PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Swapping transmission's, 08 yukon into an 03 silverado v6?
  2. (Rossler) Tranny 4L60 CLUNK in drive????
  3. TH400 conversion. Speedo question!
  4. Loud noise when car is in Reverse..?
  5. My New Circle D Converter, Wow!!!
  6. JR's FLT 4L60E GOES 151 AT BYRON!!
  7. 4l60e extension housing
  8. street/drag car trans??
  9. how long did ur trans last after your 355/383/396
  10. LT1 Stall Question?
  11. truck deep pan for 4L60E part # need
  12. 6 speed to th400 swap drive shaft problem
  13. TC / Flexplate Gap
  14. stock style flexplate for 400?
  15. Torque management question
  16. 1350 u joints stock rear?
  17. FTI conv/4L80E
  18. Bad 2-3 shift solenoid!! WTF!! HELP!
  19. tranny died what happened?
  20. 3rd trans looking for a new trans builder
  21. Do you regret going to TH400?
  22. help my car wont move
  23. Which lokar dipstick and tube for 80E conversion?
  24. TCI 3500 Converter Repair
  25. stock verter bolts suck. any advice?
  26. New to the Auto world
  27. OD or just D for daily drive.
  28. Thanks Circle-D
  29. what size cooler???
  30. Couple of questions about 4l60e internals
  31. Looking forward to a new Performabuilt level II!
  32. Stall Install?
  33. What transmission is this???
  34. How much power can your trans take
  35. OD burnout leads to weird tranny action in 4L60E?
  36. Tight stall??
  37. Transmission Sponsors and BG products trans fluid
  38. 93 4L60E interchange question???
  39. Decided on my H/C setup, need to pick what stall
  40. Milky transmission fluid
  41. '94 4L60E Question/concern
  42. Stock stall????????
  43. 4l60e vs 4l80e ?
  44. Anyone wish they had an M6?
  45. Type of trans fluid
  46. 700r4 stall question
  47. 6l80 in a First Gen F-body
  48. i now know why i have no reverse
  49. Stalls Speeds and Horsepower
  50. Using 4WD 4L60E trans with LS1 for 2WD application (car is NOT f-body)
  51. Who has sent a Vigilante back for clean/restall?
  52. Bang on part-throttle downshift, bad trans mount?
  53. Figuring out which converter to order
  54. converter
  55. th400 shifting problems
  56. SK4L60E (transgo kit) 1870 code fix
  57. 4L60e with a 74 350?
  58. Transmission Specialties
  59. 4l60e twisted input shaft splines out of the drum
  60. 4L60e Rebuild Kit
  61. still no reverse update..
  62. LS engine to powerglide
  63. 4l60 Tranny mount? good or bad
  64. All 700R4s the same?
  65. 4l60 to 4l65
  66. 4l80e
  67. Frank from Cahall, anybody else have trouble contacting him?
  68. Fmv 4l60
  69. stall?
  70. tcc pwm question
  71. scatter shield?
  72. Th400 Conversion
  73. stall problems
  74. p0740 code?
  75. will a 4l60e from an lt1 car bolt up to a 2000 v6?
  76. Torque Converter Confusion
  77. Unplugged ASR (traction Control) box.. will it mess with ABS?
  78. TH350/Driveshaft question
  79. stall speed help
  80. converter not spinning freely
  81. Stock pan with drain plug ?
  82. 4l60e to 4l80e swap not shifting right on highway??
  83. is my stall to big?
  84. I cant get the level of the fluid to be right.
  85. help!! melted wire loom ???? 4l80e
  86. th400 long tail question
  87. 4L60E Fittings
  88. th400 swap converter problem?
  89. Tranny Servo Upgrade- Stock or Aftermarket ?
  90. reprogrammed it- shifting weird- plz help
  91. Help diagnosing a possible problem.
  92. Big thanks to FTI and FLT
  93. switch from 4l60 to TH350
  94. converter unlocking....advice
  95. 98 LS1 Th350 kickdown cable attachment??
  96. 4l80e gear ratio
  97. 4l60e hd
  98. cracked flexplate
  99. OK new trans problem
  100. Does this look right??
  101. stall & stock tranny...
  102. Shifting Problems - Not downshifting or upshifting at times!
  103. Some testing on Yank converters
  104. How much is my 4l60e and vig3200 worth?
  105. Best 3-4 clutch pack
  106. So I think I just blew my input sprag??? Any advice? :(
  107. 1995 4l60e rebuild kit
  108. Make me feel better about owning an A4
  109. new trans soon!
  110. Just ordered my Yank
  111. 4l60e help. please
  112. Proper flexplate info?
  113. Vss 4l80e swap
  114. Shifter Problems
  115. 100K....So What Next?
  116. Jacked Up 4l60e
  117. 6L80E question
  118. have a question, hoping for answer.
  119. Full competition 8" converters for 4L60E
  120. Pulling transmission by myself, whats the easiest way to do it?
  121. Speed Inc Flexplate???
  122. 2nd gear downshift hesitating and/or slipping, flywheel making ticking sound
  123. Yank vs BMR Crossmember for a TH400?
  124. finally ordered it Performabuilt!
  125. What kind of tranny oil should i use??
  126. P1870 help
  127. 700R4 to LS1 Question
  128. Bad Torque Converter?
  129. What else to replace on C5 Corvette Stall install?
  130. Automatic Shifter Knob
  131. Anybody got a tune with 4L80E os merged with a f-body hptuner file
  132. Tips for installing a 4l60e (my first time)
  133. 4l60e Help
  134. 4l60e help
  135. Catalytic converter?
  136. Tranny cooler install Q's
  137. Torn between picking converter
  138. linkage question
  139. can a 700r4 be converted to a vss
  140. 4K Stall 2 much for DD?
  141. convertors and dyno numbers
  142. I finally got me a Circle D stall.........
  143. How much converter slip with a SS3600 LT1?
  144. powerglide vs th 350 how much hp gain????
  145. Block to bellhousing gap pics inside need input
  146. tranny fluid in my intake!
  147. Thinking of going TH400
  148. trans help please (4l60e problem)
  149. Pulling tranny, replace flexplate or no?
  150. Install
  151. Question TH350- Brake slow to engage
  152. No WOT/partial down shift
  153. Stall Selection
  154. Performabuilt level 2 tranny and stall without cam
  155. Tranny Issues - What do you think? Advice appreciated.
  156. want to put cam in auto trans
  157. What happened to the trans? LOL!
  158. Another which Trans For Regal 5.3
  159. Help!
  160. wanting to put in a stall but worried about miles...
  161. How to Recognize a bad stall convertor?
  162. Help me choose a converter for 2.73s
  163. any ideas? my converter is stuck in my trans
  164. 4L80E to 4L60E swap.......
  165. help
  166. help me out here
  167. How Much Stall and Who?
  168. Circle D Thanks. 7.7 Stock!!!
  169. turbo 350
  170. Performabuilt Level 2 is in!
  171. question about change of auto shifter
  172. Truck 4L60E on an LS1?
  173. stock crossmember and th400
  174. Automatic Shifter Question
  175. LT1 Th400 swap questions
  176. Help please!
  177. 700R4 and 4L60E Tailshaft
  178. no 3rd or 4th in 4l60e
  179. what to look for in a 4L60E
  180. Need a New trans for my Turbo Car, Any Specials from the Sponsers?
  181. Question 4 Ya
  182. Transmission Problem?
  183. 1st to 3rd 4l60e
  184. t56 to 4l80e
  185. hits rev limiter before shifting after fast 92 install
  186. Possible Trans problem after changing injector slope
  187. 4,500-4,800 Stall, Too Much???
  188. No drive!
  189. Engine problem need assistance
  190. 4l80e tailshaft housings
  191. Tranny Trouble
  192. Neutral saftey switch. how do you hook it up
  193. How much should a good converter slip?
  194. Auto trans wows
  195. Slipping shifts, no lockup
  196. SFK sprag vs. Borg-Warner sprag
  197. Converter pros help me pick a good converter!
  198. Clicking noise
  199. m6 to th400 problems
  200. shift solenoid question
  201. Cooler special with trans orders today thru Thursday eve or while supplies last
  202. 4l60e problems
  203. Circle D goes 1.36 60ft *pics*
  204. i need a good trans cooler help me
  205. hurst shifter, which wires to splice
  206. converter question
  207. Trans shield for 4l80e
  208. is my trans or verter toast?
  209. just finished rebuild,no reverse *detailed
  210. Quick question
  211. question breaking tail housings
  212. Cross member Question
  213. Quick Question...
  214. 4l60e problems
  215. how to tell if a 4l60e i found will fit?
  216. Park to drive question
  217. EDGE v.s YANK conv.
  218. What shifters are you guys using?
  219. the guy sent me a v6 transmission
  220. 4L60E Hose Diagram
  221. gear and converter choice for supercharger?
  222. A4 swap checklist
  223. How Much HP?
  224. Transgo+Sonnax=issues?
  225. price comparison for th350or 400 vs a built 4l60e
  226. what kind of flare?
  227. rear seal?
  228. torque management
  229. Speedo Wires
  230. Looking For An Improved/Better Version 4L60E Tailshaft Bushing
  231. Tuning VS shift kit
  232. 4L80 rebuild parts Q and others
  233. 4L80E return line fitting/plumbing, tight clearance...
  234. your opinion/ am i some what right
  235. Please Help me Decide. TH400 vs Glide?
  236. 02 sensor hitting th 350 linkage
  237. 700R4 No Forward No Reverse
  238. which servo?
  239. do vans with gen 1 engine and 4l80 have a seperate controller?
  240. Lost 4th gear, need help please (noob)
  241. 2800 SLP Torque Converter - $50 = Worth It?
  242. rebuilding my trans and hit a snag, need some help please
  243. 4l60e advice please help!
  244. What mods can I do for 4L60E 00TA
  245. Can this be possible? 4L60E
  246. Transmission Mount Nut
  247. Can I use a '92 4L80e behind a 99 LQ4 motor?
  248. Trans cooler question?
  249. Parts upgrades required for a high-hp 4l60e above the usual street/strip 4l60e
  250. bad tranny?
