View Full Version : Automatic Transmission
- 3200 stall converter - normal behavior?
- Looking to adapt 1997 4L60E trans to 2003 5.3
- 4l60e transmission slipping - HELP
- Snnx 4th super servo - GM spring location
- 4l60e Sonnax Level 2
- Th400 issues need help..
- 4l60e to lq4 block...it’s not what you think
- Tps
- Custom DCT automatic transmission in C6 Z06 corvette
- Flexplate????
- Quick Converter question
- 99 Trans Am Shaking in Overdrive
- Transgo HD2 4L80e firmness selection
- 4l60 pinless accumulator better?
- 4l80E width
- 4l60e bushings
- 4l80e converter install input, second guessing
- Flex plate for th350 behind ls1?
- Announcement: 4L60E Billet Reverse Manual Transbrake Valve Body
- rebuilt 4L60e still wont shift into 4th gear.. ** HELP**
- 4L80E automatic transmission in 2000 C5 LS1 Corvette
- Fbody 4l80 swap , only stays in high gear
- 4l60e goes forward on all gears and has trouble shifting
- Th350 Fairbanks 31006 kit
- 4L80E Pump Modification
- servos - 'vette and Sonnax 4th super hold ?
- Jake th400 auto with transbrake ?s
- Any experience/preference on a torque converter lockup kit for a 700r4 behind a LM7?
- 4l60e slip and bump on take off
- shifting promblem
- valve body (disaster)
- LT1 vs LS1 60e trans mount pad
- 4L80E Dust Cover
- 4l60e transmission code
- Should I get my shift kit installed?
- P0713 p0740 p1810
- Little showing off by customer of dyno results with our BLACK EDITION 4L60E
- 4l80 converter drag staging
- 4L60e disassembly and rebuild what is this tiny little piece?
- 1997 GMC Sierra 1500 transmission swap
- LY6 and Powerglide with mid plate???
- Cause of RPM rev at cruising and no increase in speed
- 4L80E no 3rd or 4th gear! PLEASE HELP
- 4L60E neutral safety switch connector using GM p/n connector. What pins do I need .
- 72 Pontiac Firebird TH350 to 5.3. Parts needed?
- flushing stock trans cooler?
- 2001 Suburban
- Shimming 4L60e inside a 99 Trans Am
- 4l60e slip in OD
- 4L70E Slow to Downshift 3-2
- 4l60e input shaft removal??
- 4l80e giving me fits!!
- Delayed 2nd/3rd shifts - With tune/Driving Logs Uploaded
- I NEED HELP!! 1995 4l60e
- What 4l60 easy upgrades
- 4L80E large roll pin - where did it come from?
- MSD Atomic Trans Controller
- 4l60e on a lt1
- Keep Burning Direct Clutches Level 5 4L80e NTC
- Worth restalling my yank 3600 to 4000???
- 4l80! Help!
- Live L3 Performabuilt l3 build 700r4
- 4L80E "freewheels" out of OD and/or Lockup (highway speeds)
- Budget th 400 transbrake ?
- PerformaBuilt Transmissions’ Holiday Transmission Giveaway!
- 4L60 pump alignment tool...
- Need help asap
- transmission bolt pattern
- 4l60e wiring question
- Dropped the valve body and now vehicle won't move
- Sonnax level 2 4L60E
- 4L60E, 4L80E, or TH400
- Th400 to 4l60e
- low/reverse piston wear?? 60e
- 4L60E vibration
- Converting a 4wd 8L90E to 2wd
- Car rolled back while in drive on incline and other issues
- 02 2tad 4l60e verses 03 3tad 4l60e
- 4l80e electrical components a must? I'm installing a used 4l80e into my 77 without ha
- 4l60e 3rd accumulator "Directional Switch Valve"
- How does a bump shift work?
- Newer 4l80e internals into a older 4l80e
- 2005 lq4 dished flex plate
- Flex plate
- 1992 4l80e harness for LS
- case cleaning at home
- everyone is telling me my stall is killing trans
- LS to 400 with motor plate
- Dip stick tube for 4l60E
- Only have 2 and 3
- 4.8 long crank 4l80e flexplate
- Delay 1-2 WOT shift
- Anyone used the Sonnax Overrun Clutch Kit in a 4L80e yet?
- 4L80E tailshaft, output shaft and vibrations
- 4l60e transmissions solenoids
- 4l60e low-reverse piston removal
- Trans builder in Michigan
- Problems with built 4l60e
- mileage out of stock Trans?
- 4L60E Wiring Question
- NEW ACDELCO 4L60E Reverse Input Drum are Thin walled
- 82 C10 Carbureted 6.0L/400 trans questions
- No reverse on 4l80e after dual feed
- Stall for 223/226
- 1998 WS6 TransAm A4 won't downshift on WOT :(
- 4l60e noob rebuild question
- New motor/tranny (rebuilt) 4l60e shifting issue
- Rebuilt 4l70e makes a whine
- 3000RPM Torque Converter Manners
- 4L60E Hack a Non PWM or new Trans?
- Impressive Front Planet Failure
- 99 4l60e(silverado 4x4) to 2002 5.3
- FTI converter (SRLS 0086)
- used trans any good
- Correct LS converter pilot bushing length
- New 4L80 transmission not going into gear
- Escalade ESV 05 - 4L65E to 4L80E swap?
- 1-2 accumulator ID
- Transmission leak
- No 2nd gear or reverse
- 4l60e shifting issues
- dipstick stop bracket ?
- LS1 Powerglide Conversion
- LQ4 Flexplate bolts?
- flexplate with spacer
- 99 4L80 delayed shift no kickdown
- Would 10 year old, dry stored fresh rebuild 4L60e still be good?
- 4L80E cooler line fittings
- 4L60 thrust bearings...replace or not?
- Jakes d1 trans brake issue
- Powerglide issue
- 4l80e rear planet oil problems
- 4l60e vs 4l80e
- 4l80e making squealing noise
- TH400 for Street - Keep Wave Plates or Ditch 'Em?
- 6L90E reflashing
- Won't shift out of 1st
- Help Identifying Connectors for 4L80E Swap
- Corvette servo? Shift kit? 6l80e upgrade help
- 4L60E TCC Problem
- Stall question?
- 4l60 200 firebird shifting problem
- 4L60E Dipstick Bracket
- 6l80e Hi stall converter issues
- Questions: 4L60E into a T56 roller
- 4l60e/gear question
- 4l60e reman from jeg
- How will adding HP affect the stall?
- hi 4l60e to 200r4
- Speedometer problems
- 4l80e yoke will not go in after rebuild
- Flex plate bolt/ torque
- 4l60e Reverse but, no forward gears & no manual
- 2000 4L60 E pulses per rev
- 4L65E build question
- Another 4L80E yoke question.
- 4160E trans neutral safety switch question
- TH400 Stuck 1-2 Shift Valve! Help
- Ford ATF Type F in a stock or rebuilt 4L60e?
- How bad is this? Pushed in rear plug on 4l80e when mocking it up
- 4l60e deep pan temp reduction?
- New website if anyone would like to check it out
- Hard Shifts at all times. Brown ATF <1K miles
- 4L80E Builders: Intermediate clutches
- 4L80E Leaking
- 98 TA 4l60 swap to 4l80 - help
- Need a new transmission, what are the options?
- Dipstick hash mark - fluid amount
- 4L60 Reverse Input Drum variations - why/significance?
- Jakes Performance 4l80 Recal kit, dual feed
- 4l80e Swap- Shift Noid B is On All The Time
- Extending 4l60e case.
- Vibrate/ semi hard kick from 1st gear to 2nd gear
- Madman dipstick with flexplate shield?
- 4L80e Swap into 4th gen Fbody. W/Part Numbers and Lots of Pictures!
- New Trans has cracks?
- No 4th and skipping 2nd after AFL fix- 4l80e
- replace solonoid
- i need to find Transmission fitting Tru-Cool
- No third gear
- 4l80 2 checkballs issues?
- Deciding on 9 inch rear gear choice....
- Trans cooler lines - orings at the bottom of the radiator
- Transmission fluid pan torque sequence/pattern ?
- TH400 Dipstick Options
- 4l60e transmission not working need help
- Rebuilding my first th350!
- 3-4 clutch pack
- wont go into 1st gear
- Should I add a shift kit?
- Help me pick out a 4L80e
- Gen 4 firebird M6 -4l80e swap questions
- 4L80E pump failure
- 4l80e Slip Yoke Questions
- 4l80e dual direct feed question
- Issues with my first 4l60e rebuild.
- 4L80 Tune / Nitrous Converter
- 4l80 billet input shaft
- Finally taking my 80E to the track!
- 4l80e sloppy transbrake slow to release.
- Derale cooling tube pan
- 4l60e slipping bad
- 4L60e Extremely hard shift into drive/reverse (not PCS)
- 4l60e builder
- Fbody ws6 2001 (old style vs new style 4l80swap)
- need help new 4l65e wont shift into 4th
- 6l80e cooler
- Need help with wiring
- M6 to A4, how did you cover shifter hole? Pictures?
- Need flexplate bolts longer than stock
- 4L60E input shaft checkball
- Trans cooling Line ideas?
- When is a triple disc converter needed?? 4l80e
- 4L60 won't go in any gear
- Help ID 4L60 converter
- t400 tranmission kickdown switch bracket near gas pedal 70 nova
- 4l80e torque arm?
- Oil cooler line plastic fitting caps , what P/N ?
- Fbody 4l80 ( what trans cooler should I use?)
- 97 Camaro Z28 trans
- Oil cooler hose needs replacing, what options ?
- Using a D1 brake with bump staging 4l80
- 2014 6l80e Floor Shifter
- 96 Z28 Transmission
- 4l80e acting strange after shift kit install
- trans removal question
- Jerking and bucking in fourth gear only.
- T56 to 4l60e wiring harness?
- What to replace while transmission is out?
- 4l80e Overdrive planetary thrust bearing failure
- Build for future lq9 in 96 c1500
- 4l80e Circle D triple Disk Billet stuck
- Performabuilt 4L60 after 6 years
- So what caused this crazy damage? pics included
- 4l80E RCSB Silverado Yoke Question
- Torque Converter / Gearing Question
- Untested 4l80, what to do next?
- 98 Tahoe 4*4
- Stall Converter Question for 4L60E
- 10L90 Dimensions
- Horseshoe shifter?
- Rollerizing the case on a 4l80e Question
- DD Converter selection help from Australia
- Another DIY 4L80E rebuild, Dual feed, HD2, 3-4 accumulator block off, etc
- What size converter for 6.0
- Ls swap 4l60e trans goes into neutral after 2nd gear
- trans swap question
- another 4L80E question
- Double Check: 2004 5.3 mated to a 2008 4l60e
- 4l80e pump plug
