View Full Version : Automatic Transmission
- mods for the stock shifter/th350
- Ordering from yank?
- need some help
- Christmas comes early!
- Lockup the converter with Diablo Predator??
- Going on tranny #4
- higher stall converters and freeway racing
- Problems with VSS
- Options. What to ask for during a rebuild??
- N2O with TCI SSF 3500
- yank exchange possible??
- SSF 3500 + SuperCharger
- please explain
- Anyone Spraying a TCI 3500 converter?
- converter feels loose
- Need Trans Swap Info Quick Please
- Need Help With Converter Choice
- Help: How to properly read trans dipstick to check fluid level???
- TH350/TH400 vs 200-4R
- Vacuum modulated 4L60e users, need info
- Pulled trans pan and found aluminum shavings
- swap to TH350 any HP lose
- trans pressure
- Converter Lockup?
- Before and After dyno
- PRI Show, converter info and other stuff
- Cam/Converter question
- Converter shudder....PLEASE HELP
- tranny lines
- Lost 3and 4 --
- level10 rebuild kits?
- HELP! Bad 4L60E problem
- Some SS4000 results worth seeing...
- Worth stepping up to a TCI ssf converter
- HELP Trans swap info
- Wtf?!?!?!?
- Mega - Raptor 4l60E
- Torque gain with TCI SSF 3500
- Worthwhile to change servos in stock A4?
- Just got some new stuff in and weighed it.
- Average 60' with a YTP4400?
- Weight & Dimensions, 4L60E, for shipping........................
- Transgo Full Manual shift Kit?
- should the inside of a stall clunk around?
- Surface area of lockup clutch in stock converter?
- YTP 4000+ vs. Vig 3600 Multidisc
- Anybody have a stock LS1 edit program for a 99 T/A with 3:23's?
- Century Transmission
- HELP!!: Jerks hard when shifting to Drive/Reverse from Park or Neutral
- overfilled
- Tranny Cooling Times
- Parts list for TH400 swap.
- What to expect....
- advantage or disadvantage w/ manual valve body
- need a trans which 1 tci?
- Why the mystery around 4L60E and other Autos?
- Vig 3200 performance question
- launching on stock verter
- Ouch Trans #5 Gone
- A4 with ASA cam.....and a vig 3200 problems
- Questions about SS3800 Stall??
- Cost of converting TH400 to lockup?
- TH400 Conversion what type of converter?
- Installing TC this weekend...
- thoughts on built 4l60e
- Best converter for races from a roll................................
- Vig 2800 or Vig 3200 with 2.73 gears?
- Tranny Problems Any Ideas?
- Vig 3200
- new TC
- Which converter launches harder?
- Question
- Manual Valve Body for a 4L60E?
- Had transgo shift kit installed.. could this be the cause of trans problem?
- Which Cooler to Get???
- opinions on using a PT4400 with nitrous
- Can someone help me?
- TC question
- Yank SS3800-seems weak!!!!!!
- converter L/U cause KR?
- another 4L65E question PLEASE HELP
- Yank SS3800 or SS4000 with my mods....
- Yanks 4L60E with T-brake?
- 2004r swap information (from 4l60e)
- Best aftermarket Tranny
- YUP, its lucky me again with a STRANGE problem...............
- trans problems 4l60e wont auto shift
- Pt4200
- TH400 VSS Sensor Install ?
- Good results from shift kit and no stall?
- Vig 3600 question
- My car feels messed up...I took it up to 150 and it felt like I was going 100 DTC 187
- Gains with lockup switch on PT4400
- Need Help Please, Have question
- Installing ES poly mount tomorrow
- Multidisc Vigilante converter?
- what is the best shiftkit in the market ?
- What trannies will go behind an LS1?
- A quick Warning
- Torque converter break in period?
- Vibrations in my transmission....
- flush
- Trans Cooler Install?
- Some tranny Q's .. may get long
- I think i broke my tranny help !
- Looking for a good NA/N2O converter
- B&M Trick Shift in TCI Streetfighter TC - Don't!
- PT4400 on a bolt on car?
- Issues with changing trans fluid from mineral to synthetic in older box
- Th400 vs A4 with 500 + HP
- Poly trans mont???
- HPP3 shift firmness hurt my tranny?
- TCI cast aluminum deep pan
- SS4000....Is it too big for 2.73's????
- concerning TC change
- rebuild? new? built? Grrr, please help
- Mike @ Yank... are you in here???
- Pictures from my boom
- Century Transmissions?
- Cheetah SCS Shifter Pic
- PT4000 vs. PT4400
- what is a good brand converter ?
- What to do after 7 months of idle time?
- A4 flexplate gone bad
- a few ss4000E?s
- Yank SS3600 or SS3800?
- Transmission Shop?
- B&M Trick Shift vs DexronIII viscosity
- Vibration help.
- 3800 Yank / 3:73 gear lock-up
- 4L60E rebuiding advice
- Shift Extension Question
- Switched to TYPE-F today
- anyone have a tailshaft housing?
- ? for Colonel.
- What is everyone's opinion on trans temperature?
- What size TC do I need....Help!
- TH 350 on the street
- Trany whine? Mabe converter?
- List of mods Iam adding to my 4L60E!
- Car Feel....going from stock converter to YANKSS4000 with mods...
- Are kevlar bands bad?
- Getting ready for 4L80E swap
- Redline ATF in a 4l60e?
- Glazed 3 / 4 clutches in an A4?
- swap from A4 to th350
- New Tranny Question HELP PLEASE!!
- TCI SSF 3500 Review
- A few ?s for anyone that has successfuly did an A4 to M6 swap.
- Yank STLT 3200 - How will it drive w/3.73's?
- 200-4R question
- ?'s on converter choice, a reman tranny, & install
- Convertor keeps unlocking on the highway
- Shift Extension on your vig 3600
- Fastener sizes on the 4l60e
- Quick TC and Shift Kit question
- Transmission experts please help...
- hey quick question
- Is a 4400 too much stall for me?
- sry guys, another converter question
- A 4000 stall converter in a 200-4R vs. one in a 4L60E, any difference?
- TCI SS 3500 thoughts
- 5-pinion planetary
- What Transmission for this setuo?
- deep oil pan
- discussion on broken 4l60e tailshaft housings...
- Dyno Results A4 Locked versus Unlocked
- Predator W/TC
- Is my trans. going out?
- Good Level 1 or 2 transmissions?
- transgo shift kit help
- 97 C5 w/ a tick over 40K miles.
- th400 shifter install???'s
- SS3800 opinions please
- Dropped the Z off today.
- TCI Streetfighter 3000 - First impressions
- Weird Vibration?
- VIG3600 + Nitrous
- What gears for 9" with a TH400?
- track times??? whats going on?
- ? about tranny flush and fluid and filter change on TH-400?
- TCI 3800 track results...
- TCI 3500 w 3.73 gears -- Shift point problems
- Anyone using 4000+ stall on street? (Lock up)
- Torque Management setting
- Does TM make the car lean out?
- sick of my T-56, looking for input on auto setup
- Non Electric Th700R4: Can I make it work with a LS1 ECM?
- moded A4 shifter pics
- Shift kit necessary?
- th400 is installed but wont crank
- Rossler TH-400 Trans?
- bye bye stock tranny
- Stall for LT1 (Heads Cam Car)
- yank St3500 and 2.73 combo?
- why is a py3400e better for nitrous?
- What did TCS do to my tranny?
- yet again, which one?
- Converter unlocking during hwy driving
- Line Pressure Discussion (when is too much)
- just rebuilt my trans
- A4 hard to get out of Park
- I think i need a yank.
- FLP level4 and SS3800 in..got an SES!
- TCI sf 3000 question
- Yank SS38000
- Finally Some Pics Of Install!
- Best price on TCI SSF 3500
- Go to the other side or stay with the big stall auto??
- How high a stall to go to?
- converter ?
- Tranny cooler for A4
- question about yank ss3600 converter
- torque converter ?'s
- Pilot bearing bushing
- what converter w what gear ?
- A cheap shift kit in a bottle that works!
- Yank SS3800 or SS3600?
- We found the problem with the Turbo 350
- going to take my converter out
- Yank converter
- Any Sugestions? I Need Help
- can a Yank converter be restalled????
- Anyone have a TCI 3800?
- Hey A Little Help Here
- damn th400 dipstick
- Furious
- What do you guys think about a Glide in a LS1 Hot Rod?
- transgo S/K question about changing washers
- Should i get an A4?
- Trans question
- What TC setup gains most mph in the 1/4mi
- Check out FLP's new transmission dyno...
- Turbo 350 broke the 2nd gear sprag AGAIN!
- Want a fan for my B&M 24,000 GVW cooler, which one?
- Converter slips when cold???
- Delay in Shift
- 700R4 pan on 4l60E?
- Torque managment removal?
- question about tcc lockup
- Anybody know of a better input sprag???
- Th-400 W Brake And Extras
- whistling/whining sound
- Aftermarket TC's are the only way to go with an A4.
- Small problem w/ TCI 3800
- tired of this shitty A4, what about a th350
- FINAL ANSWER...Which trans cooler line is return?
- Who has busted a 10 bolt and what did you have?
- SS4000 drivability v/s TCI 3500 within!...
- Do I have a bad converter or ...
