PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 [162] 163
  1. problems with vig 3200
  2. 4L60E Questions
  3. Pro 5.0 installation
  4. Compare Yank And PI Customer Service
  5. Could an underdrive crank pulley cause a converter unlocking problem?
  6. SFI approved flexplate for ls1?
  7. McLeod Iron Disk Installed!!
  8. PI3200, ST3500, or ST3800 ?
  9. Yank 3000 vs. Vigilante 2800
  10. QUICK: I need a write up on dropping a A4 from a 2000!
  11. ST3500 problems... Yank customer service?
  12. Someone told me that trannys built by Yank have problems
  13. Yank Trans?
  14. What's the difference between a TH350 and a TH400?
  15. Locking Up the dang Converter!...
  16. TCI Converters??
  17. Jay Fisher/Stealth torque arm installed
  18. ST3500vsVIG3600
  19. Has anyone ever lost 2 tenths and 2mph after a converter install???
  20. Bolton cars with 2.73's with ST3500 what are your bestshift points for the 1/4?
  21. Installing Gears
  22. Please post all info on 4L70 and 4L80 trannies
  23. What does efficiency mean dealing with convertors?
  24. Need help choosing a TH350
  25. Installed BMR LCAs and adj panhard today...now car feels funny...HELP
  26. Will I be happy with 3.73's with my Vig?
  27. what pin due i tap into for a converter lockup switch for a 2001
  28. Ok to install SFCs with no motor/tranny?
  29. SY3500 in a 2001 z - Gotta question
  30. TCI converters.....
  31. Tranny Temp guage install
  32. Want a harder hitting converter SY3500>>>ST4000 Good choice?
  33. Who here has/knows anything about an SY4000?
  34. Question About Clearing Converter Codes...
  35. Vig converter recieved today.What stall is it?
  36. Do TH350/400's have engine braking?
  37. Yank 4400...
  38. THE REAL DEAL: ST3500 v/s PI3200
  39. Convertor choice?
  40. POLL: How Much Trap Speed Gained w/ Your Converter
  41. hows Vig3200s and cams?
  42. TH350 conversion kit for sale
  43. what do you think of this converter/gear combo
  44. Anyone have Eibach Sportlines with FLP's??
  45. 3.73's and a vig3200???
  46. How Much Can The Rear REALLY Take (A4)
  47. Anyone running a Gear Vendors unti with their TH350/400?
  48. M6 to A4 conversion?
  49. How many LS1's are running around with TH-350's or 400's?
  50. Best sixty with the ST3500? upgrade to TP4400?
  51. Little Vigilante 3200 done good today
  52. Trans cooler???????????/
  53. Will Vig 2800 roast the tires?
  54. Spohn TA is installed
  55. Gear install Question.
  56. Next step up from SY4000?
  57. Best STREET Converter For Nitrous...
  58. Question for you TH350/400 guys...
  59. Yank stealth 2800 Converter
  60. POLL: If You Have A Stall, What Exhaust Do You Have?
  61. Poll: Lets talk converter gains
  62. Converter Question
  63. Tranny cooler line question???
  64. Adjustable LCA brackets. How to install?
  65. Any probs with a PY4000 On a 00?
  66. Is there such a thing as 'too cool' for transmission temps?
  67. Super Yank 3500 Lock Up Problems
  68. What atap parameters to check to see if my pcm is causing my converter to unlock?
  69. Driveshaft length question... A4 vs M6
  70. transgo shiftkit
  71. does Vigilante make a 10 inch converter or is the sales rep. making a mistake?
  72. clunking sound when shifting (12 bolt just installed)
  73. 4L60E Trans ques (what's prolly broken)
  74. Anyone have track results with a Stealth Thruster 3200
  75. SFC Install question
  76. Is this a good dyno for an ST-3500???
  77. Well, damn. I guess my Vig3200 does have lockup problems
  78. anyone with FLP trans please...
  79. Anyone here have the SLP 3300 Converter.
  80. A4 with hard launches
  81. Do you gain trap speeds with a convertor swap?
  82. Preparations for SFC install?
  83. Anyone have pictures of installed sfc's?
  84. 350/400 Installation
  85. A4->M6 or M6->A4 Conversion links?
  86. Help ASAP Could Nos damage a stall?
  87. Question about transbrake and stall speed
  88. Fair Price for a used Vig. 3600
  89. Cracked Flex Plate pics from a Stock car with a stock T.C.
  90. Need HELP choosing a converter for my TH400........All the TH400 converter PROSinside
  91. VIG 2800 or 3200
  92. Vig 3600 ---Good?
  93. Just installed Pro 5.0...have a few questions...
  94. Is there any way to raise the shift points for daily driving?
  95. Best place for spring install in Houston?
  96. Yank tp4600 converter question
  97. who has the #7 3600 vig converter
  98. Converter & 2.73 gears
  99. Y3000 and my 3:42's
  100. New Dyno #'s with my ST3500 ???????
  101. Do I have to change the stock shift points with 3.73 gears on my A4?
  102. Torque Converter Questions
  103. Cool idea to make super loose converters super tight in traffic.
  104. Survey: Who Spins their 4L60e over 6400 rpm
  105. Anyone's VIG 2800 hitting rev limiter???
  106. VIG 2800 and HAL shocks and springs
  107. Where should a stock A4 shift @ from 1-2 @ WOT?
  108. Questions on Vig3200...
  109. Have there been any problems with ST3500 and pre-'01 cars?
  110. Paging Patrick and others w/ Thruster Pro converter
  111. TransGo and tranny cooler ?s
  112. Hughes Converters
  113. Stock stall is like 1800 or so, right? How would a 2400 perform?
  114. Stall.....
  115. HELP choosing new converter...
  116. installation cost question.
  117. ST3500
  118. TH-350 ?'s
  119. Should my car run quicker short times (Yank TP400)?
  120. New dyno numbers on many, many converters!
  121. Need help deciding whether to get a Trans Go shift kit???
  122. Who's running the Ultra Thruster 4800?
  123. Converter lockup switch argument
  124. after market flexplate????
  125. What is required to convert from M6 to A4?
  126. 60's with offbrand converters
  127. So, how do you choose? FLP or Yank transmissions??
  128. How do I install the RATECH spacer ??
  129. 3800 to much stall for NOS???
  130. Alright, who has a high stall with loud exhaust?
  131. Anyone regret getting a converter??
  132. Effeciancy with 3200 Vigilante
  133. Yank 3000 is in, and ...
  134. TCI converter Question
  135. What would be the best converter/gear combo for highway racing?
  136. Anyone ever break a flexplate on an LS1????
  137. Thinking of running two stall converters.
  138. SY4000 users out there? Just ordered me one...
  139. Which Convertor is right for me?
  140. TA Girdle install
  141. Flywheel for 4l60e
  142. FLP tranny and Vig 3800 kicks A$$!!!!
  143. Anybody have problems with ST3500?
  144. Dyno runs with a A4 tranny
  145. Y3000 going in, need quick info for installer
  146. Yank UT 4400 Installed!
  147. Trans-Go and SY3500
  148. Installing new tranny and converter and...
  149. Pro Stock John - 4L60E Question
  150. Problems with new Torque Converter
  151. Which Yank covertor is for me???
  152. has anyone rebuilt there own 4L60E???
  153. How good are our transmissions?(A4)
  154. Anybody's ST3500s Causing Transmission problems?
  155. Paging all TH400 people.....
  156. Manually shifting an A4
  157. Is my trans temp too low?
  158. Tires with new converter
  159. factory optioned a/4 w/3.42s?
  160. A4 vs. M6...
  161. I need a A4 any want to trade for a MN6?
  162. How long would a stock rear last with a TH400????
  163. Can ANYONE explain A4 downshift points(sweet spots) going from 3.23's-3.73's? PLEASE
  164. urgent help with ripper install............
  165. I was wondering if my PY4000E ...
  166. Which Subframes will fit with my FLP's??
  167. You know what, I have no clue what a converter does/feels like?
  168. Converter question...
  169. How do i get my Vig re-stalled????
  170. Need a built TH400 locally...
  171. neal chance convertor
  172. At what speed does a brand new Vigilante 3200 lock up?
  173. torque converter for daily driver?
  174. proper convertor
  175. Tranny shifting problems with converter...
  176. Everything you ever wanted to know about a TH400 swap..I think
  177. Loose Converters & N20
  178. ?? about the change in downshift points w/ a gear change in a A4
  179. A4 lurches while in 3rd and 4th gear!
  180. The New install of the Extreme BMR Tq Arm
  181. Swap out M6 for TH400...
  182. What is needed to sintall a tranny temp. guage?
  183. Thoughts on my new SY4000!!
  184. vig2800 or ST3200 which one would you chose
  185. Need help with converter probs
  186. How to get your ST3500 to lock-up @20-25mph
  187. A4 newbie, I gotta question
  188. Normal Tranny Temperature???
  189. Post here if you have a" th350 or 400" in your Ls1
  190. I know this is LS1tech.com, but I need help in choosing a converter for my LT1??
  191. ST3500 and Ltrims?
  192. Great Customer Service From Yank...
  193. T.C. Problems '98- '00
  194. TP4400 and shift points
  195. Who is a good installer in NJ/PA for 12 bolt rears??
  196. new to A4s need advice
  197. What's the deal with Transgo and TM ?
  198. Converter and Gears???
  199. Power Steering Cooler
  200. nitrous/NA convertor compromise?
  201. Who installed their own gear?
  202. Rear Lower Control Arms: How to install?
  203. slp3300
  204. Made A Big mistake, installed a centerforce...nned help and opinions.
  205. Best way to mount tranny cooler?
  206. Anyone using a 4400 stall ?
  207. A4 Slow shifting into reverse
  208. Installed Vig3200, now car hits rev-limiter, why?
  209. 2.73 to 3.73 swap on A4-what parts do I need?
  210. Stall speed vs. Horsepower...
  211. Shift Points After Converter
  212. Felp! Transgo installed, car doesn't move...
  213. Shift Points for new converter?
  214. How does a VIG 2800 and a 75 shot of NO2 sound?
  215. how does a high stall converter like a VIG 2800 or a VIG 3200 handle in the rain?
  216. What size tranny cooler do I need now?
  217. Choosing: Vig3600 or Vig4000?
  218. how long to Vigilante Converters last????
  219. Owners w/ Converter Lockup Problems Inside Please
  220. ? about ST3500
  221. Well, what converter do I need for my TNT setup now?
  222. Gear Venders kit with TH400 and Cheetah shifter
  223. Y3000
  224. what stall speed to get?
  225. Major A4 problems 01 w/3000 miles WTF??
  226. what are the pros and cons of a VIG 3200?
  227. Traction for new Converter?
  228. Post DIY Eibach install: The front feels too solid....help me!
  229. solenoid B problem
  230. is a VIG 3200 right for me?
  231. No 2-3 shift
  232. Debating on what I should do for a converter...
  233. ST-3500.. AWESOME CONVERTER!
  234. gearing and convertor question......
  235. 200r4 swap???
  236. Installer "forgets" about Ratech pinion spacer.. bad news?
  237. Just installed sy3500
  238. TH350 ???
  239. 400 turbo, what's involved in the install.
  240. A4 fluid level. How critical?
  241. A4 bogging bad
  242. Transgo shift kit..is it good? any problems?
  243. Vig 3800
  244. Vigilante
  245. Idle Too High with ST3500
  246. Can 1LE trans mount on A4 cause the tranny to smack the tunnel during hard shifts?
  247. Converter install write up.
  248. Does anyone here use a TCI converter?
  249. Patrick G?Best Gear for bolt on A4 with TP4400?
  250. Who here has driven both a ST3500 and a SY3500 ?
