View Full Version : Automatic Transmission
- Whats Wrong
- 300rwhp - converter options
- converter and shift kit question
- Transmission Perfection!!!
- Which new vertor for my set up?
- Vig3200 or Midwest4000? HELP!!!
- Trans program problems
- HPP3 shift firmness.. INFORMED OPINIONS PLEASE!!!
- Trans not shifting on strip
- 4L60E acting up
- Sent the TC back for a restall.....
- output shaft...bent? how to check?
- Rebuilt my pro yank 4L60E
- TCI3500SS Installed !!!
- midwest 3000 2.0 installed.oh what a difference
- one cooler or two?
- TH 400 capacity
- Stall install
- What size driveshaft for TH400
- Differences in Transgo shift kits?
- a4 question
- Someone make a billet steel tailshaft housing! Please!
- what size tranny cooler?
- Can my Yank SY 3500
- Larger cooler or deep pan?
- What is best T/C for buck and where?
- Quick question on STR......
- whats the diffrence between the 4l60e and 4l65e
- Quick question? need anwser fast!!!
- changing a4 settings with edit?
- What does everybody think...
- will 4L60e transgo work on ALL 4L60e's??? friend has a 4.3L blazer w/ 4L60e
- Midwest 3200/2.0 measures 30hp+ loss unlocked -- opinions on Vig multi-discs ?
- Stall guys what Tires are you running.
- Need T/C installed in Michigan
- Few basic TH350/TH400 Questions
- tq converter question
- Shift Kit Question
- Write-ups on changing solenoids?
- Questions about my 2nd Car's problems
- shifting problems
- Which converter?
- biggest baddest nitrous converter
- shifter for manual 4l60e ?
- Manual Valvebody
- TH400 guys....what shifter
- tranny temp sending unit
- question about my trans...
- How long does it take for a restall?
- TC lockup issues??
- Installed Yank SS3800
- shift kit question
- 200-4r to LS1 mounting bolts
- 200-4r TV cable setup
- Converter for best of both worlds: Nitrous & N/A?
- th-400 with lock up
- need info asap please, 4l60e gurues
- Tranny making noise during shifts
- 2-3 shift going soft help!!!
- Time for stall
- Check this tranny out for me!!!!!
- Tranny cooler hot?
- A4 2-3 shift
- 1 - 2 sticking you guys might find this interesting
- car started in 3rd at wot?
- OE 4L60E PN please
- Anyone running a Yank th400 ?
- TCI effiency
- Sy 4000
- Pro Series band, anyone ever have one break?
- VIG 4000 Dynoed--->NOT PRETTY!!!!
- what do i need to do?
- when a TC goes in....
- Just installed my TCI converter and......
- How big of a cam can you go on stock converter?
- Worth it to go from TCI 3200 to 3800?
- A4 to A3 swap???
- How much should I sell my 200-4R for?
- Need help diagnosing trans/convertor problem
- Driveshart noise?
- keep my tci 3500 or switch to 4400 tci
- Anyone with 224/112 on A4 got a tune file i can check out
- how does a Trans cooler work?
- Intermittent trans problem - Autotap scan included
- What convertor to get 383 LT1
- manual shifting A4
- I broke the rotor...fawk
- where to launch at with vig 2800
- bad noise...please HELP!!!
- What length DS for Th400 - Moser 9"
- Tci 3800
- Tranny cooler?
- TCI bolting to flex plate?
- Skip Shift Question
- DIY TC install
- TC choice, good or bad?
- bolting TC to flywheel
- thoughts on locking up a high hp combo on the dyno?
- tourque converter install?
- TC driveability
- motor and tranny
- B&M deep pan installed
- Is it easier to yank the tranny with stock exhaust
- anyone use PTC 3500 !
- Shift points with SS3800?
- Question about line pressure at idle..
- What is a good all around Converter
- Verter question
- Stock/TCI converter weights
- th 350 conversion
- Strange vibration need some insight
- A4, ssf 3500, and slicks.. will the 10 bolt take it?
- position of jack, please hurry!!!!!!
- Vig3600 for $500 or TCI 3800 for $350?
- shift solenoid
- whats going out on my tranny?
- SLP/yank 2800 vs. Vig 2800
- Big Questions
- What is the record for an 4L60E???
- Pulling Transmission...
- Big cam shifting problems?
- trans- go installed
- B&M trick shift fluid
- Identify a Stock Converter
- FTRA and a cooler.
- Lost second gear...
- Anyone running a T-400 with gear vendors overdrive?
- signs of a bad TC
- How fast in the 1/8? 2000 A4 WS6 100 shot?
- Cooler Install....Quick question
- How much RWHP can a stall eat up on dyno?
- b&m deep pan install ????
- WEIRD PROBLEM..... help???
- Earl's braided line fittings on 4L60E
- Shift duration?
- Shifting Problem In High Rpms!!!
- chaging tranny filter, cannot get seal out
- TCI any good?
- yank 3000 vs. Super Thruster 3500 for street application, help me decide
- WTF is WRONG with this POS
- hesitation
- ???? of the day ????
- A4 and 4.10 gears users inside please
- tires with a TC?
- A4 issues- Short shifting, logs here. Also, lockup in 4th @ 33mph. Nogo? anyone?
- Aluminum flywheel (A4)?
- anyone running a ss3600
- Is putting an Auto into N while at a stop light bad?
- which STR in a TC?
- TH350 bites the dust :(
- lost first and third, what to do?
- Is the torque arm bracket on the tail of the tranny the same on the m6 and a4?
- Shift kit already installed?
- What should turn at the front of a 4L60e?
- lowered cars and deep transpans
- Model year trannies questions
- please i need help with torque converter!!
- 4L60 Shudders
- TCI SSF 3500 is it to much?
- Reccomend a convertor for my nitrous application?
- measuring converter effeciency
- Can we loose rwhp??
- AAAARRRRRGGGGG! Tranny gone!!!
- thumbs up to flp
- Screwed Up Tranny
- Converter Vibration?
- New best time with stock converter
- Need help with converters !?! Explain me what they do and how !!!
- come inside if you have a stall bigger than 4400... couple of questions
- Verter Question
- real bad flexwheel.. reflash conv??
- No second gear?
- Locked Converter on Dyno
- where to get a flexwheel?
- Sealed auto tranny?
- TCI 3500 Install
- 100% street driven with TC come inside please.
- need help!!
- SS4000 users, need info please.
- things NOT to do with a TC...?
- Problem With Trango Install. Help!!!
- yank tranny and 3/4 pack
- Coan converters, Who know's about them?
- How hot do your trannys run??
- vigilante out of balance?
- bad flexplate?
- Yank converter and synthetic trans. fluid.
- SS3800 rocks my socks!
- How many people have run 5.99 or lower with a 4L60E???
- Tranny overheating, please help before I go nuts!!
- If I Did Change...
- Speed Inc. Stage 3 4L60E guys
- Thoughts on HUGHES?
- shift points
- Tranny trouble
- I need to clarify some things about PI
- Is a 6.0L flexplate a different depth than ls1 for th350 swap? GM Spacer?
- Whats wrong with my trans!!
- Rossler 4L60E
- Time to switch verter" or stick with the same one?
- 4l60e
- Yank dealers ?
- ATF change
- TC Huh
- Aftermarket shifter
- STR Question.
- A4 Dragsters- What to do about Trans temps..
- 2-3 Shift Solenoid....
- Dyno & Locking Up Converter
- Using HPP3 shift firmness to compensate for screenless MAF?
- Website for 4L60 -> T56 swap in LS1?
- a4 problem, big time
- Big Problem with 3-4 clutches
- Tranny Problem Need Help!
- got my SSF3500 in.. have a question..
- Does anybody have good directions for the Trans-Go kit installation?
- Car shifts to wrong gear
- TCI Flexplate powdercoated ?
- Best tranny?
- Who Makes the BEST 4l60E
- SS4000 or SS4000E
- New Rebuilt Tranny, weird noise
- Parts for my rebuild!!!!!!!!!!!
- PI Vig 2800 or PT C-5 High Stall.
- Going TH400, special parts my ass.
- recalibrate pcm for high stall
- those who own a Yank SS4000
- What can cause this kind of carnage?
- What can I expect going from vig 3,200 to a 3,600?
- Truck 4l60e to TH400 swap
- converter installation cost?
- Anyone running a PYE 3600???
- How can I tell if my converter is effecient as its rated at?
- How to launch A4 with drag radials
- PT4400 Installed
- Get ready,testing a TP4400 VS VIG3800
- shift lag
- Those with the Trans-go come in.
- whats up with that variable stall valve body thing?
- rev limiter going into 3rd
- Just a Few Questions.
- LS1 to TH350
- WS6 owners
- during a TC install...?
- automatic tranny issue...
- Restalling a converter?
- Ways to cool the automatic.
- stall and gear combinations
- What do you think???
