View Full Version : Automatic Transmission
- 4l60e Vacuum Test Stand Build and Test Results
- 4l60e
- Help choosing correct torque converter stall
- 6l80e ?s/opinions....
- Torque converter help?
- What elevation for trans with adjustable crossmember
- 4l80e year
- 2009 4L80e Oil Fitting question
- 1991 4l80e behind a 5.3 problems
- 4l60 problem
- ProperTrans control module for my 4l80e
- Witch neutral safety switch for my application ?
- Off brand 5 pinion planets?
- Is this a dumb idea?
- 80e terminatorx max converter locking at wot not commanded
- 4160e 2-3 shift "flare" diagnosis
- single vs triple disc tq ?
- 4L80e behind L92
- L92/4L80E - flexplate?
- 95 4l60e with 2003 lm7
- Help! Th400
- 4l80e torque converter bolts
- Help! M30 4l60e blown tranmission 4l65e??
- Stand Alone Transmission cooler parts lists and pics
- Stand-Alone Trans Cooler
- Torque converter not locking up
- Transmission swap
- 4L80 Pump Gear and Housing Wear
- 99 Corvette Ls1 into second gen camaro what 4l60e work?
- 4L80E Oil Pump proper gear to face clearance
- 4L60E no 2nd but 1,3,4,5,6
- 2BFAST'S 69 Camaro 4L60E Build
- TH400 vs 4L80E piston, retainer and springs
- 4l60e 07 4 pinion planet from v6 07 Colorado in Gen3 4l60e
- Issues with removing Transmission w/ Solid motor mounts
- 4l60e burnt overrun clutches question
- 2001 ls1 flexplate spacer?
- Broken flexplate spacer bolts
- 4L80E assembly and disassembly compilation videos
- 4L80 - lost second - cracked case
- Summit Racing's new SFI 4.1 T-400 case
- Can u recommend good aftermarket 4l80e
- Finally found a 4L80E core at a good price!
- 4L80E Swap Main Connector Clearance
- 08 4L70E with 09 4L60E valve body?
- 2017 Camaro 1LT transmission problems?
- SFI flexplate shield and trans shield NHRA rules?
- Question about 4L60E 3-4 Clutch Endplay
- What parts are needed to build 400-425 rwhp 4l60e
- Built 4l60e vs stock 4l80e
- Any transmission guys want to look at this
- rebuilding my 4l60e. question on a couple parts
- 4l80e dipstick for 2000 trans am
- 4l80e output shaft spins easily both ways!!
- Np149 tfcase issue!
- M&M shifter
- turbo 350 blew fluid thru the shifter
- using th400 and conveter behind ls question
- Different Torque Converter?
- Trans cooler
- 4L60e problems
- 4l80e dipstick swap question
- Causes of no 2nd gear in 4L60E?
- Hp limit for gen 3 stock 4l60e input drum
- 2 step with a 4k stall
- 4l60e- Where else can I check line pressure , no access to port
- hard 1-2 shift after rebuild 4L60E 2001 camaro
- 4l60e rebuild success.. so far so good at least
- TCI Outlaw gate shifter install/Writeup
- paper waffles for th400/80e?
- 4160e
- 4160e shifting problems
- Hit a Manhole Cover and Lost Tranny Fluid
- 6l90e vs. 8l90 or 10l90 output housing
- 4l60e shifting problem not the usual ones. lol
- Transgo 1-2 & 3-4 accumulator pistons HD2 kit(pics included)
- 4L80E won't shift into, or lockup in, OVERDRIVE until transmission is HOT
- 6L80/90e Output Planetary Removal
- '05 4l60e case with '02 4l60e input shaft &pump& pump seal
- Turbo 350 shift points
- 6L80 Random trans slip
- LT1 4l60e newly installed converter - questions
- 4l60e Pinout
- 4l60e internal harness difference.
- Th400 or powerglide?
- 4l60e No/lost 1st gear
- 5.3/th400 question
- th400 wot shift governor info needed
- Anyone know what CTS V converter I could use in my 2014 truck with 6L80 and 5.3 LT?
- 2014 Sierra 5.3 6L80 considering aftermarket stall
- Is this useable?
- 4l80e pump changes through the years
- th400 ls3 speedo question
- 4l60e tcc sonnax reamer kit
- Help with 4l60e in my lt1
- Looking for info on the TransGo 4L60E-3
- Flex plate
- Torque converter on 4L80e
- Fbody output shaft length question.
- 4L60E Stand Alone Line Pressure
- 4L80e 3-4 accumulator delete via tapping the housing for set screws
- 4l60e rebuild labor cost
- Th400 shifter problems
- 4L70e Output shaft Confusion
- 4l80e shaking whole car
- 4L60E trans slip yoke lenth?
- 4L80E, huge engagement delay..what to look for on teardown?
- 2004R with CH F code
- 350 4l80e trans mount
- 4L60E pump rotor failure
- 4L80E Seems to slip when in R and OD selections
- Gen I (298mm) transmission into 2004 Silverado (300mm)
- 4l60e 7pin connect
- Question about 4l80e oil line fitting difference.
- (Edited)4l60e pump iss type vs non iss type
- Problems with CK performance 4L80e shift kit
- Should I use this 4l60e 3-4 friction clutch
- 4l60e pump bushing replaced now wont fit
- 98 4l60e and ls1 into 94 v6 car. My trans crossmember is too far back
- 350 to 4l80e questions
- 4l60e 1-2 shift
- 96-98 4l60e
- Convert TCI 6x back into 4L80E
- 4L60e mild whistling
- What computers control what transmissions?
- Shifter Not Locking Into Gear - Help!
- 4l80e front thrust adjustment location idea
- 1st rebuild. Not so great
- 4L60E rebuild kits?
- Gen 4 ISS wiring question
- weird 4l60e 4th gear issue
- Th400 no reverse only when hot
- D1 brake issue
- 97 camaro ls swap,what crossmember to use?
- Torque Converter Identification (Pictures inside)
- 4L65E lost all gears, came back
- 4l80 help
- 4l80e bolt question
- 06 4l60e- how many thrust bearings
- 4l80e direct and forward piston springs
- 98 Trans Am A4, Changing trans fluid with a trans cooler
- Easy upgrades during pan swap
- Low/ reverse piston housing picture
- 4l60e custom shifter idea's
- 80 swap, no 1st or 2nd, etc
- 4l60e transmission issues!
- What trucks came with 2wd 4L65E trans?
- Help with 4L60E TCC Regulator Spool Orientation
- What year transmissions interchange 100%?
- 6l80e to 4l65e
- Torque converter balancing problems
- 4L80e wiring problem
- 4L60E TCC strangeness (PIC attached)
- 4l80e banjo fittings
- 80e billet direct drum > at what power level?
- 80e slow to engage reverse, sometimes does not drop into 1st at a stop.
- 4l60e 4th gear WOT mods
- First 4l80e build. Here we go!
- 4l60e teflon seals
- Help I’d by case number
- Strange noise when installing boost valve on 4l60e
- 6L80 Valve Body Bolt Lengths
- 4l80e pressure issues - intermediates are now toast.
- 4L80e Converter questions
- Shifter Plate
- Sanity check. 4l60e with reverse and 1st gear, only with and without power!!
- Tailshaft bushing replacement
- Need help with step 4 on transgo hd2 4l60e shift kit
- 2002 camaro z28 auto advice
- Removing torque convertor pilot bushing?
- Th350 delayed reverse problem!?
- 10R80 vs 10L80 bellhousing, ruin my day
- Did the trans get too hot?
- a10 in a 4th gen?
- A4 trans builder suspecting high line pressure breaking my Trans
- 4L80e Short Shifting
- Starter teeth grinding!?
- 4L80E 2-3 computer ground issue
- Tci flexplate
- Torque converter shake?
- 4L80 TCC probs
- Th400 cable length. Need info.
- JW Bellhousing bolts?
- 4l80 not shifting into gear part throttle 40-60mp (grabs/drops gear top rev rang)
- Th400 1st gear??
- 4l80e pan debris ID
- No gears when warmed up 06 envoy Denali 2wd
- starter mesh
- 4L60e to 4L80e Swap - No Speedometer
- 4L80e soft shifts, even in tow/haul mode
- What converter?
- Stall speed vs. gearing
- 99 Trans Am T56 to 4L80E
- Converter install issues/questions. Help!
- Looking for a 4l80e rebuild kit
- B&M shift plus
- Quandry
- 1998 chevy suburban NO REVERSE - 4L60e
- 4l80e converter options
- Stall problem?
- 2002 ls 4l60e seems to slip into first with hard takeoff
- 2007 E38/T42 4L60E to run a 6L80E? What's needed?
- Jake's D3 TransBrake separator plate fitment
- How to wire tcc to work off a switch
- 4L80E No Reverse/ Trans Brake
- Radiator Port Thread/Size
- Brans new 4l60. Very slight leek looks like it’s coming from the pump.
- how hard is it to rebuild a 4l60e
- Older 4l80 to ls wiring harness?
- 4L80E - Gen 3 – Inconsistent in Executing 1>2 Shift
- V2 CTS V TH400 SWAP Help: No speedo
- code 83- auto tcc control feedback fault 95 firebird
- 4l65 2-3 shift very harsh under part throttle driving
- 4l60e Upgrades
- Help choosing torque converter
- Can I get my 6l80e to shift like my 4l60e?
- 4l65e problems after rebuild
- Flex plate to crank bolts tci 399753
- 4l60e issues
- 4l80e forward drum to input shaft bushing wear question
- Flexplate - Covid?
- 6l80 to 4l80 wiring conversion???
- 3-2 downshift flare. Any 4l60e experts on here?
- Built 4l60e blew/ worth fixing or go th400 ?
- 4l80e/ transbreak / not shifting
- 4l60e - transmission mounted PNP switch
- Fresh swap no shift
- 4L80 with US Quick shift 4 program
- Powerglide In 1996 Firebird With LS For Drag Racing
- Brown fluid only 4l80e
- 4l60e breather vent routing
- LS3/4L80 help
- 5.3 swap, 4l80e won't engage
- 4l60e issue nobody can figure out
- 94 4l60e works sometimes.... solved
- 4l80e “short shifting” at WOT
- 4L80E - Mixing parts from different years
- Okay to run 6L80e angled?
- 4L60e Behind New LT1
- Blocking the 3-2 shift valve, and yes the 2-3 shift
- 4L60E Fluid Change Question
- 4l80e rear band damage
- Chevy Truck
- 6L50 info
- 2003 LQ4/2004 4L60E Swap
- Transmission will not shift or shifts hard
- 2003 lq4 to 1998 4l60e???
- My 4L60E in my 2003 Z71 Chevy Tahoe problems.
- 4l60e problems
- 4L60E 2-3 hard shift
