PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Need A Converter
  2. help
  3. How to tell if N2O is blowing through pt4400?
  4. Help with auto trans ID!
  5. 4l60e Vehicles
  6. 4l80 guys out of 10 how noisy is your trans..
  7. t56 to 4l60/ 4l80 swap guys..anyone hook up shiftlock solenoid and park lock cable?
  8. Which 4000 RPM converter ??
  9. 4L60E and 600+hp
  10. th400 , what rpm stall should i use ?
  11. Location of "LCA bolts"?????
  12. help me on where to start!
  13. Time for a new converter?
  14. 4l60e
  15. Yet again, looks like i did serious damage to a tranny
  16. length of dipsticks
  17. 4l60e binding in all gears
  18. Do I have everything I need? (4L80 rebuild)
  19. Can you flush/clean a torque converter?
  20. th350 ?
  21. differnce between 4l60e and a 4l60 transmission
  22. How Long Does Tranny Fluid Keep
  23. anyone who daily drives a stalled auto come in...
  24. is the tranny cooler enough for my new tranny w/ bypassing radiator
  25. Got my 80 running, question though...
  26. TCC apply/release speed question??
  27. Huge RPM Transmission Sale + Free Shipping!
  28. A4 Shift Problem
  29. AT temp?
  30. help!! code P0757! 4l60e pros!!
  31. yank 3200 stall
  32. Pro-built 4L60E Problems. Guru's Needed.
  33. yank 3500
  34. what physically makes an expensive converter different then an ebay one
  35. 4l60e mvb?
  36. Thanks FLT for another great year 700R4
  37. 4L65 trans issue
  38. can a 96 a4 go into a 94 a4 with no problems?
  39. 4l80 swap guys how the heck do you get the speedo to read correctly??
  40. Trans specialist come in please.
  41. 4l60 upgrade
  42. Installing a Vigilante TC the easy way.
  43. 4l80e 1000HP build help
  44. t56 to 4l80 swap completed but have some questions ,problems..
  45. TH400 Converter
  46. 4L80E Torque Converter
  47. Thanks to FLT and FTI!!
  48. T-56 TO Auto swap opinions
  49. Big thanks to YANK and SLOWHAWK
  50. wts a built 4l60e
  51. 4L80 for a C5 with no cutting? I heard Yank makes one?
  52. A4 transmission overdrive locking issues
  53. How to tell if you have a shift kit?
  54. LS1 style 4L60e on C4 Corvette
  55. a4 trans flush
  56. Installing Tranny Cooler
  57. 06 v-6 truck 4L60e trans vs. fbody 4L60e
  58. 4l60 or th350 need help deciding...
  59. racing
  60. Ls1 Th400 flexplate bolts
  61. 4l60 vs 4l80e
  62. 4L60e Overdrive Problem
  63. I have a nice nice question
  64. 1000whp auto with Overdrive? Do they exist?
  65. 4l60e not locking up
  66. pheonix 3200 stall good???
  67. th350 or 400??? help
  68. Stalled guys, I have a ?
  69. 04 CTS..downshifting HARD!
  70. Do i have this right? 4l60E to th400....
  71. Vigilante Stall Part # ????'s
  72. Need help what flexplate to get??? new to autos
  73. A4 tranny going out? Help asap
  74. Performabuilt lvl2 Yank4000ss Overheating?
  75. Low 1/4 mile A4 #'s???
  76. just ordered arp flex and converbolt bolts, will i have issues with tc1 flexplate?
  77. tranny mount not lining up to k member
  78. 4l80 swap questions..dust cover ,etc.
  79. how long has your RMVB th400 w/brake lasted on the street? (miles)
  80. does this fbody fit an fbody?
  81. need a 4l60e fbody shifter lever.
  82. have a4 car, want m6. anyone going the other way wanna swap parts?
  83. 4l60e build up ideas
  84. 4l60E help?
  85. Need a part numbers for the a,b solenoids
  86. 94 lt1 4l60e
  87. Tranny Pan
  88. looking for pics of M6 to A4 wiring----Already read stickies
  89. Kind of worried about this one
  90. trans cooler and shift kit
  91. th350 stall ?
  92. Speed density tune and a 4L60e...
  93. tranny fluid change
  94. 3200 Stall
  95. busted built 4L60E good to anyone?
  96. 4l60e 1st & 2nd Gen speedometer Kits
  97. Budget Tranny setup....
  98. performabuilt in my GTO
  99. 4L80E 4x4 to 4x2 HELP
  100. What Stall to get?
  101. 4L60E Bell Housing, HELP!!
  102. Rebuilt 4x4 4L60E or Junkyard 4L60E
  103. 4l60e bounce off rev limiter few times before shift
  104. 4L60E on mild LQ4?
  105. HELP ASAP!!!!!!! cars speedometer doesnot work, and 1-3 gear shift only!
  106. 6 speed auto Swap
  107. Nitrous with 4k stall
  108. no 1st
  109. 4l60e question
  110. TQ coverter lockup issues on 93 v6 firebird
  111. 700r4 shifting problems
  112. What is a Normal temp for an A4 Trans with conveter?
  113. 400 Trans brake
  114. question for circle d
  115. Th400 yoke question
  116. budget tranny
  117. quick noob question
  118. 6L80E Hydromatic Transmission
  119. 1-2 shift is weird, 2-3 is fine, 3-4 is weird
  120. M6 to TH350 or TH400 swap - read stickies.
  121. 3600 or 4000 stall?
  122. 4l80e
  123. b&m shift improver kit install need help!
  124. Looking for trans build info
  125. diffs. in V/B's for 4l80e
  126. Thanks FLT and Circle D 1.63 60ft stock suspension w/ Front swaybar!
  127. Yank 3400 - Intermittent Lock-Up
  128. no overdirive 4l60e
  129. Cpl of Vids with PerformaBuilt T400.
  130. Think I broke 2nd, binding bad
  131. Pictures of chassis rail or cylindrical type trans coolers mounted on car..
  132. Need to get my converter tweaked suggestions?
  133. Converting the 4l60e shifter to th350 pattern
  134. What in the tranny changes locked/unlocked?
  135. How much time does it take to remove and install transmission by the book?
  136. Garage shifts vs Boost Valve
  137. which 4l60e converter?
  138. Lsx sfi rated flexplate question.
  139. Stall
  140. How durable are these?
  141. check valve/little ball bearing in input shaft
  142. TH350 to ecu speedo questions.
  143. 4l60e from 95 camaro work in 97 trans am
  144. Installing Stall Question
  145. tranny with 131K original miles+ stall, bad idea?
  146. perfromance trans rebuild kit 4L60E
  147. Converter install
  148. Auto trans failing already?
  149. atf4... DOH
  150. MY 4l80
  151. 2000 A4 camaro
  152. 700r4 converter fit a 4l60e?
  153. Odd power loss at 5k rpms..
  154. Thanks To Performabuilt.....
  155. flexplate bolts with spacer?
  156. 700r4 issues, help Performa or FLT
  157. 4l60e Question
  158. how good are performabilt transmissions? there level 2
  159. TH400 shift issues no 2-3 shift
  160. 4L80E from what vehicle?
  161. Performabuilt and Circle D goes 9's
  162. 4L60E Shift linkage where to buy
  163. 700r4 shifts into od to soon!
  164. Installing Shift Kit
  165. Thank You Performabuilt and Circle D
  166. 2000 vibration in driveline
  167. Transbrake wiring... Rossler 4L80E..
  168. TH700R4 rebuild $ WTF?
  169. NEW best with PerformaBuilt T400 9.78 VID POSTED
  170. Which stock converter will work with ls1 and 4L80e?
  171. Transmission Ventilation Tube/Rubber hose (4L60E)
  172. how to check
  173. TransBreak in Built 4L60
  174. Need help quick with a trans leak
  175. flexplate torque same as flywheel torque spec??
  176. Built 4l80e toasted
  177. 4l80 from flooded truck
  178. Never thought I'd post in here.. Making the leap
  179. selecting a th350
  180. RPM level 6 4l60
  181. Transmission Temp Gauge
  182. odd noise from trans area under firm breaking?
  183. turbo350 questions
  184. TQ arm ?
  185. built 4l60e for sale
  186. DIY auto rebuild
  187. 4l60e problems not shifting to 2nd and 4th?
  188. Binding? Reverse works but binds...
  189. no 2-3 shift at wot.
  190. Can You?
  191. How much gain will I see from T56 to 4L80 swap?
  192. Reinstalling the trans. pan
  193. Can a PT4000 hold a WOT lockup?
  194. circle d converters
  195. Anti-ballooning plate question
  196. 4l60E Seperator plate trashed, why? What to do?
  197. trans went BOOM!!!
  198. Electrical short after tranny install
  199. Driveshaft won't go in 200r4
  200. need help 3rd time trans in repair shop
  201. t56 to a4 questions
  202. 02 4l60e Speedo question
  203. 4L60 from a 1993, Best customer service when rebuilt..
  204. stage 3 4l60e for sale
  205. My installed B&M Hammer Pics
  206. A4 to TH400 in 04 GTO
  207. tranny/converter=low hp?
  208. Is there a way to test transmissions, or cost for a shop to inspect?
  209. cars f*cked
  210. Reinstalling 4l60e pump...won't go back in.
  211. th400 dipstick suggestions
  212. Th400 swap price
  213. A4 Shift Points
  214. Issues with my 4L60E when I have it locked out in a gear.
  215. Where to buy 4l60e trans cooler lines?
  216. Yank 4L80e converter interchange?
  217. 6l80E power
  218. Loose or tight ?
  219. Trans ?
  220. 4L60E or 4L80?
  221. whats the differance between 4l60e and 4l65e?
  222. need upgrades for transmission?
  223. 4l80 cooler fitting
  224. 4L60E problems
  225. 4l60 issues
  226. Turbo 400 tranny lines
  227. flywheel problems?
  228. Painted case raises temp?
  229. Possible to change gears in tranny? th400
  230. Intermittent hard shifting
  231. Trans X as a preventative for transmission issues??
  232. 3000-3500 Stall with 3.73 gears. What cam?
  233. what does a stall do? ...seriously
  234. Pontiac TH400 into LS1
  235. TCI flexplate problem
  236. th400 is giving me problems
  237. CAM ONLY 60FT!!! SS4000,4.10s, 1.35!!!
  238. Tci flexplate ?
  239. V6 Trans Behind a turbo 5.3
  240. Do I need a new transmission?
  241. 4l60e delay shift into 3rd.
  242. 4l60e performance upgades HELP
  243. Water in trany
  244. Need 4L60E Help (LS1 GTO) No gears until restart
  245. What size input shaft?
  246. Will not downshift, Please help!
  247. Why aren't gear swaps helping stalled car's?
  248. torque converter to flexplate problems
  249. My yank will be here tuesday Im excited!!
  250. 4l60e shift problems
