding Noise Driving From Complete Stop
  237. Home Built 4L80e for Turbo Truck
  238. 4l80e is torturing me
  239. Good forward pattern shifter
  240. new converter an shift kit drove 30 mi now car wont move
  241. 4l80e fmvb. what converter?
  242. is this supposed to be like this?
  243. 99 trans am tranny swap
  244. Transmission issues?
  245. Th400 swap check engine light codes
  246. 4l80e External Plugs
  247. Calling all 4l80E experts!
  248. Which torque converter should I buy?
  249. 4l60E Mods
  250. No 2-3 shift at WOT ***SOLVED***
