PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Locked Vs. Unlocked at WOT
  2. too much line pressure?!?
  3. SS4000 Vs. SS3600 "for a custom cam+N2O"
  4. June Father's day special from YANK
  5. Whats up with this?
  6. Transmission shifting early still
  7. 4l80e vs. 4l65e
  8. What bad ass convertor for a T-400 NA application?
  9. Is my trans on its way out?
  10. build 4l60e what tRANNI fLUID IS BETTER TO RUN ?
  11. Will this converter fit?? Need a quick answer please!
  12. Fuddle
  13. 4L60e and 4L65e
  14. Transgo HD-2 installed now 3-4 delay, HELP
  15. New Tranny Problem
  16. Recommended Transmission shop
  17. I'm trying to figure out what it came out of
  18. Are These the Same??
  19. hello
  20. TBSS - 3-4 Clutch Replacments Recommnedations?
  21. Transmission Fluid Question
  22. To answer the question about 4.10 with A4
  23. 4l60e pan and gasket
  24. trans leak please help!
  25. Q About Stall Converters
  26. Yank converters came thru for me
  27. After driveshaft swap, atf leak!
  28. 1st to 2nd gear problems
  29. Auto tranny problem/ 3.90 gears in C5
  30. trans wont shift into 2nd or Overdrive
  31. 4l60e runs hot and slipping in OD
  32. 3-4 Shift Slippage
  33. switching to an auto need some help
  34. down shift?????
  35. Do I need a stall?
  36. Something New From Performabuilt "restoration"
  37. trans and converter issues
  38. Best/cheapest place to buy P.I. Vigilante Converter????
  39. new trans is shuttering in overdrive
  40. Lucas ATF Additive
  41. Car hits the rev limiter at 84mph
  42. What A4 tranny oil do you guys recomend?
  43. **Transmission Help**
  44. 95 3.4 camaro a4 tranny... same as all other 4l60e
  45. ATF Change Question
  46. Tranny cooler questions
  47. where can i find the part # to the trans line "e" clips?
  48. Al vs steel pans?
  49. Gauging interest in selling 4l60E
  50. 4l80e & A4 torque arm mount....WTF!!!
  51. What is a fair price for a semi-used TH400 converter?
  52. What is your bolt on car shift points?
  53. 1-2 shift delay in FMVB 80e
  54. Help me pick a good transmission/stall combo
  55. Why is it so hard to sell my Art Carr TH350/TH400 Nitrous converter?
  56. B and M Quicksilver Install Help!
  57. deep trans pan ?
  58. question for TCI
  59. vss problem
  60. Transbrake Effects
  61. Royal Purple Synthetic MAX ATF??
  62. quick help needed!!! 95 4l60e into 96 transam
  63. 4l80E Lock Up Question Help?
  64. Help with TH400 install
  65. what stall
  66. WTB Input drum
  67. Weird problem, need suggestions
  68. multidisc converters...
  69. Recalibrate my shift points?
  70. Recalibrate my shift points?
  71. Wot Lockup With Midwest
  72. Th-350 in an LT1
  73. What to do to get the converter all the way in?
  74. 224/224 cam install stall converter ??
  75. Cooler lines for TH350 swap
  76. anyone builds in Columbus area?
  77. 4l80e people, what torque arm mount??
  78. LS1 swap 4L60e problems!
  79. Outlaw Transmisson
  80. Converter Question
  81. might be a dumb question...
  82. m6 trans mount for th400
  83. Converter Selection help
  84. Fun to drive?
  85. Vibration inside transmission?
  86. VSS signal
  87. which tranny fluid do you use??
  88. best price for ATI flexplate?
  89. just in
  90. What kind of 60' times can I get on a stock stall
  91. Circle D Review
  92. Input drum damage!!!
  93. Track results with FLT lvl 4,Yank pt4000,BMR & Tsp heads cam pk.
  94. This 95 Ta Is Converted To A Ls2 Keep That In Mind :)
  95. Circle D...11.1 @ 119 MPH N/A
  96. 4l80e swap & PCM
  97. Basically Stock LS1, 2800 stall?
  98. 2 Codes, P0748 and P0751
  99. Yank or vig 3600 or 3200 footbrake range. bolt ons.
  100. What's the right way to burnout with an A3?
  101. no 3rd or OD 95 Z28
  102. Proper way to check transmission fluid?
  103. NEW best again with level 2 10.23 vid
  104. Gear Vendors Over-Drive
  105. Single or triple disk, and converter math
  106. Questions for those with over 450RWHP AND 4L60E
  107. Is 2" of slip yolk inside 4L80e enough?
  108. LOKAR th400 on a 4l80e
  109. wtf is going on
  110. Been Pretty Busy This Year so Far.....
  111. B&M 70266 SuperCooler 58.95 shipped NEW
  112. help! trans will not shift
  113. another 4l60e in the dust
  114. th400
  115. 2-3 clutches
  116. TH400/TH350 Swap
  117. trans leaking
  118. GM 4L60e Manual .pdf
  119. Th400...DD/strip car.
  120. improving 2-3 shift
  121. Converting to a T400, couple of questions
  122. Trans flush
  123. Anchor Brand Trans Mount
  124. speedo help 94Z wiuth th350
  125. Post up pics of your aftermarket auto shifter.
  126. Converter Reccomendation
  127. tranny cooler help/where to buy
  128. please help
  129. TH350 Driveshaft
  130. Convertor lockup switch?
  131. Will i need to break it in?
  132. Prob's after used tranny install
  133. Bad Converter or Bad Transmission
  134. Anyone ever mount a tranny cooler under the car?
  135. FLT Level 5 handle a 427ci LS3?
  136. new stall and car surges when i come to a stop
  137. i feel stupid
  138. **NEED** 4l60e for my '98 Tahoe 4x4
  139. some weird T350 problems
  140. ANYONE know the Part # for the 99 Trans am A4 auto shift cable ? i need ASAP
  141. how to go about taking apart the 99 Trans am A4 Shifter and Shifter Cable
  142. Possible trans issue
  143. Vig converter universal for all LS 4l60e's?
  144. truck with 80-e problem
  145. High HP Cars (TCI Flexplate Bolts)
  146. Stallie info?
  147. help with First Gear...
  148. Restalling Converter and Shift Extensions
  149. Is my trany on the way out??
  150. converter needed
  151. 4l60 to Th350/400
  152. Hitting the rev limiter
  153. Transmission still early shifting at WOT
  154. tranny cooler install ????
  155. Trans not downshifting?
  156. Stockish Rebiuld?
  157. SS4000 times for cam only ls1.... 1.40 60ft
  158. What have you done to make your TH350 survive?
  159. 200r4?HELP!!!!!
  160. Will a GTO A/T fit 98-02 Camaro's
  161. Are people swapping out their 4L60 for the 4L80 now?
  162. Code PO756?
  163. 700r4 and 4l60e...can same tranny pan be used?
  164. Trans cable bracket
  165. **Pop**, No 3rd or D
  166. 2-3 shift = Rev Limiter
  167. Transmission doing weird stuff! Help!
  168. OK for a new stall after solving 2-3 shift hanging?
  169. changing th350 WOT shift points
  170. 4l80 cluth tech ? for builders
  171. Help Tranny Problems!!!!!
  172. Car surging in OD....
  173. 4l60e shifter linkage ball socket problem
  174. what will a stall do performance wise?
  175. torque converter question
  176. New Best 10.30
  177. 3/4 clutch
  178. i think UPS LOST MY LV2 TRANNY
  179. th400 converter install
  180. Vette Servo
  181. Will stock 4L60E survive a dyno tune?
  182. Need some luck in Vegas, 4L60e transmission dead at 59,000miles
  183. 4l60e tranny cooler kit??
  184. Transmission Problems
  185. shifter cable/linkage not lining up on 4l80e
  186. gasket material?
  187. trans pan with drain bolt?
  188. 4l60e HD2 shift kit for 4L65E?
  189. Trans Temp Questions, Please help.
  190. is the bs3 worth $2800
  191. additional parts to buy for stall/trans swap?
  192. 2-3 A4 Shift Lag
  193. mileage
  194. Trans slipping in OD, other sometimes
  195. Overdrive vibration
  196. help/advice changing a torque converter
  197. Bad Tranny
  198. 460le Overhaul/upgrade
  199. blew the 4l60
  200. No reverse (fresh build)
  201. t-400 question
  202. transmission acting up?
  203. break in on a new trans
  204. Th350, th400 or powerglide?
  205. strange shift since new stall
  206. Tuning Recommendations for ss4000
  207. Transmission service ?
  208. 3rd and 4th clutches
  209. prolly wrong section but fittings
  210. 4L80E Inlet/Outlet Question
  211. th400 problem
  212. Slipping in 4th lock up 4L60E
  213. Is this a tranny problem?
  214. 4l60e Tranny not shifting?? Stays in 3rd?
  215. 4L80e controllers which one?
  216. What Tools Are Need
  217. Hughes performance
  218. looking for a race tranny, i have one for ya
  219. Broken 99 TA , 4l60e Transmission SHIFT LINKAGE HELP
  220. tranny no go
  221. 94 A4 1st gear question..Rare??
  222. cooler lines
  223. 200r4 donor identification?
  224. 700r4 Clutch and band chart
  225. Cracked bellhousing!
  226. Need some newbie help on transcooler
  227. Hats off to builders
  228. Honda Trans Fluid??
  229. driveshaft length with th400 swap
  230. Help me diagnose a problem please
  231. Strange Experience at the Track
  232. trans dip stick wont come out
  233. tranny coolers
  234. need some trany help
  235. do I have to retune shift points with N2O
  236. Transmisson Cooler ??????
  237. Need a new "seperator plate" advise please.
  238. Shift Soleniod Need Help
  239. Shift Soleniod Need Help
  240. Trans wont go in gear after vb install
  241. Stock 4L60 help.
  242. 2-3 bind with HD2-C
  243. LT1 4L60 and LS1 4L60
  244. B&M supercooler
  245. What stall speed to go with??
  246. identifying converter...
  247. Stripped Flex plate bolts
  248. Need some help with A4 Trans
  249. FLT saves the day.
  250. Manual 4l80 & TC lockup ?
