View Full Version : Automatic Transmission
- how many of u guys have a th350 that is dd?
- Need some gurus. What do I need to do a M6 to A3 swap.
- Another 4L60E problem...
- What converter
- Weird metal-to-metal sound when shifting gears?
- Art Carr Stall?
- remote trans filter
- 2004r conversion write up
- Which B&M kit should I buy?
- Torque converter hub bushing
- Harsh enough?
- I will install B&M shift kit but?????
- Torque Converter Noise
- Am i losing the tranny or is it tuning?
- How Many Washers?
- wiring harness m6 to A4
- TC unlocking erratically
- Not shifting to 3rd at WOT
- Stall, Shift Kit and Cooler Install
- Tci 3500
- Stall question on the highway
- finally made a few passes with the transbrake and fuddle converter
- Truck P/N switch
- Question regarding flexplate...
- Popping Noise Under Console..Please Help
- What torque converter??
- My Fuddle Experiance
- Slipping In 4th
- Do deep transmission pans reduce ground clearance?
- What Size Bolts To Use with Yank PY3600E?
- Removing the dust covers/bellhousing covers?
- New Converter INSTALL TIPS so far..
- 4L60E wont go into any gear but park
- Transmission Cooler
- Transgo Shift Kit
- EPC modification
- new radiator or tranny cooler?
- Newbe converter thread.....
- Installed B&M Trans Cooler
- 700R4 shift point change question?
- $505 for converter, gears, and cooler install, sound right?
- vacuum modulation with forced induction
- Curious which stage to pick
- 2600 bucks for trany rebuild?
- '05 escalade with turbo
- Going to race my buddy in his A4.
- valve body
- Tranny's sick
- shift kit
- Replacing Torque Converter??
- wat to do for a 4l60e to hold power?
- Performance Rebuild Kit/Components?
- 4L60E Tow Haul through PCM?
- 4l60e problem
- Why do people discredit unlocked torque numbers?
- '00 4L60E into a '99
- Whats wrong with my trans?
- 93 Camaro what tranny ?
- tranny cooler big enough?
- Torque Converters???
- Stupid newbie question: 1-2 shift
- Driveline cause any other problems?
- Sick and tired of cooler hoses!!
- i need help..
- LT1 converter question
- 4l60 to th350
- Flexplate bolts, what TQ specs for standard bolts?
- Having to manually shift my A4
- understanding my tranny.....
- help with major ?'s on convertor decision
- shifter ???
- what could be wrong?
- how much trans fluid to do i put in.....
- Shift kit or not?
- Won't move until 3,000 rpms
- A4 throwing code, advice please
- 1/4 times in a stock A4 ls1
- Built 4L60e - in 3 weeks
- Yank ST/SP/YPE/SS, what's the difference?
- Transmission cooler bypass stock radiator?
- Converters?
- trans cooler (4L60E)?
- Trans Temp. gauge?
- 2wd Shaft Removal
- cooler line E cips
- transgo vacuum mod
- Who used VSS to make speedo work in TH400
- factory tanny cooler?
- TCI SSF3500 will not lock
- ???? I just put in a poly tranny mount in now i have a vibration.Help.
- How is Racing from a Roll compared to stock with a 3500 stall or better?
- trans started leaking.....
- Sharing my Trans Am (temporarily)
- TCC lock/unlock/lock/unlock - Mechanical Issue?
- Can some one tell me what to expect?
- Can someone tell me how my converter will be?
- 4L60E...I'm done with it
- Stall Converter Q..
- wierd trans problem, any suggestions?
- why is it bad to turn off TM?
- Tranny bolts..,
- tanny flush bad?
- re-flash with LS1 edit after M6 to A4 swap?
- Converters in different trans
- Gears OR Stall?
- 2nd and 3rd Gears?
- 2 tranny coolers y\n?
- Question about 3500 stall Torque Converter Drivability????
- M6 louder than A4?
- 350 turbo pic please!!!!!
- tranny builders..help please solenoid
- Rock On tranny quit handling 700rwhp
- what the best rebuild kit for 4l60e ?
- For anyone with a street driven manual valvebody trans
- Derale Pan w/Cooling Tubes Works
- Century
- Transmission Break In Period ?
- Best 60 footers with SS3600/SS4000
- what do you think?
- Shift Kit
- Vig 2800 & 3200 STR?
- OT: 4T60-E downshift problem
- BMR LT1 Torque Arm Crossmembers now available!
- Problems with 2nd gear- Please Help!!!!!
- Tranny Help Plz!
- Stock TC Bolt Removal
- Question for the experts: Transmission Flushes: Good or Bad?
- Question for H/C A4s with vacuum modulation?
- Yank SS 3200 vs.TCI 3500
- anyone done the ford AOD in Fbody swap yet?
- need a torque converter
- locking problem
- How much power can a 4l80e handle?
- Non-electrical transmissions
- Torque converter
- funny acting trans
- Thinking of rebuilding 700r4 my self. What tools do i need?
- Highest stall the computer will tolerate?
- Car doesn't shift smooth with AC on ?
- shifting an automatic
- Tranny and rear end gears??
- I want to make a new 4L60E for my car HELP ME
- TCI3500SSF is in! First Impressions
- TH400 and 4L80E mounts the same?
- TH350 Trans mount
- Transmission Cooler Mounting
- Cracked Flywheel
- Anyone ever have there Stall Converter out to be refreshed....? How much?
- NSBU Switch???
- Traction Control??
- No 4th gear lock up
- adding gears to a th400?
- stage 2 or 3 4l60e?
- Any one ever tried a Ford or Dodge VSS?
- Why did my Overrun clutches fry??
- Help tranny doing weird stuff help
- Yank Converter Gains
- Poly Mount vibrations....yes I searched...
- Need help fast on 60e problem after rebuild...
- What does it take to go th350
- Can I do it?
- Torque Converter
- 4l60e 94 to 95 tranny swap
- Whats the max HP a 2002 Z28 A4 stock tranny can safely handle?
- how much of a power loss with th400
- stall for stock cammed LT1
- Shift points...
- Th400: Trans brake questions
- 4L60E converter/flywheel - 4 or 6 bolts?
- built 4l60E & TC problem need advice
- How should I cool my new tranny? (Tech guys inside please)
- 4L60E install problems
- TH400 in 3rd gen, what do i need?
- 4l80 spacer
- cooler size for car without oem cooler
- Lets get this ball rolling.....TC1 4000 vs. Yank SS4000
- How does this set-up sound?
- help with locking converter
- Strange shifting on 87 GTA
- What stall do I have??
- What stall to choose?
- trans swap
- 4L60E trouble....HELP!!!!
- broken bolts in flywheel
- What would be considered inefficient on high stall converters?
- 4wd tranny
- Cost of Installing a Torque Converter
- Trans Temps
- jerking when puting into drive
- Why would a shift kit cause any problems?
- when all will a stall help me?
- Why the stall?
- Making the speedo work in a TH350.
- Trans go piece?
- Yank Converter/FLP Transmission Help
- $255 for TC install alot?
- Info. on a Transgo
- R/R trans
- How Much Stall/Convertor do I need?
- stall installed with pics
- will it hurt my transmission
- Transgo issue
- Best Tranny Cooler?
- what should I restall to ??? (vig)
- STR and Single/Multi Disk on a TC?
- 4L60E P1870 code and Shift Kit HELP!
- camaro trans in a trans am
- quick question help
- Rebuilt 4L60 price??????
- A B&M Ratchet killed my TH400?
- HPTuners: Converter log
- what tranny do i have?
- Tranny going out? Need help!
- Not shifting into 2nd
- I broke my flexplate could it have damaged anything else??
- whats wrong with my tranny/TC?
- Shifters
- Tranny won't shift
- Biggest tranny pan without clearance issues?
- Help with this mod!
- Any One In Chicago Area!!
- Th400 into a LS1 parts list, Please!
- HIGH rpm nitrous th400 stall...who?
- Dayco Stall??
- Shifting problems in a a4
- A4 Stock shift points
- Finally ran her at 7psi
- what convertors interchange?
- stock rearend question
- 4L60E - Who Does It Best? Who can prove it?
- Does the shift kit have bad influence on the Trans?
- Upgrading trans lines with t-400?
- 4l80e??????????
- initial impressions....Fuddle Racing 4500
- please help vig 3600 w/ 150 shot
- My car feels like a dog
- What time did you see after 3500 stall?
- Is a trans cooler necessary with TC 3500 stall.
- 4l60E Build-up
- Vigilante 3600 for sale and 4L60E!
- Yank SS 3600 how Loose
- down sides of high stall speeds?
- Aftermarket trans pump.
- Converter
- Flywheel broken into 3 pieces..
- exceptional customer service from Fuddle Racing
- Engine Oil dripping from bottem of the Trans Bellhousing
- rx7 LS1/200-4R setup
- Need some non-LS1 help on a 4L60 / TH400 Conversion
- Tourq manegment
