View Full Version : Automatic Transmission
- Anyones car shift like this? Cant figure it out!
- 4L60E 4x4 vacuum diagram
- 4L60E to TH400
- building a stronger 4l60?
- building up a th400 or glide
- Track Results/Review :: TCI 4000/2.8
- Installing stall
- Transgo shift kit?
- th-400 experts in here
- A Stall?
- my a4 problem!!!!!!!!!
- 4l80e question experts inside
- 2-3 shift at WOT hits the rev limit
- What stall for stock.
- Convertor bolts
- What is WOT?
- car shifting real hard... too hard....
- 76k Miles, Fluid Change Yes or No?
- Need dipstick for 4l80e in a TA
- WHY to not go WOT in OD!!!
- what stall?
- TCI SSF3500 Good for 150 Shot and N/A?
- DIY Install of Torque Converter.
- stock 4L60E trans in my 2002WS6. how long do i have
- torque converter clueless
- whats wrong?
- Those with G5x4 cams, what size stall
- Trans Problem!!!
- guys with converter?
- MBA Shift Knob removal
- locking stall
- Did not get the TC all the way in, damage?
- Transmission bolt sizes
- Lock Up Question ?
- Torque Converters and gas mileage
- TCI guys What stall do you have and what 60`s have you gotten?
- Driveability difference between a 2700 stall and a 5300 stall?
- Need help to convert from M6 to A4
- Huge problem after SS4000 and 3.73 install
- looking in to a fuddle converter?
- Transmission woes
- 4l80e nightmare
- Would a vacuum modulator also affect TCC apply pressure?
- Trans case size: Th400 vs. 4L80E
- Installed my Fuddle converter
- 4.10's, a4, and mpg
- 1-2 shift question
- PLEASE help!!
- Tranny Dipstick very loose
- Vss
- 3000 stall with re-gear
- what stall would u guys recommend ?
- Best Price on Vigilante TC's???
- I Need help Fast..Tranny Problem
- Guys W/ Fuddle Conveters Speak Up?
- Whos running a decent sized cam with a 3500+ stall??
- good STR on 245 streets
- 4L60e interchangeable between LS1/LT1
- I think my tranny cooler hose ruptured causing all trans fluid to be lost
- broken converter?
- Tranny Question
- 4l60/65 Or 4l80?
- lighter flexplate?
- A Hard Shifting 4L60E
- Do I have a broke Flywheel. Local help isn't trusthworthy, read please
- what year/make and model can i use a transmission in my 99 gmc yukon 4x2
- Delayed 2-3 shift (part throttle only)
- Lock up convertor ??
- automatic tranny problems
- Bellhousing
- Lock-Up problems
- Two Questions
- Speedometer issues
- yank guys speak up!!!!!!
- 4L60E Upgrade advice (rebuild time)
- 4x4 4l60e in a 2 wheel drive,will it work?
- Should I trade....
- tranny shifts
- is there a tranny with more gears?
- PPL Runnin Hughes Stalls, I have questions...
- need help transgo problem!!!!
- Do the 6 speed and auto speedo sensors use the same signal?
- is 3500 enough stall...
- cork gasket or rubber
- Installing verter on an a ex-m6
- which trans cooler do u guys recommend?
- ROck On Transmission Contact Info.
- Pattern lost...
- Hate my vig 3600, need suggestions.
- WOT in OD
- 99 C5 4l60E help!!!!!
- What Stall for H/C & 100 to 150 shot?
- Torque Converter & Nitrous
- Is it hard to go from A4 to M6?
- How would an A3/big stall/2.73 gear do?
- Shifts weird with AC on ...
- Automatic trans over reving
- Is from A4 to A3 the best move?
- Why are my torque converter bolts so short?
- no reverse or 4th
- How to fix a leaky trans cooler?
- Should I get a bigger stall if I spray?
- Trying to ID stall speed on two 4L80E converters
- Odered a Fuddle converter
- Weird Clanking/binding/popping sound please help
- Transmission place sent wrong TC bolts and shims
- Electronic speedo gear question.
- MAD Props to Fuddle Racing and TCC
- What converter for 3.37s?
- Who has gone fom a T-56 to a TH350, TH400, or glide in here please!!!
- Best locaion for a tranny temp sending unit
- th350 or th400??
- Tranny going out, need advice.
- Torque arm to rear end bolts cant stay tight!
- Help With ? About My Converter
- Transmission Performance button
- What is the trans temp supp. to be?
- How much power
- How long to install a converter on your own?
- Trans Mount
- Poly Transmission Mount - Tips and Impressions
- tranny hits rev even in drive
- Where are my starter bolts
- What converter to run with Ls1 th400
- trans shifting questions
- big stall on stock car...
- Swapping in 700r4, tailshaft issues
- 4l80E build?
- 700r4 or 4l60e
- GV overdrive
- Biggest tranny cooler possible?
- The new Fuddle Racing High Performance Street Converter
- fuddle t/c owners come in
- vibration
- what size stall
- launching with a 3600 rpm stall/2.2STR
- 4l60e with obdII
- Torque Managment????
- stock tranny and n2o
- 4L60E no upshift
- Converter interchangeable?
- well built th350 hold up to 900rwhp?
- Should I buy?? 200R4
- Th400
- shift points question
- pulling the pump from a 4l60e
- which trans cooler?
- Opinions on VIG3200
- Best shop to take my SS A4 for service in California?
- Need Suggestions on Tranny for SBC TT Chevy
- How Much $$$
- Is a restall worth it? 5300 to 4???
- b&m transpak kit and a tranny ques.
- why do LS1's do this??
- Shift Kit or Tuning
- TCI or VIG?
- electronic pressure gauge for tranny?
- Stall installation price
- Reccomendation for stall
- Converter problems even after tuning
- Manual valve body 700R4 shifting from 1st to 3rd?!?!?
- 12" stall converter vs. 10" stall converter
- hmm.. i have aquired a free midwest 3500, transmission was f'd up tho.. what to do
- tranny temp gauge problem
- Turbo torque converter
- troque converter bolts
- Doing a converter
- another what if ?
- My stall stalled
- Sun Shell Broke
- t56 to A4 swap questions
- What should be my next mod?
- MY next mod should be....
- which converter with nitros
- 98 t/a with rebuild tranny has no park or gears
- Yank 3200 Installed My Impression
- Which oil should I use?
- Who has the best price on new Protorque torque converters?
- My notes on P0756 code and symptoms...
- Trans shifting softer after 3500 install!
- precision industries restall
- tranny swap ?
- Converter and BIG stall in snow...?
- Yeehaw-- I finally broke my tranny!!!
- Throttle response
- What's the best converter for all-bolt-on cars with non-Nitto/DS3 street tires?
- Turbo-400 makes sound?
- What combo for turbo 350
- converter question
- lost 3rd after trans-go fuddle install.
- Converter won't stall enough.
- what size stall do i need
- Trans temp went to 280 degrees!!!!
- 700r4 with turbo 400 parts??
- only reverse
- How bad is it on my tranny...
- Tranny Dowel pins
- Won't lock up in 4th gear only.
- What stall for a 4000# car, 224 cam, 3.89s?
- How long is my 4L60E gonna last?
- which brand torque converter?
- Reprogramming with shift kit
- Going in tomorrow....(pic)
- Vigilante 4000,4200,4400?
- Vinci Hi Performance and Yank
- BIG Tranny Problem
- Converter clutch went out in my TCI 3500
- Friend has a tranny problem..ideas?
- Converter Install Write-Up??
- Stupid problem...HELP!!!
- stall converter question
- Whose converted from m6 to a4??
- th350 converter
- do these times seem right ?
- Converter Question
- putting in 'verter soon
- 6l80e for 06 vette, maybe GTO?
- how much would it cost??
- Trans oil pan torque sequence
- Help! Very Confused.
- better trans swap
- What MPH??
- LS1 edit of pressures????
- Important notice
- Torque convertor not locking once trans is warm??
- 3000 vs. 3500 stall convertor
- vig dealer
- Rapid death of a new 4l60e
- Inventory of rebuild kit???????
- Bullitt T/C's?
- Trans. temperature gauge - best deal
- Destroying my transmission??
- going from t56 to t400????????
- What kind of power can a stock 4L80E hold?
- TCI Stall ??
- Bad Vibration at 40MPH TCI 3500
- Tranny Shop
- No Reverse?
- trans coolant line questions
- Harsh 1-2 shift under light throttle after Transgo & Servo install
- TCI SFI Flexplate TC Bolt Holes Too Large!?
- Car feels like it drops into neutral at hard throttle...
- 4l80e swap details please
- anyoen have a link for a th350 swap
- Trans problems?
- 200r4 swap
- Gains on torque converter
- how many of u guys have a th350 that is dd?
- Need some gurus. What do I need to do a M6 to A3 swap.
