PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Harness plug on trans
  2. th350 problems now :(
  3. 4L80E problems. Again.
  4. th350 swap with Madman Dipstick
  5. Good auto trans to use with LS6
  6. 4L80E cooler fittings
  7. looking to build a th400
  8. no gears at all....
  9. Best way to clean a converter at home.
  10. 4L60E fluid....???
  11. cool video on race converters by FTI
  12. 4L60E won't shift out of 2nd in swapped car...help!
  13. Yank converter .. chewed up inside??
  14. lt1 4l60e in a ls1 car.
  15. th350 shifter
  16. Any 4L60e Quicktime bellhousing users?
  17. Transmission help PLEASE!!!
  18. Alot of money being spent. (Thoughts appreaciated)
  19. Transgo Install Question
  20. Transgo kit problem
  21. Vig. Converter
  22. 2-3 shift problem
  23. Performabuilt Level 2
  24. edge racing converters or any comparable company
  25. 99 Chevy Blaser 4l60e in 04 GTO
  26. Hayden 1405
  27. My car sucks on a roll. Stall time!
  28. Converting the speedo off a newer Auto to old school
  29. Converters
  30. second gear th350 ???
  31. Auto Transmission is about to crap out i think...
  32. Hey just a couple tips needed...
  33. My LQ9 Flexplate will not work with SBC TH350 converter and GM Adapter (Pics inside)
  34. Question about TM removal
  35. Anyone see any temp drops from running different fluids?
  36. Lock-up Clutch Questions
  37. Correct bolts for flexplate to Crank
  38. Braided Transmission Lines ?
  39. No 3rd/OD???
  40. th400 transpan selection
  41. Intermittent trans slipping WTF?
  42. 4l60e on casing
  43. TCI 4l60e converter ?
  44. 4l60e trans from 4.3 will it work
  45. what brand aftermarket 4l60 to go with?
  46. Th 350 guys! What stall are you running!
  47. What to know for tc install?
  48. how would this be for a tranny cooler
  49. YANK testing on the LS3 A6 with SS3600
  50. Trans Brake switch/button
  51. Trans.length question
  52. Hit rev limiter from 2-3 shift
  53. Add a fan to my trans cooler or buy a new cooler with a fan?
  54. Dragging Noise in First Gear
  55. Dexron VI is expensive stuff!
  56. Idle surge after stall swap...
  57. 4K+ stall on a LT1
  58. Auto swap tune
  59. Is This True About Putting Stall Converters In Stock 4l60e?
  60. which direction to install a few parts 4l80e
  61. Anyone know what this is (4L80E Plug)
  62. 4L65E shift issues
  63. Fresh 4l60e Taking a Dump?
  64. How to wire up clutch pedal for auto swap?
  65. 40 tooth reluctor ring(700R4 or 4L60E part number?
  66. 4000 stall and nitrous?
  67. NEW 4l60E No Second Gear 1-3-4(delay)-lockup HELP
  68. Possible Bad Converter?
  69. Need help I'm stumped
  70. TH400 Issues
  71. what tranny is this
  72. transmittion rebuit kit..
  73. Who should I buy from??
  74. converter install....any takers?
  75. How much is to much?
  76. Trans. tuning Question
  77. 4t60e
  78. Which bolts/nuts for SBC TH350 converter to flexplate?
  79. Built 4L60E questions
  80. TCI 6 speed Auto
  81. 4L80e swap help please...have I goofed up?
  82. VSS and related systems?
  83. starting off in 2nd
  84. Aftermarket Transmission Pans
  85. what size converter to get ls1 miata
  86. Rossler 4L80E converter won't lock
  87. How do I get rid of my "dead spots"?
  88. TH400 and gears for the street/highway
  89. dumb question but i need an answer
  90. Will a converter for a 700R4 work in a 4L60E?
  91. Transmission application question.....
  92. 1-2 Shift is rough briefly
  93. 6L80E to handle 1000hp
  94. pump bad???
  95. th400 shift kit
  96. Aftermarket shifters
  97. Another happy Yank customer
  98. TH400 VSS Pigtail HELP!!
  99. 408 camaro not running like it should
  100. Is It Normal For Shifting Firmness To Decrease With a 3500 Stall?
  101. no overdrive after fixing simple leak!!!!
  102. (C5) Shift Cable Replacement Procedure Question
  103. 94 LT1 TH400 Question, No Start.
  104. Tranny Swap question.
  105. paddle shifters
  106. Stock 4L60E strength?
  107. 3-4 clutches....what brands you guys using?
  108. Stall help ASAP !
  109. Torque Converter Bolts (4l80/yank)
  110. 4l60e Fresh Rebuild, but doesn't shift right
  111. Converter and tranny help
  112. Edumacate Me..
  113. TH400 Trans Brake ??????????????
  114. trans cooler location..(turbo car)
  115. Low Battery Voltage After 3500 Stall
  116. broke pump? torque converter?
  117. overdrive working intermittently 4l80 transmission
  118. Circle D 4c installed, results vs stock stall
  119. 4l60e Tranny
  120. Transmission not working, what's wrong?
  121. Who has pulled trannys out of junkyards and ran them?
  122. How far along have built 4L60Es come over the past 10 years?
  123. th350 shifts harder in drive?
  124. LS..... Coan TH 400/ TH 350 Converter
  125. downshift limits?
  126. New transmission question
  127. tranny service
  128. Powerloss through trans, which would have the least?
  129. 2.73 Gears and 3600 Stall
  130. Which Trans Brake for TH400?
  131. TH400 Driveshaft Length!
  132. torque converter problems.. i think..
  133. 4l60E trouble
  134. Trans Sponsors and Experts Enter
  135. Help On Sprag Installation
  136. Questions about a yank ss 4000
  137. stall
  138. braided line routing
  139. freshen up the tranny? Advice needed
  140. Transmission porblems...Is it an electrical issue?(Video inside)
  141. Monster in a box Kit?
  142. th400 help
  143. What flexplate for 1000hp?
  144. Which transmissions are interchangable?
  145. Stall converter questions, please help!
  146. Transmission cooler questions
  147. Need Help
  148. Transmission fluid clean up......
  149. Possible trans failure
  150. converter wont unlock
  151. Weird noise
  152. 4L80E in a 1999 WS6
  153. TH400 to LY6 Gen IV
  154. excessive trans heat unlocked... Trans or Converter?
  155. stall recommendation
  156. Yank Install Question
  157. Tried d instead of od at the track
  158. Who's usin the b&m hi-tek super cooler?
  159. Converter slip problem?
  160. arp torque tables
  161. what kind of 60 ft can i expect?
  162. props to FTI Converters
  163. Thanks Chris @ Circle D
  164. 94 z28 4l60e reverse issue forward gears all work
  165. Aftermarket shifters in 4l60e
  166. car wont shift do I have a problem
  167. best thing, if anything, i can do to keep my tranny from failing?
  168. Broke now what
  169. 2wd 4L60e tailshaft housing needed
  170. 4L60E Rebuilt w/Drive Problem
  171. paddle shifted ls1 question
  172. New Fbody owner. Transmission question...
  173. Difference in early 4l80e and late 4l80e transmission?
  174. No Tcc with 4l80e
  175. HELP me diagnose a 4L60 issue please
  176. Stock Stall on 2002 Camaro SS
  177. Stall Converter sponsors.....whatcha got for me....
  178. Radiator Fan on constantly after stall/cooler
  179. 4l60e?
  180. TH400 swap question
  181. C5 4L60E need help - which is return & pressure?
  182. 4L80e lock up problems, bad converter?
  183. TH350, downshift 2-1
  184. TCI overhaul kit and shift boss review
  185. Hurst shifter for 4l60e???
  186. im planning on doing a th400 swap
  187. What size stall for 2.73 car?
  188. Twin 70264 Coolers
  189. 700r4 to ls1
  190. slipping during no throttle?
  191. will a 95 RWD van 4L60E fit a 04 GTO?
  192. 4L60e issues
  193. t56 to 400
  194. transmission cooler with rebuilt tranny
  195. nut to bolt down trans to cross member?
  196. What gear do you race your built 4l60e?
  197. anyone have stall converter that was like a wet noodle?
  198. Weird Issue at roll to WOT... I think
  199. 4L60E Problem
  200. 14,000 BTU enough for 3600 stall
  201. Is it slipping or something else?
  202. Trans Cooler Mounted "Dope" Style?!?!
  203. Starter Grinding on new TCI flexplate.. helppp
  204. 4l80e tailshaft question
  205. putting in auto in a m6 car..wiring question
  206. Pump splines chewed up
  207. Transmission is done
  208. th400/vss issue
  209. What B&M Trans Cooler
  210. th400 leaking but what is leaking from? (pics inside)
  211. Trying to pull trans got 7 bellhousing bolts but cant get one... %^#$%^#&
  212. Transgo Shift Kit 4L80E-HD2
  213. Replacing gear selector shaft?
  214. Need another tune with a 3200 stall
  215. Thanks to all
  216. lets see oics of your aftermarket A4 shifter install keeping the console
  217. delay going into gear and shifts
  218. Do I need a Filter Extension for B&M Deep Pan?
  219. Help! where/how to mount a trans temp sensor?
  220. Which is the best way to launch a 3,600 Stall Converter?
  221. 97 4l60e will bolted to ls1
  222. Converter too losse?
  223. Richmond, VA....all in one shop
  224. Thanks to Slow67 - 4l80e
  225. What size stall for bolt ons, future mods? Help
  226. flexplate on correctly?
  227. shift controllers
  228. Built 4l60e???
  229. rebuild 4l60e, wich parts?
  230. replace 2000 camaro flexplate w/ the new stall ?
  231. TH350 speedo
  232. Clunk/ under WOT
  233. tunning with new convertor
  234. How much for tc install
  235. Starter from a L92 with 6L80 work on a T-56?
  236. Today only promotion 100 off
  237. transmission leak
  238. 4l60e problem!
  239. yank ss3600 people come in
  240. Ok yank converter owners especially py 3400 owners come on in
  241. Pro Built Tranny Kits
  242. does this thing sound right to you guys?
  243. M6 to A4
  244. Turbo 400
  245. Help pulling 4L60E from 94 Formula!
  246. Trans Tweaking (HPTuner ppl enter)
  247. Im baaaaack!
  248. trans ?
  249. Taking Your A6 to The Next Level - Tuning to have the best of both worlds
  250. Trans cooler ?
