PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. lots of a4 transmission questions :D
  2. 4l60e questions
  3. Thinking about a stall advice please
  4. 4L60E & YANK ss3600 (do i need a tune?)
  5. 4l60e in 88 ls1 caprice problem
  6. What is an acceptable trans temp for built 4L80e?
  7. Rebuilding my Yank?
  8. 4l80e converter choice?????
  9. Stock Stall speed 4L80e ???
  10. Cost to go through my th400
  11. converter install question.
  12. 4L60E Trans Tune
  13. 2000 Trans Am 4L60E quit. Need Advice.
  14. Urgent. At AutoZone, not sure which 4L60E fluid to get. lol plz help :D
  15. th350 vss sensor needed.
  16. PST driveshaft Leaking ATF at the BACK OF THE SLIP YOKE
  17. V8 colorado with 4L60E
  18. 1996 4l80e questions
  19. Measuring runout on Hughes 4004X
  20. slipping
  21. th400 to s60 driveshaft length?
  22. 4L60E and EFI live
  23. performance switch
  24. M6-->4L80e Need those part numbers
  25. Help me with my converter purchase!
  26. Yank SS4000..nitrous/gear???
  27. what bolts for cat racing sfi flexplate
  28. Fresh rebuilt 4l60e popping p1870 code
  29. Conversion flexplate headaches....
  30. Looking at getting a converter
  31. Calling Revmax!!
  32. 4l60E time for a rebuild?
  33. 4l60e rebuild problems
  34. 06 5.3 to a 98 4l60e. Flex plate spacer or not?
  35. 6L80e wiring questions
  36. Ws6 adapter + pistol grip
  37. 4l60e trans issue
  38. Sonnax Shift Kit Install and pics
  39. 4l60 fluid capacity??
  40. 4L80 flexplates
  41. PerformaBuild lvl2 users..
  42. help figuring out my 4l60e problems?
  43. 4L60E fault code advise.
  44. Should the flexplate be upgraded?
  45. New transmission has low pressure.
  46. Trans temp gauge sending unit came apart in the trans..
  47. Caution!! IDEAL TRANSMISSION!
  48. YANK's Memorial Day converter sale starts now!!!
  49. what year 4l80e
  50. 4L60e delay in forward gear Pros?
  51. Th400 slipping help please
  52. What's a good brand for a stall converter?
  53. In need of a 4l60e 3500 converter
  54. 4L80E Rollerized Output Shaft Upgrade
  55. TH400 internal parts - What HP what parts?
  56. bad ass 4l60e rebuild kit?
  57. Tcc problem
  58. WTH. 4l60e vent tube recirculating to tranny?
  59. Help!!!! Th350 swap
  60. anyone use tci 279600 billet input shaft for 4l80
  61. what flywheel to use 5.3 to 4l80e
  62. 4th gen Camaro SS ratchet shifter
  63. yank 3600 stall converter issue
  64. th400 to 4l60e questions
  65. 4L60e cable driven only, no electronics questions
  66. Lifespan of high hp powerglide between rebuilds?
  67. RPM or FLT Trans?
  68. Blew 4l60e, need new tranny!
  69. manual downshift behavior
  70. Has anyone put a 6L80E in a 4th Gen?
  71. 4l60e leaking from breather?
  72. torque converter not seated in trans
  73. Swapping my t56 for a auto
  74. Vacuum Modulator issue?
  75. 4L80E Rebuild Link
  76. 4th gens with Th400 come in
  77. 4L85E on a 4L60E tune w/ relay mod - shift table question?
  78. What is the drivetrain loss for the 4l60e?
  79. nubie 4l60 rebuild advice....please chime in.
  80. 4l60 jumping in and out of overdrive
  81. 6L90 power rating
  82. Question Removing a 4L60e from a 2002 Z28
  83. 1/8 mile et dropped with just circle d converter
  84. Pulling my tranny tomorrow for converter swap , any tips or tricks i need to know?
  85. 4l60e
  86. 4000SS or PT for first TC?
  87. engine wont turn after transmission installation? TC IS seated properly
  88. 4l60E shift kit which one to get
  89. Transbrakes for 4L80E
  90. Quick 4l80 question
  91. how much would you pay for th400 [dynamic]
  92. What flex plate for 4l80e
  93. 4l60e problems after 4.10s
  94. TH400 + Boost + stock valve body/vacuum modulator = wont shift right
  95. CircleD 2E 4000 Custom Stall
  96. 1 2 Accumulator piston at bottom of housing
  97. Help ID flywheel
  98. Confused on on running trans hoses
  99. using a 4l60 controller on a 4t65e
  100. anyone have trouble with running a dope style cooler?
  101. hit rev limiter with yank ss3600????
  102. Stock 4L80E vs Built 4L60E........how much stronger is the 4L80E....?
  103. Early Core 4L80E shifter arm stud size?
  104. New trans lost 3rd gear in its first 5 miles.
  105. A new noise croped up after rebuild
  106. holding 1st gear problem
  107. 4l60 flywheel?
  108. HELP replace or rebulid transmission!?
  109. What brand and stall converter for 4.8 w/ 70mm & 4L80?
  110. Hose on torque arm
  111. Stage 2 TH400 Special
  112. 4L80 trans brake problem !
  113. Kickdown Cables
  114. 9.5" or 10.5" Converter
  115. New Converter
  116. ok to drive with broken top rear torque arm bracket
  117. How long will trans last with H/C
  118. Tail shaft housing question
  119. Vibration after 4l80 install
  120. 4l60,80e question
  121. Power glide and a 5.3.
  122. People with 4l80 in 4th gen plz chime in
  123. 4L80e intermediate servo pin travel spec?
  124. 4.3 4l80e convertor
  125. 4l60e Rebuid Near Detroit Michigan.
  126. General Help Needed (Vid Included)
  127. How to correctly store a 4L60
  128. 4l80 & driveshaft
  129. 4L60E car stops running when shifted into gear?
  130. Have you seen a 4l80e with the "Ears" cut from the factory?
  131. 02 SS Accepts No Throttle After Trans Install
  132. kit to make speedo work on a th350...
  133. 4L60E hard 1-2 shift. ?????
  134. Modded 4L65E question/issue - trans guru's in here
  135. Excessive Converter Slip?
  136. 2001 camaro convertor wish ms3
  137. Single or Multi Disc Lock Up Converter?
  138. powerglide help to my ls1?
  139. converter and tune
  140. th400 problem
  141. Rebuild my 4l60e or go 4l80e?
  142. 4l60e major problems
  143. Help what is it
  144. LT1 vs. LS1 4L60E
  145. Best High Stall for Light Throttle
  146. new car, shift cable issues
  147. 2006 van 4.8 w/ 97 4l80e into OBS truck
  148. 6x issues
  149. Granatelli and Hughes transmissions team up
  150. Diagnosing lack of power
  151. Converter bolts for th400 swap..
  152. Introducing the new PerformaBuilt Level 3 - Plus 4L6XE
  153. What shift kit???
  154. Old Bell Housing TORX bolt Help.. New Part #?
  155. 4L80 Conversion a Success!...so far
  156. RPM Transmissions
  157. 4l60e need some advice
  158. 4l60e trans prob after rebuild
  159. 4l80e Shifting With Nitrous
  160. 4000 stall
  161. Who has Th400 reluctor ring and sensor in stock?
  162. Fti 3800 hard hit or yank ss3600
  163. Question after 4l60e rebuild
  164. Auto trans not shifting above 2nd gear
  165. Stalled 4L60e
  166. 98 trans am wont shift out of park
  167. weird problem during burn out
  168. TH350 bolt to 5.3?
  169. 98 camaro wont drive in reverse
  170. 4L60E Shift Problems
  171. Question on 4l80 controller
  172. So my transmission dip stick is stuck
  173. Converter Stall?????
  174. Local area trans rebuilders
  175. TCI converter won't stay locked
  176. Shift kit on LS1: Superior VS transgo HD-2 VS transgo SK VS B&M 70360
  177. 4L80E Rated @ 1200hp
  178. 3600-4200 stall questions for those with experience
  179. 4L60E Vs. T56
  180. 4L60E Upgrades
  181. Realy Monster Transmissions?
  182. Mad Dog the Best!!!!
  183. 4l60e shifter search help please
  184. Will a ls1 flexplate fit a 4.8???
  185. how to switch over a 4l60e to a 4l80e
  186. 06 4l60e servo swap
  187. 4l60 shifting 400 rpm too soon as well as rev limiter dropped 400 rpm
  188. Sonnax HD 2-3 shift valve cure flare?
  189. need help 4L60E to th400 or 700r4
  190. Stock ls1, 3.73s, stock 4l60e + slicks?
  191. what 4l60-e trans will work
  192. powerglide transmission builder in atlanta?
  193. PerFormaBuilt MayDay SPECIAL
  194. Torque Converter Install On A C5
  195. Plz help th400 yoke
  196. 4L60E yoke
  197. Which mount?
  198. th400 guys step in
  199. tci rebuild kit 4l60e
  200. weird problem, local builders puzzled
  201. 4l60e.. wtf is going on, perfect 4th gear... no 2nd gear at all
  202. can somebody with a eztcu help please?
  203. 4l60e suck 3rd transmission
  204. 4L60E question
  205. no movement in any gears after transmission installed
  206. 6l80e 2010 trans in 65 Chevelle
  207. 4L60E slipping out of 4th
  208. 4th Gear Flare?
  209. 95 formula tuned for 4.10s running
  210. 4l80e builders
  211. Stock Converter ?
  212. 4L60E Not Downshifting.....
  213. Will powerglide work or th400?
  214. confused on backup light, nuetral safety, m6 to A4 under dash harness wiring.
  215. Speedometer symptoms and diagnosing
  216. need 4l60e tail shaft housing asap
  217. No help elsewhere, I need help. Horrible noise after installing new flexplate
  218. MAD DOG TRANSMISSION 2013 log
  219. Newbe here with question
  220. 4l60e no od or lockup help
  221. 4L60E shifting question
  222. Transgo 4L60E HD3 kit help
  223. 4L80e swap w/ stock M6 driveshaft - sanity check
  224. Effect of new gear on shift point?
  225. Th400 converter play
  226. 4l60e wot shift HELP
  227. 4l60e 1st gear slips (maby low pressure) need help
  228. How much hp loss from 6spd to th350?
  229. tcc clutch brake switch connection
  230. hairline crack coming from pan bolt hole
  231. Anyone have any info on Monster Transmissions?
  232. 93 auto transmission help!!
  233. Which vehicles did slip and fixed yoke 4l80e's come from?
  234. Cooler
  235. 4l60e with 3600 stall need advice asap!!!
  236. quick stall question
  237. 4L60E Tranny Question
  238. '93 Automatic Transmission
  239. 4L80 issues... any educated guesses? CKP FMVB
  240. Converter Identification
  241. 4l60e 3rd gear issues need help
  242. Jake's Performance Transmission Sale
  243. 2002 4l60e in 2007 Silverado Speed Sensor ?
  244. 4l80e U Joint
  245. 4L60e rebuild issues..
  246. 4l80e out of a doghouse van
  247. problem with 4l60e swap.
  248. Which to do fist, Stall or Gears
  249. 4L60E, no 2nd or fourth
  250. What's the connection between spark plugs and shiftpoints
