PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 [132] 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. asa cam question
  2. poll- best converter for n/a or n2o
  3. Is my stall or tranny dead?
  4. Life expectancy?
  5. converter lockup control?
  6. tranny cooler
  7. fan switch for tranny temp controll
  8. Installing Torque Converter?
  9. Vigilante 3800
  10. 4L60E shot!
  11. RPM vs. MPH, does this seem right?
  12. HELP tranny dipstick tube problem!!
  13. Limp home mode
  14. recommendation on stall convertor
  15. AN ACTUAL TECH QUESTION/not which converter should i buy ?>
  16. 3600+ stall
  17. biggest stall i can run and still spray?!
  18. How To: Installing a B&M ratchet shifter into your 97+ F-Body
  19. Bad converter? or transmission?
  20. quick question... i got sent a 700r4 band for my 4l60e problem?
  21. Quarts?
  22. converter not locking up
  23. my 60-e finally died need help
  24. What Stall converter Should i get
  25. simple inquiry: gains over a yank 3600 to a yank 4000stall
  26. 3rd gear clutch blown, 4th time
  27. Looking for a modded 4L80e shift table
  28. What size stall??
  29. noisy tranny 1997 Olds Cutlass
  30. Best 60ft with Vig3200 and 3.23's?
  31. Stall Information Please?
  32. stock size pan w/plug?
  33. Thinking of going to a powerglide?
  34. 4.11 too much
  35. Slipping tranny
  36. valve body ?
  37. bouncing off rev limiter at wot
  38. car wont move in any gear
  39. To those who have had Yank and TCI converters...
  40. The 4L60E in my truck is jacked up.. HELP ME!
  41. torque converter
  42. Launching A4
  43. Having a problem with my 4L60E?
  44. new 200 page gm 2004R transmission technical manual
  45. Losing HP in my A4.?
  46. Yank PT 4000 driveablity and other questions..
  47. Power question.
  48. just installed my YPT 4000 today I LOVE it
  49. anyone know about flex plates? i need one with an older(smaller) bolt pattern
  50. 3rd gear mph
  51. tranny fluid flush for C5 corvette
  52. 01 converter in a 95 transmission
  53. Tailshaft area squealing???
  54. STR question
  55. What is the deal?
  56. 80E no reverse ?
  57. does anyone know anything about this street strip transmission?
  58. tranny shift points with flashscan wont change.
  59. 4th-->2nd downshift is a no go.
  60. TCI 4400 convertor
  61. Why is my car faster when launched in 2nd, or 3rd?
  62. Built A4 Troubles
  63. Bad Converter????
  64. tranny whine
  65. 4L60E to TH350 swap?
  66. Lower 1st gear ratio for 350 turbo??
  67. th-350 with 9" tailshaft.. what else do i need to bolt up?
  68. SS3800 Owners
  69. Where to get tranny controller for dyno use?
  70. Those with ss3600, info please.
  71. TH 350 and TH 400 Question
  72. BOLT holes on flexplate problems (TH400)
  73. Shift kit install - How much fluid?
  74. smallest diamater driveshaft??
  75. building my own t-350 or t-400 for 02 z28
  76. Transmission?
  77. Header or transmission prob HELP
  78. shift kit question?
  79. transmission temperature with 3600 stall
  80. tuning after TC install
  81. Air check clutch packs in 700R4?
  82. auto transmission HELP
  83. Torque/Stall converters. Please explain.
  84. a4 to m6 question
  85. can a mahual speedo work w/ 4l60???
  86. 4L60E sounding like a blower
  87. Order Stage IV tranny
  88. strange noises when shifting...
  89. 2800-3200 Stall Owners Inside...
  90. Th2004r
  91. Stroker engines with A4, What are their trap speeds?
  92. cam and stock stall help
  93. A few less asked stall questions...
  94. anyone had warranty issues with there cars trans after mods
  95. Which stall speed and gears are the best for me?
  96. derale tranny coolers
  97. Which stall speed?
  98. What stall speed is the best?
  99. tranny cooler hookup
  100. Best aftermarket 4L60E for money
  101. YANK wants your Story
  102. my first trans
  103. Guys w/ aftermarket shifters on 4l60e
  104. Will this torque converter fit?
  105. What stall should I go with?
  106. TH400 Rossler vs TH400 YANK
  107. Leaning on Yank, But maybe now TCI
  108. Th400 ????
  109. does TC`s get out of order !! how does it manifest ?
  110. How bout these mods?
  111. need help on TC
  112. Configuration ? TCI trans controller
  113. locking torque converter?
  114. How many of you are using the B&M Quicksilver?
  115. slap shifter
  116. Advise: Hey all have a question about down shiffting a stalled car?
  117. wont downshift!?
  118. shift problem that disappears after restarting car
  119. vig 3600 users
  120. a4-th400 conversion, neutral safety switch question
  121. Help!!!i Want A Yank Ss4000
  122. Holding the trans in gear. Easy question.
  123. fluid level
  124. Replacement For 4l60e
  125. Why my ASR is going off????HELP???
  126. Billet servo?
  127. Time for a performance rebuild, what do i need?
  128. slipping after trans stayed in gear
  129. Pro-built Automatics
  130. 4L60E and 4L65E questions
  131. questions on the shift kit for 4L80E
  132. Tranny Problem?
  133. How to get the speedo to work on a T-350
  134. Biggest street driven stall
  135. What all do I need?
  136. 4L60E Question: 4th Gear ratio
  137. stock stall in cam'ed car??
  138. 4200/vs4400
  139. Here's the problem
  140. TCI TH400 Question???????
  141. Converter and rpm's ?'s
  142. switch to th400?
  143. Tips on doing a converter swap.
  144. Bad tune or bad trans.
  145. TCI VS FUDDLE Is there a better?
  146. TH400 users..synthetic or not
  147. Burn Out Prob...
  148. Transmission Help Please
  149. What size converter for 98 t/a slightly modified please help?
  150. Source for 4l60e tailshaft housing
  151. TCI 4400 w/ TREX and 3.73s
  152. Safest base shift pressure????
  153. Question concerning 80E spacer on ls1/powerglide??
  154. After 350 turbo swap pinion angle way off
  155. need 98 truck trans wiring diagram
  156. Shift kit install
  157. LS1/Poweglide question.
  158. TC and cooler ??
  159. what is the difference between a 4l60 and a 4l65?
  160. Burnt clutch?
  161. No first gear with 4l60e trans.
  162. Tranny leak.
  163. broke my T-56 tailhousing...need help!!!
  164. Mild shift kit?
  165. tci ls1 breakaway converter
  166. transgo shift kit
  167. Is this slipping?
  168. 2001 Camaro Tranny
  169. Yank Converter???Help???
  170. Aftermarket converter, less chance of...
  171. Tranny temp gauge off 30 degrees?
  172. ss 3600
  173. best price on converter
  174. tranny will not go in gear
  175. How many runs can i do with a 4L80E
  176. what gains from changing 3,000 stall to 3,800
  177. SMI Transmission--Input Please!
  178. ? about JW Ultra Bell.....
  179. won't go from 2nd to 3rd gear 4L60E
  180. what stall do i need....
  181. TCI Controller questions?
  182. Tranny gone crazy!!!!!!!
  183. Spray through the shifts?
  184. Transmission Roulette?!?
  185. bigger cam/nitrous A4 guys come in please
  186. which torque converter is best for me?
  187. ARP flexplate Bolts, need P/N.
  188. th400 conversion, need a tune b/c of different conveter?
  189. torque converter bolts sheared!!!
  190. dumb stall question
  191. *pics* Barely New 2002 Silverado 4l60e 4x4 Transmission and NP246 transfercase.
  192. How far should I stall my SS3800?
  193. A4 vs myM6 with same mods ....
  194. Pure Evil transmissions???
  195. Finally ordered my FLP 4L65 today
  196. 4L60e rebuild?
  197. Ratchet Shifters for 2000 SS?4L60E
  198. in-line filter
  199. Normal vs Cruise
  200. Just installed SS4000 from Yank!
  201. Trans Filter Kit w/ Temp Gauge, Should I?
  202. What year for TH400
  203. WOT 2nd to 3rd Shifts "Problem Fixed"
  204. bumping stall up
  205. What Stall for me?
  206. Transgo Shift Kit installation problems
  207. Tranny Temp Gauge Questions...
  208. Goebel Transmission
  209. What trans cooler with t-400?
  210. Swapping Converter and Tranny Fluid/Filter, How Many Quarts?
  211. Yank SS4000 goes in tomorrow!!!
  212. when switching to rachet shifters in A3's
  213. Ping noise putting car into gear......did this problem get solved?
  214. Why is my trans pan still leaking??
  215. Help! sprag probs or tuneing problems ???? (need expert advice on this one)
  216. Worried about my Yank converter
  217. B&M shift improver kit
  218. Art Carr T350?
  219. To tune or not to tune...that is the question
  220. BFG's or Nittos?
  221. ss3200 or 3600 for my gto
  222. 4L60E transmission leak
  223. How much to install a Stall?
  224. How much to install trans?
  225. trans shifting problem, did I do some damage to the trans?
  226. Madman dipstick...need o-ring?
  227. Tranny shifting kinda funny
  228. Th400 Converter/flywheel Cover
  229. Upgrading converter, looking at TCI, need help QUICK...
  230. torque converter
  231. Powerglide or Turbo 350??
  232. just bought a 3600 stall
  233. Car shakes at 25-30 mph... TC problem?
  234. TC Tuning
  235. Quick Question
  236. Yank 6 Lug Mounting?
  237. converter
  238. Who builds a good th400? Help please!!
  239. Tranny temps finally under control
  240. 4L60e shifter problems- stuck in P and more
  241. Dropped two tenths with a TC, what's up?
  242. Transbreak for 4l60e?
  243. car is a DOG at low RPM
  244. a few questions
  245. Tranny pan, what is best for the price?
  246. third and fourth slipping?
  247. reprogrammed more trans stuff today
  248. tranny or converter problem?
  249. The mechanics of manual valve bodies...
  250. 700rwhp with a 4l60e possible
