PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 [148] 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. just got new tranny installed
  2. Shift kit?
  3. What size stall can I run on street tires with 3:23's?
  4. TC Advice
  5. 3600 vigilante and hooker Lt's going in hp gain?
  6. Need serious help!
  7. Death Knell for my trans?
  8. rearend gear ratio
  9. What Temperature SHould the Tranny Run On Average?
  10. Reprogram computer for Converter?
  11. Those with 4000+ stall on daily drivers
  12. deep trans pan or not?
  13. new ray bestos z pak ???
  14. SS3600/3800 with stage 1 tranny
  15. Help with TC Lockup Switch
  16. PT4000: 3.23's vs. 3.73's
  17. wut stall to buy
  18. Blinking SES
  19. Tranny question
  20. how much for shift kit installed
  21. Tranny or Rear?
  22. any advice for trans. cooler install w/high cap. radiator?
  23. Should I "break in" the stall?
  24. Aftermarket converters eat up hp??
  25. M6 guy needs help w/ A4 w/ stall!!
  26. HP loss with TCI SSF
  27. Trans slipping Help!
  28. LS6 swap
  29. 5th time
  30. 4L60E, 4L80E, or keep T-56
  31. car wont run after th400 and 9 inch swap?
  32. Anyone spraying a tcs 4200
  33. Vig 3200 to a PT4200 results?
  34. When Should the Stall Unlock?
  35. Another Tranny Question
  36. lockup issues on dyno w/ vig 3200
  37. No Over Drive (4th Gear)
  38. FYI- TransGo mag. article
  39. Tt3000???
  40. Dumb lockup question???
  41. Torque converters and Efficiency
  42. Ordered The Tc Today
  43. Which direction should I go.
  44. where is the EPC screen
  45. What stall for a bolt on LT1 car?
  46. Break in Period on a TCI SSF 3500?
  47. Need help with Transgo Install(only got paper instructions)
  48. What would happen if...
  49. Need Help! Please
  50. Mod Marker
  51. Unnable to hold a stall
  52. Questions about a Rossler TH350.
  53. broke a solenoid on tranny need help badly.
  54. Anyone use Royal Purple ATF?
  55. anyone have pics of a B&M pro-stick installed?
  56. Anyone using a Coan coverter?
  57. launching a SSF 3500 on 16" nittos
  58. Roll races...what STR with my VIG 2800???
  59. 4l60e
  60. Who has a YPT in their daily driver?
  61. Trying to understand
  62. Converter ?'s
  63. What the hell is going on with my Z?
  64. is it slipping?
  65. Stock tranny and a PT4400 TC
  66. Big cam and vacuum modulation
  67. What parts for a performance rebuild?
  68. Who sells..
  69. installed built tranny and different converter, now shifts 500 rpms sooner??
  70. The other voices in my head made me ask this question:
  71. Trans Go, TCI 3500 and TM ??????????
  72. TCI street fighter 4l60E
  73. should i change to f type fluid?
  74. WWT: my fresh auto for T56.
  75. Is there a difference in converters?
  76. whats wrong with my tranny
  77. Art CarrTC's
  78. installing LS1 4L60E to a '96 4.3 V6
  79. Converter question
  80. How Much Transmission Fluid Needed?
  81. !@#!# 4l60
  82. Tranny Help!!
  83. th400 cluth engagement wires
  84. Trans removed - Transgo install q's
  85. whats flp charge to install trans?
  86. ????? Auto or manual ?????
  87. trans prob?
  88. New dry converter- loose/clank normal ?
  89. 3000 or 3500 stall?
  90. Vacuum Modulator Line
  91. Performance Automotive and Transmission Center....good , bad, ...?
  92. What is the proper way to launch in an auto?
  93. Why shouldn't I get on it in OD?
  94. tranny mount confusion...
  95. Trans. wouldnt shift into overdrive???
  96. 700R4 on a 99 LS1???
  97. Does a new converter need tuning?
  98. Shift Kit.. Is it a MUST?
  99. Launching with 3.73's & ssf3500
  100. 60' times with pt4400???
  101. which Poly Trany Mount for TH400/BMR Crossmember
  102. Are the converters swappable from a truck to Fbody?
  103. Help
  104. Changing converter, What all is needed.
  105. Best way to change trans fluid
  106. The M6 guy's are gonna kill me.
  107. Will this Cam/Converter Combination Work?
  108. Where to get fittings, braided lines, etc. for B&M 28k GVW tranny cooler?
  109. LS1 Trans dip stick readings...
  110. How Many Qts in a 2000 WS6 Automatic trans?
  111. Trans. Temp. Problems.......
  112. Tranny Life
  113. who has used the yank crossmember?
  114. WOO HOO!! Finaly Here
  115. what the heck is goin on?
  116. guru needed!!!!
  117. convertor install question
  118. TC install
  119. tranny question
  120. in this day & age, customer services counts!!
  121. Built 4l60e
  122. Another satisfied PT4000 owner
  123. Loud "clunk" after Vig and Transgo Install
  124. Accumulator Piston ????
  125. convert 4l60e to 4l65e
  126. Will it be ok not to use a trans. dust/shield?
  127. Need a new tranny
  128. 2-Step in Auto?
  129. Torque converter dyno results from Yank?
  130. Those using the TCI 29.1 SFI approved flexplate, inside please.
  131. OK To Use Type F Trans Fluid?
  132. What Do You Think?? Tci 3500
  133. Tranny Install
  134. th400 users...speedo question
  135. Need Your Advice: '01Z, 3.23, Daily Driver
  136. manual 6spd to automatic 4l60e
  137. Just ordered my Torque Converter
  138. Is there more than 1 way to install a tranny temp. guage?
  139. Transmission Temp. sensor?
  140. 95 v6 car..help
  141. 2500 or 2800
  142. Thoughts about 4L60 & 4L80
  143. M6 to Th350 Swap
  144. Yank Stealth converters
  145. Non f-body trans??
  146. 2 tranny coolers
  147. what gears, shift kit?
  148. Stock Gear Ratio A4???
  149. Trans. Temp?????
  150. A good deal?
  151. SFI Flexplate available for LS1/Th400 ?
  152. 3.4' gears
  153. HVAC controlls stopped working?
  154. Is it Tough to Install a shift Kit?
  155. Midwest 4000/ 2.5 str opinions
  156. What caused all this?
  157. Converter stall and brake stall?
  158. what converter will i need
  159. th400 swap questions
  160. About to spend $1500 and need some advice
  161. 4l60e and 10s
  162. What is wrong with my transmission (A4)? Is it about to go boom?
  163. what about this kit?
  164. Who sells a built 2004R for 4 Gen fbodies?
  165. Stall converter on daily driver?
  166. 4L80E Swap?
  167. How streetable?
  168. Just Ordered My Tci 3500 Today
  169. Which tranny cooler should I get?
  170. yank SS 3800 on stock
  171. Torque converter?
  172. SS3600 or SS3800
  173. TransGo PSK vs HP kits? (quick q)
  174. Anyone else sparying with a ssf3500?
  175. lightweight th400 vs th350
  176. 3500 too high for me.
  177. Vig 2800 to Vig 3200
  178. Best TC for my 2002 Z28
  179. Pics of Tranny Coolers installed pease
  180. how do i fix this problem ???
  181. Leaking 4l60e, bad news?
  182. Neutral Saftety Switch problem (A4 to TH350)
  183. TCI Flexplate With yank?
  184. Whats the best material to use for the lines on the tranny cooler?
  185. Those that are in the process or thinking about doing a 200-4R conversion...
  186. Do any 4th gen 4L60E's lockup at wot without a switch?
  187. How 2 disable neutral safety switch, wire up back up lights, & wire up lockup switch?
  188. How long do you think your A4 will last
  189. 4th gone, 3rd kinda gone?
  190. tranny slippin???
  191. Changing Vig Converter
  192. Does TCI make a 4400 converter too?
  193. Planetary damage?
  194. what hapens if your lock up clutch slips and how much can it take?
  195. What tranny in old turbo ta's???
  196. will 3.73's alleviate verter looseness???
  197. ssf 3500 or ssf 3800
  198. Th400 users?
  199. SS 3600 or 3800 with moderate cam ?
  200. Changing my setup & need some input (Colonel)
  201. Proper shift extension drop in between gear?
  202. what rpm
  203. http://www.fbodytrans.com Tranny
  204. Pro Ratchet Install with M6 console
  205. which yank 4 me or anything else
  206. how about this setup?
  207. Going from 4000 to 4400 stall?
  208. Is Tuning Needed after a TC install?
  209. M6 to T400..gear selection
  210. Tranny Dying, Converter flush?
  211. Opinions on TCI Competition 3800
  212. Burned tranny cause odd running?
  213. Best Automatic Transmission Fluid?
  214. Derty,Raugh or Steve
  215. Tcc Lock Up Help
  216. TH400's
  217. The conversion has begun! I have a few questions.
  218. Anyone know weights of different TCs?
  219. will a 3200 tc shorten the tranny life
  220. Which tranny to get?
  221. Tranny Mount
  222. Poly mount vs stock mount
  223. Guys that got gears after converter-come in.
  224. Converter selection help for a oddball car
  225. ok to mix atf brands?
  226. Paging Derty: info about th400
  227. 4L80E Manual Valve Body
  228. everyday?
  229. Cam in stock 4l60e tranny...
  230. Which IS the right Torque Convertor?
  231. tc?
  232. Where to get an 4L60E
  233. PT4000 2.7 vs. SS4000 2.6
  234. Torque Converter & TransGo Shift Kit (long)
  235. Tranny Cooler Line Size
  236. which stall to get?
  237. Does the tranny shift at MPH or RPM in OD?
  238. TCI Flexplate or stay stock?
  239. YPT selection 4000 - 4600?
  240. SS3600 and everyday driving?
  241. Dyno questions with a stall
  242. Tranny slipping up high
  243. Moderator Announcements: Raughammer and Derty are now in this forum
  244. Will a VIG 3200 out of my 2002 Trans am work in a C5?
  245. Is the '99 4L60E any good?
  246. Which Tranny Fluid?
  247. Need Help chosing Converter
  248. Torque Converter installation...
  249. Article about 4L65E in Super Chevy!
  250. shift pts with heads & cam?
