PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Pa 4l80e trans help
  2. Help an Aussie choose a converter!
  3. Help me!!!!
  4. Swapping A 4L70E For A 4L60E...?
  5. O1' TA A4 Transmission Please Help!!
  6. 4l80e has 1,2 reverse wont shift into 3 or 4
  7. help! 4l65e
  8. 2wd 4L80e to 4wd?
  9. 1995 Trans AM Transmission issue
  10. 4l60e drive by wire to cable conversion??
  11. Getting a little power at the wheels in Nuetral
  12. 93 TA bellhouseing bolt stripped
  13. 4l60e Rebuild Thread
  14. trans temp gauge
  15. Ratchet and other after market shifters (4L60e) anyone?
  16. 4l60 wont shift out of first
  17. 4l80E TransGo HD2 Pump Stator Drill Size Hole
  18. 6L80e to 5.3?
  19. 99 4l80 to a l92
  20. 4l60e vacuum modulator kit
  21. 4l65e - P0740 - But doesn't make sense to me.
  22. Reverse is in a bind
  23. 4l65 in 2004 Corvette
  24. transmission linkage for 4L80e swap?
  25. stall converter identity
  26. 4L60E 04 gto
  27. starter and flywheel don't fit together.
  28. 4L60E transmission problem
  29. 2002 Tahoe 5.3 Won't Start After 4l60e Swap
  30. 4l60 Wont Hold 1st Gear
  31. I need help
  32. 4l80 temps
  33. 200-300rpm flare before converter locks (80e)?
  34. Possible Converter issue? 4l80e
  35. 4L60E firm&crisp part throttle, WOT shift points high
  36. 4l80e Bell housing cover
  37. 4l80e staying locked in 3rd and 4th gear after passes
  38. th400 Converter bolting to ls 5.3
  39. HELP:No drive or overdrive(4l60e)
  40. 4l60e Trans go hd2 clutch spring kit necessary?
  41. 4l60e With FTi 4000 Not Locking up!!
  42. electronic shift kit yay or nay
  43. V12 and 4L80E
  44. Electrical issues, where to start?
  45. 4l60e/65e need help!
  46. LT1 feels slow AF after rebuild
  47. Stall for my 6.0 gt45 chevelle
  48. 4L60E Has been sitting for 2 years
  49. Super Servos
  50. Need Shifter Help
  51. torque control
  52. Bad wire on shift solenoid
  53. 97 T56 to 4L60e Question
  54. 2wd truck 4l60e to ls1 camaro?
  55. P0757 after new trans and 3200 stall
  56. 2002 silverado 4.8 wont move. Clicking noise
  57. 4L60e lost all gears during a pull
  58. How many of you auto guys with street/strip cars removed E brakes?
  59. Converter is staying locked?
  60. Performabuilt Level 3 - **Update**
  61. No second gear, but has first, third, and forth!
  62. Th400 and quarter stick shifter issue
  63. Turbo 350 to lq4.
  64. p1860 code - HELP
  65. powerglige vs turbo 400
  66. 4L80 questions
  67. Converter size question
  68. 8L90 going to be available?
  69. having trans issues
  70. th400 transbrake boost building
  71. FTI street brawler 3200 with 350whp?
  72. 4l80e extension housing bushing
  73. Did I mess something up?
  74. Performance 4L60E build thread
  75. Old pre-97 4L80e cooling fittings
  76. Craigslist 80e w/ Transo shift kit clunks into reverse, normal?
  77. 4l60e storage question
  78. 4L60e no 3rd or 4th, shifting 1-2-1??
  79. .490 boost valve
  80. TH400 not staying in gear
  81. How to remove stator shaft from pump half?
  82. th400 shifting problems
  83. Rebuild 4L60 beginner question
  84. 4l80e TCC not locking
  85. USShift (Optishift) w/1991 4L80e
  86. New stall upgrade need a tune?
  87. 4L80e wiring. Pink wires?
  88. When are 300m shafts necessary
  89. Need help wiring 2step and trans break
  90. 4l80 brass in pan
  91. FLT 4l65 with a transbrake
  92. Choosing a torque converter
  93. Finishline Transmissions FLT
  94. 4L80E Filter options?
  95. TH400 question(s) and help
  96. TSP Converter by Yank
  97. Where to get 4L80e input shaft o ring
  98. 4L80 shift kit install
  99. 4L60 wont unlock or down shift at high speed
  100. 4l60e vent tube leaking
  101. TCI 399753 4l60e yank ss4000 bolts
  102. 80e manual up/down shift
  103. Transgo 4L80e-3 Data
  104. electric solenoid shifter
  105. Fluid flow to and from transmission and cooler
  106. tci converters
  107. 4l60e problem
  108. 4l80e soft 2-3 shift slips in 3rd
  109. ls 4l60e questions
  110. 4L60e dropping out of gear...
  111. 4L60e 1-2 shift shudder
  112. I'm about to be on my 9th 4l60e rebuild
  113. TH400 direct drum piston help.
  114. Tci flex plate 399754
  115. Please help!!! I just wanna go fast sometime b4 I die
  116. 4L80 guys, which pan are you using?
  117. 4L60e all of a sudden wont shift into OD. 1,2,3,are good
  118. 4l60e help please
  119. 4l60 third gear problems
  120. 7500 RPM with a Built 4L60E?
  121. 4L80E cooling lines installation
  122. Question on tuning shift point for track only use
  123. 4L60/Vigilante 4000 price check?
  124. What kind of shifters do you guys use on a 4L60E?
  125. 6L80E with upshift noise and gear slippage. Please help!
  126. 400 Turbo vs. 4L60E transmission improvement in ET times?
  127. How to hook up the speedometer on a 400 turbo on 99 Camaro?
  128. Pull the tranny to finish Transgo Hd2 4l60e?
  129. Transmission build Q
  130. Transmission build Q
  131. LS3/4l70E Trans heat issues Jeep TJ
  132. VSS for th400
  133. Tranny Guru's step on in!
  134. Which 4L60E rebuild kit ?
  135. Superior shift kit w/sonnax pinless accumulator
  136. B&M pro stick shifter woes
  137. Shifting problems
  138. P1870 code
  139. 3/4 accumulator spring
  140. Advise on Re-Stall for Stroker
  141. WOT shift hesitation after stall installation
  142. performabuilt 460le 4000 yank stall
  143. (4L60E) Violent noise from trans going into Drive
  144. 4l60 or 4l80
  145. Ballooned converter?
  146. 4l60E Transgo HD2 Questions?
  147. 4L70E with a bad, sometimes, 1-2 shift
  148. Rossler or fti th400
  149. Built 4L60E shift pressure inconsistent
  150. 94 Formula - 3rd gear, just rebuilt.
  151. 4L80e swap into older car. Range switches?
  152. How much difference would a fan make
  153. 4L60 HP/Torque Limitations
  154. 4L60e 3-4 Shift Time Any Help?
  155. 4l60E No 3rd gear. Rossler Trans, 9k miles
  156. what would cause this? TH400 rear bushing destroyed.
  157. Anyone running Rollerized reverse input drum from PATC?
  158. How to disable lockup converter??
  159. what part's from a built 700r4 are worth using in a 4l60e
  160. Broken torque converter
  161. car reverse but won't drive when in drive gear? help!!
  162. 4l80e torque converter nightmare!! please help....
  163. Hitting rev limiter?
  164. 4l60e converter question
  165. 99 Pontiac trans am - blown trans
  166. 2003 4L60E Rebuilt 1st-3rd Shift Fine, No 4th (OverDrive)
  167. Best Trans Fluid ??
  168. 4L60 1st Gear Shifting Issues
  169. 4l60e tear down
  170. Another t56 to 4l60 or 4l80e auto swap question
  171. Need help identifying this trans
  172. 4l60e slipping on freeways
  173. 4l80 temp reading location
  174. help with powerglide setup
  175. Blew my transmission. Suggestions?
  176. FTI vs Circle D budget converter
  177. HINSON Motorsports GTO Transmission Mount Update
  178. 4L80E D1 brake doesn't seem to release??
  179. Need to get 4L60E temp down below 200 degrees *Help*
  180. Help diagnose transmission whine
  181. 2002 z28 4l60e removal
  182. 4L60e make it stay in first
  183. Help 4l60e problems after couple of track passes
  184. 4l60e no first gear
  185. need help
  186. 2002 4l60e with 99 Tahoe PCM
  187. 1993 LT1 gear selector switch circuit Code 72 cause surging?
  188. Is it broken again? (4L60E)
  189. 04 GTO Weird behavior
  190. Converter input wanted, dyno sheets included
  191. 4l60e metal in valve body bore?
  192. Yank PAS 3800 anyone?
  193. Next step?
  194. 94 Chevy 1500 no reverse
  195. Dacco Stall
  196. Recommend me a converter - 4L80
  197. Precison Industries 4l80e Triple disk grinding issues low load?
  198. 4l80 shifting issues
  199. Can 8 speed auto be done on a ls1 f-body
  200. 95 4l60e
  201. LS to TH350 Converter vs flex plate transistion
  202. 4l60e longevity
  203. Jakes d3 trans brake wiring
  204. Steel braided lines...tranny cooler lines.....Easiest way...?
  205. 4L60E output shaft swap questions
  206. Anyone put a 4L80 into an 04 GTO?
  207. Need help locating trans parts
  208. 4L60E shift problems
  209. 98 Suburban 4L60e vs f body 4l60e
  210. 4L80e stall converter recommendation
  211. I Need Opinions On a Converter for Turbo Car
  212. vss senser for 200r4
  213. 4L60 driving characteristics
  214. 4l80E reverse hesitation
  215. 98 0411 pcm repin running 4l80. Get in here
  216. should the new converter spin both ways?
  217. Loud noise after 4l60 swap?
  218. 4L60E 1st gear issues
  219. Tuning a 4L80E with Holley Dominator?
  220. 4L80e downshifting?
  221. 87 Monte Carlo LS swap.
  222. 1-2 will not engage manually.
  223. 4l80e tq convertor help
  224. T56- Powerglide swap, tips, 1/4mile times, useful info
  225. 4l60e EX Raptor level 5
  226. TH350 shifts hard in reverse
  227. 4l60e las
  228. 4l80e hangs right before WOT shift point, No shift at WOT
  229. fti converter help/questions!
  230. FTI LS brawler converters
  231. What 4L60E Rebuild Kit is Best for my 1995 S10?
  232. Trans Brake Button Mounting Location
  233. 4l80e hd 2 transgo ?'s
  234. New EPCS (force motor) solenoid. Shift points different, bounces off rev limiter WOT
  235. Trans problem on 2008 Impala SS
  236. flexplate quickie
  237. Must have upgrades for street/strip 4l80e
  238. Planetary Question
  239. help diagnose my 4L80e issue please. Videos of pressure gauge
  240. 99 K1500 5.7 with 01 5.3 4L60E?
  241. change trans pan question
  242. Clips upside down in Valve Body (1998 4L60E)
  243. 4L60e won't shift into 3rd or 4th
  244. Weird issues with '99 4l60E
  245. Converter suggestions for powerglide
  246. 4l80 gurus
  247. What fluid to use in ATI Th350?
  248. Video - The Circle D Billet
  249. 4l80e wont shift in to 4th and feels like I am hitting the brakes
  250. 4l60 Whines in park, neutral, reverse
