PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. vortech 4l60e input shaft swap. HELP!!!
  2. anyone know where i can get custom emblem
  3. Vig 3600 to a CircleD 5C...Gains???
  4. What happens if you put a 4L60 (non-e) behind a newer PCM?
  5. Im so gunna get flamed for this.....
  6. noob 4l60e question.
  7. It figures as soon as I pay the car off
  8. professional builders please help with 4l60e problem
  9. RPM Transmissions are 10% for a limited time!
  10. van trans?
  11. Why do most guys here swap in 4L80E's?
  12. Installing a stall... need help
  13. Can someone read this EFI log to make sure that my lockup clutch is bad?
  14. slowed down after stall and longtubes
  15. trans question
  16. FMVB Built 4l80e problems
  17. Torque Converter Problem
  18. Recommend a "cheap" stall converter. I don't plan on racing
  19. Stock stall vs SS3600 (shift extention and characteristics)
  20. rev problems
  21. Just both my TH400
  22. Got a 3600 stall from FTI
  23. SFI shield for 4L80E?
  24. Trying to find shift cable bracket
  25. performabuilt level2 break in
  26. tranny dipstick tube ?
  27. Flt and precision industries awesome customer service
  28. Yank STR to Stall ratio chart
  29. Early lq4 + 4l80e in 2000 Camaro
  30. Trans cooler attatched to back of Radiator???? *** opinions***
  31. NEW GM Performance Part Mini-Supermatic...Answer to prayers??
  32. Trans. cooler question
  33. how much more stall on transbrake?
  34. wtb 4l80e
  35. shudder or chatter
  36. older rossler transbrake instructions
  37. 5.7 and 4l80??
  38. shift lock control solenoid - isolation diode?
  39. 4L60e sounds
  40. putting a ss3600 converter in before cam hurt??
  41. 4L60E 1st and 2nd in limp mode?
  42. Transmission cooler lines *** Help***
  43. boost an vac mod
  44. What to use to dye tractor fluid
  45. upgrading tranny, have questions
  46. 4L60E electrical plug-in leaking on top of pan….
  47. l480e into a 1968 chevelle
  48. Trans temp gauge question..
  49. TH350 vs 4l60
  50. How much power can a TH350 withstand?
  51. Best stall for a bolt on/150 shot ls1???
  52. Th400 in a C5 is it possible?
  53. 700R4 blowing fuse in 4th
  54. stand alone controller for a 6L80E
  55. Just ordered a Yank SS3600 how hard is a garage install
  56. Lost 3rd and 4th 4l60e?
  57. 4l60e rebuild kit??
  58. Pretty sure my converter isn't locking up...how to make sure that is the problem?
  59. 4l80e full throttle shifts to 4th
  60. th400 input shaft broke...snub stuck in converter
  61. replaced whole transmission and wont move!!!
  62. trans temp gauge ???
  63. Stall thread x2389834
  64. LS1 transplant,helping a buddy
  65. c6 ls2 options
  66. 700R4 reluctor ring replacement
  67. th400 cooler lines? what size
  68. 4l60e goes into gear hard
  69. 4l60e no lock up and staring off in 3rd
  70. converter and shifter help th400
  71. Newbie Help! Yank SS3200?
  72. Just ordered my circle d
  73. to any one running glides....
  74. 700r4 into 93....\
  75. tranny builder's- a few 80E ?'s
  76. 1993 t56 to 4ll60 swap
  77. LS1 + 4L80E - what flexplates will work?
  78. Drive shaft for th400 to 10bolt
  79. 4l60e Boost valve Location! Pulling my hair out!
  80. How can you tell if your convertor is dying? Low gas mileage question
  81. Converter question:
  82. B&M SuperCooler 70264 question
  83. Advice on converter
  84. What type of Torque covertor do you trust and use?
  85. TH350 with brake
  86. torque converter bolt grade
  87. nova & 4l65e shift linkage
  88. safe to drive new trans to tune?
  89. Sprag??, pcm??http://images.ibsrv.net/ibsrv/res/src:www.ls1tech.com/get/forums/images
  90. Difference in 4L60E TRANS
  91. mn6-speed fluid change on my 02 ws6
  92. PCS trans controller + 4L80E best route?
  93. th400 bellhousing..... update HELP!!
  94. Shift kit or tune?
  95. need help asap
  96. 4l60e trans question
  97. Tranny Cooler Types and Locations!
  98. 4l80e length vs 4l60e
  99. Is it even worth rebuilding the 4l60?
  100. -6 braided lines ok for a 4l60e??
  101. Thinking of installing a 4L80 in a 6 speed car - wiring harness?
  102. 4L80E Vacum??
  103. Question about Cams and Big Stalls
  104. Help me choose a Torque Convertor
  105. 4L80e Build Year & other questions
  106. can anybody tell me Driveshaft Length for a 4L80 and stock 10 bolt 2001 Camaro
  107. Whats OD?
  108. No lock up in OD
  109. which trans fluid to use?
  110. Help! I can't decide?
  111. E40 ECM 4L80E conversion no speedometer
  112. swapping LT1 4l60e (built) into LS1
  113. TH400 Shot, Need Suggestions
  114. help me pick a stall speed please
  115. Turbo 350 shift kit?
  116. Post Pics of your Aftermarket Auto Shifters
  117. Did I mess up my new trans?
  118. New Converter needed
  119. need help with converter?
  120. 700r tailshaft in 4l60
  121. 4l65 trans
  122. Stock Tranny Program
  123. YANK Special on Stealth converters
  124. Lost "Help"
  125. difference between 98-02 camaro 4l60e trans
  126. 4L60E and/or torque converter issues w/ my DD
  127. 4l60e soft shifting dramas!!!
  128. 4l80e
  129. Some Qs...
  130. 4L80E problems please help
  131. 130,000 miles too much for a converter & shift kit
  132. Can't believe the a4 was still working...time to upgrade...AGAIN
  133. 1st to 2nd shifts
  134. 4l60E Flexplate Question
  135. Parts difference between 4L60E's?
  136. Adding horsepower, will I need to upgrade tranny/drivetrain?
  137. No reverse
  138. vac mod delete
  139. th350 or 700r4?
  140. please help 4l60e
  141. Help find a trans
  142. Th400 Trans fluid...?
  143. th400 stall converter
  144. converter problem? see graph!
  145. transmission and roadcourse
  146. 4l80e neutral safety on trans. Do I need it?
  147. 4l60e
  148. Final ratio with th400 in 3rd gear
  149. Wich rebuild kit for 4L60E ?
  150. Shift kit opinions?
  151. SFI bellhouseing for an 80?
  152. TH350 converter question
  153. Questions about tourque converter lockup
  154. WHat shift kit?
  155. 4L60E experts...try to figure this out.. lol ...
  156. daily driven
  157. What torque/stall converter to buy
  158. Help with trans purchase PLZ
  159. stall question
  160. New trans and torque convertor
  161. flexplate ???
  162. Great prices on YANK converters
  163. 4l80e trans for 01 ws6
  164. Transmission Mount Nut Size?
  165. YankSS3600...Good Deal?
  166. Cable shifter stroke length?
  167. 4L80E input shaft
  168. Help compairing a few stalls...
  169. Transmission rating VS weight??
  170. what to look for when buying a 4l60e
  171. Th400 vs th200-r4?
  172. I'm having 4l60 problems
  173. Why is second gear being lazy?
  174. shifter choices
  175. Distance drive ?
  176. What ARP Bolts for TCI Flexplate to Crank
  177. 4l60E rebuild kit
  178. Tranny fluid level
  179. 2009 4L65E valve body swap
  180. any one ever try one of these gear splitter ?
  181. NEED HELP!!! Transmission Issue.
  182. 4l60 trans cooler fittings
  183. BROKEN 4L60e.. What can I get for it?
  184. TH400 question
  185. Transmission slips when hot...please help
  186. Do I need this hose?
  187. Latest Jake's Performance 4L80E Development
  188. 4L80E build for 900-1000HP?
  189. Lets see your MBA a4 shifter adapter mod!
  190. 4l60e No Gears
  191. 3600 or 3800 for a daily driver
  192. trans install issue
  193. 6l80 swap for a t56 2006 corvette
  194. trans for 550 rwhp at 8 psi
  195. 4L60E valve body question
  196. converter change w performabuilt rebuild
  197. Weird 2-3 shift in 4l60e
  198. 4L80E swap prices?
  199. sweetheat valentine sale! What do you buy your valentine?
  200. HELP!!! v2
  201. jake shoe 4l80e
  202. PNP switch adjust??
  203. 4l60e kicks out of 3rd....help
  204. What tune for ss4000?
  205. Flywheel Question....
  206. help!!
  207. Am I wrong or what?
  208. What transmission do I have???
  209. Do I need a tune after stall install??
  210. Is it crazy idea or anyone doing it?
  211. The most unusual trans issue
  212. Best place to mount tranny cooler on 99 camaro
  213. trans wont leave first.
  214. All FLT customers we want YOU!!
  215. Tranny Pan Question
  216. 60ft
  217. Replacement trans cooler lines!!!!
  218. will a 2004 gto Auto Trans fit my 1998 Auto TA
  219. who sales wider 3/4 clutches 4l60e
  220. Real world numbers th400 powerloss? from MT
  221. Help with scratch built cable linkage?
  222. mileage safe 4l60e mods
  223. Which 4L60E will bolt directly to LS2 from corvette?
  224. Bad Transmission Mount? (A4 trans)
  225. 3500 stall...
  226. need help tranny question???
  227. Is my transmission fluid low?
  228. What size stall would be best for me?
  229. B&m quicksilver?will it work with 4l60e???
  230. Please help deciding on 4L80E options (manual VB, TB etc.)
  231. lookin for cheap 80e swap parts
  232. Output shaft loose? Help me out.
  233. How high is ur stall and what can you stall it to?
  234. 4L60e use the same harness as T56?
  235. NEW FLT level 6 trans/Yank SS3600 Installed
  236. 4l60e Flexplate options
  237. IPT Performance Transmissions
  238. What year 4L60E will fit into my 95 camaro z28?
  239. helpppp!!!!! my z28 wont moveeee
  240. Is a LT to LS Stall Conversion Possible?
  241. Power glide with turbo 6.0?
  242. Torque converter questions?
  243. 278mm stall. need tune?
  244. LT1 trans on LS1
  245. 4l80e fmvb with brake ?'s AGAIN
  246. 4l60e shift problems
  247. 4L60e Problems. Vibration and power loss?
  248. just my superbowl luck.. trans went out
  249. th350 with turbo engine?
  250. 4L80E into F-body-- What OEM yr and model needed?
