PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. picking a converter
  2. Tranny in limp mode pin E con. does not have 12V
  3. Circle D - Billet Parts
  4. Shifter for 4L80E
  5. 4l80e help -- how 2 use drive by wire
  6. converter flash!!!
  7. Tranny Problems Please Help
  8. What stall?
  9. trying to learn about autos
  10. tailshaft rubber piece w/ exhaust hanger
  11. Another 4L60e going bad?
  12. How much $$$$ in your m6 to a3 conversion???
  13. Edge Converters
  14. 4L65E/4L60E and Gear Vendor OD unit?
  15. Another "Tranny cooler line blew off" instance
  16. TH400 Question
  17. Problems with installing a stall
  18. another stall question
  19. Converter Problems,your help ??????????
  20. th350 for LS1
  21. how to tell what gears i have in the rear?
  22. HELP tranny not lining up to k member
  23. Yank SS3600, What gears to go with?
  24. Urgent Trans Problems!!
  25. PTC 4200 stall converter??? daily driver??
  26. Info on adding a fan to the trans cooler.
  27. I have a question for the transmission gurus.
  28. How does this cable shift the tranny?
  29. shift extension problem w/new yank TC
  30. sound like two shifts at once
  31. Where's my first gear ?
  32. transmission
  33. Will it make it past the Dyno? Stock 4l60E 400RWHP N/A 5XX on N20
  34. Can the C5 use a LT1 Torque Converter?
  35. Looking to get a stall soon......questions??
  36. some help finding backup light wires....
  37. Pulling codes P0740 and p0785....????
  38. TECH TALK: Trans Builders Inside Please, Lets Talk Downshifting In an Auto Trans
  39. Big thanks to Dave @ Yank TC
  40. New Billet Over-Run Piston - 4L60E - Circle D
  41. 4L60e Transmission Shifter Button Problem
  42. Transmission shifting problems
  43. Part throttle shifting...
  44. Z28 Tranny Problems!!!
  45. 4l60e gone bad???
  46. 4l60e gone bad???
  47. ACE Racing Transmissions will be closed July 4th
  48. OK I am stuck PLz Help
  49. Yank will be closed for the 4th
  50. Nitrous Stall
  51. built th 400
  52. Dropping a trans
  53. biggest DD stall?
  54. 4l60e rebuild
  55. Shifter/tranny gears not lining up with 4l80e
  56. in/out cooler lines?
  57. what converter to go with
  58. Cheapest way to mount torque arm to something other then the trans?
  59. got the shakes in reverse
  60. Weber Racing Equipment is an Autorized PTC Dealer
  61. Torque Converter Clutch question
  62. No WOT Shift
  63. where to get new input housing for 4l60e
  64. 6L80 Converter
  65. tranny had demons!!!
  66. shift kit help please?
  67. Inline Cooler vs Standalone
  68. Will a higher stall help my idle & driveability
  69. Will an older 4l80e work with an LS motor
  70. New converter offerings from PerformaBuilt
  71. shifting to early
  72. Tranny problems
  73. auto tuning
  74. where to mount tranny cooler
  75. anyone tried the lucas atf additive?
  76. Where to buy a A4 upper console??
  77. A4 Swap..
  78. got a B&M Tranni Cooler 19,000GVW Cooler where to INstall in 99 Fbody
  79. th400 wiring diagram
  80. tc alignment
  81. 4l80e tools cheap (ebay)
  82. Please Help!!!
  83. Shift kits-are they necessary, better?
  84. Used/New Tranny...
  85. tranny temp sensder for aftermarket gauge question
  86. How does a convertor affect gas mpg??
  87. 4L60E 1-2 WOT Shift Issues
  88. 4l80 t-brake users what filter!!?
  89. Shift Knob Button
  90. 2-3 shift (4L60E)
  91. Yank SS 4000 results, new PB
  92. Pros and Cons
  93. Performabuilt 4L60E and Circle-D 5C converter review
  94. Stall converter and long highway driving
  95. chances of 2 tci breaking?
  96. vibration in car
  97. vss pigtail
  98. who has the vig3200
  99. tranny pan w/temp hole
  100. Screw this M6 going TH400, need to collect all the parts in one day, need advice!!!
  101. LS1 in a Jeep Wrangler.....What Stall Speed would work best?
  102. What transmission tune adjustment for converter
  103. th400 shifter install pics
  104. Torque converter question
  105. so cal transmission builders
  106. I need some pics of cooler install locations
  107. tuning in 700r4 shifting patterns?
  108. tranny starting to act up!
  109. Another M6 to 4L80 Swap In the Works
  110. My Edge Converter
  111. trouble with pan leaking 80e
  112. Cooler Question
  113. WTF is up with my tranny?
  114. THM200C to 4L60E swap
  115. wiring question???? please help
  116. Shopping for a Compushift Controller
  117. flywheel torque specs
  118. Speartech m6 to 4l80e
  119. stuck shift solenoid circuit b
  120. Torque converter solenoid
  121. Tuning a 4L60E for nitrous
  122. Car not leaving very hard, any suggestions?
  123. Tranny broke....
  124. Trans range switch problem, DTC P0706
  125. TH400 Converter Question
  126. Does a stall change with more power?
  127. Trans Temps From Those Using A DashHawk?
  128. Stall Questions
  129. ACE Racing Transmissions 2,000 H/P Powerglide
  130. no 4th gear
  131. Great News...NOT
  132. What ATF do you use and why?
  133. where to find tranny cooler??
  134. trans question
  135. trans line
  136. Tranny fluid, flamable?
  137. auto help
  138. Input drum install HELP
  139. Some racing advice for a noob : )
  140. TH400'd Nissan Skyline GT-R33 !
  141. switching from manual to auto
  142. Tranny slipping?
  143. Is it broken?
  144. What are popular big stall converter codes?
  145. Question about 350C Trans
  146. Who's Running Vig.4000 stall
  147. Vibrations in reverse and cruising in 4'th under 40 mph???
  148. shift kit?
  149. Transmission Oil Cooler Installation Questions
  150. Inquiring about my Gearbox
  151. Help me pick a stall for my T-braked 4l80e
  152. ss3600 What kind of 60' times?
  153. new tran doesn't have star shaped piece in input shaft
  154. Filter Information
  155. 700R4 4l60
  156. 4L60E squealing under hard pedal
  157. Tranny is installed. - Pics-
  158. Help needed, we're baffled!
  159. Transmission and some other things
  160. shifting problems
  161. 4l80E tunnel clearancing
  162. 2 to 1 gear change??
  163. Built 4L60E help
  164. Can someone help me find circuit 1020 coming out of the PCM
  165. Transmission Gauge Fluctuating?
  166. Do you know this brand of converter?
  167. 4L60E won't move my jeep, please help
  168. 2800 stall stalling at 2000 rpm
  169. Trany running way HOT!
  170. LS1 to LS6 Swap: Pilot Bushing Question
  171. Shifter button broke!!! Please help!!
  172. Another happy Performabuilt customer!
  173. 4L60e with motor oil in it...
  174. 2003 5.3L with 4L60e
  175. torque converter
  176. yank over-rated?
  177. how would u know ur torque converter is going out???
  178. make trans stronger?
  179. No Gears...help!!!
  180. 3rd Gear gone or just slipping?
  181. A4 - A3 swap info needed (Yes I searched..alot)
  182. Holy auto Batman
  183. powerglide question
  184. Transmission fluid 1/2 quart low!
  185. 02 C5 rear end removal
  186. Transmission cooler line
  187. Brand new Performabuit Level 2, which brand of fluid?
  188. converter spacing question
  189. Trans Prob
  190. Anyone have their trans rebuilt by CPT?
  191. break-in converter?
  192. diff between truck and car 60-e
  193. ok,so coupla quick questions again about 95 trans into 96+ fbody.
  194. 07 Vette
  195. 4L60E truck???
  196. 700r4 rebuild HELP!!!
  197. th400 TICKS very loudly
  198. traction control
  199. Performabuilt question
  200. No 1st or 4th gear in new trans
  201. Not sure if my converter is locking up completely
  202. Big Thanks To Yank
  203. Who has the best rebuilt 4L60s ???
  204. Precision Industries Vigilante 3600 dumdumdum!
  205. Need local shop to pull trans near Waterford, MI
  206. PerformaBuilt Fathers day/ June sale
  207. Whos running a 2step on a nont-braked auto?
  208. Do I need a Transcooler fan for my setup?
  209. B&M Trans cooler, will it do the job?
  210. Vig 3200 owners input please.
  211. Trans cooler bypass = increased temps?
  212. broke my tailshaft housing
  213. 4L80e rebuild. Direct drum, 5 plates with wave plate, or 6 plates without wave plate?
  214. recalabrate speedo for 4l80
  215. Transmission Mount breaking repeatedly
  216. Replacing TC ?s
  217. Possible to test a tranny?
  218. Question about spraying nitrous thorugh the shift
  219. transbreak not locking up??
  220. Issues since SS3600 install
  221. tranny sponsors please help 4L60E rev. prob.
  222. what's the diff 45 & 49
  223. collum to floor
  224. Help Advise On Brand Of Torque Conv
  225. Tranny flush myth?
  226. Rebuilding 4L60E Sponsor help
  227. Ideas on flushing transmission lines?
  228. Went to track had some issues... Please help
  229. Made some Shakedown runs. Thank you Finishline Trans!
  230. hoses ontop 0f 4l60e
  231. how many quarts in a torque converter
  232. Help identifying Hurst Pistol Grip shifter
  233. help quick a4 ls1 tranny stuck
  234. proformincebuilt level 2
  235. Dranny dipstick?
  236. Which stall with 3:73's
  237. repalce tranny
  238. Tranny/ servo failure?
  239. Pro series band
  240. Any differences between 98 and 03 4L80e?
  241. torque conv. bolts and washer?
  242. TCI Breakaway Converter??
  243. 4x4 4l80-E
  244. 1999 Ws6 tranny blew 3rd time why?
  245. temp gauge on my 4L60E
  246. HELP!!!! FINDING GRADE 8 Metric Bolts for Torque converter Whats Strongest in metric?
  247. th-400 temp gauge hookup ?
  248. A4 Transmission Tuning
  249. how many of you bracket/drag racers...
  250. who can definitively tell me what it takes to use a 94/95 trans in a 96+
