PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 [156] 157 158 159 160 161 162 163
  1. Does my new slave have the throw out bearing installed..see pics
  2. 4L60E stage 2,3 build up???
  3. Will an LS1 mate up to a 4l60 transmission?
  4. Torque converter bolts
  5. Stock Covertor Stall?
  6. Will my Vig 3600 swap over to a 4L80E?
  7. MPH shift points for A4 and M6
  8. Swapping trans to an A4 how do you program the computer?
  9. TH400 driveshaft?
  10. CONVERTER SWAP HELP
  11. how hard is ring and pinion install?
  12. Moser 12-bolt Owners... install question
  13. Yank SS3600 is in and....
  14. Need A Tranny Cooler
  15. Tranny cooler with 3600 converter?
  16. My ES poly trans mount install results with some tips....
  17. My ES poly torque arm bushing install , done the easy way........
  18. what size gears & torque converter for my 2001 A4
  19. T400... Lokar or Madman dipstick?
  20. Converter Question Daily Street Driver?
  21. 3600 stall
  22. converter problem
  23. How to tell which Super Yank you have
  24. Any Literature For Bullet Proofing 4L60E?
  25. Which aftermarket shifter for 4L60E?
  26. Trans cooler install ?
  27. 4L60E Vacuum modulator ??
  28. ST3500 Questions
  29. TH350 conversion, need help
  30. Got Spec stage III installed today.. a few ?'s
  31. Thinking of making the Cannibal an A4 ;)
  32. will an st3500 hold up with more mods
  33. Car stalls out after converter install
  34. Transgo shift kit?
  35. 12-bolt install questions
  36. Newbie Converter Question
  37. Newbie Converter Question
  38. TH400 Conversion Q's
  39. Turbo 400
  40. 4L60E Slipping @ 1-2 and 2-3 shifts.
  41. What are possible signs of when a converter takes a dump
  42. I have a TH-350 converter question
  43. tuning and high stall convertor
  44. How much to stall? Vig 3200!
  45. weird response from tranny shop about converter install.
  46. Converter Problem
  47. Tranny Question... A4
  48. Front Pump Install..
  49. YANK 3600, SES LITE... GOES INTO LIMP HOME MODE?
  50. A4 to M6 swap done
  51. what else do i need to install th350??
  52. How much space between the torque converter and the pump
  53. What is needed to install T400 into A4 car?
  54. 3.73's in A4 cut down top MPH too much??
  55. Which trans..FLP or LS1 Speed stage 3?
  56. Converter / Drivability Question
  57. Big Problems with Vigilante 3600
  58. driveability of high stall convertors
  59. Quick Converter install question
  60. need install tips for B&M hammer shifter
  61. huge converter causes stress on bottom end?
  62. HELP, my tranny or my Vigi3200 may be fried
  63. Need Help Choosing A Stall Speed
  64. Vig 3200 ?
  65. t.c.s. rocks
  66. Who's running a vig3600 and how do you like it?
  67. McLeod Rev-Lok II - Install Questions
  68. Is this converter good enough?
  69. adj master pedal pressure
  70. A4 Electrical Tranny Problem?
  71. Where do I fill my TH350 too?? help!
  72. Converter not locking consistently
  73. my first cam and converter, what should I expect guys???
  74. Stall verter causes LOSS in trap speed??
  75. VIG 3600, PROBLEMS W/SES LITE....
  76. Got Yank SS3600 last night.
  77. A4 guys inside please,,, Need help on what gears i have,,,bought used
  78. how built is my th350 gonna have to be??
  79. prices??
  80. how much will 4.10's help my A4?
  81. 4L80-E Discussion
  82. Gains from vig 3200 to 3600?
  83. Installed Vigilante 3600 - few questions & issues
  84. bmr th400 trans x member is JUNK!!!!
  85. Automatic Vs. 6-speed
  86. mounting my tranny cooler.
  87. Acceptable Tranny temps?
  88. Vig3200... 2000 corvette compatible?
  89. Spec Stage II Install Results...
  90. How much oil will leak out of the pan on my a4 when I pull it?
  91. A4 shifting prob...
  92. my verter
  93. trans cooler necessity
  94. Converter Swap from Camaro to Vette
  95. moser 12 bolt install?
  96. Problems with my A4 not down shifting, help
  97. best holding power "AND" longest lasting 4l60E?
  98. Any differences between LT1 and LS1 converter swap?
  99. Installing new slave in my '98 formula
  100. A4 to M6 swap, help
  101. Did i make a mistake buying a Yank SS3600??
  102. Convertor Question driveability
  103. converter only guys !!!!
  104. Any C5's with TCI verter?
  105. removing the input shaft checkball w/ converter swap?
  106. A4 to M6 swap info...
  107. Anyone have a tranny cooler write-up...
  108. Urgent! Tranny Install problems
  109. Moser 9" install, any good sites???
  110. can 4l60 be put behind ford engine?
  111. What size tranny cooler?
  112. Tranny just went, is FLP still the way to go?
  113. Question about a 700R4
  114. converter stall?
  115. converter?
  116. A4 with 4.10s ROCK!
  117. spec installed
  118. A4 problem after cooler blew a line
  119. 4L60E to T350 what tuning for computer.
  120. Break in time on newly built A4 transmission?
  121. locking converter in 2nd???
  122. How do you open a torque converter? Want to take pics.
  123. "OD" vs. "3rd" or "D" for WOT 4L60E driving, which do you use?
  124. Just Installed Spec Stage 3 clucth... damm hard!
  125. 4L60E Insanity
  126. TH350 and stock shifter
  127. Noise coming from the flexplate, looks fine to me? (EDIT: pics included!!)
  128. trans temp sensor
  129. Owners of A4 with 3.73's need to know
  130. A4 tranny issues
  131. vacuum modulator for 4l60e
  132. i need Directions for A4 Transmission removal
  133. Vig 3600 installed (SWEET)
  134. TH350 LS1 Swap: Will standard TH350 converter bolt right up to flexplate???
  135. Trans temp guage questions.
  136. A4 to M6 swap questions....
  137. how to be SURE converter is in all the way
  138. trans fluid! what to buy for th400
  139. 4L60E to TH350/TH400?
  140. converter and SES code 1870
  141. TP4400 + BIG cam vs ST3500 + BIG cam...??
  142. Any alternatives to hose clamps for trans cooler?
  143. Install Yank 3000 and now setting a misfire code?
  144. Please help me decide on my vig restall.
  145. Need advice on TH400 setup???
  146. stock auto tranny ratio
  147. is it ok to leave torque convertor attached to flywheel
  148. Need Tci and midwest converter times!
  149. Installing converter Monday-Phone help?
  150. Whats the verdict on line pressure.
  151. Revs to leave line @ with Vig 3200
  152. converter?
  153. 4L80E, has anyone done this yet?
  154. T400/ Automatic Valve Body Q's?
  155. 2nd 4L60E Failure in 3 Months
  156. Converter not locking...
  157. Poly engine mount installed on DR side... impressions:
  158. gear install
  159. Pro 5.0 install help Please!!!!
  160. too much stall
  161. Basically Stock w/Yank ST3500 --Opinions
  162. Any H/C/converter guys on stock 4L60-E?
  163. Install moser 12bolt rear feel really stiff now
  164. CONVERTER QUESTION
  165. What is the correct way to install a Yank SS-3800?
  166. How to Dyno a Car with vig 3200 stall
  167. Paging TH400 guys options questions within
  168. Converter Bolts Too Long
  169. Anyone running a lockup converter in TH400?
  170. Yank SS owners how are they doing?
  171. Converter Gurus inside please!!!
  172. newbie to this converter stuff.. few ??'s
  173. anyone ever have a Midwest3600??
  174. Let’s talk about life expectancy of a built 4L60E…
  175. Who here is running a TCS converter?
  176. Installed type F Ford fluid with good results
  177. Some TH400 questions...
  178. turbo 350 install cost?
  179. H/C Go in, A4 tranny goes out
  180. weight difference b/w MN6 and A4 trannys?
  181. TCI converters vs Yank - comparos?
  182. Autotap and line pressure
  183. Converter... Cut and Clean or new?
  184. TH400 swap guys, where to find...
  185. How to empty torque converter of fluid?
  186. Where do I need to put my tranny cooler???
  187. Tranny Cooler install
  188. 4:10's in an A4 with a Hi-Stall
  189. High Stall guys, how do you dyno your cars?
  190. Considering a change from a Vig3200 to a PT4400
  191. converter shudder
  192. SY3500
  193. A4 gear ratios (4th)
  194. how loose is your th400 convertor
  195. How can I tell which gear my a4 is in?
  196. A4 help:lost my D and OD?
  197. Are all 4th gen torque convertors the same?
  198. th400 want 1.3-1.4 60' yank? COAN???
  199. Thanks to East Coast Supercharging for installing my 12 bolt!
  200. SS converters
  201. transgo install costs
  202. Hi-Perf Associates 4L60E is AMAZING!
  203. 4L60E Rebuild Parts List... Need Suggestions
  204. A4/Converter guys.....what do u race in?
  205. Getting new converter what should I try? YTP4000 or Phoenix 3800 or MW 3400
  206. what converter
  207. Just got my 4l60E rebuilt...
  208. Someone help...TH400
  209. Tranny Temp Guage
  210. What cam for Vig 3600 bolt-on car?
  211. Yank Trans Went Out
  212. where to get convertor installed???
  213. Trans cooler
  214. Vigilante converters' TRUE stalls?
  215. Vig 3200
  216. A4 rear end gear movement, how much is normal?
  217. What TH-350/400 converter is everyone using?
  218. Flushing a trans cooler
  219. Th350 rebuild in Houston area
  220. verter install cost
  221. Guide to building your own Pressure Bleeder!!
  222. Need a converter
  223. which built 4l60e
  224. Question for those with Yank 4L60E crossmember for mounting stock TA on it...
  225. Diff Fluid for SLP-installed Auburn Hi-Torque
  226. Stock stall? And shift kit question.
  227. To do or not to do Torque Converter
  228. Need HELP! Should I get a yank SS 36 or 3800!?!?
  229. Which converter
  230. Tranny/verter GURU's needed
  231. Converter Install
  232. 2800 stall
  233. colonel converter
  234. th400/ use rad & OR trans cooler?
  235. th400 which trans mount?
  236. Where to put a Trany cooler?
  237. GM Techs - M6 to A4 wiring?
  238. Does anyone here use an ATI trans or converter?
  239. No more 4L60E, what are my options 700/200R
  240. How many quarts of ATF does the 4L60e take?
  241. Converter Question help please
  242. How much power/abuse did your stock 4L60-E take?
  243. 3000 Vigilante Converter, 1st gear pull off
  244. Converter / Trans Problems
  245. How much heavyer is a th400 to a 4l60e
  246. gear and converter questions
  247. Rebuilt 4L60, want go into OD and lock-up and no 1st gear with 3000 Vigilante HELP?
  248. No nothin about a Stall
  249. A4 Aftermarket Shifters
  250. Tranny help-Late shifting when cold 4L60E
