- Two questions regarding my TC/FP setup
- 4l60e family Corvette Pan and Filter
- How does TQ affect stall converter size
- 4L60 trans got up to 220, blew rubber hose line. Need help.
- 4L80E Valve body question
- 4l60e questions
- What Is The Best Way To Increase Line Pressure in a 4L60E
- 4l80e question (overdrive sprag)
- 4L80 3-4 accumulator spring
- What size stall converter?
- Tail shaft vs 5.0 auto
- Opinions on New Product
- 4L80e no 2nd after rebuild
- 4L80e Post Rebuild only 3rd, 4th, R and TC lockup. No 1/2
- 09 4L60E valve body swap.
- Converter Recommendation
- Reading the dipstick?
- Doesnt feel like its all there.
- Circle D 4k Stall
- Cleaning Reverse drum
- Any info/opinions on 4L70E GM Clutches?
- Recommend flexplate/torque converter for a LQ9
- 4l60 26/2800 stall over heating
- Replicating GN governor 2004R transmission
- 4l80e Fixed Line Pressure Pump Wear
- 4l60e forward accumulator question
- Full manual 4l60e 4200 histall soft shift
- restricting converter feed and regulating cooler oil
- What flexplate is this ?
- 4l60e rebuild
- Gear selector question (auto trans)
- Tranny part shortage ?
- Please help me. 4L80e swap problems using TCI EZ TCU
- 1998 GMC Sierras/K1500
- lost snap ring
- 3 flex plates later and I still can’t find one that fits
- Speedometer not reading after 4l80e swap
- do the corvette solenoids not have screen?
- Th400 separator plate gaskets
- 200-4R Forward Clutch Clearance
- p1810,p1815 and p0700
- Spec sheet for 4L60 E build
- 4L60E Build
- 4l60e 2-3 shift timing clearances HELP
- Aftermarket parts selection VS (4l60e)
- 4L80e carnage
- 4l60e slipping when trying to accelerate....
- Converter comparison, 4L60e
- 4l80e early vs late "hub height" difference
- Reverse input drum burnt but straight - Replace?
- 4l70E issue-need help
- LT1 4 speed auto
- 4l60e rebuild?
- Rebuilt 4l80e slipping in forward gears
- 4L65E Shield and Bolts
- transmission pan bolts
- Adapter plate for 4th gen camaro, for aftermarket shifter.
- 4L60 converter fitment issues
- 4l80e line pressure issues
- High stall RPM dip
- corvette servo
- Needing assistance w/ part selection for 4L70e rebuild
- TCC line up
- Case Check ball blocked off
- 4l60e wiring problems
- 4L60E Problems
- 4L60e to a 700r4 swap
- 4L60E vehicle speed sensor wiring question
- Need a photo of a TransGo 4L80E HD2 separator plate
- Glide / converter issues flash speeds
- 700r4 feed holes.
- Feed hole size recommendations
- Help post!!!
- 4l60e Trans Wont shift To 4th gear. Help!!!
- 4l60e VS 6l80e Roll Racing
- 4L60E No 2nd and 4th
- Flexplate
- 4l60e drilling spacer plate
- Transmission lines
- 4L60E Has Problems! ?!?!
- 4l80e planet thrust washer
- TCI 6x with 4 Speed Valve Body
- 4l60e pump
- Transmission swap
- 4l60e 3-4 clutch pack clearance
- Tahoe trans questio
- th400 drum upgrade at what power/weight/rpm?
- 4L78 clearance
- Shimming Torque Converter
- Replaced trans now no passing gear 97 4l60e
- 4L80E Random Fluid Pressure Loss
- cam no torque converter
- Aftermarket digital transmission temperature gauge automatic 99 Camaro z28
- 4l80e Clutch Clearance Recommendations + more
- 4l80e converter recommendations
- 4L60e loose pwm
- th400 mainshaft same as early 80e?
- Do I have this right?
- 4L60E rebuilt but shifting too soft at WOT.
- 4L70e Tailshaft
- Using stock 4l80e converter - anybody?
- th400 dump valve
- Sonnax HP-4L60E-01 vs Transgo 4L60E HD2
- 4l60 WOT
- Best trans cooler for Silverado with 4l60e and Lq9
- LS1 & 4L65E Compatability
- 4L60E/ 65E/ 70E Pin-out
- 4L65E DIY upgrades
- 4L80e Swap & Tunnel Brace Question
- 2005 corvette auto transmission 4l60e?
- smells like tcc but says locked and applied
- 4l80e super quick shifting...
- 4L60E Sonnax Build - Questions
- Servo type
- Squeak 1-2 and 3-4 at WOT - 4l60e
- 700r4 fluid level
- Vacuum Modulator Under Boost
- 4L60E input shafts
- Comverter
- 4L80E output shaft with the rib
- B&M megashift question.
- New converter break-in
- Will my converter work with my application?
- 1994 Chevy c1500 4l60e issue
- 4l80e billet planet lube question
- 4L60E parts availability and possible subs?
- 4L60E Pump, help request
- 4l65e behinc LS3-> Downshifting early
- 4l60e Gen3 ring gear differences
- Looking for options to upgrade my 4L60e converter
- 4L60e heavy duty build for towing
- Extreme automatic transmissions
- Wedding Congrats!
- 4l65e
- Transmission question non fbody.
- How to build a bulletproof 4l60e
- 4l80e 1-2 shift slip
- 4l80e bolts without crank extension
- 1994 Camaro Z28 4L60E rebuild parts list - need pro advice
- How make 2008 4l60e work in 2010.
- 4l80e Issues
- Cooler fittings: Banjo Bolt Vs 90 Fitting
- 600HP 4L60 or 4l80
- Looking for a good source to order 3/4 Borg Warner Clutch Packs from
- 4l60 with fti billet converter not locking up over 50mph
- 700r4 27spline and 4l60E pump swap
- 3 4l60e rebuilds all failed in less than 100miles
- 4L80e aluminum direct piston
- Help 4L80e experts - grinding noise - did i do something wrong
- Davids 4l60E rebuild
- Delux Dope Style Trans Cooler and Power Steering
- 4L60E-PRO Reprogramming Kit...
- 4l80e 2nd gear checkball seat (and manual low band seat carnage)
- 260,000 mile 4l60e
- Which stall/gear combo should I get
- 6l80e converter clutch cycling on and off
- 4l60E No 3rd and 4th gear
- Shift Extensions and Converter "STR"
- Best 6 speed auto for 1000hp to the wheels in a 3200lb car
- 1999 Camaro SS trans issues
- 4l80e noise
- Tranny stuck in Park
- 4l80 Hitting Rev Limiter Uggh!!!
- 4l60E Shift Stud Nut Thread
- 4L60E Build Advice
- Converter slippage
- My 4l60e does double downshift after shift kit install?
- 4l60E fresh rebuild: Low speed shifts to OD
- Is this a sign my 4L60E is going out?
- Flex plate bolts
- Has Anyone Ran A Neal Chance Street & Strip Lockup Torque Converter
- Question about 4L60E transplant
- Help my C5 won’t shift out of 2nd almost new rebuilt 4l60e
- Racing with a 4L60E
- Will a 98 4L60E work in my 06 Silverado
- What would cause my 4l60e to clunk on downshift?
- phoenix transmissions/ Ebay torque converter
- Co worker having transmission problems. 4l60e
- second pureed band? 4l60e
- Need help 4l60e torque converter rubbing front pump
- What trans should I use? Converter?
- Using a 6l90 shifter for a 4l60e?
- Th350 rebuild has issues
- 4L80E: EARLY Vs. LATE Lubrication-Circuit
- 4L80E OverDrive Roller-Clutch
- Resto modded fj40 help - 4l65e and maf help
- Flexplate compatibility
- truckdoug's "UGH A 4L60e" rebuild thread
- Is this 4l60e pump shaft salvagable
- Transmission Accumulation-Circuits Explained
- Strange problem - 4l60e only slips when no load
- Help with 4L60e in Sierra
- 4L60e front pump failure
- 4L80E into 98-02 Fbody.....what Driveshaft are you guys using?
- Performabuilt 4l60e 2nd-3rd clunk on upshift.
- New built/refreshed 4l60e - gear hunt
- 4L80E Trans locks up in fwd/rev.
- 4l65e shifts from 1st to 4th At 20 mph
- Yank SST3600LS in a car
- Is this why I have a delayed 4th gear engagement? Pics inside
- Is there a "stock style" dipstick & tube to work with 4L80E and 4th gen F body?
- 4l60e stuck in 3rd gear
- 4l80e #2 check ball
- 4L80E modifications guide
- Shorten auto shifter shaft????
- turbo 400 vs 4L80 for drag racing question
- Connect and Cruise 4L70E problems Need opinions
- 4L60e help
- Tranny Cooler
- Air checking 4l60e assembled trans?
- 4t80e/ f40 questions
- Transmission dipstick on 4L70E ?
- 4L80E center support w/.041 recess
- 4l60e rebuild - 95 problems
- 4l60e air checking seals question.
- Lokar sport shifter with 2005 4l80e and factory computer
- 4l80e only 4th slipping
- 4l60e 3-4 clutch pack configuration for sonnax input drum
- Looking for help on a "Good 4L80e Rebuild Plan"
- 4L80e late model soft 1st gear
- 2WD to 4WD conversion 4l80e
- TCI 6X, no electronic engine braking
- 4l80e issues?
- how cam I mimic a manual's throttle response?
- 4l60e not shifting into 3rd
- Cinfused
- 6L80e Tailhousing bolts?
- K & M Transmissions / 4L79.com
- Tips to keep my stock 4l80e alive
- 4l60e swap
- Help with Jake's Rebuild Kit
- More info on trans fluctuates pressure
- 4L60E Lubrication Modifications
- 4L60E build problems
- Inputshaft leaking?
- 80e input shaft question
- Msd 2 step with trans brake wiring
- Corvette Servos???
- Early 80e question
- 4L80e ISS and VSS
- 4L80E Did I ruin my internals?
- In overdrive doesn't shift down
- Questions about 4l60e PWM delete
- Gear endplay in OD planetary?
- Best tranny crossover with qa1 torque arm and 400 turbo
- 4l80e trans pressure fluctuates
- How far can I lower the tailshafthouseing?
- 4l80e won't go into 1st
- 97-03 vs 04 & up pump cover difference
- 4l60e 3-4 clutch apply plate issue
